[Swift-commit] r5567 - SwiftApps/SciColSim
jonmon at ci.uchicago.edu jonmon at ci.uchicago.edu
Thu Feb 9 11:34:02 CST 2012
Author: jonmon
Date: 2012-02-09 11:34:02 -0600 (Thu, 09 Feb 2012)
New Revision: 5567
Added:
   SwiftApps/SciColSim/pads.similar.beagle.xml
Modified:
   SwiftApps/SciColSim/README
   SwiftApps/SciColSim/annealing.swift
   SwiftApps/SciColSim/local.xml
Log:
updates of the annealing.swift file and the README.  Added pads and updated local sites file
Modified: SwiftApps/SciColSim/README
--- SwiftApps/SciColSim/README	2012-02-09 15:04:51 UTC (rev 5566)
+++ SwiftApps/SciColSim/README	2012-02-09 17:34:02 UTC (rev 5567)
@@ -137,15 +137,31 @@
 Sample output (w/ bugs remaining) is in sample.test-swift.output
-*** Parameter on the command line
+Optimizer output (both from C++ optimizer and Swift) generates text
+with escape sequences to display colored text. Some versions of more
+and less need special options set (eg in env var?) to display the
+colors correctly.
+*** C++ Command line args
+Usage: super_optimizer alpha_i alpha_m beta gamma delta target_innov [n_epochs n_steps n_reruns] [range] [verbose_level]
+         [T_start T_end Annealing_steps Target_rejection Starting_jump]
+         [FREEZE_alpha_i FREEZE_alpha_m FREEZE_beta FREEZE_gamma FREEZE_delta]
+*** Swift command line args and internal control vars
     The command line options are:
         -nworkers=<int>
 	-minrange=<int>
+	    Starting number for the target innovation value(Inclusive)
 	-maxrange=<int>
+	    Ending number for the target innovation value(exclusive)
 	-rangeinc=<int>
+	    How much to increment the target innovation value by
 	-tstart=<float>
@@ -154,19 +170,25 @@
 	-trejection=<float>
 	-evoreruns=<int>
+	   How many times to re-run the evolve.sh app
 	-startingjump=<float>
 	    Controls the dx and/or rejection variable
 	-alphai=<float>
+            parameter to the annealing process
 	-alpham=<float>
 	-beta=<float>
 	-gamma=<float>
 	-delta=<float>
 	-annealingcycles=<int>
 	    Number of times to run the annealing process for a given target innovation
@@ -174,22 +196,10 @@
 	-rerunsperapp=<int>
 	    Number of evolve reruns to do per app call
-    -nreps=<int>
+	-nreps=<int>
+	    How many times to repeat the annealing process for a given target innovation
-Optimizer output (both from C++ optimizer and Swift) generates text
-with escape sequences to display colored text. Some versions of more
-and less need special options set (eg in env var?) to display the
-colors correctly.
-*** C++ Command line args
-*** Swift command line args and internal control vars
 *** C++ app flow logic ===
 for target in range(58, 1009 (used 209), 50):  // 20 values    Target Values
Modified: SwiftApps/SciColSim/annealing.swift
--- SwiftApps/SciColSim/annealing.swift	2012-02-09 15:04:51 UTC (rev 5566)
+++ SwiftApps/SciColSim/annealing.swift	2012-02-09 17:34:02 UTC (rev 5567)
@@ -1,5 +1,9 @@
 import "math";
 import "colortext";
+ *TODO:
 type file;
@@ -16,15 +20,15 @@
 ( float nx ) newx( float x, float dx )
-    float r = (random()); // / (pow(2.0,31.0)-1.0);
+    float r = (random());
     if (r > 0.5)
-        nx = x + (random())*dx; // /(pow(2.0,31.0)-1.0);
+      nx = x + (random())*dx; //Java already returns a float between [0-1]
     else
-        nx = x - (random())*dx; // /(pow(2.0,31.0)-1.0);
+        nx = x - (random())*dx;
     // tracef("newx(%f,%f)=%f\n",x,dx,nx);
@@ -83,11 +87,10 @@
     iterate iter_i   // number of annealing cycles
-    {    // foreach i in [1:annealing_cycles]
         int i = iter_i + 1;
         // set new temperature, rejection threshold, and dx values for this cycle
         float temperature = T_start*exp( @tofloat( i-1 ) * ( jlog( T_end ) - jlog( T_start ) ) / @tofloat( annealing_cycles ) );
         tracef( @strcat( "multi_annealing: AR: i=%i ....T = ", color( 3, "%f" ),"\n" ), i, temperature );
@@ -115,21 +118,20 @@
             tracef( color( Blue, "multi_annealing: AR: New cycle at %i: dx[0-4]=[%f %f %f %f %f]\n" ), i, dx[i][0], dx[i][1], dx[i][2], dx[i][3], dx[i][4] );
-        else
-        { // If not new cycle, set dx[i][*] from previous dx ([i-1]). rejection[i]j] is set later.
+        else  // If not new cycle, set dx[i][*] from previous dx ([i-1]). rejection[i]j] is set later.
             foreach k in [0:NEVOPARAMS-1]
                 dx[i][k] = dx[i-1][k];
-        //foreach j in [0:NEVOPARAMS-1] { // Try a new value for each non-fixed param; then write results and accept or reject
-        iterate j
-        {  // Try a new value for each non-fixed param; then write results and accept or reject
-            // float try_x[];
+        iterate j   // Try a new value for each non-fixed param; then write results and accept or reject
             int curr = ( i * NEVOPARAMS ) + j;
             int prev = curr-1;
-            // tracef("in multi_annealing: i=%i j=%i curr=%i prev=%i\n", i, j, curr, prev);
-            if ( /*(!FIX_VARIABLES) || */ ( var_fixed[j] == 0 ) ) {  // Adjustable vars
+            if ( /* (!FIX_VARIABLES) || */ ( var_fixed[j] == 0 ) ) {  // Adjustable vars
                 // fixed=1,1,0,0,0: FIXME: FIX_VARIABLES flag has faulty logic but OK when TRUE
                 float try_x[];
@@ -172,7 +174,7 @@
                 float ratio = min( 1.0, exp( -( mlres[i][j].loss - curr_loss[prev] ) / temperature ) );
-                float r     = (random()) ; // / (pow(2.0,31.0)-1.0);  // FIXME: AR: why all the 2^31's ???
+                float r     = (random()); //Java already returns a random float between [0.0-1.0]
                 tracef("multi_annealing: AR: %f vs %f\n", r, ratio);
@@ -198,7 +200,7 @@
                     tracef( "multi_annealing: Accepting try_x[j], i=%i j=%i try_x[j]=%f\n", i, j, try_x[j] );
                     float rj[];
-                    {  // FIXME!!!
                         if (k <= j)
                             rj[k] = rejection[i][k]; // Was either set from previous j or just set for this j
@@ -216,8 +218,8 @@
                            i, try_x[0], try_x[1], try_x[2], try_x[3], try_x[4]);
-            else
-            { // Fixed Vars
+            else // Fixed Vars
                 x[i][j]         = x[i-1][j];
                 rejection[i][j] = rejection[i-1][j];
                 curr_loss[curr] = curr_loss[prev];
@@ -258,7 +260,7 @@
                  @strcat(t_start), @strcat(t_end), @strcat(annealing_steps), @strcat(t_rejection), @strcat(starting_jump),
             //    FREEZE: alpha_i alpha_m beta gamma delta
-            "1",    "1",    "0", "0",  "0",
+                            "1",    "1",  "0",  "0",  "0",
             //   operation-code:(m,a)    Nworkers           seed
                       "m",            @strcat(Nworkers), @arg("seed", "0" ) ];
@@ -280,6 +282,8 @@
 optimizer_sweep() // Implements logic of python driver script
+    rerunsPerApp = @toint(@arg("rerunsperapp", "100"));
     int minrange = @toint(@arg("minrange", "58"));
     int maxrange = @toint(@arg("maxrange", "59"));
     int rangeinc = @toint(@arg("rangeinc", "50"));
@@ -305,14 +309,12 @@
 						   @toint(@arg("evoreruns", "100")),
 						   @tofloat(@arg("startingjump", "2.3")),
 						   [@tofloat(@arg("alphai", "0.0")), @tofloat(@arg("alpham", "0.0")), @tofloat(@arg("beta", "4.0")), @tofloat(@arg("gamma", "50.0")), @tofloat(@arg("delta", "-1.0"))],
-                                                    @tofloat(target_innov),
+                                                   @tofloat(target_innov),
 						   @toint(@arg("annealingcycles", "50")) );
-rerunsPerApp = @toint(@arg("rerunsperapp", "100"));
 main()
     optimizer_sweep();
Modified: SwiftApps/SciColSim/local.xml
--- SwiftApps/SciColSim/local.xml	2012-02-09 15:04:51 UTC (rev 5566)
+++ SwiftApps/SciColSim/local.xml	2012-02-09 17:34:02 UTC (rev 5567)
@@ -4,6 +4,6 @@
     <profile namespace="karajan" key="jobThrottle">0.05</profile>
     <profile namespace="karajan" key="initialScore">10000</profile>
     <filesystem provider="local"/>
-    <workdirectory>/lustre/beagle/ketan/labs/SciColSim/swift.workdir</workdirectory>
+    <workdirectory>/gpfs/pads/swift/jonmon/Swift/work/pads</workdirectory>
   </pool>
 </config>
Added: SwiftApps/SciColSim/pads.similar.beagle.xml
--- SwiftApps/SciColSim/pads.similar.beagle.xml	                        (rev 0)
+++ SwiftApps/SciColSim/pads.similar.beagle.xml	2012-02-09 17:34:02 UTC (rev 5567)
@@ -0,0 +1,23 @@
+<config>
+  <pool handle="pads">
+    <execution provider="coaster" jobmanager="ssh:pbs" url="login.pads.ci.uchicago.edu" />
+    <filesystem provider="local"/>
+     <profile namespace="globus" key="project">CI-CCR000013</profile>
+    <profile namespace="env" key="SWIFT_GEN_SCRIPTS">KEEP</profile>
+    <profile namespace="globus" key="ppn">8</profile>
+    <profile namespace="globus" key="jobsPerNode">1</profile>
+    <profile namespace="globus" key="lowOverAllocation">100</profile>
+    <profile namespace="globus" key="highOverAllocation">100</profile>
+    <profile namespace="globus" key="maxTime">3600</profile>
+    <profile namespace="globus" key="maxWallTime">00:02:00</profile>
+    <profile namespace="globus" key="slots">10</profile>
+    <profile namespace="globus" key="nodeGranularity">1</profile>
+    <profile namespace="globus" key="maxNodes">1</profile>
+    <profile namespace="globus" key="queue">fast</profile>
+    <profile namespace="karajan" key="jobThrottle">9.59</profile>
+    <profile namespace="karajan" key="initialScore">10000</profile>
+  </pool>
+</config>
