[Swift-commit] r5564 - trunk/src/org/griphyn/vdl/karajan/lib/swiftscript
davidk at ci.uchicago.edu
Wed Feb 8 08:22:29 CST 2012
Author: davidk
Date: 2012-02-08 08:22:28 -0600 (Wed, 08 Feb 2012)
New Revision: 5564
Modified:
trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Sprintf.java
Log:
Give more detail for tracef/sprintf type mismatch errors
Modified: trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Sprintf.java
--- trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Sprintf.java 2012-02-08 03:18:57 UTC (rev 5563)
+++ trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Sprintf.java 2012-02-08 14:22:28 UTC (rev 5564)
@@ -189,7 +189,7 @@
else {
throw new ExecutionException
- ("tracef(): %b requires a boolean!");
+ ("tracef(): %b requires a boolean! " + dshandleDescription(arg));
@@ -200,7 +200,7 @@
else {
- ("tracef(): %f requires a float!");
+ ("tracef(): %f requires a float! " + dshandleDescription(arg));
@@ -212,7 +212,7 @@
else {
- ("tracef(): %i requires an int!");
+ ("tracef(): %i requires an int! " + dshandleDescription(arg));
@@ -241,7 +241,7 @@
else {
- ("tracef(): %q requires an array!");
+ ("tracef(): %q requires an array! " + dshandleDescription(arg));
@@ -252,7 +252,7 @@
else {
- ("tracef(): %s requires a string!");
+ ("tracef(): %s requires a string! " + dshandleDescription(arg));
@@ -279,4 +279,12 @@
"\t in " + spec + " character: " + i);
+ * Return String containing variable name and type of a given DSHandle
+ private static String dshandleDescription(DSHandle dshandle) {
+ String variableName = (dshandle.getRoot().toString().split(":")[0]);
+ return "Variable \"" + variableName + "\" is a " + dshandle.getType();
More information about the Swift-commit
