[Swift-commit] r5549 - SwiftApps/SciColSim
jonmon at ci.uchicago.edu
Mon Feb 6 11:08:58 CST 2012
Author: jonmon
Date: 2012-02-06 11:08:58 -0600 (Mon, 06 Feb 2012)
New Revision: 5549
Modified:
SwiftApps/SciColSim/annealing.swift
Log:
write to best_opt_some_swift.txt file using fprintf
Modified: SwiftApps/SciColSim/annealing.swift
--- SwiftApps/SciColSim/annealing.swift 2012-02-05 10:33:36 UTC (rev 5548)
+++ SwiftApps/SciColSim/annealing.swift 2012-02-06 17:08:58 UTC (rev 5549)
@@ -160,9 +160,9 @@
if ( mlres[i][j].loss < ALOT )
- tracef( "multi_annealing: AF: best_opt_some.txt: %f,%f,%f,%f,%f,%f,%f,%f\n",
+ fprintf( "best_opt_some_swift.txt", "%f,%f,%f,%f,%f,%f,%f,%f\n",
target_innov, mlres[i][j].loss, try_x[0], try_x[1], try_x[2], try_x[3], try_x[4], mlres[i][j].sdev );
- tracef( color( Red,"multi_annealing: AF: max_dist.txt - tbd\n" ) ); // FIXME: max_dist is global set in evolve()
+ fprintf( "max_dist_swift.txt", color( Red,"multi_annealing: AF: max_dist.txt - tbd\n" ) ); // FIXME: max_dist is global set in evolve()
else
{ // does this ever occur? if so did we want to still do the ratio computation above???
More information about the Swift-commit
