[Swift-commit] r5540 - SwiftApps/SciColSim
jonmon at ci.uchicago.edu
Wed Feb 1 10:51:40 CST 2012
Author: jonmon
Date: 2012-02-01 10:51:40 -0600 (Wed, 01 Feb 2012)
New Revision: 5540
Modified:
SwiftApps/SciColSim/annealing.swift
Log:
annealing.swift now has comand line arguments for -maxrange, -minrange, -rangeinc
Modified: SwiftApps/SciColSim/annealing.swift
--- SwiftApps/SciColSim/annealing.swift 2012-01-31 23:29:20 UTC (rev 5539)
+++ SwiftApps/SciColSim/annealing.swift 2012-02-01 16:51:40 UTC (rev 5540)
@@ -3,9 +3,10 @@
type file;
-type Res {
- float loss;
- float sdev;
+type Res
+ float loss;
+ float sdev;
global boolean FIX_VARIABLES = true;
@@ -13,181 +14,214 @@
global int Nworkers = @toint(@arg("nworkers","4"));
global int rerunsPerApp;
-(float nx) newx(float x, float dx)
+( float nx ) newx( float x, float dx )
- float r = (random()) ; # / (pow(2.0,31.0)-1.0);
- if (r > 0.5){
- nx = x + (random())*dx; # /(pow(2.0,31.0)-1.0);
- } else {
- nx = x - (random())*dx; # /(pow(2.0,31.0)-1.0);
+ float r = (random()); // / (pow(2.0,31.0)-1.0);
+ if (r > 0.5)
+ nx = x + (random())*dx; // /(pow(2.0,31.0)-1.0);
+ else
+ nx = x - (random())*dx; // /(pow(2.0,31.0)-1.0);
// tracef("newx(%f,%f)=%f\n",x,dx,nx);
-app (file outfile, file loss) evolve (string args[], file graph)
+app (file outfile, file loss ) evolve ( string args[], file graph )
- evolve @loss args stdout=@outfile ; // graph is passed implicitly
+ evolve @loss args stdout=@outfile; // graph is passed implicitly
-app (file x) sumloss(file loss[])
+app ( file x ) sumloss( file loss[] )
- sumloss @filenames(loss) stdout=@x;
+ sumloss @filenames(loss) stdout=@x;
-Program structure:
+ Program structure:
main
- optimizer_sweep() - formerly, python script
- multi_annealing()
- multi_loss()
- evolve()
- sumloss()
+ optimizer_sweep() - formerly, python script
+ multi_annealing()
+ multi_loss()
+ evolve()
+ sumloss()
-(file bestfile, file maxfile) multi_annealing (
- float T_start,
- float T_end,
- float Target_rejection,
- int evolve_reruns,
- float starting_jump,
- float params0[],
- float target_innov,
- int annealing_cycles)
+( file bestfile, file maxfile ) multi_annealing (
+ float T_start,
+ float T_end,
+ float Target_rejection,
+ int evolve_reruns,
+ float starting_jump,
+ float params0[],
+ float target_innov,
+ int annealing_cycles )
- int cycle=10; # const
- int NEVOPARAMS=5; # const - 5 params, alpha 1,m through delta, does not include target_innovation
+ int cycle = 10; // const
+ int NEVOPARAMS = 5; // const - 5 params, alpha 1,m through delta, does not include target_innovation
float rejection[][]; // [i][j] where i is cycle and j is evolve-parameter (alpha_i, alpha_m, beta, gamma, delta)
float x[][], dx[][], curr_loss[], curr_sdev[];
Res mlres[][];
mlres[0][0] = multi_loss( 0, 0, params0, target_innov, evolve_reruns ); // FIXME: serves for all evolve-params ???
- tracef("multi_annealing: AR: initial: %f +- %f\n",mlres[0][0].loss,mlres[0][0].sdev);
+ tracef( "multi_annealing: AR: initial: %f +- %f\n", mlres[0][0].loss, mlres[0][0].sdev );
- foreach j in [0:NEVOPARAMS-1] {
- x[0][j]=params0[j];
- dx[0][j] = starting_jump;
- rejection[0][j] = 0.0;
- curr_loss[j] = mlres[0][0].loss;
- curr_sdev[j] = mlres[0][0].sdev;
+ foreach j in [0:NEVOPARAMS-1]
+ x[0][j] = params0[j];
+ dx[0][j] = starting_jump;
+ rejection[0][j] = 0.0;
+ curr_loss[j] = mlres[0][0].loss;
+ curr_sdev[j] = mlres[0][0].sdev;
- iterate iter_i { # foreach i in [1:annealing_cycles]
- int i = iter_i + 1;
+ iterate iter_i
+ { // foreach i in [1:annealing_cycles]
+ int i = iter_i + 1;
// set new temperature, rejection threshold, and dx values for this cycle
- float temperature = T_start*exp( @tofloat(i-1)*(jlog(T_end)-jlog(T_start))/@tofloat(annealing_cycles));
+ float temperature = T_start*exp( @tofloat( i-1 ) * ( jlog( T_end ) - jlog( T_start ) ) / @tofloat( annealing_cycles ) );
- tracef(@strcat("multi_annealing: AR: i=%i ....T = ",color(3,"%f"),"\n"), i, temperature);
+ tracef( @strcat( "multi_annealing: AR: i=%i ....T = ", color( 3, "%f" ),"\n" ), i, temperature );
- // On each new "major" cycle within the annealing_cycles (other than the first) set new rejection and dx values
+ // On each new "major" cycle within the annealing_cycles (other than the first) set new rejection and dx values
- if ( i %% cycle == 1 && i > 1 ){
- tracef("multi_annealing: new cycle at i=%i\n",i);
- tracef(color(Pink, "multi_annealing: AR: New cycle at %i: prev dx[0-4]=[%f %f %f %f %f]\n"),i,dx[i-1][0],dx[i-1][1],dx[i-1][2],dx[i-1][3],dx[i-1][4]);
- foreach k in [0:NEVOPARAMS-1] {
- float newrejection = rejection[i-1][k] / @tofloat(cycle);
- if (newrejection > 0.0){
- dx[i][k] = dx[i-1][k] / (newrejection / Target_rejection);
- # FIXME: re-enable: rejection[i][k]=0.0;
+ if ( i %% cycle == 1 && i > 1 )
+ tracef( "multi_annealing: new cycle at i=%i\n", i );
+ tracef( color( Pink, "multi_annealing: AR: New cycle at %i: prev dx[0-4]=[%f %f %f %f %f]\n" ), i, dx[i-1][0], dx[i-1][1], dx[i-1][2], dx[i-1][3], dx[i-1][4] );
+ foreach k in [0:NEVOPARAMS-1]
+ float newrejection = rejection[i-1][k] / @tofloat( cycle );
+ if ( newrejection > 0.0 )
+ dx[i][k] = dx[i-1][k] / ( newrejection / Target_rejection );
+ // FIXME: re-enable: rejection[i][k]=0.0;
- else{
+ else
dx[i][k] = dx[i-1][k] * 2.0;
- # FIXME: re-enable: rejection[i][k]=rejection[i-1][k];
+ // FIXME: re-enable: rejection[i][k]=rejection[i-1][k];
// FIXME: HANGS? : tracef(color(Red,"Recomputed rejection: i=%d k=%d dx[i][k]=%f\n"), i, k, dx[i][k]);
- tracef(color(Blue, "multi_annealing: AR: New cycle at %i: dx[0-4]=[%f %f %f %f %f]\n"),i,dx[i][0],dx[i][1],dx[i][2],dx[i][3],dx[i][4]);
+ tracef( color( Blue, "multi_annealing: AR: New cycle at %i: dx[0-4]=[%f %f %f %f %f]\n" ), i, dx[i][0], dx[i][1], dx[i][2], dx[i][3], dx[i][4] );
- else { # If not new cycle, set dx[i][*] from previous dx ([i-1]). rejection[i]j] is set later.
+ else
+ { // If not new cycle, set dx[i][*] from previous dx ([i-1]). rejection[i]j] is set later.
dx[i][k] = dx[i-1][k];
- #foreach j in [0:NEVOPARAMS-1] { // Try a new value for each non-fixed param; then write results and accept or reject
- iterate j { // Try a new value for each non-fixed param; then write results and accept or reject
+ //foreach j in [0:NEVOPARAMS-1] { // Try a new value for each non-fixed param; then write results and accept or reject
+ iterate j
+ { // Try a new value for each non-fixed param; then write results and accept or reject
// float try_x[];
- int curr = (i * NEVOPARAMS) + j;
+ int curr = ( i * NEVOPARAMS ) + j;
int prev = curr-1;
// tracef("in multi_annealing: i=%i j=%i curr=%i prev=%i\n", i, j, curr, prev);
- if ( /*(!FIX_VARIABLES) || */ (var_fixed[j]==0) ) { # Adjustable vars
- # fixed=1,1,0,0,0: FIXME: FIX_VARIABLES flag has faulty logic but OK when TRUE
+ if ( /*(!FIX_VARIABLES) || */ ( var_fixed[j] == 0 ) ) { // Adjustable vars
+ // fixed=1,1,0,0,0: FIXME: FIX_VARIABLES flag has faulty logic but OK when TRUE
float try_x[];
- foreach k in [0:NEVOPARAMS-1] { // Select the evolve params to try
- if ( k < j ) {
+ { // Select the evolve params to try
+ if ( k < j )
try_x[k] = x[i][k]; // already set x[i][k]
- else {
- if ( k == j ) {
+ else
+ if ( k == j )
try_x[k] = newx(x[i-1][j],dx[i-1][j]); // permute x[i-1][j]
- else { // k > j
+ else
+ { // k > j
try_x[k] = x[i-1][k]; // use x[i-1][k] (from prior cycle)
- tracef(@strcat("multi_annealing: AR: ", color(10,"%f"), " ", color(9,"%i"),"\n"), try_x[j],j);
+ tracef( @strcat( "multi_annealing: AR: ", color( 10,"%f" ), " ", color( 9,"%i" ),"\n" ), try_x[j], j );
// Up to here, x[] and dx[] are only set for previous i
- mlres[i][j] = multi_loss(i,j,try_x, target_innov, evolve_reruns); # do the N evolve()'s, N=evolve_reruns
- tracef("multi_annealing: AR: %f +- %f\n", mlres[i][j].loss, mlres[i][j].sdev);
+ mlres[i][j] = multi_loss( i, j, try_x, target_innov, evolve_reruns ); // do the N evolve()'s, N=evolve_reruns
+ tracef( "multi_annealing: AR: %f +- %f\n", mlres[i][j].loss, mlres[i][j].sdev );
// Beyond this point, x[] and dx[] are being set for this i,j
float ALOT=100000000000.0; // 100,000,000,000. = 10^11
- if (mlres[i][j].loss < ALOT) {
- tracef("multi_annealing: AF: best_opt_some.txt: %f,%f,%f,%f,%f,%f,%f,%f\n",
- target_innov,mlres[i][j].loss,try_x[0],try_x[1],try_x[2],try_x[3],try_x[4],mlres[i][j].sdev);
- tracef(color(Red,"multi_annealing: AF: max_dist.txt - tbd\n")); // FIXME: max_dist is global set in evolve()
+ if ( mlres[i][j].loss < ALOT )
+ tracef( "multi_annealing: AF: best_opt_some.txt: %f,%f,%f,%f,%f,%f,%f,%f\n",
+ target_innov, mlres[i][j].loss, try_x[0], try_x[1], try_x[2], try_x[3], try_x[4], mlres[i][j].sdev );
+ tracef( color( Red,"multi_annealing: AF: max_dist.txt - tbd\n" ) ); // FIXME: max_dist is global set in evolve()
- else { // does this ever occur? if so did we want to still do the ratio computation above???
- tracef("multi_annealing: Loss %f > ALOT at [i][j] = [%d][%d]\n", mlres[i][j].loss, i ,j);
+ else
+ { // does this ever occur? if so did we want to still do the ratio computation above???
+ tracef( "multi_annealing: Loss %f > ALOT at [i][j] = [%d][%d]\n", mlres[i][j].loss, i ,j );
- float ratio = min(1.0, exp( -(mlres[i][j].loss-curr_loss[prev]) / temperature));
- float r = (random()) ; # / (pow(2.0,31.0)-1.0); // FIXME: AR: why all the 2^31's ???
+ float ratio = min( 1.0, exp( -( mlres[i][j].loss - curr_loss[prev] ) / temperature ) );
+ float r = (random()) ; // / (pow(2.0,31.0)-1.0); // FIXME: AR: why all the 2^31's ???
tracef("multi_annealing: AR: %f vs %f\n", r, ratio);
- if (r > ratio) { // Reject new parameter
- x[i][j] = x[i-1][j];
- rejection[i][j] = rejection[i-1][j] + 1.0; // FIXME: AR: Is this correct? incr rejection?
+ if (r > ratio)
+ { // Reject new parameter
+ x[i][j] = x[i-1][j];
+ rejection[i][j] = rejection[i-1][j] + 1.0; // FIXME: AR: Is this correct? incr rejection?
curr_loss[curr] = curr_loss[prev];
curr_sdev[curr] = curr_sdev[prev];
- # FIXME: AR: the following prints seem to replicate values in the .cpp version - please clarify.
- tracef("multi_annealing: AR: %i,%i %i Did not accept: %f (%i)\n", i, j, i, try_x[j], j);
- tracef("multi_annealing: AR: %f %f %f %f %f\n", try_x[0],try_x[1],try_x[2],try_x[3],try_x[4]);
+ // FIXME: AR: the following prints seem to replicate values in the .cpp version - please clarify.
+ tracef( "multi_annealing: AR: %i,%i %i Did not accept: %f (%i)\n", i, j, i, try_x[j], j );
+ tracef( "multi_annealing: AR: %f %f %f %f %f\n", try_x[0],try_x[1],try_x[2],try_x[3],try_x[4] );
- else { // Accept new parameter
- tracef("multi_annealing: Accepting try_x[j], i=%i j=%i\n",i,j);
- x[i][j] = try_x[j];
- rejection[i][j] = rejection[i-1][j]; // FIXME: AR: Is this correct? no incr of rejection?
- tracef("multi_annealing: Accepting try_x[j], i=%i j=%i try_x[j]=%f\n",i,j,try_x[j]);
+ else
+ { // Accept new parameter
+ tracef( "multi_annealing: Accepting try_x[j], i=%i j=%i\n",i,j );
+ x[i][j] = try_x[j];
+ rejection[i][j] = rejection[i-1][j]; // FIXME: AR: Is this correct? no incr of rejection?
curr_loss[curr] = mlres[i][j].loss;
curr_sdev[curr] = mlres[i][j].sdev;
+ tracef( "multi_annealing: Accepting try_x[j], i=%i j=%i try_x[j]=%f\n", i, j, try_x[j] );
float rj[];
- foreach k in [0:NEVOPARAMS-1] { # FIXME!!!
- if (k <= j) {
- rj[k] = rejection[i][k]; # Was either set from previous j or just set for this j
+ { // FIXME!!!
+ if (k <= j)
+ rj[k] = rejection[i][k]; // Was either set from previous j or just set for this j
- else {
- rj[k] = rejection[i-1][k]; # Not yet set, use previous
+ else
+ rj[k] = rejection[i-1][k]; // Not yet set, use previous
tracef(@strcat("multi_annealing: AR: [%i][%i] ", color(8,"Rejection counts: "),
- color(1,"%f"), " ", color(7,"%f"), " ", color(5,"%f"), " ", color(9,"%f"), " ", color(6,"%f"), "\n\n"),
+ color(1,"%f"), " ", color(7,"%f"), " ", color(5,"%f"), " ", color(9,"%f"), " ", color(6,"%f"), "\n\n"),
i, j, rj[0], rj[1], rj[2], rj[3], rj[4]);
tracef(@strcat("multi_annealing: AR: %i ", color(8,"***** Did accept! "),
- i, try_x[0], try_x[1], try_x[2], try_x[3], try_x[4]);
+ i, try_x[0], try_x[1], try_x[2], try_x[3], try_x[4]);
- else { # Fixed Vars
+ else
+ { // Fixed Vars
- # dx[i][j] not set for fixed vars
+ // dx[i][j] not set for fixed vars
} until(j == NEVOPARAMS-1);
} until(iter_i == (annealing_cycles-1));
@@ -195,157 +229,152 @@
(Res r) multi_loss( int ci, int cj, float x[], float target_innov, int evolve_reruns )
// (Res r, Stats s) multi_loss( int ci, int cj, float x[], float target_innov, int evolve_reruns ) FIXME: To obtain stats
- file rfile[];
- file ofile[]; // FIXME: to obtain timings and otehr stats
- tracef("multi_loss: entered: ci=%i cj=%i target_innov=%f evolve_reruns=%i x=%q\n",ci, cj, target_innov,evolve_reruns,x);
+ file rfile[];
+ file ofile[]; // FIXME: to obtain timings and otehr stats
- int appCalls = @toint(@tofloat(evolve_reruns) / @tofloat(rerunsPerApp)); # FIXME: handle fractional issues and rounding etc. For now must divide evenly
+ tracef("multi_loss: entered: ci=%i cj=%i target_innov=%f evolve_reruns=%i x=%q\n",ci, cj, target_innov,evolve_reruns,x);
-tracef("multi_loss appCalls=%i\n", appCalls);
- foreach i in [1:appCalls] { // repeats of the evolove() - same as n_reruns
- file outfile; // FIXME: map and save in future
- string args[] = [ // FIXME: move this to a setargs() function
- // alpha_i alpha_m beta gamma delta target_innov
+ int appCalls = @toint(@tofloat(evolve_reruns) / @tofloat(rerunsPerApp)); // FIXME: handle fractional issues and rounding etc. For now must divide evenly
+ tracef("multi_loss appCalls=%i\n", appCalls);
+ foreach i in [1:appCalls]
+ { // repeats of the evolove() - same as n_reruns
+ file outfile; // FIXME: map and save in future
+ string args[] = [ // FIXME: move this to a setargs() function
+ // alpha_i alpha_m beta gamma delta target_innov
@strcat(x[0]), @strcat(x[1]), @strcat(x[2]), @strcat(x[3]), @strcat(x[4]), @strcat(target_innov),
- // n_epochs n_steps evolve_reruns range
- // "40000", "20", @strcat(evolve_reruns), "2",
- "40000", "20", @strcat(rerunsPerApp), "2",
- // verbose_level
+ // n_epochs n_steps evolve_reruns range
+ // "40000", "20", @strcat(evolve_reruns), "2",
+ "40000", "20", @strcat(rerunsPerApp), "2",
+ // verbose_level
"1",
- // T_start T_end Annealing_steps Target_rejection Starting_jump
+ // T_start T_end Annealing_steps Target_rejection Starting_jump
"2.", "0.01", "2", "0.3", "2.3",
- // FREEZE: alpha_i alpha_m beta gamma delta
- "1", "1", "0", "0", "0",
- // operation-code:(m,a) Nworkers seed
- "m", @strcat(Nworkers), "1234567" ];
- file graph <"movie_graph.txt">;
- (outfile, rfile[i]) = evolve(args,graph);
- // (ofile[i], rfile[i]) = evolve(args,graph);
- tracef("multi_loss: i=%i calling evolve, args=%q\n", i, args);
- // tracef("multi_loss: after evolve: i=%i %k %k\n", i, outfile, rfile[i]);
- file sumfile = sumloss(rfile);
- r = readData(sumfile);
- tracef("multi_loss: returning: ci=%i cj=%i r.loss=%f r.sdev=%f\n",ci,cj,r.loss,r.sdev);
- // file statfile = sumstats(ofile); FIXME: to obtain timings and otehr stats
- // s = readStat(statsfile); FIXME: to obtain timings and otehr stats
+ // FREEZE: alpha_i alpha_m beta gamma delta
+ "1", "1", "0", "0", "0",
+ // operation-code:(m,a) Nworkers seed
+ "m", @strcat(Nworkers), "1234567" ];
+ file graph <"movie_graph.txt">;
+ ( outfile, rfile[i] ) = evolve( args, graph );
+ // (ofile[i], rfile[i]) = evolve(args,graph);
+ tracef("multi_loss: i=%i calling evolve, args=%q\n", i, args);
+ // tracef("multi_loss: after evolve: i=%i %k %k\n", i, outfile, rfile[i]);
+ file sumfile = sumloss(rfile);
+ r = readData(sumfile);
+ tracef("multi_loss: returning: ci=%i cj=%i r.loss=%f r.sdev=%f\n",ci,cj,r.loss,r.sdev);
+ // file statfile = sumstats(ofile); FIXME: to obtain timings and otehr stats
+ // s = readStat(statsfile); FIXME: to obtain timings and otehr stats
optimizer_sweep() // Implements logic of python driver script
- int minrange=58;
- int maxrange=59;
- int rangeinc=50;
+ int minrange = @toint(@arg("minrange", "58"));
+ int maxrange = @toint(@arg("maxrange", "59"));
+ int rangeinc = @toint(@arg("rangeinc", "50"));
- //int maxrange=1009;
- //int maxrange=209;
+ // FIXME: add provision for random priming and random param values when x[i] == -100 (see optimizer.cpp main())
- // FIXME: add provision for random priming and random param values when x[i] == -100 (see optimizer.cpp main())
+ int nreps = 1; // 15
- int nreps=1; # 15
// file bestfile <single_file_mapper; file=@strcat("output/T",target,".R",rep,".best_opt_some")>;
// file maxfile <single_file_mapper; file=@strcat("output/T",target,".R",rep,".max_dist")>;
- foreach target_innov in [minrange:maxrange:rangeinc] {
- foreach rep in [1:nreps] {
- file outfile; // <single_file_mapper; file=@strcat("output/T",target_innov,".R",rep,".out")>;
- file lossfile; // <single_file_mapper; file=@strcat("output/T",target_innov,".R",rep,".loss_data")>;
- (outfile,lossfile) = multi_annealing(
- T_start = 2.0,
- T_end = 0.01,
- Target_rejection = 0.3,
- evolve_reruns = 10,
- starting_jump = 2.3,
- params0[] = [0.0, 0.0, 4.0, 50.0, -1.0],
- @tofloat(target_innov),
- annealing_cycles = 2);
- 2.0,
- 0.01,
- 0.3,
- 100,
- 2.3,
- [0.0, 0.0, 4.0, 50.0, -1.0],
- 30);
+ foreach target_innov in [minrange:maxrange:rangeinc]
+ foreach rep in [1:nreps]
+ file outfile; // <single_file_mapper; file=@strcat("output/T",target_innov,".R",rep,".out")>;
+ file lossfile; // <single_file_mapper; file=@strcat("output/T",target_innov,".R",rep,".loss_data")>;
+ ( outfile,lossfile ) = multi_annealing(
+ 2.0,
+ 0.01,
+ 0.3,
+ 100,
+ 2.3,
+ [0.0, 0.0, 4.0, 50.0, -1.0],
+ @tofloat(target_innov),
+ 30 );
rerunsPerApp = 100;
main()
- optimizer_sweep();
+ optimizer_sweep();
main();
-Program structure:
main
- optimizer_sweep()
- multi_annealing()
- multi_loss()
- evolve()
- sumloss()
+ optimizer_sweep()
+ multi_annealing()
+ multi_loss()
+ evolve()
+ sumloss()
-Example parameter sets:
+ Example parameter sets:
-for target in range(58,59,50):
+ for target in range(58,59,50):
for i in range(1):
- args="./toptimizer 0 0 4 50 -1 "+target+" 40000 20 75 2 1 2. 0.01 2 0.3 2.3 1 1 1 0 0 m # > out.T"+str(target)+".i"+str(i)
- os.system(args);
+ args="./toptimizer 0 0 4 50 -1 "+target+" 40000 20 75 2 1 2. 0.01 2 0.3 2.3 1 1 1 0 0 m // > out.T"+str(target)+".i"+str(i)
+ os.system(args);
- string fastargs1[] = [
- "0", "0", "4", "50", "-1", @strcat(target),
- "40000", "20", "1000", "2",
- "1",
- "2.", "0.01", "100", "0.3", "2.3",
- "1", "1", "0", "0", "0"];
- string fastargs2[] = [
- "1",
- "2.", "0.01", "5", "0.3", "2.3",
- "1", "1", "0", "0", "0", "m"];
- string fastargs3[] = [
- "40000", "20", @strcat(repeats), "2",
- "1",
- "2.", "0.01", "2", "0.3", "2.3",
+ string fastargs1[] = [
+ "0", "0", "4", "50", "-1", @strcat(target),
+ "40000", "20", "1000", "2",
+ "1",
+ "2.", "0.01", "100", "0.3", "2.3",
+ "1", "1", "0", "0", "0"];
+ string fastargs2[] = [
+ "1",
+ "2.", "0.01", "5", "0.3", "2.3",
+ "1", "1", "0", "0", "0", "m"];
+ string fastargs3[] = [
+ "40000", "20", @strcat(repeats), "2",
+ "1",
+ "2.", "0.01", "2", "0.3", "2.3",
(string args[]) setargs()
- // string longargs[] = @strcat("0 0 4 50 -1 ",target," 40000 20 1000 2 1 2. 0.01 100 0.3 2.3 1 1 0 0 0 m");
+ // string longargs[] = @strcat("0 0 4 50 -1 ",target," 40000 20 1000 2 1 2. 0.01 100 0.3 2.3 1 1 0 0 0 m");
- // [alpha_i alpha_m beta gamma delta target_innov
- // [n_epochs n_steps n_reruns] [range]
- // [verbose_level]
- // [T_start T_end Annealing_steps Target_rejection Starting_jump]
- // [FREEZE_alpha_i FREEZE_alpha_m FREEZE_beta FREEZE_gamma FREEZE_delta] [operation-code:(m,a) Nworkers]
+ // [alpha_i alpha_m beta gamma delta target_innov
+ // [n_epochs n_steps n_reruns] [range]
+ // [verbose_level]
+ // [T_start T_end Annealing_steps Target_rejection Starting_jump]
+ // [FREEZE_alpha_i FREEZE_alpha_m FREEZE_beta FREEZE_gamma FREEZE_delta] [operation-code:(m,a) Nworkers]
-######### HOLD JUNK
+////////////////// HOLD JUNK
-# tracef(@strcat("multi_annealing: AR: %i ", color(8,"Rejection counts: "),
-# color( /* 2 */ 1," %f"), "\n\n"),
-# i, rejection[i][j] ); // , rejection[i][1], rejection[i][2], rejection[i][3], rejection[i][4]);
-# FIXME: determine correct rejection[] values to avoid hanging:
-# color( /* 2 */ 1," %f"), color(7," %f"), color(5," %f"), color(9," %f"), color(6," %f"), "\n\n"),
-# rejection[i][0], rejection[i][1], rejection[i][2], rejection[i][3], rejection[i][4]);
-# END FIXME
+// tracef(@strcat("multi_annealing: AR: %i ", color(8,"Rejection counts: "),
+// color( /* 2 */ 1," %f"), "\n\n"),
+// i, rejection[i][j] ); // , rejection[i][1], rejection[i][2], rejection[i][3], rejection[i][4]);
+// FIXME: determine correct rejection[] values to avoid hanging:
+// color( /* 2 */ 1," %f"), color(7," %f"), color(5," %f"), color(9," %f"), color(6," %f"), "\n\n"),
+// rejection[i][0], rejection[i][1], rejection[i][2], rejection[i][3], rejection[i][4]);
+// END FIXME
More information about the Swift-commit
