[Swift-commit] r5751 - SwiftApps/ParVis/HiRAMTools
    wilde at ci.uchicago.edu
    Sat Apr 21 09:53:11 CDT 2012
Author: wilde
Date: 2012-04-21 09:53:10 -0500 (Sat, 21 Apr 2012)
New Revision: 5751
Added:
   SwiftApps/ParVis/HiRAMTools/makeyearly-cdo.sh
   SwiftApps/ParVis/HiRAMTools/makeyearly.swift
   SwiftApps/ParVis/HiRAMTools/runall.config
Modified:
   SwiftApps/ParVis/HiRAMTools/makeyearly_realization.sh
   SwiftApps/ParVis/HiRAMTools/runall.sh
Log:
Add scripts to reorganize quarter0decade directory structures into yearly structures.
Added: SwiftApps/ParVis/HiRAMTools/makeyearly-cdo.sh
--- SwiftApps/ParVis/HiRAMTools/makeyearly-cdo.sh	                        (rev 0)
+++ SwiftApps/ParVis/HiRAMTools/makeyearly-cdo.sh	2012-04-21 14:53:10 UTC (rev 5751)
@@ -0,0 +1,48 @@
+#! /bin/bash
+set -o errexit
+# Create a fast (local-filesystem) working dir
+mkdir -p /scratch/wilde
+tmp=$(mktemp -d /scratch/wilde/makeyearly_XXXXXX)
+startdir=$PWD
+cd $tmp
+echo running in $PWD
+qtrdec1=$1  # 1st quarter-decade dir
+qtrdec2=$2  # 2nd quarter-decade dir
+destbase=$3 # base dir for output years
+echo destbase=$destbase
+export PATH=/soft/apps/cdo-1.4.7/bin:$PATH
+export LD_LIBRARY_PATH=/soft/apps/intel-fc-11.0.074/lib/intel64:/soft/apps/intel-cc-11.0.074/lib/intel64:/soft/apps/netcdf-3.6.3/lib:/usr/lib:/usr/X11R6/lib:/usr/local/lib
+fname=$(basename $qtrdec1 .nc)
+firstyear=$(basename $(dirname $qtrdec1) | sed -e 's/....$//')
+if echo $fname | egrep -v 'grid_spec|scalar'; then
+  cdo mergetime $qtrdec1 $qtrdec2 ${fname}.nc
+  cdo splityear ${fname}.nc ${fname}.
+  # Yields, eg, from atmos_month.tile1:
+  # atmos_month.tile1.1950.nc
+  # atmos_month.tile1.1951.nc
+  # atmos_month.tile1.1952.nc
+  # atmos_month.tile1.1953.nc
+  # atmos_month.tile1.1954.nc
+fi
+for (( y=0; y<5; y++ ))
+do
+  year=$((firstyear+y))
+  yeardir=${year}0101
+  destdir=$destbase/$yeardir
+  mkdir -p $destdir
+  if echo $fname | egrep -v 'grid_spec|scalar'; then
+    dd if=$fname.$year.nc of=$destdir/$fname.nc bs=8M
+  else
+    dd if=$qtrdec1 of=$destdir/$fname.nc bs=8M
+  fi
+done
Property changes on: SwiftApps/ParVis/HiRAMTools/makeyearly-cdo.sh
___________________________________________________________________
Added: svn:executable
Added: SwiftApps/ParVis/HiRAMTools/makeyearly.swift
--- SwiftApps/ParVis/HiRAMTools/makeyearly.swift	                        (rev 0)
+++ SwiftApps/ParVis/HiRAMTools/makeyearly.swift	2012-04-21 14:53:10 UTC (rev 5751)
@@ -0,0 +1,21 @@
+type file;
+type ncrec {
+  string f1;
+  string f2;
+string rundir=@arg("rundir","NO-OUTDIR-SPECIFIED");
+string ncfile=@arg("ncfile","ncfiles");
+app makeyearly (string dir, string f1, string f2)
+  makeyearly f1 f2 dir;
+ncrec nc[] = readData(ncfile);
+foreach n in nc {
+  makeyearly(rundir,n.f1,n.f2);
Modified: SwiftApps/ParVis/HiRAMTools/makeyearly_realization.sh
--- SwiftApps/ParVis/HiRAMTools/makeyearly_realization.sh	2012-04-17 15:11:35 UTC (rev 5750)
+++ SwiftApps/ParVis/HiRAMTools/makeyearly_realization.sh	2012-04-21 14:53:10 UTC (rev 5751)
@@ -1,23 +1,35 @@
 #! /bin/bash
-cdir=$1    # combined dir
-outdir=$2  # outdir for equivalent yearly files
+cdir=$1     # combined dir
+outbase=$2  # base of outdir for equivalent yearly files
+bindir=$(dirname $0)
+bindir=$(cd $bindir; pwd)
+echo bindir=$bindir
+# Enable one of the following patterns to name the output dir:
+outsuffix=$(basename $cdir)                              # rname
+outsuffix=$(basename $(dirname $cdir))                   # rname/rundir, use rname
+outsuffix=$(basename $(dirname $cdir))/$(basename $cdir) # rname/rundir, use both
+# generate the list of files to process: do every half-decade
+echo f1 f2 >ncfiles
 for y in $(seq 1950 5 1997); do
   startyear=${y}0101;
   nextyear=$((y+2))0701
+  find $cdir/$startyear -type f | fgrep .nc | sed -e "s,^\\(.*\\)/$startyear/\\(.*\\),\\1/$startyear/\\2 \\1/$nextyear/\\2 $outdir,"
+done >>ncfiles
-  find $cdir/$startyear -type f | fgrep .nc
-done >ncfiles
-exit
 # Create new runNNN directory
 rundir=$( echo run??? | sed -e 's/^.*run//' | awk '{ printf("run%03d\n", $1+1)}' )
 mkdir $rundir
+# Generate Swift config files (cf, tc, sites.xml):
 cat >$rundir/cf <<END
 wrapperlog.always.transfer=true
@@ -66,18 +78,18 @@
 cat >$rundir/tc <<END
-#local  combine $PWD/combine.sh
-cobalt combine $PWD/combine.sh
+cobalt makeyearly $bindir/makeyearly-cdo.sh
 END
-cp ncfiles makeyearly.swift $rundir
+# Place file list and swift script in run dir, set params, make output dir, and run script
+cp ncfiles $bindir/makeyearly.swift $rundir
 cd $rundir
 echo Running in directory $rundir
-runid=$(basename $rundir)
-mkdir -p $outdir/$runid
+runid=$(basename $rundir) # un-needed?
+outdir=$outbase/$outsuffix/$runid
+mkdir -p $outdir
-swift -config cf -tc.file tc -sites.file sites.xml makeyearly.swift -rundir=$outdir/$runid -ncfiles=ncfiles >& swift.out
+swift -config cf -tc.file tc -sites.file sites.xml makeyearly.swift -rundir=$outdir -ncfiles=ncfiles >& swift.out
Added: SwiftApps/ParVis/HiRAMTools/runall.config
--- SwiftApps/ParVis/HiRAMTools/runall.config	                        (rev 0)
+++ SwiftApps/ParVis/HiRAMTools/runall.config	2012-04-21 14:53:10 UTC (rev 5751)
@@ -0,0 +1,6 @@
+realtodo=real.todo                                        # File of names of realization subdirs to process
+realdone=real.done                                        # File of names of realization subdirs completed
+outdir=/intrepid-fs0/users/wilde/persistent/LZ/yearly     # Base dir for yearly output
+# script=combine_realizations.sh
+script=makeyearly_realization.sh
Modified: SwiftApps/ParVis/HiRAMTools/runall.sh
--- SwiftApps/ParVis/HiRAMTools/runall.sh	2012-04-17 15:11:35 UTC (rev 5750)
+++ SwiftApps/ParVis/HiRAMTools/runall.sh	2012-04-21 14:53:10 UTC (rev 5751)
@@ -1,14 +1,21 @@
 #! /bin/sh
-# ls -1d en*/history/[0-9][0-9][0-9][0-9]????   eur$ ls -1d en*/history/[0-9][0-9][0-9][0-9]????
-# The following can be made into parameters to this script. Set here for now.
-realdir=/intrepid-fs0/users/wilde/persistent/LZ/combined # Base dir of realizations
-realtodo=yearly.todo                                       # File of names of realization subdirs to process
-realdone=yearly.done                                       # File of names of realization subdirs completed
-outdir=/intrepid-fs0/users/wilde/persistent/LZ/yearly    # Base dir for combined output
+realtodo=real.todo                                       # File of full path names of realization dirs to process
+realdone=real.done                                       # File of full path names of realization dirs completed
+outdir=/intrepid-fs0/users/wilde/persistent/LZ/yearly      # Base dir for processed output
+source $bindir/runall.config # set default params
+if [ -f runall.config ]; then
+  source runall.config       # set local params
+fi
+echo bindir=$bindir script=$script
 # Helpful patterns for filename matching
 yyyy="[0-9][0-9][0-9][0-9]"
@@ -25,24 +32,23 @@
   echo RunAll: Processing $real
-  find $realdir/$real/history/$yyyymmdd  |
-    grep .nc.$yyyy      |
-    sed -e 's/.....$//' | sort | uniq > $real.groups
+# find $realdir/$real/history/$yyyymmdd  |
+#   grep .nc.$yyyy      |
+#   sed -e 's/.....$//' | sort | uniq > $real.groups
+#  echo Created $real.groups
-  echo Created $real.groups
+  echo  Running: $bindir/$script    \
+    $real \
+    $outdir
-  echo  ./makeyearly_realization.sh    \
-    "$realdir/$real/$yyyymmdd" \
-    $outdir/$real
+  $bindir/$script    \
+    $real \
+    $outdir
-  ./makeyearly_realization.sh    \
-    $outdir/$real
   echo RunAll: Completed $real
   echo $real >>$realdone
 done
 echo RunAll: all realizations are done.
More information about the Swift-commit
