[Swift-commit] r5198 - trunk/docs/userguide
ketan at ci.uchicago.edu
Thu Sep 29 22:02:15 CDT 2011
Author: ketan
Date: 2011-09-29 22:02:15 -0500 (Thu, 29 Sep 2011)
New Revision: 5198
Modified:
trunk/docs/userguide/app_procedures
Log:
added @java function into function ref
Modified: trunk/docs/userguide/app_procedures
--- trunk/docs/userguide/app_procedures 2011-09-30 00:16:08 UTC (rev 5197)
+++ trunk/docs/userguide/app_procedures 2011-09-30 03:02:15 UTC (rev 5198)
@@ -383,10 +383,12 @@
@length
- at length(array) will return the length of an array in Swift. This function will wait for all elements in the array to be written before returning the lennth.
+ at length(array) will return the length of an array in Swift. This function will wait for all elements in the array to be written before returning the length.
+ at java
+ at java(class_name, static_method, method_arg) will call a java static method of the class class_name.
Built-in procedure reference
This section details built-in procedures that are available for use in
More information about the Swift-commit
