[Swift-commit] r5188 - in trunk/tests: . language-behaviour/mappers
davidk at ci.uchicago.edu
Wed Sep 28 14:29:39 CDT 2011
Author: davidk
Date: 2011-09-28 14:29:39 -0500 (Wed, 28 Sep 2011)
New Revision: 5188
Added:
trunk/tests/language-behaviour/mappers/075551-ext-mapper-twostruct-singleproducer.setup.sh
Modified:
trunk/tests/suite.sh
Log:
Suite.sh fix to copy setup scripts to script directory
Added: trunk/tests/language-behaviour/mappers/075551-ext-mapper-twostruct-singleproducer.setup.sh
--- trunk/tests/language-behaviour/mappers/075551-ext-mapper-twostruct-singleproducer.setup.sh (rev 0)
+++ trunk/tests/language-behaviour/mappers/075551-ext-mapper-twostruct-singleproducer.setup.sh 2011-09-28 19:29:39 UTC (rev 5188)
@@ -0,0 +1,7 @@
+#!/bin/bash
+set -x
+cp -v $GROUP/07555-ext-mapper-twostruct.sh.in . || exit 1
+exit 0
Property changes on: trunk/tests/language-behaviour/mappers/075551-ext-mapper-twostruct-singleproducer.setup.sh
___________________________________________________________________
Added: svn:executable
Modified: trunk/tests/suite.sh
--- trunk/tests/suite.sh 2011-09-28 18:32:43 UTC (rev 5187)
+++ trunk/tests/suite.sh 2011-09-28 19:29:39 UTC (rev 5188)
@@ -53,7 +53,7 @@
-f)
TEXTREPORT=1
shift;;
- -h)
+ -h|--h|-help|--help)
printhelp
exit 0;;
-k)
@@ -799,8 +799,9 @@
TEST_SHOULD_FAIL=0
OUTPUT=$NAME.setup.stdout
- if [ -x $GROUP/$SETUPSCRIPT ]; then
- script_exec $GROUP/$SETUPSCRIPT "S"
+ if [ -x "$GROUP/$SETUPSCRIPT" ]; then
+ cp "$GROUP/$SETUPSCRIPT" .
+ script_exec ./$SETUPSCRIPT "S"
else
stage_files $GROUP $NAME
fi
@@ -816,7 +817,9 @@
(( TESTCOUNT++ ))
TIMEOUT=$( gettimeout $GROUP/$TIMEOUTFILE )
+ if [ -f "$GROUP/$TIMEOUTFILE" ]; then
+ cp "$GROUP/$TIMEOUTFILE" .
+ fi
grep THIS-SCRIPT-SHOULD-FAIL $GROUP/$SWIFTSCRIPT > /dev/null
TEST_SHOULD_FAIL=$(( ! $? ))
@@ -830,16 +833,18 @@
$CDM $SWIFTSCRIPT $ARGS
TEST_SHOULD_FAIL=0
- if [ -x $GROUP/$CHECKSCRIPT ]; then
+ if [ -x "$GROUP/$CHECKSCRIPT" ]; then
+ cp "$GROUP/$CHECKSCRIPT" .
OUTPUT=$NAME.check.stdout
- script_exec $GROUP/$CHECKSCRIPT "√"
+ script_exec ./$CHECKSCRIPT "√"
else
check_outputs $GROUP $NAME
fi
OUTPUT=$NAME.clean.stdout
- if [ -x $GROUP/$CLEANSCRIPT ]; then
- script_exec $GROUP/$CLEANSCRIPT "C"
+ if [ -x "$GROUP/$CLEANSCRIPT" ]; then
+ cp "$GROUP/$CLEANSCRIPT" .
+ script_exec ./$CLEANSCRIPT "C"
else
html_td width 25
html " "
@@ -860,8 +865,9 @@
TEST_SHOULD_FAIL=0
else
html_td width 25
html " "
@@ -892,8 +898,9 @@
fi
else
html_td width 25
html " "
@@ -901,8 +908,9 @@
fi
else
html_td width 25
html " "
More information about the Swift-commit
