[Swift-commit] r5182 - in trunk/tests: . language/working	language-behaviour/mappers local
    davidk at ci.uchicago.edu
    Tue Sep 27 16:05:32 CDT 2011
Author: davidk
Date: 2011-09-27 16:05:32 -0500 (Tue, 27 Sep 2011)
New Revision: 5182
Added:
   trunk/tests/language-behaviour/mappers/0755-ext-mapper.sh.in
   trunk/tests/language/working/061-stdoutinerr.setup.sh
   trunk/tests/language/working/062-stdinerrout.setup.sh
Modified:
   trunk/tests/language-behaviour/mappers/07511-fixed-array-mapper-input.check.sh
   trunk/tests/local/filesysmapper.check.sh
   trunk/tests/local/range.check.sh
   trunk/tests/suite.sh
Log:
Updates to test suite
Added: trunk/tests/language/working/061-stdoutinerr.setup.sh
--- trunk/tests/language/working/061-stdoutinerr.setup.sh	                        (rev 0)
+++ trunk/tests/language/working/061-stdoutinerr.setup.sh	2011-09-27 21:05:32 UTC (rev 5182)
@@ -0,0 +1 @@
+cp -v $GROUP/test.in .
Property changes on: trunk/tests/language/working/061-stdoutinerr.setup.sh
___________________________________________________________________
Added: svn:executable
Added: trunk/tests/language/working/062-stdinerrout.setup.sh
--- trunk/tests/language/working/062-stdinerrout.setup.sh	                        (rev 0)
+++ trunk/tests/language/working/062-stdinerrout.setup.sh	2011-09-27 21:05:32 UTC (rev 5182)
@@ -0,0 +1 @@
Property changes on: trunk/tests/language/working/062-stdinerrout.setup.sh
Modified: trunk/tests/language-behaviour/mappers/07511-fixed-array-mapper-input.check.sh
--- trunk/tests/language-behaviour/mappers/07511-fixed-array-mapper-input.check.sh	2011-09-27 19:50:12 UTC (rev 5181)
+++ trunk/tests/language-behaviour/mappers/07511-fixed-array-mapper-input.check.sh	2011-09-27 21:05:32 UTC (rev 5182)
@@ -1,6 +1,6 @@
 #!/bin/bash
 set -x
-cat $TEST_LOG | grep "file: 07511-fixed-array-mapper-input.first.in" || exit 1
-cat $TEST_LOG | grep "file: 07511-fixed-array-mapper-input.second.in" || exit 1
-cat $TEST_LOG | grep "file: 07511-fixed-array-mapper-input.third.in" || exit 1
+cat 07511-fixed-array-mapper-input.stdout | grep "file: 07511-fixed-array-mapper-input.first.in" || exit 1
+cat 07511-fixed-array-mapper-input.stdout | grep "file: 07511-fixed-array-mapper-input.second.in" || exit 1
+cat 07511-fixed-array-mapper-input.stdout | grep "file: 07511-fixed-array-mapper-input.third.in" || exit 1
 exit 0
Added: trunk/tests/language-behaviour/mappers/0755-ext-mapper.sh.in
--- trunk/tests/language-behaviour/mappers/0755-ext-mapper.sh.in	                        (rev 0)
+++ trunk/tests/language-behaviour/mappers/0755-ext-mapper.sh.in	2011-09-27 21:05:32 UTC (rev 5182)
@@ -0,0 +1,4 @@
+echo "[0].l 0755-ext-mapper.AAA.out"
+echo "[1].r 0755-ext-mapper.0.3.2.1.out"
+echo "[2].l 0755-ext-mapper.____.out"
Property changes on: trunk/tests/language-behaviour/mappers/0755-ext-mapper.sh.in
Modified: trunk/tests/local/filesysmapper.check.sh
--- trunk/tests/local/filesysmapper.check.sh	2011-09-27 19:50:12 UTC (rev 5181)
+++ trunk/tests/local/filesysmapper.check.sh	2011-09-27 21:05:32 UTC (rev 5182)
@@ -2,8 +2,8 @@
 set -x
-ls stdout.txt || exit 1
-COUNT=$( grep -c "file: [abc].dat" < stdout.txt )
+ls filesysmapper.stdout || exit 1
+COUNT=$( grep -c "file: [abc].dat" < filesysmapper.stdout )
 (( $COUNT == 3 )) || exit 1
 exit 0
Modified: trunk/tests/local/range.check.sh
--- trunk/tests/local/range.check.sh	2011-09-27 19:50:12 UTC (rev 5181)
+++ trunk/tests/local/range.check.sh	2011-09-27 21:05:32 UTC (rev 5182)
@@ -2,9 +2,9 @@
 set -x
+ls range.stdout || exit 1
-COUNT=$( grep -c "num:" stdout.txt )
+COUNT=$( grep -c "num:" range.stdout )
 (( $COUNT == 11 )) || exit 1
 exit 0
Modified: trunk/tests/suite.sh
--- trunk/tests/suite.sh	2011-09-27 19:50:12 UTC (rev 5181)
+++ trunk/tests/suite.sh	2011-09-27 21:05:32 UTC (rev 5182)
@@ -118,6 +118,7 @@
 SEQ=1
 DATE=$( date +"%Y-%m-%d" )
 TIME=$( date +"%T" )
+HOURMINSEC=$( date +"%H%M%S" )
 RUNDIRBASE="run-$DATE"
 RUNDIR=$TOPDIR/$RUNDIRBASE
@@ -363,7 +364,7 @@
 				printf %-10.10s "success">>$REPORT
 			else
 				echo -e "${RED}FAILED${GRAY}"
-				cat $RUNDIR/$TEST_LOG < /dev/null
+				cat $RUNDIR/$OUTPUT < /dev/null
 				printf %-10.10s "failure">>$REPORT
 			fi
@@ -377,17 +378,17 @@
 	    	# WIDTH=$( width "$LABEL" )
 	    	if [ "$RESULT" == "Passed" ]; then
 	      		html_td class "success" width 25 title "$CMD"
-	      		html_a_href $TEST_LOG "$LABEL"
+                        html_a_href "$TESTNAMEDIR/$OUTPUT" "$LABEL"
 	      	elif [ "$RESULT" == "None" ]; then
 	      		html_td width 25
 		   	html "  "
    			html_~td
 	    	else
 	      		html_td class "failure" width 25 title "$CMD"
-	      		html_a_href $TEST_LOG $LABEL
-	    	fi
+                fi
 	    	html_~td
 	  	elif [ "$TYPE" == "package" ]; then
 	    	BINPACKAGE=$2
@@ -596,8 +597,7 @@
   fi
   RESULT=$( result )
-  test_log
-  output_report test $SEQ "$LASTCMD" $RESULT $TEST_LOG
+  output_report test $SEQ "$LASTCMD" $RESULT $OUTPUT
   check_bailout
@@ -695,8 +695,7 @@
   LASTCMD="$@"
-  test_log
   check_bailout
@@ -711,7 +710,6 @@
   process_exec $SCRIPT
   RESULT=$( result )
-  test_log
   output_report test "$SYMBOL" "$LASTCMD" $RESULT
   check_bailout
@@ -723,7 +721,7 @@
 	RESULT="None"
-	if [ -f $GROUP/$NAME.in ]; then
+	if [ -f "$GROUP/$NAME.in" ]; then
 		echo "Copying input: $NAME.in"
 		cp -v $GROUP/$NAME.in . 2>&1 >> $OUTPUT
 		if [ "$?" != 0 ]; then
@@ -800,6 +798,7 @@
   ARGSFILE=$NAME.args
   TEST_SHOULD_FAIL=0
+  OUTPUT=$NAME.setup.stdout
   if [ -x $GROUP/$SETUPSCRIPT ]; then
     script_exec $GROUP/$SETUPSCRIPT "S"
   else
@@ -818,9 +817,10 @@
   TIMEOUT=$( gettimeout $GROUP/$TIMEOUTFILE )
-  grep THIS-SCRIPT-SHOULD-FAIL $SWIFTSCRIPT > /dev/null
+  grep THIS-SCRIPT-SHOULD-FAIL $GROUP/$SWIFTSCRIPT > /dev/null
   TEST_SHOULD_FAIL=$(( ! $?  ))
+  OUTPUT=$NAME.stdout
   monitored_exec $TIMEOUT swift     \
                        -wrapperlog.always.transfer true \
                        -sitedir.keep true               \
@@ -831,12 +831,13 @@
   TEST_SHOULD_FAIL=0
   if [ -x $GROUP/$CHECKSCRIPT ]; then
-  	export OUTPUT
+     OUTPUT=$NAME.check.stdout
     script_exec $GROUP/$CHECKSCRIPT "√"
   else
     check_outputs $GROUP $NAME
   fi
+   OUTPUT=$NAME.clean.stdout
   if [ -x $GROUP/$CLEANSCRIPT ]; then
     script_exec $GROUP/$CLEANSCRIPT "C"
   else
@@ -858,6 +859,7 @@
   TIMEOUTFILE=$NAME.timeout
   TEST_SHOULD_FAIL=0
   else
@@ -879,6 +881,8 @@
    html_~td
   fi
   if [ -x $GROUP/$SHELLSCRIPT ]; then
     script_exec $SHELLSCRIPT "X"
   else
@@ -887,6 +891,7 @@
    html_~td
   fi
   else
@@ -895,6 +900,7 @@
    html_~td
   fi
   else
@@ -1075,10 +1081,6 @@
 # Execute all tests in current GROUP
 test_group() {
-  group_sites_xml
-  group_tc_data
-  group_fs_data
-  group_swift_properties
   SWIFTS=$( echo $GROUP/*.swift )
   checkfail "Could not list: $GROUP"
@@ -1087,8 +1089,6 @@
     (( SKIP_COUNTER++ < SKIP_TESTS )) && continue
-    TESTNAME=$( basename $TEST )
 	echo
 	echo
 	echo "/--------------------------------------------------------------"
@@ -1096,21 +1096,34 @@
     echo "\--------------------------------------------------------------"
     echo
-    cp $GROUP/$TESTNAME .
     TESTLINK=$TESTNAME
    # Use repeat.txt to determine number of test iterations
     SCRIPT_BASENAME=`basename $TESTNAME .swift`
+    TESTLINK="$TESTNAMEDIR/$TESTNAME"
     if [ -f "$GROUP/$SCRIPT_BASENAME.repeat" ]; then
       ITERS_LOCAL=`cat $GROUP/$SCRIPT_BASENAME.repeat`
     fi
     for (( i=0; $i<$ITERS_LOCAL; i=$i+1 )); do
+      HOURMINSEC=$( date +"%H%M%S" )
+      TESTNAME=$( basename $TEST )
+      TESTNAMEDIR=`basename $TESTNAME .swift`-$HOURMINSEC
+      mkdir -p $TESTNAMEDIR
+      pushd $TESTNAMEDIR > /dev/null 2>&1
+      cp $TEST .
+      group_swift_properties
+      group_sites_xml
+      group_tc_data
+      group_fs_data
       start_row
       swift_test_case $TESTNAME
       (( $TESTCOUNT >= $NUMBER_OF_TESTS )) && return
       (( $SHUTDOWN )) && return
       end_row
+      popd > /dev/null 2>&1
     done
   done
     group_statistics
@@ -1125,11 +1138,12 @@
   for TEST in $SCRIPTS; do
     cp -v $GROUP/$TESTNAME .
-    TESTLINK=$TESTNAME
     start_row
     for ((i=0; $i<$ITERS_LOCAL; i=$i+1)); do
       script_test_case $TESTNAME
@@ -1178,6 +1192,7 @@
 start_group "Build"
 TESTLINK=
 EXITONFAILURE=true
+OUTPUT=checkout.stdout
 if [ "$SKIP_CHECKOUT" != "1" ]; then
   TESTNAME="Checkout CoG"
   start_row
@@ -1195,6 +1210,7 @@
 TESTNAME="Compile"
 start_row
+OUTPUT=compile.stdout
 # Exit early if the Swift directory is not there
 if [[ ! -d $TOPDIR/cog/modules/swift ]]
 then
@@ -1212,7 +1228,7 @@
   test_exec ant -quiet dist
 fi
 SWIFT_HOME=$TOPDIR/cog/modules/swift/dist/swift-svn
 if [ $BUILD_PACKAGE = "1" ]; then
   build_package
 fi
@@ -1246,6 +1262,7 @@
   (( $SHUTDOWN )) && break
 done
+footer
 exit 0
 # Local Variables:
More information about the Swift-commit
