[Swift-commit] r5172 - trunk/docs/siteguide
ketan at ci.uchicago.edu ketan at ci.uchicago.edu
Mon Sep 26 10:57:02 CDT 2011
Author: ketan
Date: 2011-09-26 10:57:01 -0500 (Mon, 26 Sep 2011)
New Revision: 5172
Modified:
   trunk/docs/siteguide/grid
Log:
Added instructions for obtaining grid certificate and registering with the Engage VO
Modified: trunk/docs/siteguide/grid
--- trunk/docs/siteguide/grid	2011-09-26 15:39:05 UTC (rev 5171)
+++ trunk/docs/siteguide/grid	2011-09-26 15:57:01 UTC (rev 5172)
@@ -41,11 +41,56 @@
 a certificate. Is this a problem from users without one? If so, make a
 copy of the page on the Swift web.
-*For TeraGrid*: Obtain a DOEGrids certifcate using the OSG ENgage
+*For TeraGrid*: Obtain a DOEGrids certifcate using the OSG Engage
 instructions above. Ask a TeraGrid PI to add you to a TeraGrid
 project. Once you obtain a login and project access (via US Mail), use
-gx-request to add your certificate
+gx-request to add your certificate.
+A detailed step-by-step instructions for requesting and installing your
+certificates in the browser and client machine are as follows:
+*Step1.* Apply for a certificate: https://pki1.doegrids.org/ca/; use ANL as
+affiliation (registration authority) in the form.
+*Step2.* When you receive your certificate via a link by mail, download and
+install it in your browser; we have tested it for firefox on linux and mac.,
+and for Chrome on mac.
+On firefox, as you click the link that you received in the mail, you will be
+prompted to install it by firefox: passphrase it and click install. Next take a
+backup of this certificate in the form of .p12.
+This is in Preferences > Advanced > Encryption > View Certificate > Your
+Certificate
+*Step3.* Install DOE CA and ESnet root CA into your browser by clicking the top
+left links on this page: http://www.doegrids.org/
+*Step4.* Go to the Engage VO registration point here:
+https://osg-engage.renci.org:8443/vomrs/Engage/vomrs from the same browser that
+has the above certs installed. Also see
+https://twiki.grid.iu.edu/bin/view/Engagement/EngageNewUserGuide for more
+details.
+*Step5.* For installation of certificate on client machine, you need to have the certificate
+that is in the browser put in your client's ~/.globus directory from where you want to access OSG
+resources. The certificate has to be in the form of .pem files with a seperate
+.pem file for key and cert. For this conversion use the above backed up .p12 file as follows:
+$ openssl pkcs12 -in your.p12 -out usercert.pem -nodes -clcerts -nokeys
+$ openssl pkcs12 -in your.p12 -out userkey.pem -nodes -nocerts
+Above commands are taken from:
+http://security.ncsa.illinois.edu/research/grid-howtos/usefulopenssl.html
+For more on openssl: http://www.openssl.org/docs/apps/openssl.html
+Step6. Test it:
+$ voms-proxy-init --voms Engage -hours 48
 To run jobs using the procedures documented here you need to be logged
 in to a "submit host" on which you will run Swift and other
 grid-related utilities. This can be any host with the OSG client stack
