[Swift-commit] r5170 - in trunk: bin tests
davidk at ci.uchicago.edu
Sat Sep 24 23:24:00 CDT 2011
Author: davidk
Date: 2011-09-24 23:24:00 -0500 (Sat, 24 Sep 2011)
New Revision: 5170
Modified:
trunk/bin/gensites
trunk/tests/suite.sh
Log:
Integrating more changes from 0.93 to trunk
Modified: trunk/bin/gensites
--- trunk/bin/gensites 2011-09-25 03:58:06 UTC (rev 5169)
+++ trunk/bin/gensites 2011-09-25 04:24:00 UTC (rev 5170)
@@ -133,19 +133,22 @@
fi
# Ensure a properties file exists
-if [ ! -f "$PROPERTIES_FILE" ]; then
- PROPERTIES_FILE="./swift.properties"
- if [ ! -f "$PROPERTIES_FILE" ]; then
+if [ -z "$PROPERTIES_FILE" ]; then
+ if [ -f "./swift.properties" ]; then
+ PROPERTIES_FILE="./swift.properties"
+ elif [ -f "$HOME/.swift/swift.properties" ]; then
PROPERTIES_FILE="$HOME/.swift/swift.properties"
fi
fi
# Setup for creating a TC file
-if [ -n "`grep -e app $PROPERTIES_FILE`" ]; then
- if [ -f "tc.data" ]; then
- mv tc.data tc.data.old
+if [ -f "$PROPERTIES_FILE" ]; then
+ if [ -n "`grep -e app $PROPERTIES_FILE`" ]; then
+ if [ -f "tc.data" ]; then
+ mv tc.data tc.data.old
+ fi
+ HOSTS=`grep -i "pool handle" $TEMPLATE_PATH|grep -v "^[[:space:]]*#"|cut -d'"' -f2`
fi
- HOSTS=`grep -i "pool handle" $TEMPLATE_PATH|grep -v "^[[:space:]]*#"|cut -d'"' -f2`
fi
# Parse values into variables for later sed processing
Modified: trunk/tests/suite.sh
--- trunk/tests/suite.sh 2011-09-25 03:58:06 UTC (rev 5169)
+++ trunk/tests/suite.sh 2011-09-25 04:24:00 UTC (rev 5170)
@@ -155,16 +155,9 @@
TESTDIR=$TOPDIR/cog/modules/swift/tests
-# Ensure all given variables are set
+# Gensites will now check the variables as needed
checkvars() {
- while (( ${#*} ))
- do
- VAR=$1
- V=$( eval "echo \${${VAR}+1}" )
- [[ $V == 1 ]] || crash "Not set: $VAR"
- shift
- done
- return 0
+ return
checkfail() {
@@ -952,18 +945,6 @@
output_report package "swift-$DATE.tar.gz"
-# Generate the sites.sed file
-make_sites_sed() {
- echo "s at _WORK_@$WORK@"
- echo "s at _HOST_@$GLOBUS_HOSTNAME@"
- echo "s at _PROJECT_@$PROJECT@"
- echo "s at _QUEUE_@$QUEUE@"
- echo "s at _EXECUTION_URL_@$EXECUTION_URL@"
- } > $RUNDIR/sites.sed
- return 0
# Setup coasters variables
if which ifconfig > /dev/null 2>&1; then
IFCONFIG=ifconfig
@@ -977,20 +958,40 @@
# Generate sites.xml
group_sites_xml() {
- TEMPLATE=$GROUP/sites.template.xml
- if [ -f $TEMPLATE ]; then
- sed -f $RUNDIR/sites.sed < $TEMPLATE > sites.xml
- [ $? != 0 ] && crash "Could not create sites.xml!"
- echo "Using: $GROUP/sites.template.xml"
+ # Determine template
+ if [ -f "$GROUP/sites.template.xml" ]; then
+ TEMPLATE="$GROUP/sites.template.xml"
+ elif [ -f "$GROUP/gensites.template" ]; then
+ TEMPLATE=`cat $GROUP/gensites.template`
else
- sed "s at _WORK_@$PWD/work@" < $TESTDIR/sites/localhost.xml > sites.xml
- echo "Using: $TESTDIR/sites/localhost.xml"
+ TEMPLATE="$TESTDIR/sites/localhost.xml"
fi
+ # Give default to _WORK_ if undefined in swift.properties
+ if [ -z "$WORK" ]
+ then
+ export WORK=$TOPDIR/work
+ fi
+ # Call gensites
+ TEMPLATE_DIRNAME=`dirname $TEMPLATE`
+ TEMPLATE=`basename $TEMPLATE`
+ if [ "$TEMPLATE_DIRNAME" != "." ]; then
+ gensites -L $TEMPLATE_DIRNAME $TEMPLATE > sites.xml
+ else
+ gensites $TEMPLATE > sites.xml
+ fi
# Generate tc.data
group_tc_data() {
+ # Gensites will create a tc.data file if it is being used
+ if [ -f "$GROUP/gensites.template" ]; then
+ return
+ fi
if [ -f $GROUP/tc.template.data ]; then
sed "s at _DIR_@$GROUP@" < $GROUP/tc.template.data > tc.data
[ $? != 0 ] && crash "Could not create tc.data!"
@@ -1097,13 +1098,20 @@
cp $GROUP/$TESTNAME .
TESTLINK=$TESTNAME
- start_row
+ # Use repeat.txt to determine number of test iterations
+ SCRIPT_BASENAME=`basename $TESTNAME .swift`
+ if [ -f "$GROUP/$SCRIPT_BASENAME.repeat" ]; then
+ ITERS_LOCAL=`cat $GROUP/$SCRIPT_BASENAME.repeat`
+ fi
for (( i=0; $i<$ITERS_LOCAL; i=$i+1 )); do
+ start_row
swift_test_case $TESTNAME
(( $TESTCOUNT >= $NUMBER_OF_TESTS )) && return
(( $SHUTDOWN )) && return
+ end_row
done
- end_row
done
group_statistics
TOTAL_TIME=0
@@ -1134,13 +1142,7 @@
-if [[ $WORK == "" ]]
-then
- WORK=$TOPDIR/work
-fi
-checkvars GROUPARG
+#checkvars GROUPARG
echo "GROUP ARGUMENT: $GROUPARG"
if [[ $GROUPARG != /* ]]; then
# Adjust relative path
@@ -1164,8 +1166,6 @@
date > $LOG
-make_sites_sed
# Here the report starts.
# Call to function header()
header
More information about the Swift-commit
