[Swift-commit] r5163 - trunk/bin
davidk at ci.uchicago.edu
Sat Sep 24 08:51:56 CDT 2011
Author: davidk
Date: 2011-09-24 08:51:56 -0500 (Sat, 24 Sep 2011)
New Revision: 5163
Modified:
trunk/bin/start-coaster-service
trunk/bin/stop-coaster-service
Log:
Use coaster service config files in $HOME/.swift
Modified: trunk/bin/start-coaster-service
--- trunk/bin/start-coaster-service 2011-09-24 13:49:51 UTC (rev 5162)
+++ trunk/bin/start-coaster-service 2011-09-24 13:51:56 UTC (rev 5163)
@@ -8,15 +8,6 @@
exit 1
-# Copy files
-copy_requested_files()
- for file in $FILES_TO_COPY
- do
- scp $file $WORKER_USERNAME@$FILES_TO_COPY_REMOTE_DESTINATION
- done
# Start futuregrid workers
start-workers-futuregrid()
@@ -44,7 +35,7 @@
for MACHINE in $WORKER_HOSTS
do
# Enable ssh tunneling if needed
- if [ $SSH_TUNNELING == "yes" ]; then
+ if [ "$SSH_TUNNELING" == "yes" ]; then
ssh -R *:$PORT:localhost:$PORT $WORKER_USERNAME@$MACHINE sleep 999 &
echo $! >> $PID_FILE
fi
@@ -53,10 +44,7 @@
scp $SWIFT_BIN/$WORKER $WORKER_USERNAME@$MACHINE:$WORKER_WORK > /dev/null 2>&1
echo "Starting worker on $MACHINE"
ssh $WORKER_USERNAME@$MACHINE $WORKER_WORK/$WORKER $EXECUTION_URL $MACHINE $LOG_DIR &
- echo $! >> $PID_FILE
- # Copy requsted file
- copy_requested_files
+ echo $! >> $PID_FILE
done
@@ -70,21 +58,17 @@
fi
do
- # Enayble ssh tunneling if needed
+ # Enable ssh tunneling if needed
- fi
+ fi
- # Copy and start worker script
scp $SWIFT_BIN/$WORKER $MACHINE:$WORKER_WORK > /dev/null 2>&1
echo Starting worker on $MACHINE
ssh $MACHINE $WORKER_WORK/$WORKER $EXECUTION_URL $MACHINE $LOG_DIR &
done
- # Copy requested files
return 0
@@ -127,25 +111,26 @@
return 0
-PID_FILE=".coaster-service-pids"
+if [ ! -d "$HOME/.swift" ]; then
+ mkdir -p "$HOME/.swift" || crash "Unable to create $HOME/.swift"
+fi
+PID_FILE="$HOME/.swift/.coaster-service-pids"
RUN_DIR=`pwd`
-pushd $(dirname $(readlink -f $0)) > /dev/null 2>&1
# Import settings
-CONFIG_FILE="../etc/coaster-service.conf"
-if [ -f "$CONFIG_FILE" ]; then
+if [ -f "$HOME/.swift/coaster-service.conf" ]; then
+ CONFIG_FILE="$HOME/.swift/coaster-service.conf"
+elif [ -f "$(dirname $(readlink -f $0))/../etc/coaster-service.conf" ]; then
+ CONFIG_FILE="$(dirname $(readlink -f $0))/../etc/coaster-service.conf"
+fi
+if [ -n "$CONFIG_FILE" ]; then
source "$CONFIG_FILE"
else
crash "Cannot find coaster-service.conf!"
fi
-# Determine Swift config file (cf - used for gensites)
-if [ -f "$RUN_DIR/cf" ]; then
- SWIFT_CONFIG_FILE="$RUN_DIR/cf"
-else
- SWIFT_CONFIG_FILE=$CONFIG_FILE
-fi
# Determine information needed about this machine
if [ -z "$IPADDR" ]; then
if [ -x "/sbin/ifconfig" ]; then
@@ -257,10 +242,10 @@
# Generate sites.xml
export EXECUTION_URL="http://$IPADDR:$SERVICE_PORT"
echo Generating sites.xml
-gensites persistent-coasters -p $SWIFT_CONFIG_FILE > $RUN_DIR/sites.xml
+gensites persistent-coasters -p $CONFIG_FILE > $RUN_DIR/sites.xml
# Generate config file
-if [ $SHARED_FILESYSTEM == "no" ]; then
+if [ "$SHARED_FILESYSTEM" == "no" ]; then
echo Generating config file
cat > $RUN_DIR/cf << EOF
use.provider.staging=true
Modified: trunk/bin/stop-coaster-service
--- trunk/bin/stop-coaster-service 2011-09-24 13:49:51 UTC (rev 5162)
+++ trunk/bin/stop-coaster-service 2011-09-24 13:51:56 UTC (rev 5163)
@@ -1,10 +1,5 @@
#!/bin/bash
-# Files relative to location of this script
-SWIFTVM_INSTANCES=".swiftvm_instances"
# crash: Report a problem and exit
crash()
@@ -13,8 +8,21 @@
exit 1
+# Location of required files
+SWIFTVM_INSTANCES="$HOME/.swift/.swiftvm_instances"
+fi
+if [ -z "$CONFIG_FILE" ]; then
+ crash "Unable to find coaster-service.conf!"
+fi
# Read config file to determine worker mode
More information about the Swift-commit
