[Swift-commit] r5159 - in SwiftApps/SwiftR: . Swift/R Swift/exec
tga at ci.uchicago.edu
Fri Sep 23 18:22:17 CDT 2011
Author: tga
Date: 2011-09-23 18:22:17 -0500 (Fri, 23 Sep 2011)
New Revision: 5159
Modified:
SwiftApps/SwiftR/Makefile
SwiftApps/SwiftR/Swift/R/Workers.R
SwiftApps/SwiftR/Swift/exec/EvalRBatchPersistent.sh
Log:
Getting the R server cleanup logic working.
Modified: SwiftApps/SwiftR/Makefile
--- SwiftApps/SwiftR/Makefile 2011-09-23 22:04:00 UTC (rev 5158)
+++ SwiftApps/SwiftR/Makefile 2011-09-23 23:22:17 UTC (rev 5159)
@@ -7,7 +7,7 @@
PKG_FILES += Swift/DESCRIPTION
PKG_FILES += Swift/NAMESPACE
-PKG_FILE += Swift/src/Makefile Swift/src/make.include
+PKG_FILES += Swift/src/Makefile Swift/src/make.include
PKG_FILES += $(shell find Swift/src/swift-patches -not -path '*/.svn*')
PACKAGE_DEPS = $(PKG_FILES) Makefile
Modified: SwiftApps/SwiftR/Swift/R/Workers.R
--- SwiftApps/SwiftR/Swift/R/Workers.R 2011-09-23 22:04:00 UTC (rev 5158)
+++ SwiftApps/SwiftR/Swift/R/Workers.R 2011-09-23 23:22:17 UTC (rev 5159)
@@ -139,9 +139,10 @@
if(! is.null(workmode) ) {
cmdString <- paste(cmdString, "-m", shQuote(workmode))
- if (! is.null(retries) ) {
- cmdString <- paste(cmdString, "-retries", shQuote(retries))
+ if (is.null(retries) ) {
+ retries <- 3
+ cmdString <- paste(cmdString, "-retries", shQuote(retries))
if (server == "local")
nodes <- 1
Modified: SwiftApps/SwiftR/Swift/exec/EvalRBatchPersistent.sh
--- SwiftApps/SwiftR/Swift/exec/EvalRBatchPersistent.sh 2011-09-23 22:04:00 UTC (rev 5158)
+++ SwiftApps/SwiftR/Swift/exec/EvalRBatchPersistent.sh 2011-09-23 23:22:17 UTC (rev 5159)
@@ -53,6 +53,8 @@
fi
TRAPS="EXIT 1 2 3 15"
+HAS_MUTEX=false
+RPID=
function onexit() { # FIXME: move this logic into worker.pl, or try to use R timeout option if it works on fifos - need to test.
trap - $TRAPS
@@ -60,9 +62,38 @@
if [ "_$RPIDS" != _ ]; then
kill $RPIDS >& /dev/null
fi
+ if [ "$HAS_MUTEX" = "true" ]; then
+ rmdir $SLOTDIR/mutex
+ HAS_MUTEX=false
+ fi
+function launchRServer() {
+ #Start R server and set RPID to the value
+ mkfifo $SLOTDIR/toR.fifo
+ mkfifo $SLOTDIR/fromR.fifo
+ echo "$0: INFO: Launching $RServerScript $SLOTDIR"
+ #echo PATH: $PATH > $SLOTDIR/R.log
+ #which Rscript >> $SLOTDIR/R.log
+ echo LD_LIBRARYPATH= $LD_LIBRARY_PATH
+ PATH=.:$PATH
+ echo PATH= $PATH
+ echo R_LIBS_USER= $R_LIBS_USER
+ slotdir=$1
+ # Use R instead of Rscript due to Rscript issues on some
+ # platforms (e.g. cray xt)
+ R --slave --no-restore --file=$RServerScript \
+ --args $slotdir >> $slotdir/R.log 2>&1 & # launch R server
+ RPID=$!
+ echo $RPID > $SLOTDIR/R.pid
+ echo "$0: INFO: Launched $RServerScript $slotdir Rscript"
trap "onexit 1" 1
trap "onexit 2" 2
trap "onexit 3" 3
@@ -70,19 +101,34 @@
trap "onexit EXIT" EXIT
-function idletimer {
- cd $1
- while true; do
- touch idle
- sleep 60
- if [ ! -f lastwrite -o \( idle -nt lastwrite \) ]; then
- # FIXME: should work, but does not: echo quit x x >toR.fifo # fifo problem?
- RPID=$(cat R.pid)
- echo killing idle R process $RPID
- kill $RPID
- exit 0
+function start_idletimer {
+ # After the specified number of seconds
+ # kill the specified R process
+ local timeout=$1
+ local rpid=$2
+ local idletimer_id=$$$(date '+%s%N') # timestamp in ns plus pid should be unique
+ echo "$idletimer_id" > $SLOTDIR/idletimer
+ sleep ${timeout}s
+ touch $SLOTDIR/timeout_reached
+ # if mutex has been acquired, know another process active
+ if mkdir $SLOTDIR/mutex ; then
+ touch $SLOTDIR/timeout_reached_mutex
+ new_idletimer_id=$(cat $SLOTDIR/idletimer)
+ echo new: "$new_idletimer_id" old "$idletimer_id" > $SLOTDIR/idletimer_ids
+ if [ "$new_idletimer_id" = "$idletimer_id" ]; then
+ touch $SLOTDIR/timeout_reached_mutex_killed
+ echo killing idle R process $rpid
+ kill $rpid
+ rm -f $SLOTDIR/idletimer $SLOTDIR/fromR.fifo $SLOTDIR/toR.fifo
+ touch $SLOTDIR/timedout
+ else
+ touch $SLOTDIR/timeout_reached_mutex_notkilled
+ fi
fi
- done
+ ) &> /dev/null &
# Ensure that the dir for this slot exists.
@@ -104,28 +150,40 @@
WORKERDIR=$BASEDIR/worker.$SWIFT_WORKER_PID
SLOTDIR=$WORKERDIR/${SWIFT_JOB_SLOT}
+# terminate timeout as early as possible
+rm ${SLOTDIR}/idletimer
mkdir -p $WORKERDIR
RPIDS=
TIMEOUT=30
+IDLE_TIMEOUT=10
+timeout_pid=
function start_timeout {
- ppid=$$
- child_pid=$1
+ local ppid=$$
+ local child_pid=$1
trap "timeout_handler" SIGHUP
- sleep ${TIMEOUT}s
- kill -1 $ppid &> /dev/null #SIGHUP
- if [ "$child_pid" != "" ]; then
- kill -1 $child_pid &> /dev/null #SIGHUP
- fi
+ trap "exit 0" 1 # timeout cancelled with SIGHUP
+ sleep ${TIMEOUT}s
+ kill -1 $ppid &> /dev/null #SIGHUP
+ if [ "$child_pid" != "" ]; then
+ kill -1 $child_pid &> /dev/null #SIGHUP
+ fi
+ timeout_pid=$!
function stop_timeout {
#DEBUG
trap "" SIGHUP
+ if [ ! -z "$timeout_pid" ]; then
+ kill -1 $timeout_pid
+ timeout_pid=
+ fi
function timeout_handler {
@@ -145,48 +203,41 @@
mkdir $SLOTDIR >& /dev/null
if [ $? = 0 ]; then
- mkfifo $SLOTDIR/toR.fifo
- mkfifo $SLOTDIR/fromR.fifo
- chmod +x $RServerScript
- echo "$0: INFO: Launching $RServerScript $SLOTDIR"
- #echo PATH: $PATH > $SLOTDIR/R.log
- #which Rscript >> $SLOTDIR/R.log
- echo LD_LIBRARYPATH= $LD_LIBRARY_PATH
- PATH=.:$PATH
- echo PATH= $PATH
- echo R_LIBS_USER= $R_LIBS_USER
- # Use R instead of Rscript due to Rscript issues on some
- # platforms (e.g. cray xt)
- R --slave --no-restore --file=$RServerScript \
- --args $SLOTDIR >> $SLOTDIR/R.log 2>&1 & # launch R server
- #$RServerScript $SLOTDIR >> $SLOTDIR/R.log 2>&1 & # launch R server
- # idletimer $SLOTDIR </dev/null >/dev/null 2>&1 & # R saves pid in R.pid for idletimer to kill it
- echo "$0: INFO: Launched $RServerScript $SLOTDIR Rscript"
+ launchRServer $SLOTDIR
else
# wait to make sure fifo exists
- # fromR fifo is created last, so wait for that one
+ # R.pid is created last and left if, so wait for that
while true; do
- if [ -p $SLOTDIR/fromR.fifo ]; then
+ if [ -f $SLOTDIR/R.pid ]; then
+ RPID=$(cat $SLOTDIR/R.pid)
break
fi
done
fi
+# At this point we've launched an R server, or maybe discovered
+# an existing server. IT is still possible that the old server
+# was timed out, btu to be sure we will acquire a mutex first
# Ready to talk to the server: send request and read response
#FIXME: what if mutex isn't cleaned up?
start_timeout
while true; do
+ HAS_MUTEX=true
if [ $? != 0 ]; then
sleep 1;
else
+ if [ -f $SLOTDIR/timedout ]; then
+ rm -f $SLOTDIR/timedout
+ fi
break;
fi
done
stop_timeout
echo DB: Obtained $SLOTDIR/mutex
absimports=
for im in $imports; do
absimports="$absimports $(pwd)/$im"
@@ -207,11 +258,17 @@
res=$(cat < $SLOTDIR/fromR.fifo)
echo DB: Got response: $res
+ # While still holding mutex, start timer to shut down idle R server
+ start_idletimer $IDLE_TIMEOUT $RPID
+ HAS_MUTEX=false
echo DB: Freed $SLOTDIR/mutex
# Test if R server reported an error
if echo "$res" | grep -q '^ERROR:'
then
@@ -221,6 +278,7 @@
stop_timeout
echo "ERROR: Could not write to fifo ok"
+ HAS_MUTEX=false
exit 1
fi
More information about the Swift-commit
