[Swift-commit] r5146 - in trunk/src/org/griphyn/vdl: karajan/lib util
wozniak at ci.uchicago.edu
Wed Sep 21 10:53:23 CDT 2011
Author: wozniak
Date: 2011-09-21 10:53:22 -0500 (Wed, 21 Sep 2011)
New Revision: 5146
Modified:
trunk/src/org/griphyn/vdl/karajan/lib/RuntimeStats.java
trunk/src/org/griphyn/vdl/util/VDL2Config.java
Log:
New VDL2Config settings ticker.prefix and ticker.date.format
Modified: trunk/src/org/griphyn/vdl/karajan/lib/RuntimeStats.java
--- trunk/src/org/griphyn/vdl/karajan/lib/RuntimeStats.java 2011-09-21 15:48:47 UTC (rev 5145)
+++ trunk/src/org/griphyn/vdl/karajan/lib/RuntimeStats.java 2011-09-21 15:53:22 UTC (rev 5146)
@@ -25,7 +25,8 @@
public static final Arg PA_STATE = new Arg.Positional("state");
//formatter for timestamp against std.err lines
- public static final SimpleDateFormat formatter = new SimpleDateFormat("E, dd MMM yyyy HH:mm:ss Z");
+ public static SimpleDateFormat formatter =
+ new SimpleDateFormat("E, dd MMM yyyy HH:mm:ss Z");
public static final int MIN_PERIOD_MS=1000;
public static final int MAX_PERIOD_MS=30000;
@@ -74,10 +75,21 @@
t.setDaemon(true);
t.start();
setTicker(stack, t);
+ // Allow user to reformat output date
+ String format;
+ try {
+ format = VDL2Config.getDefaultConfig().getTickerDateFormat();
+ catch (IOException e) {
+ throw new ExecutionException(e);
+ if (format != null && format.length() > 0)
+ formatter =
+ new SimpleDateFormat(format);
return null;
public Object vdl_setprogress(VariableStack stack) throws ExecutionException {
setProgress(stack, TypeUtil.toString(PA_STATE.getValue(stack)));
return null;
@@ -116,6 +128,8 @@
private boolean disabled;
private boolean shutdown;
+ String tickerPrefix;
public ProgressTicker() {
super("Progress ticker");
try {
@@ -123,6 +137,8 @@
logger.info("Ticker disabled in configuration file");
disabled = true;
+ tickerPrefix =
+ VDL2Config.getConfig().getTickerPrefix();
logger.debug("Could not read swift properties", e);
@@ -156,7 +172,7 @@
long now = System.currentTimeMillis();
if(lastDumpTime + MIN_PERIOD_MS > now) return;
lastDumpTime = now;
- printStates("Progress:");
+ printStates(tickerPrefix);
void finalDumpState() {
@@ -190,16 +206,16 @@
return summary;
- void printStates(String header) {
+ void printStates(String prefix) {
Map<String, Integer> summary = getSummary();
// SimpleDateFormat formatter = new SimpleDateFormat("E, dd MMM yyyy HH:mm:ss Z");
// output the results of summarization, in a relatively
// pretty form - first the preferred order listed elements,
// and then anything remaining
- System.err.print(header);
+ System.err.print(prefix + " ");
//System.err.print(" time:" + (System.currentTimeMillis() - start));
- System.err.print(" time: " + formatter.format(System.currentTimeMillis()));
+ System.err.print(formatter.format(System.currentTimeMillis()));
for (int pos = 0; pos < preferredOutputOrder.length; pos++) {
String key = preferredOutputOrder[pos];
Modified: trunk/src/org/griphyn/vdl/util/VDL2Config.java
--- trunk/src/org/griphyn/vdl/util/VDL2Config.java 2011-09-21 15:48:47 UTC (rev 5145)
+++ trunk/src/org/griphyn/vdl/util/VDL2Config.java 2011-09-21 15:53:22 UTC (rev 5146)
@@ -98,6 +98,8 @@
put("cdm.broadcast.mode", "file");
put("use.provider.staging", "false");
+ put("ticker.date.format", "");
+ put("ticker.prefix", "Progress: time:");
private VDL2Config(VDL2Config other) {
@@ -215,6 +217,14 @@
return Boolean.valueOf(getProperty(VDL2ConfigProperties.PROVENANCE_LOG, "false")).booleanValue();
+ public String getTickerDateFormat() {
+ return getProperty("ticker.date.format");
+ public String getTickerPrefix() {
+ return getProperty("ticker.prefix");
public String toString() {
return "Swift configuration " + files;
More information about the Swift-commit
