[Swift-commit] r5121 - in trunk/tests/mpi/fusion: long short
wozniak at ci.uchicago.edu
Thu Sep 15 14:36:27 CDT 2011
Author: wozniak
Date: 2011-09-15 14:36:27 -0500 (Thu, 15 Sep 2011)
New Revision: 5121
Modified:
trunk/tests/mpi/fusion/long/100-mci.clean.sh
trunk/tests/mpi/fusion/long/100-mci.swift
trunk/tests/mpi/fusion/long/mpi-sleep.c
trunk/tests/mpi/fusion/long/sites.template.xml
trunk/tests/mpi/fusion/long/tc.template.data
trunk/tests/mpi/fusion/short/tc.template.data
Log:
Improve test for MPI on Fusion
Modified: trunk/tests/mpi/fusion/long/100-mci.clean.sh
--- trunk/tests/mpi/fusion/long/100-mci.clean.sh 2011-09-15 14:43:40 UTC (rev 5120)
+++ trunk/tests/mpi/fusion/long/100-mci.clean.sh 2011-09-15 19:36:27 UTC (rev 5121)
@@ -2,6 +2,6 @@
set -x
-rm -v transform-*.txt || exit 1
+# rm -v transform-*.txt || exit 1
exit 0
Modified: trunk/tests/mpi/fusion/long/100-mci.swift
--- trunk/tests/mpi/fusion/long/100-mci.swift 2011-09-15 14:43:40 UTC (rev 5120)
+++ trunk/tests/mpi/fusion/long/100-mci.swift 2011-09-15 19:36:27 UTC (rev 5121)
@@ -8,9 +8,9 @@
file input<"100-input.txt">;
-int total = 10;
+int total = 1;
-foreach i in [0:total] {
+foreach i in [0:total-1] {
file output<single_file_mapper;file=@strcat("transform-",i,".txt")>;
output = transform(input);
Modified: trunk/tests/mpi/fusion/long/mpi-sleep.c
--- trunk/tests/mpi/fusion/long/mpi-sleep.c 2011-09-15 14:43:40 UTC (rev 5120)
+++ trunk/tests/mpi/fusion/long/mpi-sleep.c 2011-09-15 19:36:27 UTC (rev 5121)
@@ -1,7 +1,6 @@
* Simple Hydra test
- * No I/O
* usage: mpi-sleep <duration>
@@ -11,11 +10,12 @@
#include <assert.h>
+#include <errno.h>
#include <stdbool.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
-#include <sys/stat.h>
+#include <sys/utsname.h>
#include <unistd.h>
#include <mpi.h>
@@ -26,7 +26,9 @@
#ifdef ENABLE_DEBUG
#define DEBUG(...) __VA_ARGS__
#define debug(...) \
- { printf("%i: ", mpi_rank); printf(__VA_ARGS__); }
+ { printf("%i: ", mpi_rank); \
+ printf(__VA_ARGS__); \
+ fflush(stdout); }
#else
#define DEBUG(...)
#define debug(...)
@@ -37,6 +39,8 @@
void print_help(void);
void startup(void);
+void write_header(void);
+void write_data(void);
void crash(char* msg);
void check(void* value, char* msg);
@@ -45,14 +49,16 @@
const int INPUT_MAX = 10;
int input_count = 0;
+char hostname[1024];
char output[1024];
-bool write_header = false;
+bool enable_write_header = false;
int main(int argc, char* argv[])
int duration = -1;
char* inputs[INPUT_MAX];
+ output[0] = '\0';
int opt = -1;
while ((opt = getopt(argc, argv, "i:o:v")) != -1)
@@ -67,7 +73,7 @@
case 'o':
strcpy(output, optarg);
case 'v':
- write_header = true;
+ enable_write_header = true;
break;
@@ -100,22 +106,17 @@
// INTRO BARRIER
debug("barrier1\n");
MPI_Barrier(MPI_COMM_WORLD);
- debug("sleep %i\n", duration);
+ // WRITE HEADER
+ if (enable_write_header)
+ write_header();
// SLEEP
+ debug("sleep %i\n", duration);
sleep(duration);
// WRITE OUTPUT
- if (mpi_rank == 0)
- debug("write to: %s\n", output);
- FILE* file = fopen(output, "w");
- check(file, "could not write to file!");
- if (write_header)
- fprintf(file, "rank: %i/%i\n", mpi_rank, mpi_size);
- fprintf(file, "howdy\n");
- fclose(file);
+ write_data();
// FINAL BARRIER
debug("barrier2\n");
@@ -132,6 +133,14 @@
FILE* file;
char filename[1024];
// DEBUG(system("/bin/hostname"));
+ if (mpi_rank == 0)
+ if (strlen(output) == 0)
+ printf("No output file!\n");
+ exit(1);
debug("size: %i\n", mpi_size);
debug("rank: %i\n", mpi_rank);
DEBUG(pwd = getenv("PWD"));
@@ -143,6 +152,56 @@
// DEBUG(fclose(file));
+ An output header written only by rank 0
+void write_header()
+ debug("write_header(): %s\n", output);
+ FILE* file = fopen(output, "w");
+ check(file, "could not write to file!");
+ fprintf(file, "rank 0: header\n");
+ fclose(file);
+void read_hostname()
+ struct utsname name;
+ if (uname (&name) == -1)
+ printf("Could not call uname()!\n");
+ MPI_Abort(MPI_COMM_WORLD, 1);
+ strcpy(hostname, name.nodename);
+ char* filename = "/etc/HOSTNAME";
+ FILE* file = fopen(filename, "r");
+ if (!file)
+ printf("Could not open: %s\n", filename);
+ fscanf(file, "%s", hostname);
+ fclose(file);
+void write_data()
+ debug("write_data(): %s\n", output);
+ read_hostname();
+ FILE* file = fopen(output, "a");
+ fprintf(file, "rank: %i/%i %s\n",
+ mpi_rank, mpi_size, hostname);
+ fclose(file);
void print_help()
printf("usage: <options> <duration>\n");
Modified: trunk/tests/mpi/fusion/long/sites.template.xml
--- trunk/tests/mpi/fusion/long/sites.template.xml 2011-09-15 14:43:40 UTC (rev 5120)
+++ trunk/tests/mpi/fusion/long/sites.template.xml 2011-09-15 19:36:27 UTC (rev 5121)
@@ -8,21 +8,19 @@
<pool handle="fusion">
<execution jobmanager="local:pbs" provider="coaster" url="none"/>
<filesystem provider="local" url="none" />
- <profile namespace="globus" key="maxWallTime">100</profile>
- <profile namespace="globus" key="maxTime">7200</profile>
+ <profile namespace="globus" key="maxWallTime">1</profile> <!-- minutes -->
+ <!-- <profile namespace="globus" key="maxTime">500</profile> -->
<profile key="jobsPerNode" namespace="globus">1</profile>
<profile key="slots" namespace="globus">1</profile>
- <profile key="nodeGranularity" namespace="globus">6</profile>
- <profile key="maxNodes" namespace="globus">6</profile>
+ <profile key="nodeGranularity" namespace="globus">2</profile>
+ <profile key="maxNodes" namespace="globus">2</profile>
<profile key="workerLoggingLevel" namespace="globus">DEBUG</profile>
<profile key="workerLoggingDirectory" namespace="globus">{wdir}</profile>
+ <profile key="queue" namespace="globus">shared</profile>
<profile key="jobThrottle" namespace="karajan">5.99</profile>
<profile key="initialScore" namespace="karajan">10000</profile>
<workdirectory>{wdir}</workdirectory>
</pool>
</config>
-<!-- RESERVATIONS:
-Add something like this to your providerAttributes:
-pbs.resources=advres=modFTDock.47 -->
Modified: trunk/tests/mpi/fusion/long/tc.template.data
--- trunk/tests/mpi/fusion/long/tc.template.data 2011-09-15 14:43:40 UTC (rev 5120)
+++ trunk/tests/mpi/fusion/long/tc.template.data 2011-09-15 19:36:27 UTC (rev 5121)
@@ -17,7 +17,4 @@
localhost paste /bin/paste INSTALLED INTEL32::LINUX null
localhost cp /bin/cp INSTALLED INTEL32::LINUX null
-# hydra-tests-2
-fusion mpi_cp _DIR_/mpi-cp INSTALLED INTEL32::LINUX globus::hostCount=2
-fusion mpi_sleep _DIR_/mpi-sleep INSTALLED INTEL32::LINUX globus::hostCount=2
+fusion mpi_sleep _DIR_/mpi-sleep INSTALLED INTEL32::LINUX globus::mpi.processes=4;globus::mpi.ppn=2
Modified: trunk/tests/mpi/fusion/short/tc.template.data
--- trunk/tests/mpi/fusion/short/tc.template.data 2011-09-15 14:43:40 UTC (rev 5120)
+++ trunk/tests/mpi/fusion/short/tc.template.data 2011-09-15 19:36:27 UTC (rev 5121)
@@ -19,4 +19,4 @@
# hydra-tests-2
+fusion mpi_cp _DIR_/mpi-cp INSTALLED INTEL32::LINUX globus::mpi.processes=2
More information about the Swift-commit
