[Swift-commit] r5081 - in trunk: docs/siteguide tests/groups
davidk at ci.uchicago.edu
Wed Sep 7 12:40:07 CDT 2011
Author: davidk
Date: 2011-09-07 12:40:07 -0500 (Wed, 07 Sep 2011)
New Revision: 5081
Added:
trunk/tests/groups/group-beagle.sh
trunk/tests/groups/group-crow.sh
trunk/tests/groups/group-fusion.sh
trunk/tests/groups/group-mcs.sh
Removed:
trunk/tests/groups/group-pbs.sh
trunk/tests/groups/group-sge.sh
trunk/tests/groups/group-ssh.sh
trunk/tests/groups/local-pbs-coasters.sh
trunk/tests/groups/local-sge-coasters.sh
Modified:
trunk/docs/siteguide/pads
trunk/tests/groups/group-intrepid.sh
trunk/tests/groups/group-pads.sh
trunk/tests/groups/group-queenbee.sh
trunk/tests/groups/group-surveyor.sh
Log:
New provider test groups, doc updates
Modified: trunk/docs/siteguide/pads
--- trunk/docs/siteguide/pads 2011-09-07 16:45:33 UTC (rev 5080)
+++ trunk/docs/siteguide/pads 2011-09-07 17:40:07 UTC (rev 5081)
@@ -33,7 +33,7 @@
The first step is to paste the text below into a file named sites.xml.
-include::../../tests/providers/PADS/coasters/sites.template.xml[]
+include::../../tests/providers/pads/coasters/sites.template.xml[]
This file will require just a few customizations. First, create a
@@ -52,7 +52,7 @@
Paste the following example into a file named tc.data
-include::../../tests/providers/PADS/coasters/tc.template.data[]
+include::../../tests/providers/pads/coasters/tc.template.data[]
Copy a Swift Script
@@ -197,7 +197,7 @@
Below is the template that is used by Swift's test suite for running on PADS.
Before you can use this configuration file, you will need to modify \_WORK_ to a directory writable by you,
@@ -210,7 +210,7 @@
Below is the tc.data file used by Swift's test suite for running on PADS.
Copy these commands and save it as tc.data.
Added: trunk/tests/groups/group-beagle.sh
--- trunk/tests/groups/group-beagle.sh (rev 0)
+++ trunk/tests/groups/group-beagle.sh 2011-09-07 17:40:07 UTC (rev 5081)
@@ -0,0 +1,9 @@
+# GROUPLIST definition to run on Beagle
+GROUPLIST=( $TESTDIR/local \
+ $TESTDIR/providers/beagle/coasters \
+ $TESTDIR/provdiers/beagle/pbs \
+checkvars WORK QUEUE PROJECT
Added: trunk/tests/groups/group-crow.sh
--- trunk/tests/groups/group-crow.sh (rev 0)
+++ trunk/tests/groups/group-crow.sh 2011-09-07 17:40:07 UTC (rev 5081)
@@ -0,0 +1,8 @@
+# GROUPLIST definition to run on Crow
+ $TESTDIR/providers/crow \
Added: trunk/tests/groups/group-fusion.sh
--- trunk/tests/groups/group-fusion.sh (rev 0)
+++ trunk/tests/groups/group-fusion.sh 2011-09-07 17:40:07 UTC (rev 5081)
@@ -0,0 +1,8 @@
+# GROUPLIST definition to run on Fusion
+ $TESTDIR/providers/fusion/coasters \
Modified: trunk/tests/groups/group-intrepid.sh
--- trunk/tests/groups/group-intrepid.sh 2011-09-07 16:45:33 UTC (rev 5080)
+++ trunk/tests/groups/group-intrepid.sh 2011-09-07 17:40:07 UTC (rev 5081)
@@ -2,7 +2,7 @@
# GROUPLIST definition to run on Intrepid
- $TESTDIR/providers/local-cobalt/intrepid \
+ $TESTDIR/providers/intrepid \
Added: trunk/tests/groups/group-mcs.sh
--- trunk/tests/groups/group-mcs.sh (rev 0)
+++ trunk/tests/groups/group-mcs.sh 2011-09-07 17:40:07 UTC (rev 5081)
@@ -0,0 +1,8 @@
+# GROUPLIST definition to run on MCS bag of machines
+ $TESTDIR/providers/mcs \
Modified: trunk/tests/groups/group-pads.sh
--- trunk/tests/groups/group-pads.sh 2011-09-07 16:45:33 UTC (rev 5080)
+++ trunk/tests/groups/group-pads.sh 2011-09-07 17:40:07 UTC (rev 5081)
@@ -3,5 +3,6 @@
GROUPLIST=(
$TESTDIR/providers/local \
- $TESTDIR/providers/local-pbs/pads \
+ $TESTDIR/providers/pads/coasters \
+ $TESTDIR/providers/pads/pbs \
Deleted: trunk/tests/groups/group-pbs.sh
--- trunk/tests/groups/group-pbs.sh 2011-09-07 16:45:33 UTC (rev 5080)
+++ trunk/tests/groups/group-pbs.sh 2011-09-07 17:40:07 UTC (rev 5081)
@@ -1,7 +0,0 @@
-# GROUPLIST definition to run pbs tests
-GROUPLIST=(
- $TESTDIR/providers/local-pbs \
- $TESTDIR/providers/local-pbs-coasters \
Modified: trunk/tests/groups/group-queenbee.sh
--- trunk/tests/groups/group-queenbee.sh 2011-09-07 16:45:33 UTC (rev 5080)
+++ trunk/tests/groups/group-queenbee.sh 2011-09-07 17:40:07 UTC (rev 5081)
@@ -2,5 +2,5 @@
GROUPLIST=(
- $TESTDIR/providers/local-pbs/queenbee \
+ $TESTDIR/providers/queenbee/pbs \
Deleted: trunk/tests/groups/group-sge.sh
--- trunk/tests/groups/group-sge.sh 2011-09-07 16:45:33 UTC (rev 5080)
+++ trunk/tests/groups/group-sge.sh 2011-09-07 17:40:07 UTC (rev 5081)
@@ -1,6 +0,0 @@
-# GROUPLIST definition to run sge tests
-GROUPLIST=(
- $TESTDIR/providers/sge-local \
Deleted: trunk/tests/groups/group-ssh.sh
--- trunk/tests/groups/group-ssh.sh 2011-09-07 16:45:33 UTC (rev 5080)
+++ trunk/tests/groups/group-ssh.sh 2011-09-07 17:40:07 UTC (rev 5081)
@@ -1,7 +0,0 @@
-GROUPLIST=(
- $TESTDIR/providers/ssh \
- $TESTDIR/providers/ssh-pbs-coasters \
Modified: trunk/tests/groups/group-surveyor.sh
--- trunk/tests/groups/group-surveyor.sh 2011-09-07 16:45:33 UTC (rev 5080)
+++ trunk/tests/groups/group-surveyor.sh 2011-09-07 17:40:07 UTC (rev 5081)
@@ -2,7 +2,7 @@
GROUPLIST=( $TESTDIR/providers/local \
- $TESTDIR/providers/local-cobalt/surveyor \
+ $TESTDIR/providers/surveyor \
Deleted: trunk/tests/groups/local-pbs-coasters.sh
--- trunk/tests/groups/local-pbs-coasters.sh 2011-09-07 16:45:33 UTC (rev 5080)
+++ trunk/tests/groups/local-pbs-coasters.sh 2011-09-07 17:40:07 UTC (rev 5081)
@@ -1,6 +0,0 @@
-GROUPLIST=(
Deleted: trunk/tests/groups/local-sge-coasters.sh
--- trunk/tests/groups/local-sge-coasters.sh 2011-09-07 16:45:33 UTC (rev 5080)
+++ trunk/tests/groups/local-sge-coasters.sh 2011-09-07 17:40:07 UTC (rev 5081)
@@ -1,6 +0,0 @@
-GROUPLIST=(
- $TESTDIR/providers/local-sge-coasters \
More information about the Swift-commit
