[Swift-commit] r5064 - usertools/persistent-coasters
wozniak at ci.uchicago.edu
Fri Sep 2 15:36:05 CDT 2011
Author: wozniak
Date: 2011-09-02 15:36:05 -0500 (Fri, 02 Sep 2011)
New Revision: 5064
Modified:
usertools/persistent-coasters/README.txt
Log:
Formatting
Modified: usertools/persistent-coasters/README.txt
--- usertools/persistent-coasters/README.txt 2011-09-02 16:00:16 UTC (rev 5063)
+++ usertools/persistent-coasters/README.txt 2011-09-02 20:36:05 UTC (rev 5064)
@@ -42,9 +42,12 @@
== Input files
+settings.sh+::
-Settings for this script suite
+Settings for this script suite: +NODES+, etc.
+sites.passivate-template.xml+::
-Used by
+Used to set Coaster service settings:
++jobsPerNode+, etc.
++nodeGranularity+ is not set here:
+this is controlled by the +NODES+ value
+swift.properties+::
Normal Swift properties
@@ -52,7 +55,7 @@
These are places you can look to see what happened.
-* Worker logs go into +WORKER_LOGDIR+ ($PWD/logs)
+* Worker logs go into +WORKER_LOGDIR+ (+$PWD/logs+)
** These will be named in accordance with the worker mode
* The coaster service standard output:
+$WORKER_LOGDIR/coaster-service.out+
More information about the Swift-commit
