[Swift-commit] r5055 - trunk/docs/siteguide
wilde at ci.uchicago.edu
Thu Sep 1 16:10:15 CDT 2011
Author: wilde
Date: 2011-09-01 16:10:15 -0500 (Thu, 01 Sep 2011)
New Revision: 5055
Modified:
trunk/docs/siteguide/grid
Log:
edits to Grid tools for site config guide.
Modified: trunk/docs/siteguide/grid
--- trunk/docs/siteguide/grid 2011-09-01 21:09:25 UTC (rev 5054)
+++ trunk/docs/siteguide/grid 2011-09-01 21:10:15 UTC (rev 5055)
@@ -121,8 +121,52 @@
concatenates all the site names that sucessfully resturned an output
file from site tests.
+Installing software on OSG sites
+The command "foreachsite" will execute a local shell script passed to
+it as an argument, on each OSG site in the Engage VO ReSS site
+catalog. The user's installscript will execute on either the head node
+(as a GRAM "fork" job) or on a worker node, as controlled by the
+-resource option. Its syntax is:
+$ ./foreachsite -help
+./foreachsite foreachsite [-resource fork|worker ] [-sites alt-sites-file] scriptname
+To install your software, create a script similar to "myapp.sh",
+below, which (in this example) reads a tar file of a pre-compiled
+application "myapp-2.12" and executes a test script for that
+application. The test script should print some reconizable indication
+of its success or failure:
+$ cat myinstall.sh
+renice 2 -p $$
+IDIR=OSG_APP/extenci/myname/myapp
+mkdir -p $IDIR
+cd $IDIR
+wget http://my.url.edu/~mydir/myapp-2.12.tar.tgz
+tar zxf myapp-2.12.tar.tgz
+myapp-2.12/bin/test_myapp.sh
+if [ $? = 0 ]; then
+ echo INSTALL SUCCEEDED
+else
+ echo INSTALL FAILED
+fi
+$ foreachsite -resource fork myinstall.sh
+$ # Wait a file here, then poll for successfully installed apps...
+$ grep SUCCEEDED run.89/*/*.stdout
Starting a single coaster service
This single coaster service will service all grid sites:
More information about the Swift-commit
