[Swift-commit] r5053 - usertools/persistent-coasters
wozniak at ci.uchicago.edu
Thu Sep 1 15:10:13 CDT 2011
Author: wozniak
Date: 2011-09-01 15:10:12 -0500 (Thu, 01 Sep 2011)
New Revision: 5053
Modified:
usertools/persistent-coasters/README.txt
Log:
Fixes to README
Modified: usertools/persistent-coasters/README.txt
--- usertools/persistent-coasters/README.txt 2011-09-01 20:07:04 UTC (rev 5052)
+++ usertools/persistent-coasters/README.txt 2011-09-01 20:10:12 UTC (rev 5053)
@@ -1,21 +1,24 @@
+Persistent Coasters Helper Scripts
// This is an asciidoc file but should also be human-readable
-= Usage
+== Usage
. Edit +settings.sh+
. Run +./start-service.zsh+
.. +start-service.zsh+ does the steps outlined above
-. Start your application SwiftScripts with the generated sites.xml
+. Start your application SwiftScripts with the generated +sites.xml+
-= Concepts
+== Concepts
* Worker mode: How to launch the worker.pl scripts
-= Overview of persistent CoasterService process
+== Overview of persistent CoasterService process
. Source +settings.sh+
-. Start coaster service
+. Start coaster service
. Get URL to which Swift should connect from service output
. Run Swift once to send settings to CoasterService,
putting CoasterService in passive mode
@@ -23,7 +26,7 @@
. Connect workers to CoasterService
. Run Swift for application
-= Testing
+== Testing
After the service has started, you will have fresh sites.xml and tc.data
files. You can then run:
@@ -36,7 +39,7 @@
Read +system-info.out+ to see if it worked.
-= Output files
+== Output files
* Worker logs go into +WORKER_LOGDIR+ ($PWD/logs)
** These will be named in accordance with the worker mode
More information about the Swift-commit
