[Swift-commit] r5047 - trunk/tests/mpi/fusion/long
wozniak at ci.uchicago.edu
Thu Sep 1 10:46:51 CDT 2011
Author: wozniak
Date: 2011-09-01 10:46:51 -0500 (Thu, 01 Sep 2011)
New Revision: 5047
Modified:
trunk/tests/mpi/fusion/long/100-mci.swift
trunk/tests/mpi/fusion/long/sites.template.xml
trunk/tests/mpi/fusion/long/tc.template.data
Log:
Minor improvements
Modified: trunk/tests/mpi/fusion/long/100-mci.swift
--- trunk/tests/mpi/fusion/long/100-mci.swift 2011-09-01 15:41:56 UTC (rev 5046)
+++ trunk/tests/mpi/fusion/long/100-mci.swift 2011-09-01 15:46:51 UTC (rev 5047)
@@ -8,7 +8,9 @@
file input<"100-input.txt">;
-foreach i in [0:4] {
+int total = 10;
+foreach i in [0:total] {
file output<single_file_mapper;file=@strcat("transform-",i,".txt")>;
output = transform(input);
Modified: trunk/tests/mpi/fusion/long/sites.template.xml
--- trunk/tests/mpi/fusion/long/sites.template.xml 2011-09-01 15:41:56 UTC (rev 5046)
+++ trunk/tests/mpi/fusion/long/sites.template.xml 2011-09-01 15:46:51 UTC (rev 5047)
@@ -8,7 +8,7 @@
<pool handle="fusion">
<execution jobmanager="local:pbs" provider="coaster" url="none"/>
<filesystem provider="local" url="none" />
- <profile namespace="globus" key="maxWallTime">1</profile>
+ <profile namespace="globus" key="maxWallTime">100</profile>
<profile namespace="globus" key="maxTime">7200</profile>
<profile key="jobsPerNode" namespace="globus">1</profile>
Modified: trunk/tests/mpi/fusion/long/tc.template.data
--- trunk/tests/mpi/fusion/long/tc.template.data 2011-09-01 15:41:56 UTC (rev 5046)
+++ trunk/tests/mpi/fusion/long/tc.template.data 2011-09-01 15:46:51 UTC (rev 5047)
@@ -19,5 +19,5 @@
# hydra-tests-2
-beagle mpi_cp _DIR_/mpi-cp INSTALLED INTEL32::LINUX globus::hostCount=2
-beagle mpi_sleep _DIR_/mpi-sleep INSTALLED INTEL32::LINUX globus::hostCount=2
+fusion mpi_cp _DIR_/mpi-cp INSTALLED INTEL32::LINUX globus::hostCount=2
+fusion mpi_sleep _DIR_/mpi-sleep INSTALLED INTEL32::LINUX globus::hostCount=2
More information about the Swift-commit
