[Swift-commit] r5039 - trunk/docs/userguide
wozniak at ci.uchicago.edu wozniak at ci.uchicago.edu
Thu Sep 1 10:14:07 CDT 2011
Author: wozniak
Date: 2011-09-01 10:14:07 -0500 (Thu, 01 Sep 2011)
New Revision: 5039
Modified:
   trunk/docs/userguide/cdm
Log:
Whitespace
Modified: trunk/docs/userguide/cdm
--- trunk/docs/userguide/cdm	2011-09-01 03:31:29 UTC (rev 5038)
+++ trunk/docs/userguide/cdm	2011-09-01 15:14:07 UTC (rev 5039)
@@ -2,202 +2,202 @@
 Overview
-. The user specifies a CDM policy in a file, customarily fs.data.
-. fs.data is given to Swift on the command line.
-. The Swift data module (org.globus.swift.data) is informed of the CDM policy.
-. At job launch time, the VDL Karajan code queries the CDM policy,
-   .. altering the file staging phase, and
-   .. sending fs.data to the compute site.
-. At job run time, the Swift wrapper script
-   .. consults a Perl script to obtain policy, and
-   .. uses wrapper extensions to modify data movement.
-. Similarly, stage out can be changed.
+. The user specifies a CDM policy in a file, customarily fs.data.
+. fs.data is given to Swift on the command line.
+. The Swift data module (org.globus.swift.data) is informed of the CDM policy.
+. At job launch time, the VDL Karajan code queries the CDM policy,
+   .. altering the file staging phase, and
+   .. sending fs.data to the compute site.
+. At job run time, the Swift wrapper script
+   .. consults a Perl script to obtain policy, and
+   .. uses wrapper extensions to modify data movement.
+. Similarly, stage out can be changed.
 .Command line
-$ swift -sites.file sites.xml -tc.file tc.data -cdm.file fs.data stream.swift
+$ swift -sites.file sites.xml -tc.file tc.data -cdm.file fs.data stream.swift
 CDM policy file format
 .Example
-# Describe CDM for my job
-property GATHER_LIMIT 1
-rule .*input.txt DIRECT /gpfs/homes/wozniak/data
-rule .*xfile*.data BROADCAST /dev/shm
-rule .* DEFAULT
-The lines contain:
-. A directive, either rule or property
-. A rule has:
-   .. A regular expression
-   .. A policy token
-   .. Additional policy-specific arguments
-. A property has
-   .. A policy property token
-   .. The token value
-. Comments with # .
-. Blank lines are ignored.
+# Describe CDM for my job
+property GATHER_LIMIT 1
+rule .*input.txt DIRECT /gpfs/homes/wozniak/data
+rule .*xfile*.data BROADCAST /dev/shm
+rule .* DEFAULT
+The lines contain:
+. A directive, either rule or property
+. A rule has:
+   .. A regular expression
+   .. A policy token
+   .. Additional policy-specific arguments
+. A property has
+   .. A policy property token
+   .. The token value
+. Comments with # .
+. Blank lines are ignored.
 .Notes
-. The policy file is used as a lookup database by Swift and Perl methods.
-. For example, a lookup with the database above given the argument input.txt would result in the Direct policy.
-. If the lookup does not succeed, the result is DEFAULT.
- . Policies are listed as subclasses of org.globus.swift.data.policy.Policy .
+. The policy file is used as a lookup database by Swift and Perl methods.
+. For example, a lookup with the database above given the argument input.txt would result in the Direct policy.
+. If the lookup does not succeed, the result is DEFAULT.
+ . Policies are listed as subclasses of org.globus.swift.data.policy.Policy .
 Policy Descriptions
-.Default
-* Just use file staging as provided by Swift/CoG.  Identical to behavior if no CDM file is given.
+.Default
+* Just use file staging as provided by Swift/CoG.  Identical to behavior if no CDM file is given.
 .Broadcast
-* The input files matching the pattern will be stored in the given directory, an LFS location, with links in the job directory.
-* On the BG/P, this will make use of the f2cn tool.
-* On machines not implementing an efficient broadcast, we will just ensure correctness.  For example, on a workstation, the location could be in a /tmp RAM FS.
+* The input files matching the pattern will be stored in the given directory, an LFS location, with links in the job directory.
+* On the BG/P, this will make use of the f2cn tool.
+* On machines not implementing an efficient broadcast, we will just ensure correctness.  For example, on a workstation, the location could be in a /tmp RAM FS.
 .Direct
-rule .*input.txt DIRECT /gpfs/scratch/wozniak/
-* Allows for direct I/O to the parallel FS without staging.
-* The input files matching the pattern must already exist in the given directory, a GFS location.  Links will be placed in the job directory.
-* The output files matching the pattern will be stored in the given directory, with links in the job directory.
-* Example: In the rule above, the Swift-generated file name ./data/input.txt would be accessed by the user job in /gpfs/homes/wozniak/data/input.txt .
-.Local
-rule .*input.txt LOCAL dd /gpfs/homes/wozniak/data obs=64K
-* Allows for client-directed input copy to the compute node.
-* The user may specify cp or dd as the input transfer program.
-* The input files matching the pattern must already exist in the given directory, a GFS location.  Copies will be placed in the job directory.
-* Argument list: [tool] [GFS directory] [tool arguments]*
+rule .*input.txt DIRECT /gpfs/scratch/wozniak/
+* Allows for direct I/O to the parallel FS without staging.
+* The input files matching the pattern must already exist in the given directory, a GFS location.  Links will be placed in the job directory.
+* The output files matching the pattern will be stored in the given directory, with links in the job directory.
+* Example: In the rule above, the Swift-generated file name ./data/input.txt would be accessed by the user job in /gpfs/homes/wozniak/data/input.txt .
+.Local
+rule .*input.txt LOCAL dd /gpfs/homes/wozniak/data obs=64K
+* Allows for client-directed input copy to the compute node.
+* The user may specify cp or dd as the input transfer program.
+* The input files matching the pattern must already exist in the given directory, a GFS location.  Copies will be placed in the job directory.
+* Argument list: [tool] [GFS directory] [tool arguments]*
 .Gather
-property GATHER_LIMIT 500000000 # 500 MB
-property GATHER_DIR /dev/shm/gather
-property GATHER_TARGET /gpfs/wozniak/data/gather_target
-rule .*.output.txt GATHER
-* The output files matching the pattern will be present to tasks in the job directory as usual but noted in a _swiftwrap shell array GATHER_OUTPUT.
-* The GATHER_OUTPUT files will be cached in the GATHER_DIR, an LFS location.
-* The cache will be flushed when a job ends if a du on GATHER_DIR exceeds GATHER_LIMIT.
-* As the cache fills or on stage out, the files will be bundled into randomly named tarballs in GATHER_TARGET, a GFS location.
-* If the compute node is an SMP, GATHER_DIR is a shared resource.  It is protected by the link file GATHER_DIR/.cdm.lock .
-* Unpacking the tarballs in GATHER_TARGET will produce the user-specified filenames.
+property GATHER_LIMIT 500000000 # 500 MB
+property GATHER_DIR /dev/shm/gather
+property GATHER_TARGET /gpfs/wozniak/data/gather_target
+rule .*.output.txt GATHER
+* The output files matching the pattern will be present to tasks in the job directory as usual but noted in a _swiftwrap shell array GATHER_OUTPUT.
+* The GATHER_OUTPUT files will be cached in the GATHER_DIR, an LFS location.
+* The cache will be flushed when a job ends if a du on GATHER_DIR exceeds GATHER_LIMIT.
+* As the cache fills or on stage out, the files will be bundled into randomly named tarballs in GATHER_TARGET, a GFS location.
+* If the compute node is an SMP, GATHER_DIR is a shared resource.  It is protected by the link file GATHER_DIR/.cdm.lock .
+* Unpacking the tarballs in GATHER_TARGET will produce the user-specified filenames.
 .Summary
-. Files created by application
-. Acquire lock
-. Move files to cache
-. Check cache size
-. If limit exceeded, move all cache files to outbox
-. Release lock
-. If limit was exceeded, stream outbox as tarball to target
+. Files created by application
+. Acquire lock
+. Move files to cache
+. Check cache size
+. If limit exceeded, move all cache files to outbox
+. Release lock
+. If limit was exceeded, stream outbox as tarball to target
 .Notes
-* Gather required quite a bit of shell functionality to manage the lock, etc. This is placed in cdm_lib.sh .
-* vdl_int.k needed an additional task submission (cdm_cleanup.sh) to perform the final flush at workflow completion time .  This task also uses cdm_lib.sh .
+* Gather required quite a bit of shell functionality to manage the lock, etc. This is placed in cdm_lib.sh .
+* vdl_int.k needed an additional task submission (cdm_cleanup.sh) to perform the final flush at workflow completion time .  This task also uses cdm_lib.sh .
 VDL/Karajan processing
-. CDM functions are available in Karajan via the cdm namespace.
-. These functions are defined in org.globus.swift.data.Query .
-. If CDM is enabled, VDL skips file staging for files unless the policy is DEFAULT.
-Swift wrapper CDM routines
+. CDM functions are available in Karajan via the cdm namespace.
+. These functions are defined in org.globus.swift.data.Query .
+. If CDM is enabled, VDL skips file staging for files unless the policy is DEFAULT.
+Swift wrapper CDM routines
-. The cdm.pl script is shipped to the compute node if CDM is enabled.
-. When linking in inputs, CDM is consulted by _swiftwrap:cdm_lookup().
-. The cdm_action() shell function handles CDM methods, typically just producing a link.
-Test cases
+. The cdm.pl script is shipped to the compute node if CDM is enabled.
+. When linking in inputs, CDM is consulted by _swiftwrap:cdm_lookup().
+. The cdm_action() shell function handles CDM methods, typically just producing a link.
+Test cases
-. Simple test cases are in:
-      https://svn.mcs.anl.gov/repos/wozniak/collab/cdm/scripts/cdm-direct and
-      https://svn.mcs.anl.gov/repos/wozniak/collab/cdm/scripts/all-pairs
-. Do a:
-      mkdir cdm
-      cd cdm
-      svn co https://svn.mcs.anl.gov/repos/wozniak/collab/cdm/scripts
-. In cdm-direct, run:
-      source ./setup.sh local local local
-. Run workflow:
-      swift -sites.file sites.xml -tc.file tc.data -cdm.file fs.data stream.swift
-. Note that staging is skipped for input.txt
-      policy: file://localhost/input.txt : DIRECT
-      FILE_STAGE_IN_START file=input.txt ...
-      FILE_STAGE_IN_SKIP file=input.txt policy=DIRECT
-      FILE_STAGE_IN_END file=input.txt ...
-. In the wrapper output, the input file is handled by CDM functionality:
-      Progress  2010-01-21 13:50:32.466572727-0600  LINK_INPUTS
-      CDM_POLICY: DIRECT /homes/wozniak/cdm/scripts/cdm-direct
-      CDM: jobs/t/cp_sh-tkul4nmj input.txt DIRECT /homes/wozniak/cdm/scripts/cdm-direct
-      CDM[DIRECT]: Linking jobs/t/cp_sh-tkul4nmj/input.txt to /homes/wozniak/cdm/scripts/cdm-direct/input.txt
-      Progress  2010-01-21 13:50:32.486016708-0600  EXECUTE
-. all-pairs is quite similar but uses more policies.
+. Simple test cases are in:
+      https://svn.mcs.anl.gov/repos/wozniak/collab/cdm/scripts/cdm-direct and
+      https://svn.mcs.anl.gov/repos/wozniak/collab/cdm/scripts/all-pairs
+. Do a:
+      mkdir cdm
+      cd cdm
+      svn co https://svn.mcs.anl.gov/repos/wozniak/collab/cdm/scripts
+. In cdm-direct, run:
+      source ./setup.sh local local local
+. Run workflow:
+      swift -sites.file sites.xml -tc.file tc.data -cdm.file fs.data stream.swift
+. Note that staging is skipped for input.txt
+      policy: file://localhost/input.txt : DIRECT
+      FILE_STAGE_IN_START file=input.txt ...
+      FILE_STAGE_IN_SKIP file=input.txt policy=DIRECT
+      FILE_STAGE_IN_END file=input.txt ...
+. In the wrapper output, the input file is handled by CDM functionality:
+      Progress  2010-01-21 13:50:32.466572727-0600  LINK_INPUTS
+      CDM_POLICY: DIRECT /homes/wozniak/cdm/scripts/cdm-direct
+      CDM: jobs/t/cp_sh-tkul4nmj input.txt DIRECT /homes/wozniak/cdm/scripts/cdm-direct
+      CDM[DIRECT]: Linking jobs/t/cp_sh-tkul4nmj/input.txt to /homes/wozniak/cdm/scripts/cdm-direct/input.txt
+      Progress  2010-01-21 13:50:32.486016708-0600  EXECUTE
+. all-pairs is quite similar but uses more policies.
 PTMap case
-. Start with vanilla PTMap:
-   .. cd cdm
-   .. mkdir apps
-   .. cd apps
-   .. https://svn.mcs.anl.gov/repos/wozniak/collab/cdm/apps/ptmap
-. Source setup.sh
-. Use start.sh, which
-   .. applies CDM policy from fs.local.data
+. Start with vanilla PTMap:
+   .. cd cdm
+   .. mkdir apps
+   .. cd apps
+   .. https://svn.mcs.anl.gov/repos/wozniak/collab/cdm/apps/ptmap
+. Source setup.sh
+. Use start.sh, which
+   .. applies CDM policy from fs.local.data
 CDM site-aware policy file format
 Example
-#Describe CDM for my job
-#Use DIRECT and BROADCAST if on cluster1, else use DEFAULT behavior
-rule cluster1 .*input.txt DIRECT /gpfs/homes/wozniak/data
-rule cluster1 .*xfile*.data BROADCAST /dev/shm
-rule ANYWHERE .* DEFAULT
+#Describe CDM for my job
+#Use DIRECT and BROADCAST if on cluster1, else use DEFAULT behavior
+rule cluster1 .*input.txt DIRECT /gpfs/homes/wozniak/data
+rule cluster1 .*xfile*.data BROADCAST /dev/shm
+rule ANYWHERE .* DEFAULT
 The lines contain:
-. A rule has:
-   .. A regular expression for site matchin
-   .. A regular expression for filename matching
-   .. A policy token
-. A property has
+. A rule has:
+   .. A regular expression for site matchin
+   .. A regular expression for filename matching
+   .. A policy token
+. A property has
