[Swift-commit] r5258 - trunk/src/org/griphyn/vdl/karajan/lib/swiftscript
wozniak at ci.uchicago.edu
Sat Oct 22 23:03:13 CDT 2011
Author: wozniak
Date: 2011-10-22 23:03:13 -0500 (Sat, 22 Oct 2011)
New Revision: 5258
Modified:
trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Assert.java
trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Fprintf.java
trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Sprintf.java
Log:
New formatter %b (boolean); fixes for toString/getValue, PathParser
Modified: trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Assert.java
--- trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Assert.java 2011-10-23 04:00:52 UTC (rev 5257)
+++ trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Assert.java 2011-10-23 04:03:13 UTC (rev 5258)
@@ -1,6 +1,6 @@
package org.griphyn.vdl.karajan.lib.swiftscript;
-import org.apache.log4j.Logger;
+// import org.apache.log4j.Logger;
import org.globus.cog.karajan.arguments.Arg;
import org.globus.cog.karajan.stack.VariableStack;
import org.globus.cog.karajan.workflow.ExecutionException;
@@ -16,8 +16,8 @@
public class Assert extends VDLFunction {
- private static final Logger logger =
- Logger.getLogger(Assert.class);
+ // private static final Logger logger =
+ // Logger.getLogger(Assert.class);
static {
setArguments(Assert.class, new Arg[] { Arg.VARGS });
@@ -31,7 +31,7 @@
if (args.length == 2)
if (args[1].getType() == Types.STRING)
- message = args[1].toString();
+ message = (String) args[1].getValue();
else
throw new ExecutionException
("Second argument to assert() must be a String!");
@@ -50,8 +50,8 @@
success = false;
else if (value.getType() == Types.INT) {
- double d = ((Double) value.getValue()).doubleValue();
- if (d == 0.0)
+ double d = ((Integer) value.getValue()).intValue();
+ if (d == 0)
success = false;
else
Modified: trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Fprintf.java
--- trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Fprintf.java 2011-10-23 04:00:52 UTC (rev 5257)
+++ trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Fprintf.java 2011-10-23 04:03:13 UTC (rev 5258)
@@ -39,8 +39,8 @@
check(args);
- String filename = args[0].toString();
- String spec = args[1].toString();
+ String filename = (String) args[0].getValue();
+ String spec = (String) args[1].getValue();
DSHandle[] vars = Sprintf.copyArray(args, 2, args.length-2);
StringBuilder output = new StringBuilder();
@@ -59,10 +59,10 @@
("fprintf(): requires at least 2 arguments!");
if (! args[0].getType().equals(Types.STRING))
- ("fprintf(): first argument is a string filename!");
+ ("fprintf(): first argument must be a string filename!");
- ("fprintf(): second argument is a string specifier!");
+ ("fprintf(): second argument must be a string specifier!");
private static void write(String filename, String msg)
Modified: trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Sprintf.java
--- trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Sprintf.java 2011-10-23 04:00:52 UTC (rev 5257)
+++ trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Sprintf.java 2011-10-23 04:03:13 UTC (rev 5258)
@@ -23,6 +23,7 @@
%%: % sign. <br>
%M: Filename output: waits for close
%p: Not typechecked, output as in trace(). <br>
+ %b: Typechecked boolean output. <br>
%f: Typechecked float output. <br>
%i: Typechecked int output. <br>
%s: Typechecked string output. <br>
@@ -119,6 +120,9 @@
if (c == 'M') {
append_M(vars[arg], output);
+ else if (c == 'b') {
+ append_b(vars[arg], output);
else if (c == 'f') {
append_f(vars[arg], output);
@@ -161,6 +165,17 @@
+ private static void append_b(DSHandle arg, StringBuilder output)
+ throws ExecutionException {
+ if (arg.getType() == Types.BOOLEAN) {
+ output.append(arg.getValue());
+ else {
+ throw new ExecutionException
+ ("tracef(): %b requires a boolean!");
private static void append_f(DSHandle arg, StringBuilder output)
if (arg.getType() == Types.FLOAT) {
@@ -192,7 +207,7 @@
try {
int size = node.size();
for (int i = 0; i < size; i++) {
- String entry = ""+i;
+ String entry = "["+i+"]";
DSHandle handle =
node.getField(Path.parse(entry));
output.append(handle.getValue());
More information about the Swift-commit
