[Swift-commit] r5251 - in SwiftApps/SwiftR/Swift: src tests tests/OpenMx tests/perf
tga at ci.uchicago.edu
Thu Oct 20 18:32:32 CDT 2011
Author: tga
Date: 2011-10-20 18:32:32 -0500 (Thu, 20 Oct 2011)
New Revision: 5251
Added:
SwiftApps/SwiftR/Swift/tests/perf/perfutils.R
Removed:
SwiftApps/SwiftR/Swift/tests/perf_tests.R
Modified:
SwiftApps/SwiftR/Swift/src/Makefile
SwiftApps/SwiftR/Swift/tests/OpenMx/BootstrapParallelBigger.R
SwiftApps/SwiftR/Swift/tests/OpenMx/RAM-3Factor-96Indicators-covdata-a.R
SwiftApps/SwiftR/Swift/tests/perf/param_size.R
SwiftApps/SwiftR/Swift/tests/perf/serialisation_overhead.R
Log:
Working on R check errors
* Delete Swift/inst directory for CRAN package
* Move perf_tests.R so it isn't automatically run by check script
Modified: SwiftApps/SwiftR/Swift/src/Makefile
--- SwiftApps/SwiftR/Swift/src/Makefile 2011-10-20 23:32:20 UTC (rev 5250)
+++ SwiftApps/SwiftR/Swift/src/Makefile 2011-10-20 23:32:32 UTC (rev 5251)
@@ -53,6 +53,7 @@
removeall: removebuild
rm -rf ./$(SWIFT_INST)
+ rm -rf ../inst
removebuild:
Modified: SwiftApps/SwiftR/Swift/tests/OpenMx/BootstrapParallelBigger.R
--- SwiftApps/SwiftR/Swift/tests/OpenMx/BootstrapParallelBigger.R 2011-10-20 23:32:20 UTC (rev 5250)
+++ SwiftApps/SwiftR/Swift/tests/OpenMx/BootstrapParallelBigger.R 2011-10-20 23:32:32 UTC (rev 5251)
@@ -26,7 +26,7 @@
require(OpenMx)
require(Swift)
-source("Swift/tests/perf_tests.R")
+source("Swift/tests/perf/perfutils.R")
Modified: SwiftApps/SwiftR/Swift/tests/OpenMx/RAM-3Factor-96Indicators-covdata-a.R
--- SwiftApps/SwiftR/Swift/tests/OpenMx/RAM-3Factor-96Indicators-covdata-a.R 2011-10-20 23:32:20 UTC (rev 5250)
+++ SwiftApps/SwiftR/Swift/tests/OpenMx/RAM-3Factor-96Indicators-covdata-a.R 2011-10-20 23:32:32 UTC (rev 5251)
@@ -26,7 +26,7 @@
library(OpenMx)
library(Swift)
# Data for factor model.
Modified: SwiftApps/SwiftR/Swift/tests/perf/param_size.R
--- SwiftApps/SwiftR/Swift/tests/perf/param_size.R 2011-10-20 23:32:20 UTC (rev 5250)
+++ SwiftApps/SwiftR/Swift/tests/perf/param_size.R 2011-10-20 23:32:32 UTC (rev 5251)
@@ -1,5 +1,5 @@
require(Swift)
cores <- 4
intsize <- 4
Copied: SwiftApps/SwiftR/Swift/tests/perf/perfutils.R (from rev 5250, SwiftApps/SwiftR/Swift/tests/perf_tests.R)
--- SwiftApps/SwiftR/Swift/tests/perf/perfutils.R (rev 0)
+++ SwiftApps/SwiftR/Swift/tests/perf/perfutils.R 2011-10-20 23:32:32 UTC (rev 5251)
@@ -0,0 +1,105 @@
+# Helper functions for building performance tests suites that don't quite fit in the
+# main SwiftR code because they can detach the Swift package..
+swiftSetup <- function (...) {
+ libraries <- search()
+ if ("package:Swift" %in% libraries) {
+ library(Swift)
+ options(.swift.detach=T)
+ library(Swift)
+ swiftSess <- swiftInit(...)
+ options(.swift.printtiming=getOption("swift.printtiming"))
+ options(swift.printtiming=TRUE)
+ # Wait to start
+ Sys.sleep(10)
+ # Run some small jobs to ensure workers are started and warmed up
+ swiftapply(function (x) { x },
+ rep(1, swiftSess$cores * swiftSess$nodes * 2),
+ callsperbatch=1)
+ return (swiftSess)
+swiftTearDown <- function (...) {
+ swiftShutdown()
+ options(swift.printtiming=getOption(".swift.printtiming"))
+ dt <- getOption(".swift.detach")
+ options(.swift.detach=NULL)
+ if (!is.null(dt) && dt) {
+ detach(package:Swift)
+sfSetup <- function(..., cpus=ncpus) {
+ if (!("package:snowfall" %in% libraries)) {
+ library(snowfall)
+ options(.snowfall.detach=T)
+ # Swift needs to be detached
+ options(.swift.reattach=T)
+ sfInit(..., cpus=ncpus)
+ # warmup
+ sfLapply(rep(1, ncpus * 2),
+ function (x) { x })
+sfTearDown <- function (...) {
+ sfStop()
+ dt <- getOption(".snowfall.detach")
+ options(.snowfall.detach=NULL)
+ detach(package:snowfall)
+ rt <- getOption(".swift.reattach")
+ options(.swift.reattach=NULL)
+ if (!is.null(rt) && rt) {
+ library(Swift)
+makePerfTestGroup <- function (mode, name, f, allargs, prep=NULL, ...) {
+ params <- list(...)
+ paramstr <- paste(names(params),
+ rep("=", length(params)),
+ lapply(params, deparse),
+ sep="", collapse=", ")
+ if (mode == "swift") {
+ tg <- Swift:::makeParamTestGroup(name=paste("swift_",name, " ", paramstr,sep=""),
+ f=f, prep=prep,
+ allargs=allargs,
+ perfparams = params,
+ setup=function() {swiftSetup(...)},
+ teardown = swiftTearDown)
+ else if (mode == "snowfall") {
+ tg <- Swift:::makeParamTestGroup(name=paste("sf_",name, paramstr, sep=""),
+ f=f,prep=prep,
+ allargs=allargs,
+ setup=function() {sfSetup(...)},
+ teardown = sfTearDown)
+ else {
+ print("Making serial test")
+ tg <- Swift:::makeParamTestGroup(name=paste("serial_",name, paramstr, sep=""),
+ f=f,prep=prep,
+ allargs=allargs,
+ perfparams = list(),
+ setup=function()
+ {try(detach(package:Swift)); try(detach(package:Snowfall))} )
+ return (tg)
Modified: SwiftApps/SwiftR/Swift/tests/perf/serialisation_overhead.R
--- SwiftApps/SwiftR/Swift/tests/perf/serialisation_overhead.R 2011-10-20 23:32:20 UTC (rev 5250)
+++ SwiftApps/SwiftR/Swift/tests/perf/serialisation_overhead.R 2011-10-20 23:32:32 UTC (rev 5251)
@@ -1,6 +1,6 @@
require(Swift)
source("Swift/tests/OpenMx/BootstrapParallelBigger.R")
args = 128
Deleted: SwiftApps/SwiftR/Swift/tests/perf_tests.R
--- SwiftApps/SwiftR/Swift/tests/perf_tests.R 2011-10-20 23:32:20 UTC (rev 5250)
+++ SwiftApps/SwiftR/Swift/tests/perf_tests.R 2011-10-20 23:32:32 UTC (rev 5251)
@@ -1,105 +0,0 @@
-# Helper functions for building performance tests suites that don't quite fit in the
-# main SwiftR code because they can detach the Swift package..
-swiftSetup <- function (...) {
- libraries <- search()
- if ("package:Swift" %in% libraries) {
- library(Swift)
- options(.swift.detach=T)
- library(Swift)
- swiftSess <- swiftInit(...)
- options(.swift.printtiming=getOption("swift.printtiming"))
- options(swift.printtiming=TRUE)
- # Wait to start
- Sys.sleep(10)
- # Run some small jobs to ensure workers are started and warmed up
- swiftapply(function (x) { x },
- rep(1, swiftSess$cores * swiftSess$nodes * 2),
- callsperbatch=1)
- return (swiftSess)
-swiftTearDown <- function (...) {
- swiftShutdown()
- options(swift.printtiming=getOption(".swift.printtiming"))
- dt <- getOption(".swift.detach")
- options(.swift.detach=NULL)
- if (!is.null(dt) && dt) {
- detach(package:Swift)
-sfSetup <- function(..., cpus=ncpus) {
- if (!("package:snowfall" %in% libraries)) {
- library(snowfall)
- options(.snowfall.detach=T)
- # Swift needs to be detached
- options(.swift.reattach=T)
- sfInit(..., cpus=ncpus)
- # warmup
- sfLapply(rep(1, ncpus * 2),
- function (x) { x })
-sfTearDown <- function (...) {
- sfStop()
- dt <- getOption(".snowfall.detach")
- options(.snowfall.detach=NULL)
- detach(package:snowfall)
- rt <- getOption(".swift.reattach")
- options(.swift.reattach=NULL)
- if (!is.null(rt) && rt) {
- library(Swift)
-makePerfTestGroup <- function (mode, name, f, allargs, prep=NULL, ...) {
- params <- list(...)
- paramstr <- paste(names(params),
- rep("=", length(params)),
- lapply(params, deparse),
- sep="", collapse=", ")
- if (mode == "swift") {
- tg <- Swift:::makeParamTestGroup(name=paste("swift_",name, " ", paramstr,sep=""),
- f=f, prep=prep,
- allargs=allargs,
- perfparams = params,
- setup=function() {swiftSetup(...)},
- teardown = swiftTearDown)
- else if (mode == "snowfall") {
- tg <- Swift:::makeParamTestGroup(name=paste("sf_",name, paramstr, sep=""),
- f=f,prep=prep,
- allargs=allargs,
- setup=function() {sfSetup(...)},
- teardown = sfTearDown)
- else {
- print("Making serial test")
- tg <- Swift:::makeParamTestGroup(name=paste("serial_",name, paramstr, sep=""),
- f=f,prep=prep,
- allargs=allargs,
- perfparams = list(),
- setup=function()
- {try(detach(package:Swift)); try(detach(package:Snowfall))} )
- return (tg)
More information about the Swift-commit
