[Swift-commit] r5220 - trunk/libexec/log-processing
wozniak at ci.uchicago.edu
Wed Oct 12 11:54:38 CDT 2011
Author: wozniak
Date: 2011-10-12 11:54:38 -0500 (Wed, 12 Oct 2011)
New Revision: 5220
Modified:
trunk/libexec/log-processing/README.txt
Log:
More README connections
Modified: trunk/libexec/log-processing/README.txt
--- trunk/libexec/log-processing/README.txt 2011-10-11 19:13:16 UTC (rev 5219)
+++ trunk/libexec/log-processing/README.txt 2011-10-12 16:54:38 UTC (rev 5220)
@@ -1,21 +1,21 @@
Log Processing
-To properly generate log plots, you must enable VDL/Karajan logging.
-TODO:How?
You should check the scripts that you intend to use to determine
what log lines they require and ensure that you are generating
-those lines via log4j.properties
+those lines via +swift/etc/log4j.properties+.
-Make sure log4.properties contains:
+To properly generate log plots, you must enable VDL/Karajan logging.
+Make sure +log4.properties+ contains:
log4j.logger.swift=DEBUG
log4j.logger.org.globus.cog.abstraction.coaster.service.job.manager.Cpu=DEBUG
log4j.logger.org.globus.cog.abstraction.coaster.service.job.manager.Block=DEBUG
-TODO: Does it work for coasters-based runs only?
+The script programs referred to below are in
++swift/libexec/log-processing+.
Normalize event times in the log to the run start time
@@ -25,7 +25,6 @@
./iso-to-secs < original.log > swift-run.log
* Generate the log, assuming the log is titled +swift-run.log+
@@ -57,9 +56,8 @@
. Build up a completed data file:
-./cpu-job-completed.pl < swift-run.norm > completed.data
+./cpu-job-complete.pl < swift-run.norm > completed.data
-TODO: This file: cpu-job-completed seems to be missing
. Plot with the JFreeChart-based plotter in usertools/plotter:
@@ -107,23 +105,22 @@
swift_plotter.zsh -s buckets.cfg buckets.eps buckets.data
-Utilities
+== Utilities
-* +iso-to-secs+
++iso-to-secs+::
Convert human-readable log dates to Unix time
-* +extract-start-time+
++extract-start-time+::
Pull out the first Unix timestamp from the log file
-* +normalise-event-start-time+
++normalise-event-start-time+::
Convert Unix seconds to seconds from start time, given a start time file
-* +normalise-event-start-time-to-any+
++normalise-event-start-time-to-any+::
Convert Unix seconds to seconds from start time, given a start time number
-* +sec-to-hour.pl+
++sec-to-hour.pl+::
Convert seconds to hours in the Unix time column.
-* +sec-to-min.pl+
++sec-to-min.pl+::
Convert seconds to minutes in the Unix time column.
More information about the Swift-commit
