[Swift-commit] r5209 - trunk/bin
davidk at ci.uchicago.edu
Thu Oct 6 21:49:42 CDT 2011
Author: davidk
Date: 2011-10-06 21:49:42 -0500 (Thu, 06 Oct 2011)
New Revision: 5209
Modified:
trunk/bin/start-coaster-service
Log:
start-coaster-service can now use a relay host to start workers not directly available due to firewall restrictions
Modified: trunk/bin/start-coaster-service
--- trunk/bin/start-coaster-service 2011-10-07 02:46:55 UTC (rev 5208)
+++ trunk/bin/start-coaster-service 2011-10-07 02:49:42 UTC (rev 5209)
@@ -43,7 +43,7 @@
# Copy and start worker script
scp $SWIFT_BIN/$WORKER $WORKER_USERNAME@$MACHINE:$WORKER_WORK > /dev/null 2>&1
echo "Starting worker on $MACHINE"
- ssh $WORKER_USERNAME@$MACHINE $WORKER_WORK/$WORKER $EXECUTION_URL $MACHINE $LOG_DIR &
+ ssh $WORKER_USERNAME@$MACHINE "$WORKER_WORK/$WORKER $EXECUTION_URL $MACHINE $LOG_DIR" &
echo $! >> $PID_FILE
done
@@ -56,6 +56,11 @@
if [ -z "$PORT" ]; then
crash "start-workers-ssh: Port number not specified, giving up"
fi
+ if [ -n "$WORKER_RELAY_HOST" ]; then
+ scp $SWIFT_BIN/$WORKER $WORKER_USERNAME@$WORKER_RELAY_HOST:/tmp > /dev/null 2>&1
+ fi
for MACHINE in $WORKER_HOSTS
do
# Enable ssh tunneling if needed
@@ -64,10 +69,20 @@
fi
- scp $SWIFT_BIN/$WORKER $MACHINE:$WORKER_WORK > /dev/null 2>&1
- echo Starting worker on $MACHINE
- ssh $MACHINE $WORKER_WORK/$WORKER $EXECUTION_URL $MACHINE $LOG_DIR &
- echo $! >> $PID_FILE
+ # Use a relay host
+ ssh $WORKER_USERNAME@$WORKER_RELAY_HOST ssh $MACHINE mkdir -p $WORKER_WORK > /dev/null 2>&1
+ ssh $WORKER_USERNAME@$WORKER_RELAY_HOST "scp /tmp/$WORKER $WORKER_USERNAME@$MACHINE:$WORKER_WORK" > /dev/null 2>&1
+ echo Starting worker on $MACHINE
+ ssh $WORKER_USERNAME@$WORKER_RELAY_HOST ssh $WORKER_USERNAME@$MACHINE "WORKER_LOGGING_LEVEL=$WORKER_LOGGING_LEVEL $WORKER_WORK/$WORKER $EXECUTION_URL $MACHINE $WORKER_LOG_DIR" &
+ echo $! >> $PID_FILE
+ # Connect directly
+ else
+ scp $SWIFT_BIN/$WORKER $WORKER_USERNAME@$MACHINE:$WORKER_WORK > /dev/null 2>&1
+ fi
done
return 0
@@ -242,7 +257,11 @@
# Generate sites.xml
export EXECUTION_URL="http://$IPADDR:$SERVICE_PORT"
echo Generating sites.xml
-gensites persistent-coasters -p $CONFIG_FILE > $RUN_DIR/sites.xml
+if [ -f "gensites.template" ]; then
+ gensites `cat gensites.template` -p $CONFIG_FILE > $RUN_DIR/sites.xml
+else
+ gensites persistent-coasters -p $CONFIG_FILE > $RUN_DIR/sites.xml
+fi
# Generate config file
if [ "$SHARED_FILESYSTEM" == "no" ]; then
@@ -255,17 +274,3 @@
EOF
fi
-# Generate TC file
-echo Generating tc.data
-cat > $RUN_DIR/tc.data << EOF
-persistent-coasters echo /bin/echo null null null
-persistent-coasters cat /bin/cat null null null
-persistent-coasters ls /bin/ls null null null
-persistent-coasters grep /bin/grep null null null
-persistent-coasters sort /bin/sort null null null
-persistent-coasters paste /bin/paste null null null
-persistent-coasters cp /bin/cp null null null
-persistent-coasters wc /usr/bin/wc null null null
-persistent-coasters hostname /bin/hostname null null null
-EOF
More information about the Swift-commit
