[Swift-commit] r5203 - usertools/plotter/src/plotter
wozniak at ci.uchicago.edu
Mon Oct 3 12:46:44 CDT 2011
Author: wozniak
Date: 2011-10-03 12:46:44 -0500 (Mon, 03 Oct 2011)
New Revision: 5203
Added:
usertools/plotter/src/plotter/Bars.java
Modified:
usertools/plotter/src/plotter/Plots.java
usertools/plotter/src/plotter/Plotter.java
Log:
New Bar plot- one minor problem remains...
Added: usertools/plotter/src/plotter/Bars.java
--- usertools/plotter/src/plotter/Bars.java (rev 0)
+++ usertools/plotter/src/plotter/Bars.java 2011-10-03 17:46:44 UTC (rev 5203)
@@ -0,0 +1,311 @@
+package plotter;
+import java.awt.Color;
+import java.awt.geom.Rectangle2D;
+import java.io.BufferedOutputStream;
+import java.io.File;
+import java.io.FileInputStream;
+import java.io.FileNotFoundException;
+import java.io.FileOutputStream;
+import java.io.IOException;
+import java.io.OutputStream;
+import java.util.ArrayList;
+import java.util.List;
+import java.util.Properties;
+import org.apache.commons.io.IOUtils;
+import org.apache.xmlgraphics.java2d.GraphicContext;
+import org.apache.xmlgraphics.java2d.ps.EPSDocumentGraphics2D;
+import org.jfree.chart.ChartFactory;
+import org.jfree.chart.JFreeChart;
+import org.jfree.chart.plot.CategoryPlot;
+import org.jfree.chart.plot.PlotOrientation;
+import org.jfree.chart.renderer.category.BarRenderer;
+import org.jfree.data.category.CategoryDataset;
+import org.jfree.data.category.DefaultCategoryDataset;
+ * See main() for command-line arguments
+public class Bars
+ static Properties properties;
+ static String title = null;
+ static String xlabel = "x";
+ static String ylabel = "y";
+ /** If true, use only black and white */
+ public static boolean bw = false;
+ static String axis_x_type = "normal";
+ static String axis_y_type = "normal";
+ static int width = 400;
+ static int height = 400;
+ // null indicates the value was not set by the user
+ static Double xmin = null;
+ static Double xmax = null;
+ static Double ymin = null;
+ static Double ymax = null;
+ static boolean withLegend = true;
+ static boolean verbose = false;
+ Args: Lines <properties> <output file> <data file>*
+ Reads settings from properties: see scanProperties()
+ Produces EPS output file
+ Data files are two-columns of numbers each -
+ see LineReader.read() and LineReader.array()
+ public static void bars(String props, String output,
+ List<String> names, boolean verbose)
+ Bars.verbose = verbose;
+ Bits.init();
+ Util.verbose(verbose);
+ String propFile = props;
+ List<double[][]> data = new ArrayList<double[][]>();
+ List<String> labels = new ArrayList<String>();
+ properties = new Properties();
+ load(propFile);
+ scanProperties();
+ for (String name : names)
+ File file = new File(name);
+ Util.verbose("open: " + file);
+ List<String> lines = null;
+ try
+ lines = LineReader.read(file);
+ if (lines == null)
+ System.err.println("Problem when reading: "+file);
+ catch (FileNotFoundException e)
+ System.err.println("not found: " + file);
+ System.exit(1);
+ double[][] array = LineReader.array(lines);
+ data.add(array);
+ addLabel(name, labels);
+ Util.verbose("array:\n" + toString(array));
+ CategoryDataset dataset = makeDataset(data);
+ plot(dataset, title, xlabel, ylabel, output);
+ private static CategoryDataset makeDataset(List<double[][]> data)
+ DefaultCategoryDataset result = new DefaultCategoryDataset();
+ //int j = 0;
+ for (double[][] d : data)
+ for (int i = 0; i < d.length; i++)
+ result.addValue((Number) d[i][1], "", String.valueOf(d[i][0]));
+ return result;
+ Generate simple plot.
+ @param collection The x,y data.
+ @param title Plot title.
+ @param xlabel X label text.
+ @param ylabel Y label text.
+ @param output EPS filename.
+ @return true/false depending if the method completed without error or not
+ public static boolean plot(CategoryDataset dataset,
+ String title, String xlabel,
+ String ylabel, String output)
+ EPSDocumentGraphics2D g2d = null;
+ Rectangle2D.Double rectangle = null;
+ OutputStream out = null;
+ try
+ out = new BufferedOutputStream(new FileOutputStream(output));
+ g2d = new EPSDocumentGraphics2D(false);
+ g2d.setGraphicContext
+ (new GraphicContext());
+ rectangle = new Rectangle2D.Double(0, 0, width, height);
+ g2d.setupDocument(out, width, height);
+ catch (IOException e)
+ System.err.println("Problem with file: " + output);
+ return false;
+ JFreeChart chart =
+ ChartFactory.createBarChart(title, xlabel, ylabel,
+ dataset, PlotOrientation.VERTICAL,
+ true, true, false);
+ setupPlot(chart, dataset);
+ chart.draw(g2d, rectangle);
+ try
+ g2d.finish();
+ catch (Exception e)
+ System.err.println("Error!" + e);
+ IOUtils.closeQuietly(out);
+ System.out.println("PLOTTED: " + output);
+ return true;
+ private static void setupPlot(JFreeChart chart,
+ CategoryDataset collection)
+ CategoryPlot plot = chart.getCategoryPlot();
+ Plots.setupLegend(chart, properties);
+ plot.setBackgroundPaint(Color.WHITE);
+ // BarRenderer.setDefaultShadowsVisible(false);
+ BarRenderer renderer = (BarRenderer) plot.getRenderer();
+ renderer.setGradientPaintTransformer(null);
+ renderer.setSeriesPaint(0, Color.red);
+ renderer.setSeriesPaint(1, Color.green);
+ plot.setRenderer(renderer);
+ // renderer.setShadowVisible(false);
+ Various plot properties. All are currently optional
+ Example.
+ Assume you want to plot a two-column table in file.data.
+ The first column is the x values and the second column
+ is the y values. See LineReader for details.
+ Your properties may include:
+ title = Plot
+ xlabel = size
+ ylabel = speed
+ label.file.data = legend text
+ shape.file.data = shape setting
+ width (output image width)
+ height (output image height)
+ xmin, xmax, ymin, ymax (auto-selected if not given)
+ bw (Black and white, true/false, default false)
+ legend.enabled (true/false, default true)
+ static void scanProperties()
+ title = properties.getProperty("title");
+ xlabel = properties.getProperty("xlabel");
+ ylabel = properties.getProperty("ylabel");
+ String tmp;
+ tmp = properties.getProperty("width");
+ if (tmp != null)
+ width = Integer.parseInt(tmp.trim());
+ tmp = properties.getProperty("height");
+ if (tmp != null)
+ height = Integer.parseInt(tmp.trim());
+ tmp = properties.getProperty("xmin");
+ if (tmp != null)
+ xmin = Double.parseDouble(tmp);
+ tmp = properties.getProperty("xmax");
+ if (tmp != null)
+ xmax = Double.parseDouble(tmp);
+ tmp = properties.getProperty("ymin");
+ if (tmp != null)
+ ymin = Double.parseDouble(tmp);
+ tmp = properties.getProperty("ymax");
+ if (tmp != null)
+ ymax = Double.parseDouble(tmp);
+ tmp = properties.getProperty("bw");
+ if (tmp != null)
+ bw = Boolean.parseBoolean(tmp);
+ tmp = properties.getProperty("legend.enabled");
+ if (tmp != null)
+ withLegend = Boolean.parseBoolean(tmp);
+ tmp = properties.getProperty("axis.x");
+ if (tmp != null)
+ axis_x_type = tmp;
+ tmp = properties.getProperty("axis.y");
+ if (tmp != null)
+ axis_y_type = tmp;
+ static void load(String propFile)
+ try
+ if (propFile.equals("-"))
+ properties.load(System.in);
+ else
+ properties.load(new FileInputStream(propFile));
+ System.err.println(e);
+ System.exit(1);
+ e.printStackTrace();
+ System.exit(1);
+ static void addLabel(String name, List<String> labels)
+ String label = properties.getProperty("label."+name);
+ if (label == null)
+ label = "";
+ labels.add(label);
+ static boolean showShape(String name)
+ String mode = properties.getProperty("shape."+name);
+ // System.out.println(mode);
+ if ("none".equals(mode))
+ return false;
+ return true;
+ static String toString(double[][] array)
+ StringBuilder sb = new StringBuilder();
+ for (int i = 0; i < array.length; i++)
+ double[] row = array[i];
+ for (int j = 0; j < row.length; j++)
+ sb.append(array[i][j]);
+ if (j < row.length-1)
+ sb.append(" ");
+ sb.append("\n");
+ return sb.toString();
Modified: usertools/plotter/src/plotter/Plots.java
--- usertools/plotter/src/plotter/Plots.java 2011-10-03 16:28:43 UTC (rev 5202)
+++ usertools/plotter/src/plotter/Plots.java 2011-10-03 17:46:44 UTC (rev 5203)
@@ -14,22 +14,22 @@
public class Plots
- static void setupLegend(JFreeChart chart,
- Properties properties)
- LegendTitle legend = chart.getLegend();
- Font font = getLegendFont(properties);
- if (font != null)
- legend.setItemFont(font);
+ static void setupLegend(JFreeChart chart,
+ Properties properties)
+ LegendTitle legend = chart.getLegend();
+ Font font = getLegendFont(properties);
+ if (font != null)
+ legend.setItemFont(font);
- static Font getLegendFont(Properties properties)
- Font result = null;
- String name = properties.getProperty("legend.font");
- if (name == null)
- return null;
- result = new Font(name, Font.PLAIN, 12);
- return result;
+ static Font getLegendFont(Properties properties)
+ Font result = null;
+ String name = properties.getProperty("legend.font");
+ if (name == null)
+ return null;
+ result = new Font(name, Font.PLAIN, 12);
+ return result;
Modified: usertools/plotter/src/plotter/Plotter.java
--- usertools/plotter/src/plotter/Plotter.java 2011-10-03 16:28:43 UTC (rev 5202)
+++ usertools/plotter/src/plotter/Plotter.java 2011-10-03 17:46:44 UTC (rev 5203)
@@ -1,13 +1,16 @@
package plotter;
import gnu.getopt.Getopt;
public class Plotter
public static void main(String[] args)
- Getopt plot = new Getopt( "Plotter", args, "sdh");
+ Getopt plot = new Getopt( "Plotter", args, "bdhs");
* Fix this check: Need to check to see if the specify one of the types of plots first
* then check to see if the argument counts is correct.
@@ -39,6 +42,14 @@
d.plotter( tmp );
break;
+ case 'b':
+ String props = args[1];
+ String output = args[2];
+ List<String> dataFiles = dataFileList(args, 3);
+ Bars.bars(props, output, dataFiles, true);
+ break;
/* Do not understand option for what graph */
default:
@@ -47,6 +58,14 @@
+ static List<String> dataFileList(String[] args, int start)
+ List<String> result = new ArrayList<String>(args.length);
+ for (int i = start; i < args.length; i++)
+ result.add(args[i]);
+ return result;
public static void usage()
System.err.println( "usage: [-s,-d] [<options>] <properties> <output> <data>*" );
More information about the Swift-commit
