[Swift-commit] r4533 - in trunk: etc src/org/griphyn/vdl/karajan src/org/griphyn/vdl/karajan/lib src/org/griphyn/vdl/util
wozniak at ci.uchicago.edu wozniak at ci.uchicago.edu
Fri May 27 12:26:44 CDT 2011
Author: wozniak
Date: 2011-05-27 12:26:44 -0500 (Fri, 27 May 2011)
New Revision: 4533
Modified:
   trunk/etc/log4j.properties
   trunk/src/org/griphyn/vdl/karajan/Loader.java
   trunk/src/org/griphyn/vdl/karajan/lib/VDLFunction.java
   trunk/src/org/griphyn/vdl/util/VDL2Config.java
Log:
Enable auto-insertion of input file text in log
May be disabled by changing log4j.logger.swift.textfiles
Modified: trunk/etc/log4j.properties
--- trunk/etc/log4j.properties	2011-05-27 17:21:44 UTC (rev 4532)
+++ trunk/etc/log4j.properties	2011-05-27 17:26:44 UTC (rev 4533)
@@ -11,12 +11,13 @@
 log4j.appender.FILE.layout=org.apache.log4j.PatternLayout
 log4j.appender.FILE.layout.ConversionPattern=%d{yyyy-MM-dd HH:mm:ss,SSSZZZZZ} %-5p %c{1} %m%n
-log4j.logger.swift=DEBUG
 log4j.logger.org.apache.axis.utils=ERROR
 # Swift
+log4j.logger.swift=DEBUG
+log4j.logger.swift.textfiles=DEBUG
 log4j.logger.org.globus.swift.trace=INFO
 log4j.logger.org.griphyn.vdl.karajan.Loader=DEBUG
 log4j.logger.org.griphyn.vdl.karajan.functions.ProcessBulkErrors=WARN
Modified: trunk/src/org/griphyn/vdl/karajan/Loader.java
--- trunk/src/org/griphyn/vdl/karajan/Loader.java	2011-05-27 17:21:44 UTC (rev 4532)
+++ trunk/src/org/griphyn/vdl/karajan/Loader.java	2011-05-27 17:26:44 UTC (rev 4533)
@@ -37,6 +37,7 @@
 import org.globus.cog.karajan.workflow.nodes.grid.AbstractGridNode;
 import org.globus.cog.util.ArgumentParser;
 import org.globus.cog.util.ArgumentParserException;
+import org.globus.cog.util.TextFileLoader;
 import org.globus.swift.data.Director;
 import org.griphyn.vdl.engine.Karajan;
 import org.griphyn.vdl.karajan.functions.ConfigProperty;
@@ -90,10 +91,10 @@
                 ap.usage();
                 System.exit(0);
-	    if (ap.isPresent(ARG_VERSION)){
-		ap.version();
-		System.exit(0);
+            if (ap.isPresent(ARG_VERSION)){
+            	ap.version();
+            	System.exit(0);
             if (ap.isPresent(ARG_MONITOR)) {
                 new Monitor().start();
@@ -175,7 +176,8 @@
             VariableStack stack = new LinkedStack(ec);
             VDL2Config config = loadConfig(ap, stack);
             addCommandLineProperties(config, ap);
+            debugSitesText(config);
             if (ap.isPresent(ARG_DRYRUN)) {
                 stack.setGlobal(CONST_VDL_OPERATION, VDL_OPERATION_DRYRUN);
@@ -226,7 +228,8 @@
         String cdmString = null;
         try {
             cdmString = ap.getStringValue(ARG_CDMFILE);
-            File cdmFile = new File(cdmString);
+            File cdmFile = new File(cdmString);
+            debugText("CDM FILE", cdmFile);
             Director.load(cdmFile);
         catch (IOException e) {
@@ -246,6 +249,7 @@
             ParsingException, IncorrectInvocationException,
             CompilationException, IOException {
         File swiftscript = new File(project);
+        debugText("SWIFTSCRIPT", swiftscript);
         String projectBase = project.substring(0, project.lastIndexOf('.'));
         File xml = new File(projectBase + ".xml");
         File kml = new File(projectBase + ".kml");
@@ -328,7 +332,44 @@
         return kml.getAbsolutePath();
-    private static void loadBuildVersion() {
+       Enter the text content of given files into the log
+       @throws IOException
+    public static void debugText(String name, File file) {
+    	Logger textLogger = Logger.getLogger("swift.textfiles");
+    	try {
+    		if (textLogger.isDebugEnabled()) {
+    			String text = TextFileLoader.loadFromFile(file);
+    			textLogger.debug("BEGIN " + name + ":\n" + text + "\n");
+    			textLogger.debug("END " + name + ":");
+    	catch (IOException e) {
+    		logger.warn("Could not open: " + file);
+    static void debugSitesText(VDL2Config config) {
+    	VDL2Config defaultConfig = null;
+    	try {
+			defaultConfig = VDL2Config.getDefaultConfig();
+		} catch (IOException e) {
+			logger.warn("Could not log sites file text");
+		String poolFile = config.getPoolFile();
+		String defaultPoolFile = defaultConfig.getPoolFile();
+		if (poolFile.equals(defaultPoolFile)) {
+			textLogger.debug("using default sites file");
+		else {
+			debugText("SITES", new File(poolFile));
+	private static void loadBuildVersion() {
         try {
             File f = new File(System.getProperty("swift.home")
                     + "/libexec/buildid.txt");
@@ -363,7 +404,9 @@
             Map.Entry e = (Map.Entry) i.next();
             String name = (String) e.getKey();
             if (ap.isPresent(name)) {
-                config.setProperty(name, ap.getStringValue(name));
+            	String value = ap.getStringValue(name);
+            	logger.debug("setting: " + name + " to: " + value);
+            	config.setProperty(name, value);
Modified: trunk/src/org/griphyn/vdl/karajan/lib/VDLFunction.java
--- trunk/src/org/griphyn/vdl/karajan/lib/VDLFunction.java	2011-05-27 17:21:44 UTC (rev 4532)
+++ trunk/src/org/griphyn/vdl/karajan/lib/VDLFunction.java	2011-05-27 17:26:44 UTC (rev 4533)
@@ -33,6 +33,7 @@
 import org.globus.swift.catalog.transformation.File;
 import org.globus.swift.catalog.types.TCType;
 import org.griphyn.vdl.karajan.AssertFailedException;
+import org.griphyn.vdl.karajan.Loader;
 import org.griphyn.vdl.karajan.TCCache;
 import org.griphyn.vdl.karajan.VDL2FutureException;
 import org.griphyn.vdl.karajan.WrapperMap;
@@ -608,6 +609,7 @@
 			TCCache tc = (TCCache) stack.firstFrame().getVar(TC);
 			if (tc == null) {
 				String prop = ConfigProperty.getProperty(VDL2ConfigProperties.TC_FILE, stack);
+				Loader.debugText("TC", new java.io.File(prop));
 				tc = new TCCache(File.getNonSingletonInstance(prop));
 				stack.firstFrame().setVar(TC, tc);
Modified: trunk/src/org/griphyn/vdl/util/VDL2Config.java
--- trunk/src/org/griphyn/vdl/util/VDL2Config.java	2011-05-27 17:21:44 UTC (rev 4532)
+++ trunk/src/org/griphyn/vdl/util/VDL2Config.java	2011-05-27 17:26:44 UTC (rev 4533)
@@ -40,7 +40,7 @@
 		return config.check();
-	private static synchronized VDL2Config getDefaultConfig() throws IOException {
+	public static synchronized VDL2Config getDefaultConfig() throws IOException {
 		if (config == null) {
 			config = new VDL2Config();
 			for (int i = 0; i < CONFIG_FILE_SEARCH_PATH.length; i++) {
