[Swift-commit] r4531 - in trunk: etc tests tests/providers tests/providers/persistent-coasters tests/providers/persistent-coasters/mcs
davidk at ci.uchicago.edu
Fri May 27 09:51:13 CDT 2011
Author: davidk
Date: 2011-05-27 09:51:12 -0500 (Fri, 27 May 2011)
New Revision: 4531
Added:
trunk/tests/providers/persistent-coasters/
trunk/tests/providers/persistent-coasters/mcs/
trunk/tests/providers/persistent-coasters/mcs/001-catsn.check.sh
trunk/tests/providers/persistent-coasters/mcs/001-catsn.clean.sh
trunk/tests/providers/persistent-coasters/mcs/001-catsn.setup.sh
trunk/tests/providers/persistent-coasters/mcs/001-catsn.swift
trunk/tests/providers/persistent-coasters/mcs/001-catsn.timeout
trunk/tests/providers/persistent-coasters/mcs/README
trunk/tests/providers/persistent-coasters/mcs/catsn.0001.out.expected
trunk/tests/providers/persistent-coasters/mcs/catsn.0002.out.expected
trunk/tests/providers/persistent-coasters/mcs/catsn.0003.out.expected
trunk/tests/providers/persistent-coasters/mcs/catsn.0004.out.expected
trunk/tests/providers/persistent-coasters/mcs/catsn.0005.out.expected
trunk/tests/providers/persistent-coasters/mcs/catsn.0006.out.expected
trunk/tests/providers/persistent-coasters/mcs/catsn.0007.out.expected
trunk/tests/providers/persistent-coasters/mcs/catsn.0008.out.expected
trunk/tests/providers/persistent-coasters/mcs/catsn.0009.out.expected
trunk/tests/providers/persistent-coasters/mcs/catsn.0010.out.expected
trunk/tests/providers/persistent-coasters/mcs/coaster-service.conf
trunk/tests/providers/persistent-coasters/mcs/data.txt
trunk/tests/providers/persistent-coasters/mcs/sites.template.xml
trunk/tests/providers/persistent-coasters/mcs/tc.template.data
trunk/tests/providers/persistent-coasters/mcs/title.txt
Modified:
trunk/etc/coaster-service.conf
trunk/tests/suite.sh
Log:
Provider tests for persistent coasters on MCS machines over ssh
Modified: trunk/etc/coaster-service.conf
--- trunk/etc/coaster-service.conf 2011-05-25 20:53:04 UTC (rev 4530)
+++ trunk/etc/coaster-service.conf 2011-05-27 14:51:12 UTC (rev 4531)
@@ -14,7 +14,7 @@
export WORKER_LOGGING=INFO
# Worker host names for ssh
-export WORKERS_HOSTS="host1 host2 host3"
+export WORKER_HOSTS="host1 host2 host3"
# Directory to keep log files, relative to working directory when launching start-coaster-service
export LOG_DIR=logs
Added: trunk/tests/providers/persistent-coasters/mcs/001-catsn.check.sh
--- trunk/tests/providers/persistent-coasters/mcs/001-catsn.check.sh (rev 0)
+++ trunk/tests/providers/persistent-coasters/mcs/001-catsn.check.sh 2011-05-27 14:51:12 UTC (rev 4531)
@@ -0,0 +1,12 @@
+#!/bin/bash
+set -x
+for count in `seq --format "%04.f" 1 1 10`
+do
+ [ -f catsn.$count.out ] || exit 1
+ CONTENTS1=$( cat catsn.$count.out.expected )
+ CONTENTS2=$( cat catsn.$count.out )
+ [[ $CONTENTS1 == $CONTENTS2 ]] || exit 1
+done
+exit 0
Property changes on: trunk/tests/providers/persistent-coasters/mcs/001-catsn.check.sh
___________________________________________________________________
Added: svn:executable
Added: trunk/tests/providers/persistent-coasters/mcs/001-catsn.clean.sh
--- trunk/tests/providers/persistent-coasters/mcs/001-catsn.clean.sh (rev 0)
+++ trunk/tests/providers/persistent-coasters/mcs/001-catsn.clean.sh 2011-05-27 14:51:12 UTC (rev 4531)
@@ -0,0 +1,4 @@
+#!/bin/bash
+stop-coaster-service
Property changes on: trunk/tests/providers/persistent-coasters/mcs/001-catsn.clean.sh
Added: trunk/tests/providers/persistent-coasters/mcs/001-catsn.setup.sh
--- trunk/tests/providers/persistent-coasters/mcs/001-catsn.setup.sh (rev 0)
+++ trunk/tests/providers/persistent-coasters/mcs/001-catsn.setup.sh 2011-05-27 14:51:12 UTC (rev 4531)
@@ -0,0 +1,5 @@
+#!/bin/bash
+cp -v $GROUP/data.txt . || exit 1
+cp -v $GROUP/*expected . || exit 1
+start-coaster-service || exit 1
Property changes on: trunk/tests/providers/persistent-coasters/mcs/001-catsn.setup.sh
Added: trunk/tests/providers/persistent-coasters/mcs/001-catsn.swift
--- trunk/tests/providers/persistent-coasters/mcs/001-catsn.swift (rev 0)
+++ trunk/tests/providers/persistent-coasters/mcs/001-catsn.swift 2011-05-27 14:51:12 UTC (rev 4531)
@@ -0,0 +1,12 @@
+type file;
+app (file o) cat (file i)
+ cat @i stdout=@o;
+file out[]<simple_mapper; location=".", prefix="catsn.",suffix=".out">;
+foreach j in [1:@toint(@arg("n","10"))] {
+ file data<"data.txt">;
+ out[j] = cat(data);
Added: trunk/tests/providers/persistent-coasters/mcs/001-catsn.timeout
--- trunk/tests/providers/persistent-coasters/mcs/001-catsn.timeout (rev 0)
+++ trunk/tests/providers/persistent-coasters/mcs/001-catsn.timeout 2011-05-27 14:51:12 UTC (rev 4531)
@@ -0,0 +1 @@
+180
Added: trunk/tests/providers/persistent-coasters/mcs/README
--- trunk/tests/providers/persistent-coasters/mcs/README (rev 0)
+++ trunk/tests/providers/persistent-coasters/mcs/README 2011-05-27 14:51:12 UTC (rev 4531)
@@ -0,0 +1 @@
+Before running this test, be sure to copy coaster-service.conf to your swift etc directory
Added: trunk/tests/providers/persistent-coasters/mcs/catsn.0001.out.expected
--- trunk/tests/providers/persistent-coasters/mcs/catsn.0001.out.expected (rev 0)
+++ trunk/tests/providers/persistent-coasters/mcs/catsn.0001.out.expected 2011-05-27 14:51:12 UTC (rev 4531)
@@ -0,0 +1 @@
+Hello world
Added: trunk/tests/providers/persistent-coasters/mcs/catsn.0002.out.expected
--- trunk/tests/providers/persistent-coasters/mcs/catsn.0002.out.expected (rev 0)
+++ trunk/tests/providers/persistent-coasters/mcs/catsn.0002.out.expected 2011-05-27 14:51:12 UTC (rev 4531)
@@ -0,0 +1 @@
+Hello world
Added: trunk/tests/providers/persistent-coasters/mcs/catsn.0003.out.expected
--- trunk/tests/providers/persistent-coasters/mcs/catsn.0003.out.expected (rev 0)
+++ trunk/tests/providers/persistent-coasters/mcs/catsn.0003.out.expected 2011-05-27 14:51:12 UTC (rev 4531)
@@ -0,0 +1 @@
+Hello world
Added: trunk/tests/providers/persistent-coasters/mcs/catsn.0004.out.expected
--- trunk/tests/providers/persistent-coasters/mcs/catsn.0004.out.expected (rev 0)
+++ trunk/tests/providers/persistent-coasters/mcs/catsn.0004.out.expected 2011-05-27 14:51:12 UTC (rev 4531)
@@ -0,0 +1 @@
+Hello world
Added: trunk/tests/providers/persistent-coasters/mcs/catsn.0005.out.expected
--- trunk/tests/providers/persistent-coasters/mcs/catsn.0005.out.expected (rev 0)
+++ trunk/tests/providers/persistent-coasters/mcs/catsn.0005.out.expected 2011-05-27 14:51:12 UTC (rev 4531)
@@ -0,0 +1 @@
+Hello world
Added: trunk/tests/providers/persistent-coasters/mcs/catsn.0006.out.expected
--- trunk/tests/providers/persistent-coasters/mcs/catsn.0006.out.expected (rev 0)
+++ trunk/tests/providers/persistent-coasters/mcs/catsn.0006.out.expected 2011-05-27 14:51:12 UTC (rev 4531)
@@ -0,0 +1 @@
+Hello world
Added: trunk/tests/providers/persistent-coasters/mcs/catsn.0007.out.expected
--- trunk/tests/providers/persistent-coasters/mcs/catsn.0007.out.expected (rev 0)
+++ trunk/tests/providers/persistent-coasters/mcs/catsn.0007.out.expected 2011-05-27 14:51:12 UTC (rev 4531)
@@ -0,0 +1 @@
+Hello world
Added: trunk/tests/providers/persistent-coasters/mcs/catsn.0008.out.expected
--- trunk/tests/providers/persistent-coasters/mcs/catsn.0008.out.expected (rev 0)
+++ trunk/tests/providers/persistent-coasters/mcs/catsn.0008.out.expected 2011-05-27 14:51:12 UTC (rev 4531)
@@ -0,0 +1 @@
+Hello world
Added: trunk/tests/providers/persistent-coasters/mcs/catsn.0009.out.expected
--- trunk/tests/providers/persistent-coasters/mcs/catsn.0009.out.expected (rev 0)
+++ trunk/tests/providers/persistent-coasters/mcs/catsn.0009.out.expected 2011-05-27 14:51:12 UTC (rev 4531)
@@ -0,0 +1 @@
+Hello world
Added: trunk/tests/providers/persistent-coasters/mcs/catsn.0010.out.expected
--- trunk/tests/providers/persistent-coasters/mcs/catsn.0010.out.expected (rev 0)
+++ trunk/tests/providers/persistent-coasters/mcs/catsn.0010.out.expected 2011-05-27 14:51:12 UTC (rev 4531)
@@ -0,0 +1 @@
+Hello world
Added: trunk/tests/providers/persistent-coasters/mcs/coaster-service.conf
--- trunk/tests/providers/persistent-coasters/mcs/coaster-service.conf (rev 0)
+++ trunk/tests/providers/persistent-coasters/mcs/coaster-service.conf 2011-05-27 14:51:12 UTC (rev 4531)
@@ -0,0 +1,33 @@
+# Keep all interesting settings in one place
+# User should modify this to fit environment
+# Location of SWIFT. If empty, PATH is referenced
+export SWIFT=
+# Where to place/launch worker.pl on the remote machine for sites.xml
+export WORKER_WORK=/home/${USER}/work
+# How to launch workers: local, ssh, or cobalt
+export WORKER_MODE=ssh
+# Worker logging setting passed to worker.pl for sites.xml
+export WORKER_LOGGING=INFO
+# Worker host names for ssh
+export WORKER_HOSTS="crush.mcs.anl.gov thwomp.mcs.anl.gov stomp.mcs.anl.gov crank.mcs.anl.gov steamroller.mcs.anl.gov grind.mcs.anl.gov churn.mcs.anl.gov trounce.mcs.anl.gov thrash.mcs.anl.gov vanquish.mcs.anl.gov"
+# Directory to keep log files, relative to working directory when launching start-coaster-service
+export LOG_DIR=logs
+# Manually define ports. If not specified, ports will be automatically generated
+export LOCAL_PORT=
+export SERVICE_PORT=
+# start-coaster-service tries to automatically detect IP address. Specify here if auto detection is not working correctly
+export IPADDR=
+# Below are various settings to give information about how to create sites.xml
+export work=$HOME/work
+export queue=prod-devel
+export maxtime=20
+export nodes=64
Added: trunk/tests/providers/persistent-coasters/mcs/data.txt
--- trunk/tests/providers/persistent-coasters/mcs/data.txt (rev 0)
+++ trunk/tests/providers/persistent-coasters/mcs/data.txt 2011-05-27 14:51:12 UTC (rev 4531)
@@ -0,0 +1 @@
+Hello world
Added: trunk/tests/providers/persistent-coasters/mcs/sites.template.xml
--- trunk/tests/providers/persistent-coasters/mcs/sites.template.xml (rev 0)
+++ trunk/tests/providers/persistent-coasters/mcs/sites.template.xml 2011-05-27 14:51:12 UTC (rev 4531)
@@ -0,0 +1,13 @@
+<config>
+ <pool handle="persistent-coasters">
+ <execution provider="coaster-persistent"
+ url="_EXECUTION_URL_"
+ jobmanager="local:local"/>
+ <profile namespace="globus" key="workerManager">passive</profile>
+ <profile namespace="globus" key="workersPerNode">4</profile>
+ <profile key="jobThrottle" namespace="karajan">.03</profile>
+ <profile namespace="karajan" key="initialScore">10000</profile>
+ <filesystem provider="local" url="none" />
+ <workdirectory>_WORK_</workdirectory>
+ </pool>
+</config>
Property changes on: trunk/tests/providers/persistent-coasters/mcs/sites.template.xml
Added: trunk/tests/providers/persistent-coasters/mcs/tc.template.data
--- trunk/tests/providers/persistent-coasters/mcs/tc.template.data (rev 0)
+++ trunk/tests/providers/persistent-coasters/mcs/tc.template.data 2011-05-27 14:51:12 UTC (rev 4531)
@@ -0,0 +1,7 @@
+persistent-coasters echo /bin/echo INSTALLED INTEL32::LINUX
+persistent-coasters cat /bin/cat INSTALLED INTEL32::LINUX
+persistent-coasters ls /bin/ls INSTALLED INTEL32::LINUX
+persistent-coasters grep /bin/grep INSTALLED INTEL32::LINUX
+persistent-coasters sort /bin/sort INSTALLED INTEL32::LINUX
+persistent-coasters paste /bin/paste INSTALLED INTEL32::LINUX
+persistent-coasters wc /usr/bin/wc INSTALLED INTEL32::LINUX
Added: trunk/tests/providers/persistent-coasters/mcs/title.txt
--- trunk/tests/providers/persistent-coasters/mcs/title.txt (rev 0)
+++ trunk/tests/providers/persistent-coasters/mcs/title.txt 2011-05-27 14:51:12 UTC (rev 4531)
@@ -0,0 +1 @@
+MCS Machines with Persistent Coasters and SSH
Modified: trunk/tests/suite.sh
--- trunk/tests/suite.sh 2011-05-25 20:53:04 UTC (rev 4530)
+++ trunk/tests/suite.sh 2011-05-27 14:51:12 UTC (rev 4531)
@@ -892,6 +892,7 @@
echo "s at _HOST_@$GLOBUS_HOSTNAME@"
echo "s at _PROJECT_@$PROJECT@"
echo "s at _QUEUE_@$QUEUE@"
+ echo "s at _EXECUTION_URL_@$EXECUTION_URL@"
} > $RUNDIR/sites.sed
return 0
More information about the Swift-commit
