[Swift-commit] r4523 - trunk/tests/providers/local-pbs-coasters/crow/big
wozniak at ci.uchicago.edu
Mon May 23 15:43:21 CDT 2011
Author: wozniak
Date: 2011-05-23 15:43:21 -0500 (Mon, 23 May 2011)
New Revision: 4523
Added:
trunk/tests/providers/local-pbs-coasters/crow/big/201-cps.check.sh
trunk/tests/providers/local-pbs-coasters/crow/big/201-cps.clean.sh
trunk/tests/providers/local-pbs-coasters/crow/big/201-cps.setup.sh
trunk/tests/providers/local-pbs-coasters/crow/big/201-cps.swift
trunk/tests/providers/local-pbs-coasters/crow/big/201-cps.timeout
trunk/tests/providers/local-pbs-coasters/crow/big/cps.sh
trunk/tests/providers/local-pbs-coasters/crow/big/data.txt
trunk/tests/providers/local-pbs-coasters/crow/big/sites.template.xml
trunk/tests/providers/local-pbs-coasters/crow/big/title.txt
Log:
Multi-node Crow test that can easily be made bigger
Added: trunk/tests/providers/local-pbs-coasters/crow/big/201-cps.check.sh
--- trunk/tests/providers/local-pbs-coasters/crow/big/201-cps.check.sh (rev 0)
+++ trunk/tests/providers/local-pbs-coasters/crow/big/201-cps.check.sh 2011-05-23 20:43:21 UTC (rev 4523)
@@ -0,0 +1,9 @@
+#!/bin/sh
+set -x
+COUNT=$( ls 201-output* | wc -l )
+[[ $COUNT == 40 ]] || exit 1
+exit 0
Property changes on: trunk/tests/providers/local-pbs-coasters/crow/big/201-cps.check.sh
___________________________________________________________________
Added: svn:executable
Added: trunk/tests/providers/local-pbs-coasters/crow/big/201-cps.clean.sh
--- trunk/tests/providers/local-pbs-coasters/crow/big/201-cps.clean.sh (rev 0)
+++ trunk/tests/providers/local-pbs-coasters/crow/big/201-cps.clean.sh 2011-05-23 20:43:21 UTC (rev 4523)
@@ -0,0 +1,7 @@
+#!/bin/sh
+set -x
+rm -rv 201-output-[12]-*.txt || exit 1
+exit 0
Property changes on: trunk/tests/providers/local-pbs-coasters/crow/big/201-cps.clean.sh
Added: trunk/tests/providers/local-pbs-coasters/crow/big/201-cps.setup.sh
--- trunk/tests/providers/local-pbs-coasters/crow/big/201-cps.setup.sh (rev 0)
+++ trunk/tests/providers/local-pbs-coasters/crow/big/201-cps.setup.sh 2011-05-23 20:43:21 UTC (rev 4523)
@@ -0,0 +1,12 @@
+#!/bin/sh
+set -x
+ uname -a
+ date
+} > 201-input-1.txt
+cp -v 201-input-1.txt 201-input-2.txt
+exit 0
Property changes on: trunk/tests/providers/local-pbs-coasters/crow/big/201-cps.setup.sh
Added: trunk/tests/providers/local-pbs-coasters/crow/big/201-cps.swift
--- trunk/tests/providers/local-pbs-coasters/crow/big/201-cps.swift (rev 0)
+++ trunk/tests/providers/local-pbs-coasters/crow/big/201-cps.swift 2011-05-23 20:43:21 UTC (rev 4523)
@@ -0,0 +1,24 @@
+type file;
+app (file o) cps(file i, int s)
+ cps @o @i s;
+file input1<"201-input-1.txt">;
+file input2<"201-input-2.txt">;
+foreach i in [1:20]
+ string s = @strcat("201-output-1-", i, ".txt");
+ file output<single_file_mapper;file=s>;
+ output = cps(input1, i);
+foreach j in [1:20]
+ string s = @strcat("201-output-2-", j, ".txt");
+ output = cps(input2, 10+j);
Property changes on: trunk/tests/providers/local-pbs-coasters/crow/big/201-cps.swift
Added: trunk/tests/providers/local-pbs-coasters/crow/big/201-cps.timeout
--- trunk/tests/providers/local-pbs-coasters/crow/big/201-cps.timeout (rev 0)
+++ trunk/tests/providers/local-pbs-coasters/crow/big/201-cps.timeout 2011-05-23 20:43:21 UTC (rev 4523)
@@ -0,0 +1 @@
+1000
Added: trunk/tests/providers/local-pbs-coasters/crow/big/cps.sh
--- trunk/tests/providers/local-pbs-coasters/crow/big/cps.sh (rev 0)
+++ trunk/tests/providers/local-pbs-coasters/crow/big/cps.sh 2011-05-23 20:43:21 UTC (rev 4523)
@@ -0,0 +1,9 @@
+#!/bin/sh
+DEST=$1
+SRC=$2
+DURATION=$3
+sleep $DURATION
+cp -v $SRC $DEST
Property changes on: trunk/tests/providers/local-pbs-coasters/crow/big/cps.sh
Copied: trunk/tests/providers/local-pbs-coasters/crow/big/data.txt (from rev 4516, trunk/tests/providers/local-pbs-coasters/crow/data.txt)
--- trunk/tests/providers/local-pbs-coasters/crow/big/data.txt (rev 0)
+++ trunk/tests/providers/local-pbs-coasters/crow/big/data.txt 2011-05-23 20:43:21 UTC (rev 4523)
@@ -0,0 +1 @@
+HELLO
Added: trunk/tests/providers/local-pbs-coasters/crow/big/sites.template.xml
--- trunk/tests/providers/local-pbs-coasters/crow/big/sites.template.xml (rev 0)
+++ trunk/tests/providers/local-pbs-coasters/crow/big/sites.template.xml 2011-05-23 20:43:21 UTC (rev 4523)
@@ -0,0 +1,29 @@
+<config>
+<import file="sys.xml"/>
+<set name="wdir" value="_WORK_"/>
+<pool handle="crow">
+ <execution jobmanager="local:pbs" provider="coaster" url="none"/>
+ <filesystem provider="local" url="none" />
+ <profile namespace="globus" key="maxWallTime">1</profile>
+ <profile namespace="globus" key="maxTime">7200</profile>
+ <profile namespace="globus" key="providerAttributes">
+ pbs.aprun;pbs.mpp;depth=6
+ </profile>
+ <profile key="jobsPerNode" namespace="globus">6</profile>
+ <profile key="slots" namespace="globus">2</profile>
+ <profile key="nodeGranularity" namespace="globus">4</profile>
+ <profile key="maxNodes" namespace="globus">16</profile>
+ <profile key="workerLoggingLevel" namespace="globus">DEBUG</profile>
+ <profile key="workerLoggingDirectory" namespace="globus">{wdir}</profile>
+ <profile key="jobThrottle" namespace="karajan">5.99</profile>
+ <profile key="initialScore" namespace="karajan">10000</profile>
+ <workdirectory>{wdir}</workdirectory>
+</pool>
+</config>
+<!-- RESERVATIONS:
+Add something like this to your providerAttributes:
+pbs.resources=advres=modFTDock.47 -->
Copied: trunk/tests/providers/local-pbs-coasters/crow/big/title.txt (from rev 4518, trunk/tests/providers/local-pbs-coasters/crow/title.txt)
--- trunk/tests/providers/local-pbs-coasters/crow/big/title.txt (rev 0)
+++ trunk/tests/providers/local-pbs-coasters/crow/big/title.txt 2011-05-23 20:43:21 UTC (rev 4523)
@@ -0,0 +1 @@
+Local PBS Coasters: Crow big
More information about the Swift-commit
