[Swift-commit] r4503 - trunk/tests/providers/local-coasters
wozniak at ci.uchicago.edu
Mon May 23 09:40:28 CDT 2011
Author: wozniak
Date: 2011-05-23 09:40:27 -0500 (Mon, 23 May 2011)
New Revision: 4503
Added:
trunk/tests/providers/local-coasters/201-cp.check.sh
trunk/tests/providers/local-coasters/201-cp.clean.sh
trunk/tests/providers/local-coasters/201-cp.setup.sh
trunk/tests/providers/local-coasters/201-cp.swift
trunk/tests/providers/local-coasters/201-input-1.txt
Log:
Multi-job local Coasters test
Added: trunk/tests/providers/local-coasters/201-cp.check.sh
--- trunk/tests/providers/local-coasters/201-cp.check.sh (rev 0)
+++ trunk/tests/providers/local-coasters/201-cp.check.sh 2011-05-23 14:40:27 UTC (rev 4503)
@@ -0,0 +1,9 @@
+#!/bin/sh
+set -x
+COUNT=$( ls 201-output* | grep -c )
+[[ ${COUNT} == 40 ]] || exit 1
+exit 0
Property changes on: trunk/tests/providers/local-coasters/201-cp.check.sh
___________________________________________________________________
Added: svn:executable
Added: trunk/tests/providers/local-coasters/201-cp.clean.sh
--- trunk/tests/providers/local-coasters/201-cp.clean.sh (rev 0)
+++ trunk/tests/providers/local-coasters/201-cp.clean.sh 2011-05-23 14:40:27 UTC (rev 4503)
@@ -0,0 +1,7 @@
+#!/bin/sh
+set -x
+rm -rv 201-output-[12]-*.txt || exit 1
+exit 0
Property changes on: trunk/tests/providers/local-coasters/201-cp.clean.sh
Added: trunk/tests/providers/local-coasters/201-cp.setup.sh
--- trunk/tests/providers/local-coasters/201-cp.setup.sh (rev 0)
+++ trunk/tests/providers/local-coasters/201-cp.setup.sh 2011-05-23 14:40:27 UTC (rev 4503)
@@ -0,0 +1,12 @@
+#!/bin/sh
+set -x
+ uname -a
+ date
+} > 201-input-1.txt
+cp -v 201-input-1.txt 201-input-2.txt
+exit 0
Property changes on: trunk/tests/providers/local-coasters/201-cp.setup.sh
Added: trunk/tests/providers/local-coasters/201-cp.swift
--- trunk/tests/providers/local-coasters/201-cp.swift (rev 0)
+++ trunk/tests/providers/local-coasters/201-cp.swift 2011-05-23 14:40:27 UTC (rev 4503)
@@ -0,0 +1,24 @@
+type file;
+app (file o) cp(file i)
+ cp @i @o;
+file input1<"201-input-1.txt">;
+file input2<"201-input-2.txt">;
+foreach i in [1:20]
+ string s = @strcat("201-output-1-", i, ".txt");
+ file output<single_file_mapper;file=s>;
+ output = cp(input1);
+foreach j in [1:20]
+ string s = @strcat("201-output-2-", j, ".txt");
+ output = cp(input2);
Property changes on: trunk/tests/providers/local-coasters/201-cp.swift
Added: trunk/tests/providers/local-coasters/201-input-1.txt
--- trunk/tests/providers/local-coasters/201-input-1.txt (rev 0)
+++ trunk/tests/providers/local-coasters/201-input-1.txt 2011-05-23 14:40:27 UTC (rev 4503)
@@ -0,0 +1,2 @@
+Linux wozniak-desktop 2.6.32-30-generic #59-Ubuntu SMP Tue Mar 1 21:30:46 UTC 2011 x86_64 GNU/Linux
+Tue Mar 22 14:02:02 CDT 2011
More information about the Swift-commit
