[Swift-commit] r4481 - trunk
davidk at ci.uchicago.edu
Mon May 16 14:41:02 CDT 2011
Author: davidk
Date: 2011-05-16 14:41:02 -0500 (Mon, 16 May 2011)
New Revision: 4481
Modified:
trunk/build.xml
Log:
Updated build.xml to build docs
Modified: trunk/build.xml
--- trunk/build.xml 2011-05-16 19:38:01 UTC (rev 4480)
+++ trunk/build.xml 2011-05-16 19:41:02 UTC (rev 4481)
@@ -55,6 +55,8 @@
fixeol:
change newlines to the unix standard.
+ docs:
+ Build Swift documentation from asciidoc txt files
</echo>
</target>
@@ -87,7 +89,6 @@
<chmod perm="+x" file="${dist.dir}/bin/swiftconfig"/>
<chmod perm="+x" file="${dist.dir}/bin/swiftrun"/>
<chmod perm="+x" file="${dist.dir}/bin/gensites"/>
- <chmod perm="+x" file="${dist.dir}/bin/chxml"/>
<chmod perm="+x" file="${dist.dir}/libexec/log-processing/active-state-transitions"/>
<chmod perm="+x" file="${dist.dir}/libexec/log-processing/add-runid-as-prefix"/>
<chmod perm="+x" file="${dist.dir}/libexec/log-processing/affine-transform"/>
@@ -261,6 +262,15 @@
</target>
+ <!-- Docs -->
+ <target name="docs">
+ <property name="docs.out" value="docs/"></property>
+ <exec executable="docs/build_docs.sh">
+ <arg value="${docs.out}"></arg>
+ </exec>
+ </target>
<!-- Compile -->
@@ -367,7 +377,7 @@
<ant antfile="${main.buildfile}" target="module.package"/>
</target>
- <target name="generateVersion" unless="no.version">
+ <target name="generateVersion">
<echo file="libexec/version.txt">Swift ${version} </echo>
<exec os="Linux, Mac OS X" executable="libexec/svn-revision" append="true" output="libexec/version.txt"/>
<exec os="Linux, Mac OS X" executable="libexec/generate-buildid" append="false" output="libexec/buildid.txt"/>
More information about the Swift-commit
