[Swift-commit] r4467 - in trunk/src/org/griphyn/vdl: karajan mapping
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Thu May 12 16:17:42 CDT 2011
Author: hategan
Date: 2011-05-12 16:17:41 -0500 (Thu, 12 May 2011)
New Revision: 4467
Modified:
   trunk/src/org/griphyn/vdl/karajan/ArrayIndexFutureList.java
   trunk/src/org/griphyn/vdl/karajan/DSHandleFutureWrapper.java
   trunk/src/org/griphyn/vdl/mapping/AbstractDataNode.java
Log:
a better (hopefully) implementation of listeners
Modified: trunk/src/org/griphyn/vdl/karajan/ArrayIndexFutureList.java
--- trunk/src/org/griphyn/vdl/karajan/ArrayIndexFutureList.java	2011-05-12 21:16:03 UTC (rev 4466)
+++ trunk/src/org/griphyn/vdl/karajan/ArrayIndexFutureList.java	2011-05-12 21:17:41 UTC (rev 4467)
@@ -11,7 +11,6 @@
 import org.globus.cog.karajan.stack.VariableNotFoundException;
 import org.globus.cog.karajan.stack.VariableStack;
-import org.globus.cog.karajan.workflow.ExecutionException;
 import org.globus.cog.karajan.workflow.events.EventTargetPair;
 import org.globus.cog.karajan.workflow.futures.FutureEvaluationException;
 import org.globus.cog.karajan.workflow.futures.FutureIterator;
@@ -19,18 +18,17 @@
 import org.globus.cog.karajan.workflow.futures.FutureListener;
 import org.globus.cog.karajan.workflow.futures.FutureNotYetAvailable;
 import org.globus.cog.karajan.workflow.futures.ListenerStackPair;
-import org.globus.cog.util.CopyOnWriteArrayList;
 import org.griphyn.vdl.mapping.DSHandle;
 import org.griphyn.vdl.mapping.DSHandleListener;
 public class ArrayIndexFutureList implements FutureList, DSHandleListener {
     private ArrayList<Object> keys;
-    private Map values;
+    private Map<?, ?> values;
     private boolean closed;
-    private CopyOnWriteArrayList<ListenerStackPair> listeners;
+    private ArrayList<ListenerStackPair> listeners;
     private FutureEvaluationException exception;
-    public ArrayIndexFutureList(DSHandle handle, Map values) {
+    public ArrayIndexFutureList(DSHandle handle, Map<?, ?> values) {
         this.values = values;
         keys = new ArrayList<Object>();
         handle.addListener(this);
@@ -93,7 +91,7 @@
     public synchronized void addModificationAction(FutureListener target,
             VariableStack stack) {
         if (listeners == null) {
-            listeners = new CopyOnWriteArrayList<ListenerStackPair>();
+            listeners = new ArrayList<ListenerStackPair>();
         listeners.add(new ListenerStackPair(target, stack));
@@ -102,22 +100,20 @@
-    private synchronized void notifyListeners() {
-        if (listeners == null) {
-            return;
+    private void notifyListeners() {
+        ArrayList<ListenerStackPair> l;
+        synchronized (this) {
+            if (listeners == null) {
+                return;
+            l = listeners;
+            listeners = null;
-        Iterator<ListenerStackPair> i = listeners.iterator();
-        try {
-            while (i.hasNext()) {
-                ListenerStackPair etp = i.next();
-                i.remove();
-                etp.listener.futureModified(this, etp.stack);
+        for (ListenerStackPair lsp : l) {
+            lsp.listener.futureModified(this, lsp.stack);
-        finally {
-            listeners.release();
     public EventTargetPair[] getListenerEvents() {
Modified: trunk/src/org/griphyn/vdl/karajan/DSHandleFutureWrapper.java
--- trunk/src/org/griphyn/vdl/karajan/DSHandleFutureWrapper.java	2011-05-12 21:16:03 UTC (rev 4466)
+++ trunk/src/org/griphyn/vdl/karajan/DSHandleFutureWrapper.java	2011-05-12 21:17:41 UTC (rev 4467)
@@ -4,10 +4,10 @@
 package org.griphyn.vdl.karajan;
 import java.util.LinkedList;
+import java.util.List;
-import org.globus.cog.karajan.workflow.events.EventBus;
 import org.globus.cog.karajan.workflow.futures.Future;
@@ -62,20 +62,21 @@
-			return;
+	    List<ListenerStackPair> l;
+	    synchronized(this) {
+	            return;
+	        l = listeners;
+	        listeners = null;
+			WaitingThreadsMonitor.removeThread(lsp.stack);
+			lsp.listener.futureModified(DSHandleFutureWrapper.this, lsp.stack);
-		while (!listeners.isEmpty()) {
-			final ListenerStackPair etp = listeners.removeFirst();
-			WaitingThreadsMonitor.removeThread(etp.stack);
-			EventBus.post(new Runnable() {
-                public void run() {
-                    etp.listener.futureModified(DSHandleFutureWrapper.this, etp.stack);
-		listeners = null;
 	public synchronized int listenerCount() {
Modified: trunk/src/org/griphyn/vdl/mapping/AbstractDataNode.java
--- trunk/src/org/griphyn/vdl/mapping/AbstractDataNode.java	2011-05-12 21:16:03 UTC (rev 4466)
+++ trunk/src/org/griphyn/vdl/mapping/AbstractDataNode.java	2011-05-12 21:17:41 UTC (rev 4467)
@@ -3,23 +3,18 @@
 package org.griphyn.vdl.mapping;
-import org.griphyn.vdl.karajan.Loader;
 import java.util.ArrayList;
 import java.util.Collection;
 import java.util.HashMap;
-import java.util.Iterator;
-import java.util.LinkedList;
 import java.util.Map;
 import org.apache.log4j.Logger;
+import org.griphyn.vdl.karajan.Loader;
+import org.griphyn.vdl.karajan.VDL2FutureException;
 import org.griphyn.vdl.type.Field;
 import org.griphyn.vdl.type.Type;
 import org.griphyn.vdl.type.Types;
-import org.griphyn.vdl.karajan.VDL2FutureException;
 import org.griphyn.vdl.util.VDL2Config;
@@ -573,17 +568,25 @@
-    protected synchronized void notifyListeners() {
-        if (listeners != null) {
-            for (DSHandleListener listener : listeners) {
-                if (logger.isDebugEnabled()) {
-                    logger.debug("Notifying listener \"" + listener
-                        + "\" about \"" + getIdentifyingString() + "\"");
-                listener.handleClosed(this);
+    protected void notifyListeners() {
+        List<DSHandleListener> l;
+                return;
+            l = listeners;
             listeners = null;
+        for (DSHandleListener listener : l) {
+            if (logger.isDebugEnabled()) {
+                logger.debug("Notifying listener \"" + listener
+                    + "\" about \"" + getIdentifyingString() + "\"");
+            listener.handleClosed(this);
     public String getIdentifier() {
