[Swift-commit] r4452 - SwiftApps/SwiftR/Swift/exec
tga at ci.uchicago.edu
Fri May 6 16:17:29 CDT 2011
Author: tga
Date: 2011-05-06 16:17:29 -0500 (Fri, 06 May 2011)
New Revision: 4452
Modified:
SwiftApps/SwiftR/Swift/exec/start-swift
Log:
improved error message when swift fails to start correctly.
Modified: SwiftApps/SwiftR/Swift/exec/start-swift
--- SwiftApps/SwiftR/Swift/exec/start-swift 2011-05-06 19:49:43 UTC (rev 4451)
+++ SwiftApps/SwiftR/Swift/exec/start-swift 2011-05-06 21:17:29 UTC (rev 4452)
@@ -565,6 +565,7 @@
# Standard clenuup actions
function stdcleanup_start {
# don't accept any more requests: unlink fifo from filesystem
+ echo stdcleanup_start 1&>2
if [ -p requestpipe ]; then
rm requestpipe
fi
@@ -727,9 +728,17 @@
exitcode=$?
# Do any cleanup if swift exits in this manner
if [ "$exitcode" != 0 ]; then
- echo "error: Swift exited unexpectedly with $exitcode" > resultpipe &
- echopid=$!
- sleep 5
- kill $echopid &> /dev/null
+ echo "error: Swift exited unexpectedly with return code $exitcode"
+ if [ "$keepdir" = TRUE ]; then
+ echo "See logs in $trundir for more information"
+ else
+ echo "Turn on keep work option to retain logs"
+ fi
+ ( echo "error: swift exited unexpectedly with return code $exitcode" > resultpipe
+ echopid=$!
+ sleep 5
+ kill $echopid
+ ) &> /dev/null &
fi
More information about the Swift-commit
