[Swift-commit] r4231 - trunk/src/org/griphyn/vdl/karajan/lib/swiftscript
wozniak at ci.uchicago.edu wozniak at ci.uchicago.edu
Thu Mar 31 13:52:02 CDT 2011
Author: wozniak
Date: 2011-03-31 13:52:02 -0500 (Thu, 31 Mar 2011)
New Revision: 4231
Modified:
   trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java
Log:
Whitespace and warning fixes
Modified: trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java
--- trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java	2011-03-30 17:57:26 UTC (rev 4230)
+++ trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java	2011-03-31 18:52:02 UTC (rev 4231)
@@ -1,8 +1,6 @@
 package org.griphyn.vdl.karajan.lib.swiftscript;
 import java.io.IOException;
-import java.util.List;
-import java.util.ArrayList;
 import java.util.regex.Matcher;
 import java.util.regex.Pattern;
@@ -54,9 +52,10 @@
 		setArguments("swiftscript_length", new Arg[] { Arg.VARGS });
-	private static final Logger traceLogger = Logger.getLogger("org.globus.swift.trace");
-	public DSHandle swiftscript_trace(VariableStack stack) throws ExecutionException, NoSuchTypeException,
-			InvalidPathException {
+	private static final Logger traceLogger =
+	    Logger.getLogger("org.globus.swift.trace");
+	public DSHandle swiftscript_trace(VariableStack stack)
+	throws ExecutionException {
 		DSHandle[] args = SwiftArg.VARGS.asDSHandleArray(stack);
@@ -72,8 +71,8 @@
 		return null;
-	public DSHandle swiftscript_strcat(VariableStack stack) throws ExecutionException, NoSuchTypeException,
+	public DSHandle swiftscript_strcat(VariableStack stack)
 		Object[] args = SwiftArg.VARGS.asArray(stack);
 		int provid = VDLFunction.nextProvenanceID();
 		StringBuffer buf = new StringBuffer();
@@ -87,7 +86,7 @@
 			if(VDL2Config.getConfig().getProvenanceLog()) {
 				DSHandle[] provArgs = SwiftArg.VARGS.asDSHandleArray(stack);
 				for (int i = 0; i < provArgs.length; i++) {
-					VDLFunction.logProvenanceParameter(provid, (DSHandle)provArgs[i], ""+i);
+					VDLFunction.logProvenanceParameter(provid, provArgs[i], ""+i);
 				VDLFunction.logProvenanceResult(provid, handle, "strcat");
@@ -97,8 +96,8 @@
 		return handle;
-	public DSHandle swiftscript_strcut(VariableStack stack) throws ExecutionException, NoSuchTypeException,
+	public DSHandle swiftscript_strcut(VariableStack stack)
 		String inputString = TypeUtil.toString(PA_INPUT.getValue(stack));
 		String pattern = TypeUtil.toString(PA_PATTERN.getValue(stack));
@@ -131,9 +130,8 @@
 		return handle;
-    public DSHandle swiftscript_strstr(VariableStack stack) throws ExecutionException, NoSuchTypeException,
+    public DSHandle swiftscript_strstr(VariableStack stack)
         if (logger.isDebugEnabled()) {
@@ -147,8 +145,9 @@
         return handle;
-	public DSHandle swiftscript_strsplit(VariableStack stack) throws ExecutionException, NoSuchTypeException,
+	public DSHandle swiftscript_strsplit(VariableStack stack)
+	throws ExecutionException, InvalidPathException {
 		String str = TypeUtil.toString(PA_INPUT.getValue(stack));
@@ -167,8 +166,8 @@
 		return handle;
-	public DSHandle swiftscript_regexp(VariableStack stack) throws ExecutionException, NoSuchTypeException,
+	public DSHandle swiftscript_regexp(VariableStack stack)
 		String transform = TypeUtil.toString(PA_TRANSFORM.getValue(stack));
@@ -204,8 +203,8 @@
 		return handle;
-	public DSHandle swiftscript_toint(VariableStack stack) throws ExecutionException, NoSuchTypeException,
+	public DSHandle swiftscript_toint(VariableStack stack)
 		int i = inputString.indexOf(".");
 		if( i >= 0 )
@@ -230,8 +229,8 @@
 		return handle;
-	public DSHandle swiftscript_tofloat(VariableStack stack) throws ExecutionException, NoSuchTypeException,
+	public DSHandle swiftscript_tofloat(VariableStack stack)
 		DSHandle handle = new RootDataNode(Types.FLOAT);
@@ -253,8 +252,8 @@
 	 * Takes in a float and formats to desired precision and returns a string
-	public DSHandle swiftscript_format(VariableStack stack) throws ExecutionException, NoSuchTypeException,
+	public DSHandle swiftscript_format(VariableStack stack)
 	    String inputFormat = TypeUtil.toString(PA_TRANSFORM.getValue(stack));
 	    DSHandle handle = new RootDataNode(Types.STRING);
@@ -273,8 +272,8 @@
 	 * Takes in an int and pads zeros to the left and returns a string
-	public DSHandle swiftscript_pad(VariableStack stack) throws ExecutionException, NoSuchTypeException,
+	public DSHandle swiftscript_pad(VariableStack stack)
@@ -283,7 +282,8 @@
 	    int zeros_to_pad = Integer.parseInt(inputFormat);
 	    zeros_to_pad += num_length;
-	    String output = String.format("%0"+zeros_to_pad+"d", Integer.parseInt(inputString));
+	    String output = String.format("%0"+zeros_to_pad+"d",
+	                                  Integer.parseInt(inputString));
 	    handle.setValue(output);
 	    handle.closeShallow();
@@ -295,17 +295,16 @@
 	public DSHandle swiftscript_tostring(VariableStack stack)
-                throws ExecutionException, NoSuchTypeException,
-                Object input = PA_INPUT.getValue(stack);
-                DSHandle handle = new RootDataNode(Types.STRING);
-                handle.setValue(""+input);
-                handle.closeShallow();
-                return handle;
+	    Object input = PA_INPUT.getValue(stack);
+	    DSHandle handle = new RootDataNode(Types.STRING);
+	    handle.setValue(""+input);
+	    handle.closeShallow();
+	    return handle;
 	public DSHandle swiftscript_dirname(VariableStack stack)
-	throws ExecutionException, NoSuchTypeException, InvalidPathException {
 	    DSHandle handle;
 	    try
@@ -326,12 +325,14 @@
-	 * This is copied from swiftscript_dirname. Both the functions could be changed to be more readable.
+	 * This is copied from swiftscript_dirname.
+	 * Both the functions could be changed to be more readable.
 	 * Returns length of an array.
-	 * Good for debugging because array needs to be closed before the length is determined
+	 * Good for debugging because array needs to be closed
+	 *   before the length is determined
 	public DSHandle swiftscript_length(VariableStack stack)
 	    DSHandle handle;
 	    DSHandle[] args = SwiftArg.VARGS.asDSHandleArray( stack );
 	    DSHandle arg = args[0];
@@ -339,7 +340,8 @@
 	    if( !( adn.isClosed() ) )
-	        throw new FutureNotYetAvailable( VDLFunction.addFutureListener( stack, adn ) );
+	        throw new FutureNotYetAvailable
+	        (VDLFunction.addFutureListener(stack, adn));
 	    int result = adn.size();
