[Swift-commit] r4190 - in SwiftApps/SwiftR/Swift: R tests
Thu Mar 17 14:01:08 CDT 2011
Author: tga
Date: 2011-03-17 14:01:08 -0500 (Thu, 17 Mar 2011)
New Revision: 4190
Modified:
   SwiftApps/SwiftR/Swift/R/TestFramework.R
   SwiftApps/SwiftR/Swift/tests/param_size.R
   SwiftApps/SwiftR/Swift/tests/perf_tests.R
Log:
Fixed argument size benchmark: now runs correctly and gives plottable results.
Modified: SwiftApps/SwiftR/Swift/R/TestFramework.R
--- SwiftApps/SwiftR/Swift/R/TestFramework.R	2011-03-17 03:31:54 UTC (rev 4189)
+++ SwiftApps/SwiftR/Swift/R/TestFramework.R	2011-03-17 19:01:08 UTC (rev 4190)
@@ -39,7 +39,7 @@
         test$name = paste(fname, substring(deparse(args), 5) , sep="")
         if (!is.null(prep)) {
             test$fun <- f
-            test$fun <- buildClosure(prep, args)
+            test$prep <- buildClosure(prep, args)
         else {
             test$fun <- buildClosure(f, args)
@@ -134,10 +134,12 @@
         if (!is.null(test$prep)) {
             prep <- try(test$prep())
             if (inherits(res, "try-error")) {
+                print("prep failed")
                 group$tests[[i]]$passed <- res
                 group$tests[[i]]$time <- 0
             else {
+                print("prep ran")
                 startTime = proc.time()[["elapsed"]]
                 group$tests[[i]]$passed <- try(test$fun(prep))
                 endTime <- proc.time()[["elapsed"]]
Modified: SwiftApps/SwiftR/Swift/tests/param_size.R
--- SwiftApps/SwiftR/Swift/tests/param_size.R	2011-03-17 03:31:54 UTC (rev 4189)
+++ SwiftApps/SwiftR/Swift/tests/param_size.R	2011-03-17 19:01:08 UTC (rev 4190)
@@ -4,12 +4,14 @@
 cores <- 4
 intsize <- 4
-param.bytes <- lapply(1:26, function (x) {list(cores, 4 * (2**x))})
+param.bytes <- lapply(1:24, function (x) {list(cores, 4 * (2**x))})
 id <- function (x) {x}
 test <- function (arr) {
     res <- swiftLapply(arr, id)
+    length(res)
+    return (NULL)
 makeArray <- function (procs, arr.bytes) {
     #arrsize is in bytes
@@ -20,10 +22,25 @@
     return(args)
-testGroup <- makePerfTestGroup(mode="swift", name="ArgSize",
+ts <- makeTestSuite(groups=list(
+            makePerfTestGroup(mode="swift", name="ArgSize",
                 f=test, prep=makeArray,
                 allargs=param.bytes,
-                server="local", cores=cores)
+                server="local", cores=cores),
+                f=test, prep=makeArray,
+                allargs=param.bytes,
+                server="ssh", cores=1, hosts="nettle wapato dandelion cattail")
+res <- runTestSuite(ts)
-ts <- makeTestSuite(groups=list(testGroup))
-res <- runTestSuite(ts)
+anl <- mergeGroupResults(analyseSuitePerf(res,
+                argnames=c("procs", "arr.bytes"), perfparams=c('server')))
+loc <- subset(anl, server=="local")
+ssh <- subset(anl, server=="ssh")
+plot(x=ssh$arr.bytes, y=ssh$time, col='red', ylab="time", xlab="Argument size (bytes)")
+points(x=loc$arr.bytes, y=loc$time)
Modified: SwiftApps/SwiftR/Swift/tests/perf_tests.R
--- SwiftApps/SwiftR/Swift/tests/perf_tests.R	2011-03-17 03:31:54 UTC (rev 4189)
+++ SwiftApps/SwiftR/Swift/tests/perf_tests.R	2011-03-17 19:01:08 UTC (rev 4190)
@@ -3,6 +3,11 @@
 swiftSetup <- function (...) {
+    libraries <- search()
+    if ("package:Swift" %in% libraries) {
+        library(Swift)
+        options(.swift.detach=T)
     library(Swift)
     swiftSess <- swiftInit(...)
     # Wait to start
@@ -16,11 +21,25 @@
 swiftTearDown <- function (...) {
     swiftShutdown()
-    detach(package:Swift)
+    dt <- getOption(".swift.detach")
+    options(.swift.detach=NULL)
+    if (!is.null(dt) && dt) {
+        detach(package:Swift)
 sfSetup <- function(..., cpus=ncpus) {
-    library(snowfall)
+    if (!("package:snowfall" %in% libraries)) {
+        library(snowfall)
+        options(.snowfall.detach=T)
+    # Swift needs to be detached
+        options(.swift.reattach=T)
     sfInit(..., cpus=ncpus)
     # warmup
     sfLapply(rep(1, ncpus * 2),
@@ -30,7 +49,16 @@
 sfTearDown <- function (...) {
     sfStop()
-    detach(package:snowfall)
+    dt <- getOption(".snowfall.detach")
+    options(.snowfall.detach=NULL)
+        detach(package:snowfall)
+    rt <- getOption(".swift.reattach")
+    options(.swift.reattach=NULL)
+    if (!is.null(rt) && rt) {
+        library(Swift)
