[Swift-commit] r4174 - in SwiftApps/SwiftR: . Swift Swift/R Swift/tests Swift/tests/OpenMx
Wed Mar 9 14:57:16 CST 2011
Author: tga
Date: 2011-03-09 14:57:14 -0600 (Wed, 09 Mar 2011)
New Revision: 4174
Added:
   SwiftApps/SwiftR/Swift/tests/OpenMx/
   SwiftApps/SwiftR/Swift/tests/OpenMx/BootstrapParallelBigger.R
   SwiftApps/SwiftR/Swift/tests/OpenMx/RAM-3Factor-96Indicators-covdata-a.R
   SwiftApps/SwiftR/Swift/tests/perf_tests.R
Removed:
   SwiftApps/SwiftR/mxtests/
Modified:
   SwiftApps/SwiftR/IMMEDIATE-TODO
   SwiftApps/SwiftR/Swift/NAMESPACE
   SwiftApps/SwiftR/Swift/R/TestFramework.R
Log:
Fixed up the performance test suite so that it is packaged with the library.
Fixed up analysis functions to work more nicely.  This is still a work in progress.
Modified: SwiftApps/SwiftR/IMMEDIATE-TODO
--- SwiftApps/SwiftR/IMMEDIATE-TODO	2011-03-08 00:24:50 UTC (rev 4173)
+++ SwiftApps/SwiftR/IMMEDIATE-TODO	2011-03-09 20:57:14 UTC (rev 4174)
@@ -16,9 +16,34 @@
     - parallel OpenMx Tests
 HIGH:
+-- Feedback from queue
+HIGH:
 -- get working on beagle.
 HIGH:
+-- Test on Mac
+HIGH:
+-- Usability testing package
+-- Instructions + survey
+MED:
+-- OpenMx specific instructions.
+HIGH:
+-- Check  java version ahead of time
+HIGH:
+-- email swift-devel about automated tests
+MED:
+-- IBI performance tests
+MED:
+-- Add OpenMx tests to test suite
+HIGH:
 - tests
 -- simple calibration tests (n args, arg sizes, durations, etc)
 -- openmx tests
Modified: SwiftApps/SwiftR/Swift/NAMESPACE
--- SwiftApps/SwiftR/Swift/NAMESPACE	2011-03-08 00:24:50 UTC (rev 4173)
+++ SwiftApps/SwiftR/Swift/NAMESPACE	2011-03-09 20:57:14 UTC (rev 4174)
@@ -27,4 +27,6 @@
 export(mkPerfTest)
 export(doPerfTest)
 export(analysePerf)
+export(analyseSuitePerf)
+export(mergeGroupResults)
Modified: SwiftApps/SwiftR/Swift/R/TestFramework.R
--- SwiftApps/SwiftR/Swift/R/TestFramework.R	2011-03-08 00:24:50 UTC (rev 4173)
+++ SwiftApps/SwiftR/Swift/R/TestFramework.R	2011-03-09 20:57:14 UTC (rev 4174)
@@ -46,8 +46,26 @@
     return (makeTestGroup(name, tests, setup, teardown))
-analysePerf <- function (testGroupResults, nargs=0, perfparams=NULL) {
+analyseSuitePerf <- function (testSuite, ...) {
+    # See analyse perf below: does the same for a test suite and returns a list of the results
+    # for each group
+    lapply(testSuite$groups,
+        function (g) {
+            res <- analysePerf(g, ...)
+            n <- length(res[[1]])
+            res$group <- rep(g$name, n)
+            return (res)
+analysePerf <- function (testGroupResults, argnames=NULL, perfparams=NULL, includePassed=FALSE) {
     # Build a list of vectors of performance results for easier analysis
+    # argnames: names to give to the arguments to the test function, ordered by position
+    # The number here is the number of arguments that are extracted from
+    # the test result data.
+    # perfparams: names of the parameters passed to swfit/snowfall init functions
+    #   that you want to include in the final data
     # [[1]] -> first arg
     # [[2]] -> second arg
@@ -56,18 +74,21 @@
     # $passed
     # $time
     collated <- list()
-    if (nargs >= 1) {
-        for (i in 1:nargs) {
+    if (length(argnames) >= 1) {
+        for (i in 1:length(argnames)) {
             collated[[i]] <- unlist(lapply(testGroupResults$tests,
                             function(test) {test$args[[i]]}))
+            names(collated)[[i]] <- argnames[[i]]
     n <- length(testGroupResults$tests)
     collated$name <- unlist(lapply(testGroupResults$tests,
                         function(test) {test$name }))
-    collated$passed <-unlist(lapply(testGroupResults$tests,
-                        function(test) {test$passed }))
+    if (includePassed) {
+        collated$passed <-unlist(lapply(testGroupResults$tests,
+                            function(test) {test$passed }))
     collated$time <- unlist(lapply(testGroupResults$tests,
                         function(test) {test$time }))
@@ -82,6 +103,18 @@
+# Takes a list of analysed group results from analysePerf and combines them into
+# a single data frame.  This has to assume that all data in these lists is valid
+# for inclusion in a data frame.  Merge rules are those of the built-in merge function
+mergeGroupResults <- function (groupResults) {
+    frames <- lapply(groupResults, data.frame)
+    res <- frames[[1]]
+    for (frame in frames[2:length(frames)]) {
+        res <- merge(res, frame, all=T)
+    return (res)
 runTestGroup <- function (group) {
     cat("\n*** Starting test group ", group$name, "***\n")
     if (!is.null(group$setup))
Added: SwiftApps/SwiftR/Swift/tests/OpenMx/BootstrapParallelBigger.R
--- SwiftApps/SwiftR/Swift/tests/OpenMx/BootstrapParallelBigger.R	                        (rev 0)
+++ SwiftApps/SwiftR/Swift/tests/OpenMx/BootstrapParallelBigger.R	2011-03-09 20:57:14 UTC (rev 4174)
@@ -0,0 +1,206 @@
+#!/bin/env Rscript
+#   Copyright 2007-2010 The OpenMx Project
+#   Licensed under the Apache License, Version 2.0 (the "License");
+#   you may not use this file except in compliance with the License.
+#   You may obtain a copy of the License at
+#        http://www.apache.org/licenses/LICENSE-2.0
+#   Unless required by applicable law or agreed to in writing, software
+#   distributed under the License is distributed on an "AS IS" BASIS,
+#   WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
+#   See the License for the specific language governing permissions and
+#   limitations under the License.
+# This file is meant to be opened using the source command from an R instance
+#   with working directory of either
+#  a) the root of the R library directory in which is
+#  b) the root of the SwiftR source trunk
+#  ie.
+# > source("Swift/tests/OpenMx/BootstrapParallelBigger.R")
+# You can then make a custom bootstrap performance testing suite
+# using makeBootstrapTestGroup and makeTestSuite, and run it
+# using swiftR's test suite mechanism.
+require(OpenMx)
+require(Swift)
+source("Swift/tests/perf_tests.R")
+# This is the main test function, which can be
+# run with varying combinations of the three
+# parameters.
+bootstrapTest <- function (nVar, nObs, nReps) {
+    set.seed(10)
+    topModel <- buildModels(nVar, nObs, nReps)
+    modelResults <- mxRun(topModel, silent=TRUE, suppressWarnings=TRUE)
+    print(modelResults at output$wallTime)
+    # Only return some statistics about the model: the returned model data
+    # can be huge in size otherwise
+    return (modelResults at output)
+# This function sets up the OpenMx models to
+# use for the test
+buildModels <- function (nVar, nObs, nReps) {
+    # parameters for the simulation: lambda = factor loadings,
+    # specifics = specific variances
+    goodStartValues <- TRUE
+    if (!is.logical(goodStartValues)) {
+      stop("'goodStartValues' should be logical. Try again.")
+    lambda <- matrix(1:nVar*2/nVar, nVar, 1)
+    specifics <- diag(nVar)
+    chl <- chol(lambda %*% t(lambda) + specifics)
+    # indices for parameters and hessian estimate in results
+    pStrt <- 3
+    pEnd <- pStrt + 2*nVar - 1
+    hStrt <- pEnd + 1
+    hEnd <- hStrt + 2*nVar - 1
+    # dimension names for OpenMx
+    dn <- list()
+    dn[[1]] <- paste("Var", 1:nVar, sep="")
+    dn[[2]] <- dn[[1]]
+    # function to get a covariance matrix
+    randomCov <- function(nObs, nVar, chl, dn) {
+      x <- matrix(rnorm(nObs*nVar), nObs, nVar)
+      x <- x %*% chl
+      thisCov <- cov(x)
+      dimnames(thisCov) <- dn
+      return(thisCov)
+    createNewModel <- function(index, prefix, model) {
+            modelname <- paste(prefix, index, sep='')
+            model at data@observed <- randomCov(nObs, nVar, chl, dn)
+            model at name <- modelname
+            return(model)
+    getStats <- function(model) {
+            retval <- c(model at output$status[[1]],
+                    max(abs(model at output$gradient)),
+                    model at output$estimate,
+                    sqrt(diag(solve(model at output$hessian))))
+            return(retval)
+    # initialize obsCov for MxModel
+    obsCov <- randomCov(nObs, nVar, chl, dn)
+    # results matrix: get results for each simulation
+#    results <- matrix(0, nReps, hEnd)
+#    dnr <- c("inform", "maxAbsG", paste("lambda", 1:nVar, sep=""),
+#             paste("specifics", 1:nVar, sep=""),
+#             paste("hessLambda", 1:nVar, sep=""),
+#             paste("hessSpecifics", 1:nVar, sep=""))
+#    dimnames(results)[[2]] <- dnr
+    # instantiate MxModel
+    template <- mxModel(name="stErrSim",
+                           mxMatrix(name="lambda", type="Full", nrow=nVar, ncol=1,
+                                    free=TRUE, values=(1:nVar*2/nVar)*goodStartValues),
+                           mxMatrix(name="specifics", type="Diag", nrow=nVar,
+                                    free=TRUE, values=rep(1, nVar)),
+                           mxAlgebra(lambda %*% t(lambda) + specifics,
+                                     name="preCov", dimnames=dn),
+                           mxData(observed=obsCov, type="cov", numObs=nObs),
+                           mxMLObjective(covariance='preCov'),
+                           independent = TRUE)
+    topModel <- mxModel(name = 'container')
+    # Don't need to export as local environment will automatically
+    # be sent
+    #swiftExportAll()
+    submodels <- omxLapply(1:nReps, createNewModel, 'stErrSim', template)
+    cat(length(submodels), "submodels created\n")
+#    names(submodels) <- imxExtractNames(submodels)
+    names(submodels) <- imxExtractNames(submodels)
+    topModel at submodels <- submodels
+    return (topModel)
+# Construct a performance test group which contains bootstrap instances with
+# a range of different parameter values.  Additional arguments are
+# passed to swiftInit or sfInit as appropriate
+makeBootstrapTestGroup <- function (argsList, ...) {
+    makePerfTestGroup(
+            name="BootstrapParallelBigger",
+            f=bootstrapTest,
+            allargs=argsList,
+testArgs <- list(
+                list(75, 100, 4),
+                list(75, 100, 8),
+                list(75, 100, 16),
+                list(75, 100, 32),
+                list(75, 100, 64),
+                list(75, 100, 128),
+                list(75, 100, 256),
+                list(75, 100, 512),
+                list(75, 100, 786),
+                list(75, 100, 1024),
+                list(75, 100, 1024 + 512),
+                list(75, 100, 2048 )
+testArgsShort <- list(
+                list(25, 100, 4),
+                list(25, 100, 8),
+                list(25, 100, 16),
+                list(25, 100, 32),
+                list(25, 100, 64),
+                list(25, 100, 128),
+                list(25, 100, 256),
+                list(25, 100, 512),
+                list(25, 100, 786),
+                list(25, 100, 1024),
+                list(25, 100, 1024 + 512),
+                list(25, 100, 2048 )
+# An example test suite which runs on a ssh cluster
+# on multiple cores of a machine and in vanilla R
+sampleTestSuite <- makeTestSuite(
+    groups=list(
+       # 16 cores
+       makeBootstrapTestGroup(mode="swift", server="ssh", cores=2,
+            hosts=c("nettle", "wapato", "dandelion", "cattail",
+                "chicory", "echinacea", "amaranth", "black-cohosh"),
+            argsList=testArgs[3:5]),
+       # 8 cores
+            hosts="nettle wapato dandelion cattail",
+            argsList=testArgs[2:5]),
+       makeBootstrapTestGroup(mode="swift", server="local", cores=4,
+            argsList=testArgs[1:4]),
+       makeBootstrapTestGroup(mode="swift", server="local", cores=2,
+       makeBootstrapTestGroup(mode="swift", server="local", cores=1,
+            argsList=testArgs[1:2]),
+       makeBootstrapTestGroup(mode="serial", argsList=testArgs[1:2])
Copied: SwiftApps/SwiftR/Swift/tests/OpenMx/RAM-3Factor-96Indicators-covdata-a.R (from rev 4173, SwiftApps/SwiftR/mxtests/swift/RAM-3Factor-96Indicators-covdata-a.R)
--- SwiftApps/SwiftR/Swift/tests/OpenMx/RAM-3Factor-96Indicators-covdata-a.R	                        (rev 0)
+++ SwiftApps/SwiftR/Swift/tests/OpenMx/RAM-3Factor-96Indicators-covdata-a.R	2011-03-09 20:57:14 UTC (rev 4174)
@@ -0,0 +1,143 @@
+# Program: RAM-3Factor-12Indicators.R
+#  Author: Steven M. Boker
+#    Date: Fri Jul 30 13:45:12 EDT 2010
+# This program is a factor model using standard RAM.
+# Revision History
+#    -- Fri Jul 30 13:45:12 EDT 2010
+#      Created RAM-3Factor-12Indicators.R.
+# Read libraries and set options.
+library(OpenMx)
+library(Swift)
+# Data for factor model.
+defaultArgs <- list(1000, 3, 32)
+# Construct a performance test group which contains CI instances with
+makeCITestGroup <- function (argsList, ...) {
+            name="cov.confidence.interval",
+            f=cov.confidence.interval,
+            allargs=argsList,
+cov.confidence.interval <- function (numberSubjects, numberFactors, numberIndPerFactor) {
+    #numberSubjects <- 1000
+    #numberFactors <- 3
+    #numberIndPerFactor <- 32
+    numberIndicators <- numberIndPerFactor*numberFactors # must be a multiple of numberFactors
+    XMatrix <- matrix(rnorm(numberSubjects*numberFactors, mean=0, sd=1), numberSubjects, numberFactors)
+    tLoadings <- c(1, seq(.5, .9, length.out=(numberIndPerFactor-1)), rep(0, numberIndPerFactor*2),
+      rep(0, numberIndPerFactor*1), 1, seq(.5, .9, length.out=(numberIndPerFactor-1)), rep(0, numberIndPerFactor*1),
+      rep(0, numberIndPerFactor*2), 1, seq(.5, .9, length.out=(numberIndPerFactor-1)))
+    BMatrix <- matrix(tLoadings, numberFactors, numberIndicators, byrow=TRUE)
+    UMatrix <- matrix(rnorm(numberSubjects*numberIndicators, mean=0, sd=1), numberSubjects, numberIndicators)
+    YMatrix <- XMatrix %*% BMatrix + UMatrix
+    cor(XMatrix)
+    dimnames(YMatrix) <- list(NULL, paste("X", 1:numberIndicators, sep=""))
+    YFrame <- data.frame(YMatrix)
+    round(cor(YFrame), 3)
+    round(cov(YFrame), 3)
+    indicators <- paste("X", 1:numberIndicators, sep="")
+    totalVars <- numberIndicators + numberFactors
+    # Build an orthogonal simple structure factor model
+    latents <- paste("F", 1:numberFactors, sep="")
+    uniqueLabels <- paste("U_", indicators, sep="")
+    meanLabels <- paste("M_", latents, sep="")
+    factorVarLabels <- paste("Var_", latents, sep="")
+    latents1 <- latents[1]
+    indicators1 <- indicators[1:numberIndPerFactor]
+    loadingLabels1 <- paste("b_F1", indicators[1:numberIndPerFactor], sep="")
+    latents2 <- latents[2]
+    indicators2 <- indicators[numberIndPerFactor+(1:numberIndPerFactor)]
+    loadingLabels2 <- paste("b_F2", indicators[numberIndPerFactor+(1:numberIndPerFactor)], sep="")
+    latents3 <- latents[3]
+    indicators3 <- indicators[(2*numberIndPerFactor)+(1:numberIndPerFactor)]
+    loadingLabels3 <- paste("b_F3", indicators[(2*numberIndPerFactor)+(1:numberIndPerFactor)], sep="")
+    threeFactorOrthogonal <- mxModel("threeFactorOrthogonal",
+        type="RAM",
+        manifestVars=c(indicators),
+        latentVars=c(latents,"dummy1"),
+        mxPath(from=latents1, to=indicators1,
+               arrows=1, all=TRUE,
+               free=TRUE, values=.2,
+               labels=loadingLabels1),
+        mxPath(from=latents2, to=indicators2,
+               labels=loadingLabels2),
+        mxPath(from=latents3, to=indicators3,
+               labels=loadingLabels3),
+        mxPath(from=latents1, to=indicators1[1],
+               arrows=1,
+               free=FALSE, values=1),
+        mxPath(from=latents2, to=indicators2[1],
+               arrows=1,
+        mxPath(from=latents3, to=indicators3[1],
+               arrows=1,
+        mxPath(from=indicators,
+               arrows=2,
+               labels=uniqueLabels),
+        mxPath(from=latents,
+               arrows=2,
+               free=TRUE, values=.8,
+               labels=factorVarLabels),
+        mxPath(from="one", to=indicators,
+               arrows=1, free=FALSE, values=0),
+        mxPath(from="one", to=c(latents),
+               arrows=1, free=TRUE, values=.1,
+               labels=meanLabels),
+        mxCI(c('A', 'S')),
+        mxData(observed=cov(YFrame), means=mean(YFrame),
+            numObs=nrow(YFrame), type="cov")
+    threeFactorOrthogonalOut <- mxRun(threeFactorOrthogonal)
+    threeFactorCI <- omxParallelCI(threeFactorOrthogonalOut)
+    totalTime <- threeFactorCI at output$wallTime
+    seqTime <- threeFactorOrthogonalOut at output$wallTime
+    return (threeFactorCI at output)
+        groups=list(makeCITestGroup(mode="swift",
+            argsList=list(defaultArgs), server="local", cores=4
Copied: SwiftApps/SwiftR/Swift/tests/perf_tests.R (from rev 4173, SwiftApps/SwiftR/mxtests/swift/MakeTests.R)
--- SwiftApps/SwiftR/Swift/tests/perf_tests.R	                        (rev 0)
+++ SwiftApps/SwiftR/Swift/tests/perf_tests.R	2011-03-09 20:57:14 UTC (rev 4174)
@@ -0,0 +1,74 @@
+# Helper functions for building performance tests suites that don't quite fit in the
+# main SwiftR code because they can detach the Swift package..
+swiftSetup <- function (...) {
+    library(Swift)
+    swiftSess <- swiftInit(...)
+    # Wait to start
+    Sys.sleep(10)
+    # Run some small jobs to ensure workers are started and warmed up
+    swiftapply(function (x) { x },
+            rep(1, swiftSess$cores * swiftSess$nodes * 2),
+            callsperbatch=1)
+    return (swiftSess)
+swiftTearDown <- function (...) {
+    swiftShutdown()
+    detach(package:Swift)
+sfSetup <- function(..., cpus=ncpus) {
+    library(snowfall)
+    sfInit(..., cpus=ncpus)
+    # warmup
+    sfLapply(rep(1, ncpus * 2),
+                function (x) { x })
+sfTearDown <- function (...) {
+    sfStop()
+    detach(package:snowfall)
+makePerfTestGroup <- function (mode, name, f, allargs, ...) {
+    params <- list(...)
+    paramstr <- paste(names(params),
+                rep("=", length(params)),
+                lapply(params, deparse),
+                sep="", collapse=", ")
+    if (mode == "swift") {
+        tg <- makeParamTestGroup(name=paste("swift_",name, " ", paramstr,sep=""),
+            f=f,
+            allargs=allargs,
+            perfparams = params,
+            setup=function() {swiftSetup(...)},
+            teardown = swiftTearDown)
+    else if (mode == "snowfall") {
+        tg <- makeParamTestGroup(name=paste("sf_",name, paramstr, sep=""),
+            f=f,
+            allargs=allargs,
+            setup=function() {sfSetup(...)},
+            teardown = sfTearDown)
+    else {
+        print("Making serial test")
+        tg <- makeParamTestGroup(name=paste("serial_",name, paramstr, sep=""),
+            f=f,
+            allargs=allargs,
+            perfparams = list(),
+            setup=function()
+                {try(detach(package:Swift)); try(detach(package:Snowfall))} )
+    return (tg)
Property changes on: SwiftApps/SwiftR/Swift/tests/perf_tests.R
___________________________________________________________________
