[Swift-commit] r4617 - SwiftApps/Montage/docs
jonmon at ci.uchicago.edu jonmon at ci.uchicago.edu
Tue Jun 14 20:47:50 CDT 2011
Author: jonmon
Date: 2011-06-14 20:47:31 -0500 (Tue, 14 Jun 2011)
New Revision: 4617
Added:
   SwiftApps/Montage/docs/API.pdf
Modified:
   SwiftApps/Montage/docs/API.html
   SwiftApps/Montage/docs/API.txt
   SwiftApps/Montage/docs/updateAPI.sh
Log:
added pdf version of the API. updates to the doc generation script and source.
Modified: SwiftApps/Montage/docs/API.html
--- SwiftApps/Montage/docs/API.html	2011-06-15 01:00:37 UTC (rev 4616)
+++ SwiftApps/Montage/docs/API.html	2011-06-15 01:47:31 UTC (rev 4617)
@@ -706,11 +706,11 @@
-asciidoc.install(2);
+asciidoc.install(3);
 </script>
 </head>
-<body class="article" style="max-width:1100px">
+<body class="article" style="max-width:750px">
 <div id="header">
 <h1>Swift Montage API</h1>
 <div id="toc">
@@ -719,7 +719,8 @@
 </div>
 </div>
 <div id="content">
-<div id="preamble">
+<div class="sect1">
+<h2 id="_overview">1. Overview</h2>
 <div class="sectionbody">
 <div class="paragraph"><p>This is the API for the Swift Montage wrappers. Montage is a toolkit for
 generating science grade astronomical mosaics. The image file format for
@@ -740,50 +741,61 @@
 </div>
 </div>
 <div class="sect1">
-<h2 id="X1">Swift Montage API</h2>
+<h2 id="_swift_montage_api">2. Swift Montage API</h2>
 <div class="sect2">
-<h3 id="_types">Types</h3>
+<h3 id="_types">2.1. Types</h3>
 <div class="paragraph"><p>These are all the Types that are declared for Swift. They are located in the
 file Swift_Montage_types.swift.</p></div>
+<div class="sect3">
+<h4 id="_image">2.1.1. Image</h4>
 <div class="listingblock">
-<div class="title">Image</div>
 <div class="content">
 <pre><tt>type Image;</tt></pre>
 </div></div>
 <div class="paragraph"><p>This is the Image type.  It is used to declare the raw images, projected
 images, difference images, rectified images, and the mosaic.</p></div>
+</div>
+<h4 id="_header">2.1.2. Header</h4>
-<div class="title">MosaicData</div>
-<pre><tt>type MosaicData;</tt></pre>
+<pre><tt>type Header;</tt></pre>
 </div></div>
-<div class="paragraph"><p>This is the MosaicData type. It is used to declare and map to the FITS header
+<div class="paragraph"><p>This is the Header type. It is used to declare and map to the FITS header
 file.</p></div>
+</div>
+<h4 id="_table">2.1.3. Table</h4>
-<div class="title">Table</div>
 <pre><tt>type Table;</tt></pre>
 </div></div>
 <div class="paragraph"><p>This is the Table type. During the execution of the workflow several files of
 metadata is generated. These are tables that the Montage functions use to read
 for the next stage of the workflow.</p></div>
+</div>
+<h4 id="_jpeg">2.1.4. JPEG</h4>
-<div class="title">JPEG</div>
 <pre><tt>type JPEG</tt></pre>
 </div></div>
 <div class="paragraph"><p>This is the JPEG type. This is used to map to the jpeg version of the mosaic.</p></div>
+</div>
+<h4 id="_status">2.1.5. Status</h4>
-<div class="title">Status</div>
 <pre><tt>type Status;</tt></pre>
 </div></div>
 <div class="paragraph"><p>This is the status type. During the difference stage of the workflow status
 file are generated that have the information about the coefficients that will
 be used to rectify the image.</p></div>
+</div>
+<h4 id="_backgroundstruct">2.1.6. BackgroundStruct</h4>
-<div class="title">BackgroundStruct</div>
 <pre><tt>type BackgroundStruct
@@ -796,8 +808,10 @@
 <div class="paragraph"><p>This is a struct type. The entries are a string for the name of the image and
 three coefficients to rectify this portion of the mosaic of all floating point
 types.</p></div>
+</div>
+<h4 id="_diffstruct">2.1.7. DiffStruct</h4>
-<div class="title">DiffStruct</div>
 <pre><tt>type DiffStruct
@@ -812,8 +826,9 @@
 entry unique, the two images that overlapped which are name plus and minus,
 and the name of the difference image that they produced.</p></div>
 </div>
+</div>
 <div class="sect2">
-<h3 id="_app_procedures">App Procedures</h3>
+<h3 id="_app_procedures">2.2. App Procedures</h3>
 <div class="paragraph"><p>These are all the app procedures for Swift Montage. They are located in the
 file Swift_Montage_Apps.swift</p></div>
 <div class="admonitionblock">
@@ -825,10 +840,11 @@
 user cannot choose which options to run.</td>
 </tr></table>
 </div>
+<h4 id="_madd">2.2.1. mAdd</h4>
-<div class="title">mAdd</div>
-<pre><tt>app ( Image mos ) mAdd( Image imgs[], Table img_tbl, MosaicData hdr )</tt></pre>
+<pre><tt>app ( Image mos ) mAdd( Image imgs[], Table img_tbl, Header hdr )</tt></pre>
 </div></div>
 <div class="paragraph"><p>This app procedure will call the mAdd fucntion from the Montage toolkit.  This
 procedure takes
@@ -836,8 +852,10 @@
 the FITS header file for the mosaic being created.  The procedure then outputs
 a single FITS file that represents the mosaic. All the images that will be
 part of this mosaic must reside in the same directory.</p></div>
+</div>
+<h4 id="_mbackground">2.2.2. mBackground</h4>
-<div class="title">mBackground</div>
 <pre><tt>app ( Image bg_img ) mBackground( Image img, float a, float b, float c )</tt></pre>
 </div></div>
@@ -845,8 +863,10 @@
 toolkit. This procedure takes in a single image along with the
 three coefficients. The procedure then output the background rectified image
 after the coefficients have been applied.</p></div>
+</div>
+<h4 id="_mbgmodel">2.2.3. mBgModel</h4>
-<div class="title">mBgModel</div>
 <pre><tt>app ( Table rect_tbl ) mBgModel( Table img_tbl, Table fits_tbl )</tt></pre>
 </div></div>
@@ -855,8 +875,10 @@
 will be added into a mosaic and a table of the information that is required to
 fit them together. The procedure will then output a rectification table of the
 coefficients that must be applied to the images.</p></div>
+</div>
+<h4 id="_mconcatfit">2.2.4. mConcatFit</h4>
-<div class="title">mConcatFit</div>
 <pre><tt>app ( Table fits_tbl ) mConcatFit( Table status_tbl, Status stats[] )</tt></pre>
 </div></div>
@@ -865,24 +887,30 @@
 from either mFitplane or mDiffFit and a list of these status files as
 input. The procedure will then output a table of all the status files
 together. The status files must all reside in the same directory.</p></div>
+</div>
+<h4 id="_mdiff">2.2.5. mDiff</h4>
-<div class="title">mDiff</div>
-<pre><tt>app ( Image diff_img ) mDiff( Image proj_img_1, Image proj_img_2, MosaicData hdr )</tt></pre>
+<pre><tt>app ( Image diff_img ) mDiff( Image proj_img_1, Image proj_img_2, Header hdr )</tt></pre>
 </div></div>
 <div class="paragraph"><p>This app procedure will call the mDiff function from the Montage toolkit. This
 procedure takes in two images and the FITS header file for the mosaic. The procedure will then output a
 difference image representing the information of where the two images overlap.</p></div>
+</div>
+<h4 id="_mdifffit">2.2.6. mDiffFit</h4>
-<div class="title">mDiffFit</div>
-<pre><tt>app ( Image diff_img, Status stat ) mDiffFit( Image img_1, Image img_2, MosaicData hdr )</tt></pre>
+<pre><tt>app ( Image diff_img, Status stat ) mDiffFit( Image img_1, Image img_2, Header hdr )</tt></pre>
 </div></div>
 <div class="paragraph"><p>This app procedure will call the mDiffFit function from the Montage
 toolkit. The mDiffFit function in Montage is the combination of the mDiff and
 mFitplane functions.</p></div>
+</div>
+<h4 id="_mfitplane">2.2.7. mFitplane</h4>
-<div class="title">mFitplane</div>
 <pre><tt>app ( Status stat ) mFitplane( Image diff_img )</tt></pre>
 </div></div>
@@ -890,8 +918,10 @@
 toolkit. This procedure takes in as input the difference image that was the output from
 the mDiff procedure. The procedure will then output a status file that
 contains the information on how to fit these two images together.</p></div>
+</div>
+<h4 id="_mimgtbl">2.2.8. mImgtbl</h4>
-<div class="title">mImgtbl</div>
 <pre><tt>app ( Table img_tbl ) mImgtbl( Image imgs[] )</tt></pre>
 </div></div>
@@ -899,25 +929,31 @@
 toolkit. This procedure takes in as input a list of images to create a table
 from. The output is an image table that represents these images. All the
 images that will be part of this table must reside in the same directory.</p></div>
+</div>
+<h4 id="_mmakehdr">2.2.9. mMakeHdr</h4>
-<div class="title">mMakeHdr</div>
-<pre><tt>app ( MosaicData hdr ) mMakeHdr( Table img_tbl )</tt></pre>
+<pre><tt>app ( Header hdr ) mMakeHdr( Table img_tbl )</tt></pre>
 </div></div>
 <div class="paragraph"><p>This app procedure will call the mMakeHdr function from the Montage
 toolkit. This procedure will take in as input an image table representing the
 images that will be combined into a single mosaic. The procedure will then output the
 FITS header file for the mosaic.</p></div>
+</div>
+<h4 id="_mjpeg">2.2.10. mJPEG</h4>
-<div class="title">mJPEG</div>
 <pre><tt>app ( JPEG mos_img_jpg ) mJPEG( Image mos_img )</tt></pre>
 </div></div>
 <div class="paragraph"><p>This app procedure will call the mJPEG function from the Montage toolkit. This
 procedure will take in as input as input a FITS image. The procedure will
 then ouput the same image in jpeg format.</p></div>
+</div>
+<h4 id="_moverlaps">2.2.11. mOverlaps</h4>
-<div class="title">mOverlaps</div>
 <pre><tt>app ( Table diff_tbl ) mOverlaps( Table img_tbl )</tt></pre>
 </div></div>
@@ -925,12 +961,14 @@
 toolkit. This procedure takes in as input an image table of the images that
 will be combined into a single mosaic. The procedure will then output a table
 of all the images that overlap with each other in the mosaic.</p></div>
+</div>
+<h4 id="_mproject">2.2.12. mProject</h4>
-<div class="title">mProjectPP</div>
-<pre><tt>app ( Image proj_img ) mProjectPP( Image raw_img, MosaicData hdr )</tt></pre>
+<pre><tt>app ( Image proj_img ) mProject( Image raw_img, Header hdr )</tt></pre>
 </div></div>
-<div class="paragraph"><p>This app procedure will call the mProjectPP function from the Montage
+<div class="paragraph"><p>This app procedure will call the mProject function from the Montage
 toolkit. This procedure takes in as input a FITS image file and the FITS header file
 that for the mosaic. The output is the projected image.</p></div>
@@ -938,18 +976,18 @@
 <td class="icon">
 <img src="./images/icons/note.png" alt="Note" />
 </td>
-<td class="content">The mProjectPP app procedure is a "special case" version of mProject
-and can be used only where the input and output images have tangent-plane
-projections (e.g. TAN, SIN) or where they can be approximated with acceptable
-error.</td>
+<td class="content">The mProject app procedure is for general projection. There are some cases in
+which the faster mProjectPP procedure should be used.</td>
 </tr></table>
 </div>
+</div>
+<h4 id="_mprojectpp">2.2.13. mProjectPP</h4>
-<div class="title">mProject</div>
-<pre><tt>app ( Image proj_img ) mProject( Image raw_img, MosaicData hdr )</tt></pre>
+<pre><tt>app ( Image proj_img ) mProjectPP( Image raw_img, Header hdr )</tt></pre>
 </div></div>
-<div class="paragraph"><p>This app procedure will call the mProject function from the Montage
+<div class="paragraph"><p>This app procedure will call the mProjectPP function from the Montage
@@ -957,20 +995,26 @@
 <td class="icon">
 </td>
-<td class="content">The mProject app procedure is for general projection. There are some cases in
-which the faster mProjectPP procedure should be used.</td>
+<td class="content">The mProjectPP app procedure is a "special case" version of mProject
+and can be used only where the input and output images have tangent-plane
+projections (e.g. TAN, SIN) or where they can be approximated with acceptable
+error.</td>
 </tr></table>
 </div>
+</div>
+<h4 id="_mshrink">2.2.14. mShrink</h4>
-<div class="title">mShrink</div>
 <pre><tt>app ( Image shrunk ) mShrink( Image original, int factor )</tt></pre>
 </div></div>
 <div class="paragraph"><p>This app procedure will call the mShrink function in the Montage toolkit. This
 procedure takes in as input a single image and an re-sizing factor represented
 as an integer. The procedure will then output the re-sized image.</p></div>
+</div>
+<h4 id="_backgound_list">2.2.15. Backgound_list</h4>
-<div class="title">Backgound_list</div>
 <pre><tt>app ( Table back_tbl ) Background_list( Table imgs_tbl, Table rect_tbl )</tt></pre>
 </div></div>
@@ -980,8 +1024,10 @@
 coefficients to rectify the mosaic. The procedure will then output a file in a
 format that can be read in by the Swift readData2 function into the
 Background_struct declared type.</p></div>
+</div>
+<h4 id="_create_status_table">2.2.16. create_status_table</h4>
-<div class="title">create_status_table</div>
 <pre><tt>app ( Table stat_tbl ) create_status_table( Table diff_tbl )</tt></pre>
 </div></div>
@@ -991,15 +1037,18 @@
 the mOverlaps procedure. The procedure will the output a table that can be
 used as input to the mConcatFit app procedure.</p></div>
 </div>
+</div>
 <div class="sect2">
-<h3 id="_batch_wrappers">Batch Wrappers</h3>
+<h3 id="_batch_wrappers">2.3. Batch Wrappers</h3>
 <div class="paragraph"><p>These are the Batch scripts. These scripts do most of the file mapping
 and is where the parallelization is taking place. They are located in the file
 Swift_Montage_Batch.swift</p></div>
+<h4 id="_mbackgroundbatch">2.3.1. mBackgroundBatch</h4>
-<div class="title">mBackgroundBatch</div>
-<pre><tt>( Image rect_imgs[] ) mBackgroundBatch( string dest_dir, Image proj_imgs[], Table img_tbl, Table rect_tbl )</tt></pre>
+<pre><tt>( Image rect_imgs[] ) mBackgroundBatch( string dest, Image imgs[], Table img_tbl,
+                                        Table rect_tbl )</tt></pre>
 </div></div>
 <div class="paragraph"><p>This batch swift script takes in as input a destination directory for the
 rectified images, a list of images that will be combined into a
@@ -1015,10 +1064,13 @@
 <td class="content">mBackgroundBatch calls the mBackground app procedure.</td>
 </tr></table>
 </div>
+</div>
+<h4 id="_mdiffbatch">2.3.2. mDiffBatch</h4>
-<div class="title">mDiffBatch</div>
-<pre><tt>( Image diff_imgs[] ) mDiffBatch( string src_dir, string dest_dir, string files[], Table diff_tbl, MosaicData hdr )</tt></pre>
+<pre><tt>( Image diff_imgs[] ) mDiffBatch( string src, string dest, string filenames[],
+                                  Table diff_tbl, Header hdr )</tt></pre>
 </div></div>
 <div class="paragraph"><p>This batch script takes in as input a source directory of where the images to calculate
 overlaps are located, a destination directory of where to store these
@@ -1043,11 +1095,14 @@
 <td class="content">mDiffBatch calls the mDiff app procedure.</td>
 </tr></table>
 </div>
+</div>
+<h4 id="_mdifffitbatch">2.3.3. mDiffFitBatch</h4>
-<div class="title">mDiffFitBatch</div>
-<pre><tt>( Image diff_imgs[], Table fits_tbl ) mDiffFitBatch( string src_dir, string dest_dir, string stat_dir,
-                                                     string files[], Table diff_tbl, MosaicData hdr )</tt></pre>
+<pre><tt>( Image diff_imgs[], Table fits_tbl ) mDiffFitBatch( string src, string dest, string stat,
+                                                     string filenames[],
 </div></div>
 calculate overlaps are located, a destination directory of where to store
@@ -1074,10 +1129,12 @@
 <td class="content">mDiffFitBatch calls the mDiffFit app procedure.</td>
 </tr></table>
 </div>
+</div>
+<h4 id="_mfitbatch">2.3.4. mFitBatch</h4>
-<div class="title">mFitBatch</div>
-<pre><tt>( Table fits_tbl ) mFitBatch( string stat_dir, Image diff_imgs[], Table diff_tbl )</tt></pre>
+<pre><tt>( Table fits_tbl ) mFitBatch( string stat, Image diff_imgs[], Table diff_tbl )</tt></pre>
 </div></div>
 <div class="paragraph"><p>This batch script takes in as input a directory for which the status files
 will be put in, the list of difference images that has
@@ -1092,10 +1149,12 @@
 <td class="content">mFitBatch calls the mFitplane app procedure.</td>
 </tr></table>
 </div>
+</div>
+<h4 id="_mprojectbatch">2.3.5. mProjectBatch</h4>
-<div class="title">mProjectBatch</div>
-<pre><tt>( Image proj_imgs[] ) mProjectBatch( string dest_dir, Image raw_imgs[], MosaicData hdr )</tt></pre>
+<pre><tt>( Image proj_imgs[] ) mProjectBatch( string dest, Image raw_imgs[], Header hdr )</tt></pre>
 </div></div>
 <div class="paragraph"><p>This batch script takes in as input the destination directory for the
 projected images, a list of raw image files and the FITS header file
@@ -1105,20 +1164,21 @@
 <table><tr>
 <td class="icon">
-<img src="./images/icons/note.png" alt="Note" />
+<img src="./images/icons/warning.png" alt="Warning" />
 </td>
-<td class="content">mProjectBatch calls the faster mProjectPP app procedure if the image allows
-it. If mProjectPP cannot be used then the app procedure mProject is called.</td>
+<td class="content">mProjectBatch currently only calls the general mProject app
+procedure. It does not check to see if the faster projection mProjectPP can be used.</td>
 </tr></table>
 </div>
 </div>
 </div>
 </div>
 </div>
+</div>
 <div id="footnotes"><hr /></div>
 <div id="footer">
 <div id="footer-text">
-Last updated 2011-06-14 14:35:29 CDT
+Last updated 2011-06-14 20:39:02 CDT
 </div>
 </div>
 </body>
Added: SwiftApps/Montage/docs/API.pdf
--- SwiftApps/Montage/docs/API.pdf	                        (rev 0)
+++ SwiftApps/Montage/docs/API.pdf	2011-06-15 01:47:31 UTC (rev 4617)
@@ -0,0 +1,2578 @@
+%PDF-1.4
+%ÐÔÅØ
+1 0 obj
+<< /S /GoTo /D (section.1) >>
+endobj
+4 0 obj
+(Overview)
+endobj
+5 0 obj
+<< /S /GoTo /D (section.2) >>
+endobj
+8 0 obj
+(Swift Montage API)
+endobj
+9 0 obj
+<< /S /GoTo /D (subsection.2.1) >>
+endobj
+12 0 obj
+(Types)
+endobj
+13 0 obj
+<< /S /GoTo /D (subsubsection.2.1.1) >>
+endobj
+16 0 obj
+(Image)
+endobj
+17 0 obj
+<< /S /GoTo /D (subsubsection.2.1.2) >>
+endobj
+20 0 obj
+(Header)
+endobj
+21 0 obj
+<< /S /GoTo /D (subsubsection.2.1.3) >>
+endobj
+24 0 obj
+(Table)
+endobj
+25 0 obj
+<< /S /GoTo /D (subsubsection.2.1.4) >>
+endobj
+28 0 obj
+(JPEG)
+endobj
+29 0 obj
+<< /S /GoTo /D (subsubsection.2.1.5) >>
+endobj
+32 0 obj
+(Status)
+endobj
+33 0 obj
+<< /S /GoTo /D (subsubsection.2.1.6) >>
+endobj
+36 0 obj
+(BackgroundStruct)
+endobj
+37 0 obj
+<< /S /GoTo /D (subsubsection.2.1.7) >>
+endobj
+40 0 obj
+(DiffStruct)
+endobj
+41 0 obj
+<< /S /GoTo /D (subsection.2.2) >>
+endobj
+44 0 obj
+(App Procedures)
+endobj
+45 0 obj
+<< /S /GoTo /D (subsubsection.2.2.1) >>
+endobj
+48 0 obj
+(mAdd)
+endobj
+49 0 obj
+<< /S /GoTo /D (subsubsection.2.2.2) >>
+endobj
+52 0 obj
+(mBackground)
+endobj
+53 0 obj
+<< /S /GoTo /D (subsubsection.2.2.3) >>
+endobj
+56 0 obj
+(mBgModel)
+endobj
+57 0 obj
+<< /S /GoTo /D (subsubsection.2.2.4) >>
+endobj
+60 0 obj
+(mConcatFit)
+endobj
+61 0 obj
+<< /S /GoTo /D (subsubsection.2.2.5) >>
+endobj
+64 0 obj
+(mDiff)
+endobj
+65 0 obj
+<< /S /GoTo /D (subsubsection.2.2.6) >>
+endobj
+68 0 obj
+(mDiffFit)
+endobj
+69 0 obj
+<< /S /GoTo /D (subsubsection.2.2.7) >>
+endobj
+72 0 obj
+(mFitplane)
+endobj
+73 0 obj
+<< /S /GoTo /D (subsubsection.2.2.8) >>
+endobj
+76 0 obj
+(mImgtbl)
+endobj
+77 0 obj
+<< /S /GoTo /D (subsubsection.2.2.9) >>
+endobj
+80 0 obj
+(mMakeHdr)
+endobj
+81 0 obj
+<< /S /GoTo /D (subsubsection.2.2.10) >>
+endobj
+84 0 obj
+(mJPEG)
+endobj
+85 0 obj
+<< /S /GoTo /D (subsubsection.2.2.11) >>
+endobj
+88 0 obj
+(mOverlaps)
+endobj
+89 0 obj
+<< /S /GoTo /D (subsubsection.2.2.12) >>
+endobj
+92 0 obj
+(mProject)
+endobj
+93 0 obj
+<< /S /GoTo /D (subsubsection.2.2.13) >>
+endobj
+96 0 obj
+(mProjectPP)
+endobj
+97 0 obj
+<< /S /GoTo /D (subsubsection.2.2.14) >>
+endobj
+100 0 obj
+(mShrink)
+endobj
+101 0 obj
+<< /S /GoTo /D (subsubsection.2.2.15) >>
+endobj
+104 0 obj
+(Backgound\137list)
+endobj
+105 0 obj
+<< /S /GoTo /D (subsubsection.2.2.16) >>
+endobj
+108 0 obj
+(create\137status\137table)
+endobj
+109 0 obj
+<< /S /GoTo /D (subsection.2.3) >>
+endobj
+112 0 obj
+(Batch Wrappers)
+endobj
+113 0 obj
+<< /S /GoTo /D (subsubsection.2.3.1) >>
+endobj
+116 0 obj
+(mBackgroundBatch)
+endobj
+117 0 obj
+<< /S /GoTo /D (subsubsection.2.3.2) >>
+endobj
+120 0 obj
+(mDiffBatch)
+endobj
+121 0 obj
+<< /S /GoTo /D (subsubsection.2.3.3) >>
+endobj
+124 0 obj
+(mDiffFitBatch)
+endobj
+125 0 obj
+<< /S /GoTo /D (subsubsection.2.3.4) >>
+endobj
+128 0 obj
+(mFitBatch)
+endobj
+129 0 obj
+<< /S /GoTo /D (subsubsection.2.3.5) >>
+endobj
+132 0 obj
+(mProjectBatch)
+endobj
+133 0 obj
+<< /S /GoTo /D [134 0 R  /FitH ] >>
+endobj
+136 0 obj <<
+/Length 216
+/Filter /FlateDecode
+stream
+xڝMK1†ïùïq÷°ãL>&ÉQA¥Ain¥‡bÛ¥`-…Bÿ~³¦E/^2IfxÞy#Ïæ¡˜»§ÀÈ”Õ*ÊjI#GrÙ¡l°ì—ýîÜ6p÷rü<¯Çm{Ü¿ÎúU™W€ U€º	às"ñ‚A„r
+±ŸÍc1'#5˜!JZbR¶x?˜åб©½9˜*—¯É‚0Y§õþ…y3|[þgm2’(d•ië˜"xö”¢ÿîSóé…»±ê¹m¿7±?ƒ~óð‰¼KÿѸº+Ui
+endstream
+endobj
+134 0 obj <<
+/Type /Page
+/Contents 136 0 R
+/Resources 135 0 R
+/MediaBox [0 0 595.276 841.89]
+/Parent 142 0 R
+>> endobj
+137 0 obj <<
+/D [134 0 R /XYZ -16.307 900.716 null]
+>> endobj
+140 0 obj <<
+/D [134 0 R /XYZ 56.693 759.068 null]
+>> endobj
+135 0 obj <<
+/Font << /F50 138 0 R /F51 139 0 R /F52 141 0 R >>
+/ProcSet [ /PDF /Text ]
+>> endobj
+178 0 obj <<
+/Length 903
+stream
+xÚí›Ko›@€ïüŠ=í¾Ù=&ižRT·¶ÔCEÄ`‡ÆØ.ƉúïËcÁPU±¢’½ÃÌÀÇììÌ,ÌçÖñÄúrÆPP	"ÀdÂy*
+&¸±ÇÏÑ,u\‘}½Z¦þ<,.ÛÉU& ™	4À”€8Ûãb祈(ʏ´N'ÖogšÀ€(2žÂP ¦±us‹@ýwdJ‚çâÈpŒ ¡"û¾ cë»…^XO &PaÌsí•P& Ç¢T~’.ÓMaB©;™k#~œç"¼½€€KDŒ•'cÇÅ!ûÛ“ƒ‘&ùçS>ka¥!€#Iv±¨:©[p«]âA©´DëøÏ~µºZ—))ÎÑxPQM—Àâ35G"ûÏ:ܼTvãJ*lèd¶£O»aJõÅ–Ì„¨Ÿ€roǃGraš<©ÉìI&ö2Ο¶†hްAܶ¨åАh¬¡dcVÓŸ5@‡”j Åíß/Z¾*‘a:L´L£½ž7…z„ªÃ¡ºX¹¦:NýtÛšQqÎMd¤·
+ÍõØŸ>ΓÕvŒÓd;M›
+”G
+°·F æi`_£™C¸=ëÆÅ<ソ$ê¾È\j®Dç¬Gëu™#’Õ4¶I;{å”›A¶Ç„»SSR§¦ñQ´3S8‡8“:3w´)›Rf8ö ­ίWA¸h
+Šg|Oˆô ˆUΟ¬–S?=‹Z"N<ƒ±—÷Bd•dÆÕä¶EQš
+î0=T4Ñvø¨ÊðÏ*
+3Žë…¿lpcæ@`Ê
+æe<Oï[S ŠLÆ9°Hª*¢×þcÑè¿Zm3Á
+ÈÞ»&FŽëå »Ú)67F½€Âkžùn‡ÉÂ_·¨x&Yé?I¢IŽ’Õ¯°]‚—ÒÌf{Ír¿6K_²Lý`ˆ.É4ÆñC-?Û<ö#†K^-ªëyqýnm:ºÄ0ì!<Q›&¡Ÿ†w›béÈ]ÚµÜK0lн53þºft©nFûéô¡lGÿLüõ:LZ3U&ͪé>î^m at wÍè]Û²¤ÝÐB¸ñË÷§†ÚÀH³~Þ‰‹)i<¯ï(iG+¤“¦”Âðë	¿]pÜ5›ÿō|ÔòMÏaŠœ±n9ë̿ۑ0ß—]¹ízÁ’!ˆ„:äýʿې³
+endstream
+endobj
+177 0 obj <<
+/Type /Page
+/Contents 178 0 R
+/Resources 176 0 R
+/Parent 142 0 R
+/Annots [ 143 0 R 144 0 R 145 0 R 146 0 R 147 0 R 148 0 R 149 0 R 150 0 R 151 0 R 152 0 R 153 0 R 154 0 R 155 0 R 156 0 R 157 0 R 158 0 R 159 0 R 160 0 R 161 0 R 162 0 R 163 0 R 164 0 R 165 0 R 166 0 R 167 0 R 168 0 R 169 0 R 170 0 R 171 0 R 172 0 R 173 0 R 174 0 R 175 0 R ]
+>> endobj
+143 0 obj <<
+/Type /Annot
+/Subtype /Link
+/Border[0 0 0]/H/I/C[1 0 0]
+/Rect [55.697 706.356 113.38 715.332]
+/A << /S /GoTo /D (section.1) >>
+>> endobj
+144 0 obj <<
+/Type /Annot
+/Subtype /Link
+/Rect [55.697 676.558 154.535 687.437]
+/A << /S /GoTo /D (section.2) >>
+>> endobj
+145 0 obj <<
+/Type /Annot
+/Subtype /Link
+/Rect [70.641 658.49 119.099 669.394]
+/A << /S /GoTo /D (subsection.2.1) >>
+>> endobj
+146 0 obj <<
+/Type /Annot
+/Subtype /Link
+/Rect [93.555 640.558 152.324 651.461]
+/A << /S /GoTo /D (subsubsection.2.1.1) >>
+>> endobj
+147 0 obj <<
+/Type /Annot
+/Subtype /Link
+/Rect [93.555 624.682 156.19 633.529]
+/A << /S /GoTo /D (subsubsection.2.1.2) >>
+>> endobj
+148 0 obj <<
+/Type /Annot
+/Subtype /Link
+/Rect [93.555 606.749 149.315 615.596]
+/A << /S /GoTo /D (subsubsection.2.1.3) >>
+>> endobj
+149 0 obj <<
+/Type /Annot
+/Subtype /Link
+/Rect [93.555 588.817 150.122 597.663]
+/A << /S /GoTo /D (subsubsection.2.1.4) >>
+>> endobj
+150 0 obj <<
+/Type /Annot
+/Subtype /Link
+/Rect [93.555 570.884 151.786 579.73]
+/A << /S /GoTo /D (subsubsection.2.1.5) >>
+>> endobj
+151 0 obj <<
+/Type /Annot
+/Subtype /Link
+/Rect [93.555 550.894 199.925 561.798]
+/A << /S /GoTo /D (subsubsection.2.1.6) >>
+>> endobj
+152 0 obj <<
+/Type /Annot
+/Subtype /Link
+/Rect [93.555 535.018 167.576 543.865]
+/A << /S /GoTo /D (subsubsection.2.1.7) >>
+>> endobj
+153 0 obj <<
+/Type /Annot
+/Subtype /Link
+/Rect [70.641 515.028 159.457 525.932]
+/A << /S /GoTo /D (subsection.2.2) >>
+>> endobj
+154 0 obj <<
+/Type /Annot
+/Subtype /Link
+/Rect [93.555 499.153 152.334 507.999]
+/A << /S /GoTo /D (subsubsection.2.2.1) >>
+>> endobj
+155 0 obj <<
+/Type /Annot
+/Subtype /Link
+/Rect [93.555 479.163 183.876 490.067]
+/A << /S /GoTo /D (subsubsection.2.2.2) >>
+>> endobj
+156 0 obj <<
+/Type /Annot
+/Subtype /Link
+/Rect [93.555 461.23 172.817 472.134]
+/A << /S /GoTo /D (subsubsection.2.2.3) >>
+>> endobj
+157 0 obj <<
+/Type /Annot
+/Subtype /Link
+/Rect [93.555 445.355 174.481 454.201]
+/A << /S /GoTo /D (subsubsection.2.2.4) >>
+>> endobj
+158 0 obj <<
+/Type /Annot
+/Subtype /Link
+/Rect [93.555 427.422 151.527 436.268]
+/A << /S /GoTo /D (subsubsection.2.2.5) >>
+>> endobj
+159 0 obj <<
+/Type /Annot
+/Subtype /Link
+/Rect [93.555 409.489 162.605 418.336]
+/A << /S /GoTo /D (subsubsection.2.2.6) >>
+>> endobj
+160 0 obj <<
+/Type /Annot
+/Subtype /Link
+/Rect [93.555 389.499 167.836 400.403]
+/A << /S /GoTo /D (subsubsection.2.2.7) >>
+>> endobj
+161 0 obj <<
+/Type /Annot
+/Subtype /Link
+/Rect [93.555 371.566 161.748 382.47]
+/A << /S /GoTo /D (subsubsection.2.2.8) >>
+>> endobj
+162 0 obj <<
+/Type /Annot
+/Subtype /Link
+/Rect [93.555 355.571 173.255 364.537]
+/A << /S /GoTo /D (subsubsection.2.2.9) >>
+>> endobj
+163 0 obj <<
+/Type /Annot
+/Subtype /Link
+/Rect [93.555 337.758 157.873 346.605]
+/A << /S /GoTo /D (subsubsection.2.2.10) >>
+>> endobj
+164 0 obj <<
+/Type /Annot
+/Subtype /Link
+/Rect [93.555 317.768 170.994 328.672]
+/A << /S /GoTo /D (subsubsection.2.2.11) >>
+>> endobj
+165 0 obj <<
+/Type /Annot
+/Subtype /Link
+/Rect [93.555 299.835 163.402 310.739]
+/A << /S /GoTo /D (subsubsection.2.2.12) >>
+>> endobj
+166 0 obj <<
+/Type /Annot
+/Subtype /Link
+/Rect [93.555 281.903 174.481 292.806]
+/A << /S /GoTo /D (subsubsection.2.2.13) >>
+>> endobj
+167 0 obj <<
+/Type /Annot
+/Subtype /Link
+/Rect [93.555 266.027 161.749 274.874]
+/A << /S /GoTo /D (subsubsection.2.2.14) >>
+>> endobj
+168 0 obj <<
+/Type /Annot
+/Subtype /Link
+/Rect [93.555 246.037 189.972 256.941]
+/A << /S /GoTo /D (subsubsection.2.2.15) >>
+>> endobj
+169 0 obj <<
+/Type /Annot
+/Subtype /Link
+/Rect [93.555 229.081 203.232 239.008]
+/A << /S /GoTo /D (subsubsection.2.2.16) >>
+>> endobj
+170 0 obj <<
+/Type /Annot
+/Subtype /Link
+/Rect [70.641 210.172 160.005 221.075]
+/A << /S /GoTo /D (subsection.2.3) >>
+>> endobj
+171 0 obj <<
+/Type /Annot
+/Subtype /Link
+/Rect [93.555 192.239 207.118 203.143]
+/A << /S /GoTo /D (subsubsection.2.3.1) >>
+>> endobj
+172 0 obj <<
+/Type /Annot
+/Subtype /Link
+/Rect [93.555 176.363 174.769 185.21]
+/A << /S /GoTo /D (subsubsection.2.3.2) >>
+>> endobj
+173 0 obj <<
+/Type /Annot
+/Subtype /Link
+/Rect [93.555 158.431 185.848 167.277]
+/A << /S /GoTo /D (subsubsection.2.3.3) >>
+>> endobj
+174 0 obj <<
+/Type /Annot
+/Subtype /Link
+/Rect [93.555 140.498 169.499 149.344]
+/A << /S /GoTo /D (subsubsection.2.3.4) >>
+>> endobj
+175 0 obj <<
+/Type /Annot
+/Subtype /Link
+/Rect [93.555 120.508 186.645 131.412]
+/A << /S /GoTo /D (subsubsection.2.3.5) >>
+>> endobj
+179 0 obj <<
+/D [177 0 R /XYZ -11.232 900.716 null]
+>> endobj
+176 0 obj <<
+/Font << /F50 138 0 R /F51 139 0 R /F52 141 0 R /F57 180 0 R >>
+>> endobj
+183 0 obj <<
+/Length 1788
+stream
+xÚ½YKsÛ6¾ëWðHÍÔ|NOÉ4I™¶i­[šÉÐ$3¡H•¤âº¿¾»X€")º•¢ØáA`±¯owqoãqïíìÕböâMȽ”¥‘Œ¼ÅÚ‹$‹b/á1S©ò+ïƒsŸ¯Ûù•¹ÿKU¶ÙFÓàåûëùÇÅ;  ¼D
+		PHïJ–†!‘°#NüÔD¸möz1ûk&€
+î	/ŒXçÅ©`—Þr;ûð‘{+øöÎã,HïÞ¬Üz¡àLªú…w3û}Æ­(| ’ô„d©!²äˆEä8BÜ&ïÕàœû¿}Õõºþ×\ÏEèß[ûâÞ•LXÅ]Þ€TiàSú흦	ԏ鬫zôÉ©º•‚û:ÛítݰùU¨þ·ýŒ†mU_òvtÂF—ºÎÚ¼ÜЇf™ëri)lêleÊš¶®Êj›/³‚>n«&Ë—îäp
+¢£°};æÛÎúr.Û‡ã·YÛõ'|Å0í›ÂèõïüÖí½>\ÌUè×YÙìªÚR»yhZ½¥¾#üæzqÃ:îb–(1tTn•mFÍ*k3`XUs‰F5s»¬ÎŠB4j–u¾³zƒa‘•›=0ÆH]c¸Þ¼¥^DÑžÖºeûýHr0y5<-ÿG8»Ÿ”ì˘»ö.³¢Üe–ú­Ö%õj½«u£ËV¯,±f`-ëãx„~ƒj!ù@ÅU§(ø˜ow…Þ©†Æ$îÊ[Û#‹á^îÛ¼*iz[­ŒòpSE-H8~'̐7 ‘5΢ӠGÚÃAMÔ©Ö–À\öpe–ùLƒ°Õ¾^êf@”˜E}ۏ  ¼ùdŒ»vw¢a
+01;ªv ±Æ.ì¸0s|ŽT@ÑÆXàתÕ1r„ªWU{‡†II %,x@—;¾ÍË#Sèç¨\›ÙÖxÍ›…n–(AÇÚ»c"°|‹›÷[`÷ä岨¯Ð¹pM^Òìì@£÷s׿wñ3́¢ýr-[cdÜNæ´çf·¸¢°ç¬çŠ`=àø¾F¦(N!ãmFÖûriÝF»ºÚi:¥x ÜgÇiÆÙ’ƒ aïÿO/a,™”Öðr2½8Ü»ÖÀÜߘ|£iÖ¦Ôn#ÅY¦.÷(¹'µ§°é4¶˜GÜØéæ‘ô0)—¿tcÃoV»:v_&2'– wѾ۳ÒË«Q03r¢`‡Ñ΢´ºèkƒ“ûiÆûdóʧùa
+p¤´Ø@g±;=¢5ÈD}ƒ˜%àu¸
+›Qä‹yàQÂxd\	硾`RxG’zµöÖýe at mzöø€0fZ{ ¸úRúä¶#ú®¼:å„>­ˆ¥2ýÌ‚õÆ£Îp)'ƒ=¼"VÚ˜ Î0ŠöcB`戻zchÿÇS­Qµ'ËÕ>@xJxÃ*“'¾km©‘tõ΁LÁù×íp9$È•]d2´éZÌŽÖU¾´©7?À@Äb?ëeë(å@©ÿy•›¿Öµ-9‡û#Hã¯Ð…þ׬\8¡’ô$ppO‡ÞŸ5Ô¾õ‰fVIÈÙ'µŠHñd Ñ¿Ô—3{:¨Uƒ‚’sAÝ·îù¨V±`’ρjB2Á Õ½ëQ—ö¬@4I°ÆzÝ×[Xã¢j‡mŽ-í×m¶.ëÂËõîzGRÖ=yê‘bj¨û„©ûN´— ®èé (Sà]ÅOÀýË x9³§n»Œ»Zét .Ìeíñ'“„ÅAòø“X®¹÷Ÿ‚œåZºƒ@Ç:ma‡‚¡
+ýŸö5&>|(옸%ã4Þlë¦.ü8U8ü~5j|”Qö¾\èfHj«Û4†¬Û—½2|®°WæòåÄ@‰:Q±†w¬M¼ÞoÜ]ëw†ñ¤†à1*ý»S’jlèjDÍ­¿¿rB7Q蟆‚É0ôîýë·§ú#'	“§‹>"OÓ'‹>#ú—EŸË™=#úp¨é“èÜès°í$#S6)VòÏrD¬÷”ÿHùFˆqÂ?^œòOîŸwzÙØÒГÉþ¾­à§ß:Ú¬Ý7'"NH,¸ƒ'Dœ€öpqûþˆÒ¿q3{:â„À‚[‹¸¾uÏOøòL £ç@_
+õ6Oà‹#Sìþ‰†ä1}¿$6ÉÞü%€ÓníÑ=¹¬Ÿ
+ªúë'ŸøiOwf÷Ì}*ߡӥtǬyuƒwöñ<:,/éÏû.
+Éÿ¶Ú·‡E‰~Yç^ùîs÷"x«‹Bær¿~EsÔ©ÿýÎx”~Ëß~ÿ£f©&
+endstream
+endobj
+182 0 obj <<
+/Type /Page
+/Contents 183 0 R
+/Resources 181 0 R
+/Parent 142 0 R
+>> endobj
+184 0 obj <<
+/D [182 0 R /XYZ -16.307 900.716 null]
+>> endobj
+2 0 obj <<
+/D [182 0 R /XYZ 56.693 759.068 null]
+>> endobj
+185 0 obj <<
+/D [182 0 R /XYZ 56.693 731.272 null]
+>> endobj
+6 0 obj <<
+/D [182 0 R /XYZ 56.693 596.031 null]
+>> endobj
+186 0 obj <<
+/D [182 0 R /XYZ 56.693 556.98 null]
+>> endobj
+10 0 obj <<
+>> endobj
+187 0 obj <<
+/D [182 0 R /XYZ 56.693 529.727 null]
+>> endobj
+14 0 obj <<
+/D [182 0 R /XYZ 56.693 500.03 null]
+>> endobj
+188 0 obj <<
+/D [182 0 R /XYZ 56.693 474.337 null]
+>> endobj
+189 0 obj <<
+/D [182 0 R /XYZ 56.693 468.461 null]
+>> endobj
+190 0 obj <<
+/D [182 0 R /XYZ 56.693 471.351 null]
+>> endobj
+18 0 obj <<
+/D [182 0 R /XYZ 56.693 417.347 null]
+>> endobj
+192 0 obj <<
+/D [182 0 R /XYZ 56.693 391.654 null]
+>> endobj
+193 0 obj <<
+/D [182 0 R /XYZ 56.693 385.778 null]
+>> endobj
+194 0 obj <<
+/D [182 0 R /XYZ 56.693 388.667 null]
+>> endobj
+22 0 obj <<
+/D [182 0 R /XYZ 56.693 334.664 null]
+>> endobj
+195 0 obj <<
+/D [182 0 R /XYZ 56.693 308.97 null]
+>> endobj
+196 0 obj <<
+/D [182 0 R /XYZ 56.693 303.095 null]
+>> endobj
+197 0 obj <<
+/D [182 0 R /XYZ 56.693 305.984 null]
+>> endobj
+26 0 obj <<
+/D [182 0 R /XYZ 56.693 240.025 null]
+>> endobj
+198 0 obj <<
+/D [182 0 R /XYZ 56.693 214.332 null]
+>> endobj
+199 0 obj <<
+/D [182 0 R /XYZ 56.693 208.456 null]
+>> endobj
+200 0 obj <<
+/D [182 0 R /XYZ 56.693 211.345 null]
+>> endobj
+30 0 obj <<
+/D [182 0 R /XYZ 56.693 157.342 null]
+>> endobj
+201 0 obj <<
+/D [182 0 R /XYZ 56.693 131.648 null]
+>> endobj
+202 0 obj <<
+/D [182 0 R /XYZ 56.693 125.773 null]
+>> endobj
+203 0 obj <<
+/D [182 0 R /XYZ 56.693 128.662 null]
+>> endobj
+181 0 obj <<
+/Font << /F50 138 0 R /F51 139 0 R /F52 141 0 R /F90 191 0 R >>
+>> endobj
+206 0 obj <<
+/Length 2021
+stream
+xÚ½Z[³›6~?¿‚G{&Q%¡LŸÒ{:ÓNÚœ·4“Á€m&6¸€{æL§ÿ½«›
+ØNÀ
+y±….ß®öÚ]	lüüðÝãÃ7?qÄ(Të@P$da‰Â8³àÝâíS±n—/)Njߪ²M6¹yxõæõòý㯠@‚ D¨ X^‚bÎ
+…2Z|cþ„öðããÃßÔÀ	¸@äɘ iîÞ½ÇAm¿±8
+žtÏ}À	F4PÞoþxÀv*¸7%ÚÑÈa³,¬Bi5ܸàÝK‚1^|—¤KŠ7µú«Žeö¶­ik:ÔTõ÷ó`!’˜2¤H5U͉@”°€¢8Šƒ:Ö]{`×k/ñ)A’S'À ÕÛßZ©ï¬=FBK ˜Æ_ at Y
+XoSøÓÒcC/ëÒK9ÂalèmŸyÝK à[ºê!ÍW•ºJ7ÌF‚ôÙèèã{Òá«ìmã†pdlÿïÈ7EÄ1ŠB6›éø~¦óWvÄJ–l48D„cͦ­‹r3n-¯ËdŸ6µÅ·céˆ"I>}|O:¼•O‡ˆÁYë×»*iDZ‘ÜÍ„”(&b>&úøžLx+;‰ˆ
+šÊÄên&Ô$¹œ‰>¾'ÞÊN`B‚¦ŒOf"½›	ÎQQàlLôñ=™ðUö¦Ÿ<F4²1ìã"ŒcŸ ôjÝÍœ‚þâÈFÛ¢ˆŸÅóÁž¨jé²
+ÕÐòeˆc蟛º¼¯—»1µ­=VQ·­«Ú¢¸¡Úê¶j=h*ö&uQ˜eæëÜ6§U¾^R¾øcš ‚•ßV¦½ÎÓ¶X?»qnJ‡ªn‹ª4Õ™Ñb_5I¡W=Ø­—鮐E%»)€Ü^$37x>TEiÓ.e£õޝAŽà!—xÎnäÕìæ‡b½ž”Ïp	°BΗÐp-x¾7{€ï÷fû+;>¡á‚!‹©	͐áÑ©‡ü8fñ|Dôñ=‰ðUö¶ÙÁ4”ÓrNLæ³]ßÓvÞÊŽ8£ˆJëÔ~6.L€ýŸÜ*p!ÎwB2À÷äÂ[Ù	\€‡I|ôn.ˆDXÎw<2À÷äÂ[Ù	\PŒB»·¿ÖqÉ(2»cs7X Bæ;oà{rá­ì.pŒ¦“ÉØåýl°˜#Âç;nàû±á¯ìx6X!ÆÂÉld÷ÜMFdB­ÙÈèã{’á«ìÍЇEúÄì’éSù5²Ká÷)ýµÙ¥&»B'ˆðxÊ.¡ì²Kmv	uçìR©mmû´$xQ™‡´‚>ÕÎÂ/É¢ló%á‹M^[™í6±"öÉG5ÒÁl6J̳©<–ÅßÇü…ºý"67ìK&9½À®”ÐÔO^ï’Ã!ÏLï§m‘nM5nzi­có`n}†I5uÖËíÎõbPiô‚Ây¨ËQOMð’©y×y™Ú:—Vë~I{Z?[ê*;¦yv%…UW<.‡
+!Ù¤.‰¥WSØW‡ƒ¹F|cnè ÷X獽Šì® ¤ÜìiÁäUÔ°Þ;OSL4¼QÚAëgsÖ …ËûPµÂˆYaçIŸdìª4iskå¢ÈSÇ
+»¼ƒüÁ‚~€‰6¨ÑÂú; ùk‚#ÆYJŠ¢ËûÓ°sªöמÝýéå}©Ã‚—»—í÷ªÍ¯\öÎ4¾?Ö°0Úݳ!ÈÌ
+ÕA‘4¶¶´ž/•áa},ÓNgcD(l“:3¥´Êr[4k·‹ulòÚvKʲjmy[Uíñ´…×Ù¼=·4 ñX¢Ë{jg›P¢8œdçÏÞO‡˜é“·ø¹ºü÷¯2µmd#wg;•t¾ó*%âd¾€ïç;ý•~C#Œlâ«ö”—*dùslëo5S¢Ñª¹!ƒ|Z,¨l8}QÍŠýæ"L~÷þŧñ“Õn<þ‡vµŠøŒ€_ò$ƒ½b”„mVÚ¶Ÿ
+%Cœ²¯$Q)\:cƒ¤ˆX¿ѳ_3õO…vÐg¹ªôÚÐUëcZÚsn¨_×Õ~Ðõ¼‹«ÚªÚ},Zð‹óŽÙ­
+¡}£RÕ<5:Q\¤E˜º•ÅJ2å®´·Õ&-ë%ÃóPw<OÙiéèãà¡ÐÚ@AwPí0ãn þ9ÿéõã[SÚšå¤Ë'—> 5{% Ë«Ü÷C1­s%è«bƒU¨îZÌ ”¦TÛÃQßQÀCbþ@Ûå׌`Äçx­ÎèØKnxb´µΫ‹héÄHÍ®)(­\šÔí0¦,š®[>6'š"ËoMÍ)DÍ
+u/SA¤-øbÒÉ­ørùØÈ—œ@&ÄèŒw%DbÄÄ|w%|?_ë¯ìx_K$È­õ¯ámW›°wÜépÏßœÍíw'úDŸ¯[¾ôj>èÔӍ!!šþ*7é„	ĹìŸu„֍‹¾c€z»åBƒuãPgOXoÅé—e™fëÍ»#ÎÞ\Õž¼yÈIG—ž
+¬çÍ¡µ°è‰y´¾IW¹#5Ÿ]e>oz¬§¢Ýv}wYÅËËúNÞOßO Ö‰Ç9€^u
+¤½ØGŸòöó)G²nóz0þêÇP¿M”1'8Î#:E€Ê]1<¹öU4Ëøž¢ÿZú­
+endstream
+endobj
+205 0 obj <<
+/Type /Page
+/Contents 206 0 R
+/Resources 204 0 R
+/Parent 142 0 R
+>> endobj
+207 0 obj <<
+/D [205 0 R /XYZ -11.232 900.716 null]
+>> endobj
+34 0 obj <<
+/D [205 0 R /XYZ 56.693 759.068 null]
+>> endobj
+208 0 obj <<
+/D [205 0 R /XYZ 56.693 739.087 null]
+>> endobj
+209 0 obj <<
+/D [205 0 R /XYZ 56.693 733.109 null]
+>> endobj
+210 0 obj <<
+/D [205 0 R /XYZ 56.693 735.998 null]
+>> endobj
+211 0 obj <<
+/D [205 0 R /XYZ 56.693 725.039 null]
+>> endobj
+212 0 obj <<
+/D [205 0 R /XYZ 56.693 714.08 null]
+>> endobj
+213 0 obj <<
+/D [205 0 R /XYZ 56.693 703.121 null]
+>> endobj
+214 0 obj <<
+/D [205 0 R /XYZ 56.693 692.163 null]
+>> endobj
+215 0 obj <<
+/D [205 0 R /XYZ 56.693 681.204 null]
+>> endobj
+216 0 obj <<
+/D [205 0 R /XYZ 56.693 670.245 null]
+>> endobj
+38 0 obj <<
+/D [205 0 R /XYZ 56.693 604.038 null]
+>> endobj
+217 0 obj <<
+/D [205 0 R /XYZ 56.693 578.243 null]
+>> endobj
+218 0 obj <<
+/D [205 0 R /XYZ 56.693 572.266 null]
+>> endobj
+219 0 obj <<
+/D [205 0 R /XYZ 56.693 575.155 null]
+>> endobj
+220 0 obj <<
+/D [205 0 R /XYZ 56.693 564.196 null]
+>> endobj
+221 0 obj <<
+/D [205 0 R /XYZ 56.693 553.237 null]
+>> endobj
+222 0 obj <<
+/D [205 0 R /XYZ 56.693 542.278 null]
+>> endobj
+223 0 obj <<
+/D [205 0 R /XYZ 56.693 531.319 null]
+>> endobj
+224 0 obj <<
+/D [205 0 R /XYZ 56.693 520.36 null]
+>> endobj
+225 0 obj <<
+/D [205 0 R /XYZ 56.693 509.402 null]
+>> endobj
+226 0 obj <<
+/D [205 0 R /XYZ 56.693 498.443 null]
+>> endobj
+42 0 obj <<
+/D [205 0 R /XYZ 56.693 432.236 null]
+>> endobj
+227 0 obj <<
+/D [205 0 R /XYZ 56.693 403.851 null]
+>> endobj
+46 0 obj <<
+/D [205 0 R /XYZ 56.693 322.8 null]
+>> endobj
+228 0 obj <<
+/D [205 0 R /XYZ 56.693 294.848 null]
+>> endobj
+229 0 obj <<
+/D [205 0 R /XYZ 56.693 288.87 null]
+>> endobj
+230 0 obj <<
+/D [205 0 R /XYZ 56.693 291.759 null]
+>> endobj
+50 0 obj <<
+/D [205 0 R /XYZ 56.693 213.598 null]
+>> endobj
+231 0 obj <<
+/D [205 0 R /XYZ 56.693 187.803 null]
+>> endobj
+232 0 obj <<
+/D [205 0 R /XYZ 56.693 181.825 null]
+>> endobj
+233 0 obj <<
+/D [205 0 R /XYZ 56.693 184.714 null]
+>> endobj
+204 0 obj <<
+>> endobj
+236 0 obj <<
+/Length 2171
+stream
+xÚÍZKsã6¾ûWð(U­<H8&»;ɤjª’Œn“©)Z¢dîH¤CÑëÊ¿Oh€ ‡Ž%ÓÒîEš@wãÁþð¡I“]B“o~XÝ|÷.£‰"Jr™¬¶‰äDæIAs"”HV›äÓâãS½í—·<£‹mÓ—»ÊV¾ÿåýòóêgPÀ’H¡¤h(Òä–1¢²ÌªÐ#/ßÙ?©»Ýü{uóÇ
+7hÂ’L	örň¤<Yn>}¦ÉžýœP’ª"y2-IÆ(áBByŸ|¼ùõ†âPh4$xät§Š0*­Cœp"Œ®_òé–QJ‡vÚMµ·aú¹þûqä± 9M“\R€{à±–gLÎÒ„U¨¤«’mèb¤mZú­º„r¬b¦[ÏՏÓëwÓ{Š…P—$Š«7pÖ(ìv‰-ü†ë©¨]Ï4\OSÍs»žåÃÃx5%,æï4£(ëÅ«òn_E]ŸmÚUëþK·Æû{Cñ¾ò½ßÖÅú°›ðpñ73°­ûãËsðò[à â@ؘñÖL¾öa$sÛ„2’RŒC«ûú¸¼ia6Œ)<tíºÚ<v•­>Õû½-­K[R‹~É÷Ë[¶À6~)Mmûجûºm°Öµ[êï±¹šFÚ¶û¯uO–0e©÷GÝè˯KFz[£öÿëàÐ,Z,{½ 0!6úb°ëª‡®:VMÔñ7·žñ\.öõ±·¢vk%F±oVöVj'EËî°g¹ÙT+ª›¾E¡ÚcY¯m¹l6Ñ3ôVK¬ÉÀ›ºÙ¶Ý¡´s;P£K]õÇcÝ9ËÎîï”òÞ+;Xaßî*¨uË,[hVü^@¦^Wq°P‚î-µýÃ#b`iÿt4¨µåµóX÷Àáé.[¯ÄÖmµ]òÌx»®q5Lƒ5XºÃ>°K÷µ®nØŽ4ÚÅ"Ñ»8Â>³ „ål€½töþÙ60’wuâ+,'ŒÉ˟䌰,¿ðôϾùΞ|’§$MÓëßiAÿYàí¬Aß±/ûÇã+Ðï£éxº‘ãXÿ§ÏËsñO²‚0Y\ÿ2¥ˆä<Ä?ž!þéBý”~ÿt	N.¥©Ч»Zè‹:|!„>!²À•ȃútµFí¥{ж`­nvƒÝ‰Ho·4I¹‰¾û
++zS¶xªŒyíª¦êÊÞ]¨â  TÕNLù Sð°/›Êönø_µ	ñ[;C ±ø§öW÷Ù:`¶ø¬ŸåÑö©@!=´@ø‚‡áô鑨´š›©é˜ ³	Ü*´ï^F÷0…P{+`õV/vÀÎ[‚Õ¬7Ûš±õò€¥M­±·íþ\J„ö—Џè—M£,ÜöÄw7•BˆË_‡c‘§¾‘þyÀ7ßÙӁ/v)%Ÿ	|ïÍÙù¤p¿]ñ8Õ+oØTç`ÞþÁ«ÿíßv&æ½Æ?ÓÆOU¹˜p’‘ûM7“Qê×PÙ55U9)„Š%WÈ(yLå¸g”ð %”,7„‚G[
+¸$w€ªuøö—ÔZ< fiî=‰)­npI¨Ö¨½ÒÒ…ÈûÌ@4fEVß½_}œB’{»Ä€çƒ».ç‹m‹B«
+–jO¥²à Û…Ž
+G3±_c›8°ÒÒÒþmpÊ ²›5jr„ÇÇ‚À‹<f˜ú‰;cù¾ê°wÙÍÏĸ=KÖx¹dÙâ¿ú§êöåùlL>G§s±”$Ë.‡H)ËI¦ØÅi¤"ÍwötDJ9%E®þçˆôÖgཊç1†»ÿ¤KYJ$×@:¡$¡YsÇÌqÇ4fn™çŽ™çŽ©;¿gcn’=¦ž=fC—€=¦!{ä©ã/«µ<"Ò•ÙëÄйu{¸«›òvêöt¸ÝûæJ/@oCd¼©é!TGg_ÕåÓàൟ¶a„(HÎ/HXÏI./GXFúçÁÃ|gO‡!¼?s	Ë•‚w¼«.½OcT/oiž’<¿Êi_PfŒOûŒâiŸÆ§}沺„§}êNû,Šºœö©?í3:´Nû4<í§…
+<9žö)žöµ¿ØÚ\!…f Íè@ý܁‚™òé
+Åæ|l®¦ bc¢
+R% Ę®\ÈQ2U༖à×Uœ”QþVKù¤ÈKöDþ¶IQOH¬w%6\ë)­›±×!3˜º2C¸oµïOq>Æ¥Ÿ,21è{z5dj¦nË΄bÞvý6wêW>‰J/‡œg ër„a¤"ÌwötD€HB¸T×ËÝLp*&˜µ¿ôyþ-2*\y¢ø5S“Ñ©X2<Ë8tIº¤C-³qG3l¤ÁÉað[‡X-Ä)÷~|c>L§H¼W×Þúº¡Zdÿ0E!ñ¼½¤	zñqÝUeN–6_ãR
+8“õQîÜ®†à­}@Ý%¦zÚÈ 1¡\—4þžAQWù”¸1ö½›øþ>zì„N¬ÐÆm+whù¡ìztuë:8G¯LcbF.–ËÐ@M£Á‡òkõ“£™/¾8Ldqü­±€ÁY©Ë}À6Ò?æ;{:0`"i!gbÁ›^><ÑžºêÇkçã6ð5p€QŽJ#f@¹c":˜ƒ™<pÌ€»#¸0l´ždó($‘ƒ°K@xH¤Oü¬¼F3åÑÕ-KТEÒÇ‘ÎC¸£Œ¼@ê£õB,_ჹð@é›ÚË“€×íçeÂ~ ŠÅ”;ƒ>­ hŽØ"â
+"ÈD ?¡&Ía4¸Ä†–zeØ˜º"òBèO¸…§¾sN)¡R½æ3ç¿ £²I
+endstream
+endobj
+235 0 obj <<
+/Type /Page
+/Contents 236 0 R
+/Resources 234 0 R
+/Parent 142 0 R
+>> endobj
+237 0 obj <<
+/D [235 0 R /XYZ -16.307 900.716 null]
+>> endobj
+54 0 obj <<
+/D [235 0 R /XYZ 56.693 759.068 null]
+>> endobj
+238 0 obj <<
+/D [235 0 R /XYZ 56.693 739.087 null]
+>> endobj
+239 0 obj <<
+/D [235 0 R /XYZ 56.693 734.297 null]
+>> endobj
+240 0 obj <<
+/D [235 0 R /XYZ 56.693 737.186 null]
+>> endobj
+58 0 obj <<
+/D [235 0 R /XYZ 56.693 661.911 null]
+>> endobj
+241 0 obj <<
+/D [235 0 R /XYZ 56.693 637.304 null]
+>> endobj
+242 0 obj <<
+/D [235 0 R /XYZ 56.693 632.514 null]
+>> endobj
+243 0 obj <<
+/D [235 0 R /XYZ 56.693 635.403 null]
+>> endobj
+62 0 obj <<
+/D [235 0 R /XYZ 56.693 560.129 null]
+>> endobj
+244 0 obj <<
+/D [235 0 R /XYZ 56.693 535.521 null]
+>> endobj
+245 0 obj <<
+/D [235 0 R /XYZ 56.693 530.731 null]
+>> endobj
+246 0 obj <<
+/D [235 0 R /XYZ 56.693 533.621 null]
+>> endobj
+66 0 obj <<
+/D [235 0 R /XYZ 56.693 458.346 null]
+>> endobj
+247 0 obj <<
+/D [235 0 R /XYZ 56.693 433.739 null]
+>> endobj
+248 0 obj <<
+/D [235 0 R /XYZ 56.693 428.949 null]
+>> endobj
+249 0 obj <<
+/D [235 0 R /XYZ 56.693 431.838 null]
+>> endobj
+70 0 obj <<
+/D [235 0 R /XYZ 56.693 368.518 null]
+>> endobj
+250 0 obj <<
+/D [235 0 R /XYZ 56.693 343.911 null]
+>> endobj
+251 0 obj <<
+/D [235 0 R /XYZ 56.693 339.121 null]
+>> endobj
+252 0 obj <<
+/D [235 0 R /XYZ 56.693 342.01 null]
+>> endobj
+74 0 obj <<
+/D [235 0 R /XYZ 56.693 266.736 null]
+>> endobj
+253 0 obj <<
+/D [235 0 R /XYZ 56.693 242.128 null]
+>> endobj
+254 0 obj <<
+/D [235 0 R /XYZ 56.693 237.339 null]
+>> endobj
+255 0 obj <<
+/D [235 0 R /XYZ 56.693 240.228 null]
+>> endobj
+78 0 obj <<
+/D [235 0 R /XYZ 56.693 164.953 null]
+>> endobj
+256 0 obj <<
+/D [235 0 R /XYZ 56.693 140.346 null]
+>> endobj
+257 0 obj <<
+/D [235 0 R /XYZ 56.693 135.556 null]
+>> endobj
+258 0 obj <<
+/D [235 0 R /XYZ 56.693 138.445 null]
+>> endobj
+234 0 obj <<
+>> endobj
+261 0 obj <<
+/Length 2220
+stream
+xÚåZKã¸¾÷¯ödÛ\>$J:î"»“ “NÚ·Éb@˲­iYr$y;_Ÿ"‹”)µzڏXä¤â«ªH–¿¯Hš›€ïn~YÜüô[Dƒ”¤’Ë`±$'2‘Š`±
+>Íî‹u7¿åý­®:µÉ±ðóÝûùï‹ €	(B+А„Á-c$"Tˆ8™ý„©‡Ýüº¸ù÷
+7hÀ‚H	öâ”Iyín>ýNƒ´}(	Ó$x4=wAÄ(áB‚\÷7ÿ¸¡v*t0%îyät‡)aT¢Cœp(?ÜÀàÓ-£”Îvî~}‡-0ݨ?ïFþ
+Ó0ˆ|e¢ýÕõ“„³0à$MҠɃµïà@Ûtísœ“„¦Î *fº÷¥úí¢õ»Å=Å‚¯K’”§ßÁY£°Ù(üÓîfJq7C7¹$4µ»©öûñVJØÉÑÈmñX¯íqÜê=°=wuû¹Øm>Ùo^0žnj÷Ì8þº‡ïwú÷vŽ‹_wïõf)Iø%=ùƒô1Æm!e„22‹mÑjXIÌfaßÔY¾:4nÒÙcQ–ؐ)'uÛ\]#®UÖu…£ÖM½õõ@jëº|(:2¿"ò¼Ozãé¬SsFg¶¾¨¬Ó­+ïv|V½ðóÛûŽÞ
+XDIÆ…Þkí	è_l-Ê¡½#TϧB©>XÔM’ÎZµ³’ÑjE;àË>Ÿ³h¶ÁÒºnv
+VÀ›„‚£‚%z²iôüûySª}{b¸ÉP!ÙõT
+NBʯ† #ý—!èåÎžŽ RDð½@jYžO«b½þÜ-Ëo„Ïa\¡gø¨þU_iž’‚ø
+0TBpH—ÔXôŠc‹¡ñÆ Þ¢GÜc(Ô!d@,±F»Ì¦ÍÃRè`±ÔsÄR]{ÄÒ”÷Þ<sÂ!¨m5 ¤}îˈfºÊvfÛÍìÁÓ¦˜õ:$©u
+3HëL4ö«kí
+€´´ý²z·,ª|…=‹ª«±^á§-ªMi»ê"ƒù…\Z„†ZzhaÎfeïM…R}èp^GÕ8cÖy¯Êò¤iÔz§ŽÛ5µ E·E€ÏUf¥Ô6C.èÃMîLàÓ4p×Ì9Øû’g݉¿š(¼"Dà7=øî,0Ò\îìé,Á	FðKiàŒ,~-_^OS_¤»Æ‹©+%ҍzœðpöã×
+ü5W+øqda»j.䘈DŽFo’§G4!<Œ#©å9ÌP%õð
+–f¤Ãém¡)y£K6[OÝ£•&¤}¶žŽ]ðFZ¨Ó÷eDb]…“‘MŽj¤Þ
+ʧ¹FU«x:°µF¶lWÕõùöÐ;Ìü{ÆÐhÝŽ†ìqó•—ä“Qðáw=2"ašK†Y·Ï"¼{–0MHewÏòü^Åé’1aˆ+ó±îò‰K¡ÑúácîÇ”lÖ"†	ÇÉÃw=°*
+öÙä,3¬—*±Õ®Ä’	€äNƒrB[›cŒÏT›[½˜ðÙã¶0D	¢MpÚTmg¶Ôóøî®·ê»ÚnëC¹šŠ™¥Í˜m¾"Ï/ÀÜbŠ˜pžœ³1¯^|…ý8ô8[¼ÊÙ0½ÓpH¤à0ÝÕ˜[Ä)q|5æ鿌¹/wötæú¢UF6æv‘õÌÝ"–D$É[p·ˆb%lx>LÒŽÎ.ýí4¸ó¡cb†Ð—‡ýE[B¼Ãa:8&ž+ M‡‡ÃÔB³½LKŽÔã!
+>–ycGÝÐëÓ🞺…`$LãïBÝ‚¥„'ç3·ˆ†Á eŒ(üý„¢™½nÇÏí>Ï
+CÙPÒüŠ̹>˶OPaNÄž!«ÆlŸjû-­!Í«vdU>¡ôh3 ;縋 _™Þ.ÈY]½=rODÒVi†D_‘Î;UA&ÒÝîKUåýu‡MD썆8sáJ6&5	g‹9=?ü;Ü¿ÿhàÃ0ÁIzçc¼º†þOîêÆ^‹¸”Ö¾©užòðãJÇó¿nϲ|ß©¥ÖQÚ1yCج™C¾œŽð$„ԁ×t„
+2æ_!„ÓéÈý¶)ª‡1•Câ_ñ!ŽsI~½„‘þËҐ˝==
+á‚Fßð¡Ý6g'!~L])©›bSTª<3)ªî4ýk•uõ¥)ç‚$B¼E
+ÂáøAùðú  	#ö Þ¦  Ùº xC•Û?Sðòèc2¨íû³­á˜}ÐÄóbdÜÏ><ÊövÜM
+kúÛaݺëÍ!³è‘Ս4ùm[ü†Ú¬ÂcÍ®šr“Vq)‚j]òâîn;|Àƒl%Zù–'Ãîù›!ºõ•¼ä„ëàhËQ™&Ÿ‡M}¨VŸË¢=õR˜…1¨Âëá:’„,º®ô_†ë—;{:®3‘‰·{\ªìáÛß!Â6Í(¼®÷JØNxúŸa¡üñ;<D2!HÈå[ <c)²ÔGyÁíŸ9´àa’."&i	Q^K‡Ÿí%*Ð ùÔm5Þër›5žs#••œÝ¢ÊÊÃJC–Ü`ÛwUèå®›'´nÎxƒÞöpZt¤2õÞÖÀdᣟeìÖ€NPîsŒ.ß —ê˘µ¨l“%lžu­> ™ª­ms/…ºÑ®µWŸºj™ðkÎÑ¥ã«'Õ¯žÆ
+¬p¼¦e<âÚæju´:±!KùZ˜ô‰:+€ÕZl7á«¿X?agœLȏçê(‰Ùt­¿”ÐÛFQÈ-³³–Ùt»Â*w–ײYîcþ÷ÅéPvœ9aéªeî|T+l*\ËSo0H&þÕ£ÇþEuŠ[²÷þžDÝs³ÏÂ^ô·]sÈ,K¯ò¬„½t·Oû7Oý2¤„Êô[þMù?ûkà_
+endstream
+endobj
+260 0 obj <<
+/Type /Page
+/Contents 261 0 R
+/Resources 259 0 R
+/Parent 142 0 R
+>> endobj
+262 0 obj <<
+/D [260 0 R /XYZ -11.232 900.716 null]
+>> endobj
+82 0 obj <<
+/D [260 0 R /XYZ 56.693 759.068 null]
+>> endobj
+263 0 obj <<
+/D [260 0 R /XYZ 56.693 739.087 null]
+>> endobj
+264 0 obj <<
+/D [260 0 R /XYZ 56.693 734.166 null]
+>> endobj
+265 0 obj <<
+/D [260 0 R /XYZ 56.693 737.055 null]
+>> endobj
+86 0 obj <<
+/D [260 0 R /XYZ 56.693 673.418 null]
+>> endobj
+266 0 obj <<
+/D [260 0 R /XYZ 56.693 648.68 null]
+>> endobj
+267 0 obj <<
+/D [260 0 R /XYZ 56.693 643.76 null]
+>> endobj
+268 0 obj <<
+/D [260 0 R /XYZ 56.693 646.649 null]
+>> endobj
+90 0 obj <<
+/D [260 0 R /XYZ 56.693 573.114 null]
+>> endobj
+269 0 obj <<
+/D [260 0 R /XYZ 56.693 546.319 null]
+>> endobj
+270 0 obj <<
+/D [260 0 R /XYZ 56.693 541.398 null]
+>> endobj
+271 0 obj <<
+/D [260 0 R /XYZ 56.693 544.287 null]
+>> endobj
+94 0 obj <<
+/D [260 0 R /XYZ 56.693 422.55 null]
+>> endobj
+272 0 obj <<
+/D [260 0 R /XYZ 56.693 395.655 null]
+>> endobj
+273 0 obj <<
+/D [260 0 R /XYZ 56.693 390.734 null]
+>> endobj
+274 0 obj <<
+/D [260 0 R /XYZ 56.693 393.624 null]
+>> endobj
+98 0 obj <<
+/D [260 0 R /XYZ 56.693 269.994 null]
+>> endobj
+275 0 obj <<
+/D [260 0 R /XYZ 56.693 243.099 null]
+>> endobj
+276 0 obj <<
+/D [260 0 R /XYZ 56.693 238.179 null]
+>> endobj
+277 0 obj <<
+/D [260 0 R /XYZ 56.693 241.068 null]
+>> endobj
+102 0 obj <<
+/D [260 0 R /XYZ 56.693 177.431 null]
+>> endobj
+278 0 obj <<
+/D [260 0 R /XYZ 56.693 152.693 null]
+>> endobj
+279 0 obj <<
+/D [260 0 R /XYZ 56.693 147.772 null]
+>> endobj
+280 0 obj <<
+/D [260 0 R /XYZ 56.693 150.662 null]
+>> endobj
+259 0 obj <<
+>> endobj
+284 0 obj <<
+/Length 2180
+stream
+xÚíZKsã8¾çWèhW%l>D‘:nÏlÏöTí³]5‡ž®”"Ó±vlÉ#É›êýõ¤,ËvÇŽì>LíI4 ‚ Ðè9¢ÑOwïgwï>H¥$MxÍQÂI¢"M©ˆfóèóäÓK±h§\ÒÉ_«²Íž
+þøÓ?>N¿Ì~,Ò  VA¬AƒŽ£ÆH*%ª0CéÉ;ü$vÚÝŸgw¿ß10ƒF,’	I`=•2’Påë»Ï_h4ÞÏ%qª£'¹Ž$£„‹Æ«èÓÝ?ï¨ß
+ÝÛïYtÇ)a4Aƒ8á„¡abôùQJ'ym²Ö<6mÖn›Ç6{š2:Y”…-Yqûùi°A#%8QÌnÀ’%KgqÄIªÓ¨6Ñ¢oñž²ãÔCýœ%yX 3+=V¿?¥}ýá´ÏY¡¯+!)O¯`¬SX?G8ø—woJѽqß½\*Rto¶Ù}›€k¥’zúP¯—˜eOÁÕ'Mð¢6@Û§Õ‰…Ø·:ˆ²Á²°‰«Z;/‹×­}=¼™&
+®Õˆø>z_ûOwh’*¢c†-‹Æ>Ò¹ÉdSW¹™okƒô—bµBFžáHNÚ¥g;mTb/÷×vY•(Øäu±iÃì¬E©°vQæ«íÜÌ=µ¬‚“ä΋ÚämUEÞ¢ª÷¤“îYZxVÁp&{/çK
+6uC¦pöþ„ÞÛ¾ýÙf¿Ù­ϵ¶ÙoÖýÞl[/¹ôS $¦,3µ)óN;”ËüŒeÐòdŒ×ûlJSÑÎ=ãë@÷úïÿ™291õ*Û
+î¶rtÃ}·B’ñn…ªmë6cÇ™çy:±Ìóò¬ÄÁ“gmç:;­Á¯?7¯,³þ¡*ó¬ýP„¥\àÁ ·‘þerY7%Sư/!ˆNDÈ8âhºyŸµ¹õÜsã/èo{xÏ®ý»JyLD"õ0'0ϝX’† CÍK¤ùÈ„“ð+ÌÚ1p¼BâºjZ¤Tü¢N`ýJ)_yýk°´(Ÿ‘‘•s¤º»„—¥©Í`ö&«ánšUñ߬-ðÊí&@£6 mVYnvÖÚÓøêשFͪÊ1Ñ«WvVÃØ]»GãÝ‘Æ]Ågî „õ%#Zu®$ì¨3×ï³|Êéä·çÚ~ªm9ßù÷¼VJI CÝAÈ8&’‹›!ˆþqb´±'ñ‚Œ!½0Ÿ^^Oµ×þ~=ÕÚwÿ±X?7ÄþùËôLt`ãb(ÄÏòrhдµ½MçaÓ´Ãî¯vÇOâþjÈô6a¯ß7x¤%DÆÍ®Ã¾þ‘×a´±g j®à©ÓKˆ†g3Íùqñ?jJA‰TÉ÷€š’¦$‘qj
+Æ'O˜@cÌŽ ¢%÷Q°êrÖýFÔeIH±W­(}ö³ôL´|f‡¤€bÙ…M`kY¥S6±·¯¹‡ß\Í«¢ñK٤흎=˜.*·=ƒ”¼Z?%¨?’W‹q‘B¤¥,6ÈŠüÞþ°I‰n%vHLå›€FÙbZ·Ì¥éMhpŒÈxÇÕý5´Á Ý_À¡“¾Ú¼2ÒÚãÊX¹	ˆ	ÁümãGO~€˜Uaüa³&Ã7÷à8¬Ý—ÐÄá’.Ò]Í t€«0£Jäwx¨’ÐY–àö€âÈêŽÆJ/ZS#Ùóõñ=‚À2³ˆQ7J"ZwzpÎp÷ä<@±Î˜o/väTtv§†lÝu‰
+µçUiöáY@ƒdð¬àwïIH ÁýŒá¾Æpûí!ÑkÅ©&~‡öÐa;(èdÁ•ÝþVµæH/k°Ïº³—¾—r·egƒCÁõ±ÈðU¬î•;à8rØÖrFvÑÎ_mˆ	­‰”»ò„ðã˜öÇb±¸Å
+Å	“úv(V$Œ°4½YÚè—¶G{ÅŠ$†¡n€b]Ãh$Š
+‘scüÚÔù…ðõÆèøõ‹beÊlmNcä×/›„༂ÝW?ò&Œ5õü* ÍQ»€e®/Ư'Z¥¯9ý/&›C¶>k‰å¼‰Ž”¯\²ïŽOˆ{}XÁ8¶Ã ¢}DlY.×DÄøÛC!lÝÙÉÕ¶Î
+Žû=SÁ<a]+I„–ŽUÔÁ$†ø¾óí*k½leSê^ÒYR{
+¾eda¦h
+ÝÇçû&õÿ+’3êÎ@ê$˜H¾ÝÔaËÕ²‹ æ9Kœ çñ!Uݸqt½,`â»áȈ¢©Ú	v'D; L;€J= ¦zÿqTeØD§k‡Èƒj¸—c¸ÐCõ´ë¥§1,W¶YQ6HY.Š€ÑÙäë¼lÑzQ4­ ˜XOc:¹GPŽÕˆ é ñáãì’–xAµ;Å4´æûsp» —$†~çi÷ç·5³ïþ±“Èƒ `ÙõfáâÌ‚dfŒÄ=t}R‰oT‡Þù5 7W‚0ì8œ<‡<ͱƒ‚¿Û§H)‰ïánèXaš'¼û¸fяèÛi|ð*z:á- VñXûªþ$Y]ú¼|è'][Ñy“Ô㟃´?`Ë.x¿{Ì”î^˜®{mëû6b	ª4Þ@¬þ
+¢f¾·è7ëÎ4áo*Â÷@% T—‡¯Q\1­ˆŠ/+®v`ñt9eeÞV at 1ø²4¹jÅ9‚í
+(qº€úP´—ÖPŒI¢Dr»ŠÑ˜(¥núÇ!ÇÑÆž¬¡Õ„&ñ÷­¡®×ÿ^móöÿCèçÿË´oÿ·Ç[ÿĐ
+¢™¾Ù5ÛW?6õŒúLÄŒh®¢TFýëÿ+f͉–·kí«ç‘Ѧ^à `Jþ˜³Jíßï¯W.8=¦EÒ·üëâÿ Ec£S
+endstream
+endobj
+283 0 obj <<
+/Type /Page
+/Contents 284 0 R
+/Resources 282 0 R
+/Parent 303 0 R
+>> endobj
+281 0 obj <<
+/Type /XObject
+/Subtype /Form
+/FormType 1
+/PTEX.FileName (/usr/local/share/dblatex/latex/contrib/db2latex/graphics/warning.pdf)
+/PTEX.PageNumber 1
+/PTEX.InfoDict 304 0 R
+/BBox [0 0 29 29]
+/Resources <<
+/ProcSet [ /PDF ]
+/ExtGState <<
+/R8 305 0 R
+/R7 306 0 R
+/Length 566
+stream
+xœ]TIŽT1ÝçY³0±9b¡$@¢{Xp}žó‡¢[µ(Ù•<¿Á©ß}÷QŸóûñÚ>~þãOãÑÿ6¥t
+îŸÛ>Ô¹j²ÈÏÎé4'÷W5«‹3åì/%H´K*­ììJ,ë.ÓHܯӏ&>È=o¼—&)” dŸ$+ú]KÒÒïÃ7Ô£] :(mmçÔ¤àë'§»<(_çOU'æK2‘÷Ô»¾X½óáÑ~¶op/˽ˮ_§‘H“º–]&¤úì°ñ2Ԑ%Œƒdâw^Ä%bTØXE!xÒ²8jÄ$Ì4Œ÷³3 xÄÁ7×"Ý89м ”2€mÐïÌF6µ,œ’a;¦,ሁw½8•]50&¦ê}‚)¦ÿ‡0HcÝ3p	haž<Žå	$u3Ø«óT¢Ïú©õîœn aE<ÝRœô7~ê$Î|:®kcíDJñ»Ì*Ú«ç›è¬¡ÆbÞVßsÊúʏUˆ9ºc–ÈfšÄUÂŽ•)æÐÙÃ)Yì®aÆTlé¡mw’†@c!Ì\B¡Ã¶6ëËUî§ àÉðišrx.åç7Ú®º’gøuŸ0;6Š-cÃàåb†¦ä¹EB+4v#\î‰äì¬ìg'û3u•D-Zï\ȧ•-V‘׍c=}ÕÞ`‚%Ûêõ2dSíÀ5—=o*Ê{ücÍÒ‚Ý­G»³IíïÓ{´ïÚ—öi×ö
+endstream
+endobj
+304 0 obj
+/Producer (GPL Ghostscript SVN PRE-RELEASE 8.61)
+/CreationDate (D:20100125210014Z)
+/ModDate (D:20100125210014Z)
+endobj
+305 0 obj
+/Type /ExtGState
+/op true
+endobj
+306 0 obj
+/Type /ExtGState
+/OPM 1
+/SA true
+endobj
+285 0 obj <<
+/D [283 0 R /XYZ -16.307 900.716 null]
+>> endobj
+106 0 obj <<
+/D [283 0 R /XYZ 56.693 759.068 null]
+>> endobj
+286 0 obj <<
+/D [283 0 R /XYZ 56.693 739.087 null]
+>> endobj
+287 0 obj <<
+/D [283 0 R /XYZ 56.693 733.109 null]
+>> endobj
+288 0 obj <<
+/D [283 0 R /XYZ 56.693 735.998 null]
+>> endobj
+110 0 obj <<
+/D [283 0 R /XYZ 56.693 657.837 null]
+>> endobj
+289 0 obj <<
+/D [283 0 R /XYZ 56.693 629.451 null]
+>> endobj
+114 0 obj <<
+/D [283 0 R /XYZ 56.693 587.653 null]
+>> endobj
+290 0 obj <<
+/D [283 0 R /XYZ 56.693 561.858 null]
+>> endobj
+291 0 obj <<
+/D [283 0 R /XYZ 56.693 555.881 null]
+>> endobj
+292 0 obj <<
+/D [283 0 R /XYZ 56.693 558.77 null]
+>> endobj
+293 0 obj <<
+/D [283 0 R /XYZ 56.693 547.811 null]
+>> endobj
+118 0 obj <<
+/D [283 0 R /XYZ 56.693 406.486 null]
+>> endobj
+294 0 obj <<
+/D [283 0 R /XYZ 56.693 378.534 null]
+>> endobj
+295 0 obj <<
+/D [283 0 R /XYZ 56.693 372.556 null]
+>> endobj
+296 0 obj <<
+/D [283 0 R /XYZ 56.693 375.445 null]
+>> endobj
+297 0 obj <<
+/D [283 0 R /XYZ 56.693 364.487 null]
+>> endobj
+122 0 obj <<
+/D [283 0 R /XYZ 56.693 150.064 null]
+>> endobj
+298 0 obj <<
+/D [283 0 R /XYZ 56.693 122.112 null]
+>> endobj
+299 0 obj <<
+/D [283 0 R /XYZ 56.693 116.134 null]
+>> endobj
+300 0 obj <<
+/D [283 0 R /XYZ 56.693 119.023 null]
+>> endobj
+301 0 obj <<
+/D [283 0 R /XYZ 56.693 108.064 null]
+>> endobj
+302 0 obj <<
+/D [283 0 R /XYZ 56.693 97.105 null]
+>> endobj
+282 0 obj <<
+/XObject << /Im1 281 0 R >>
+>> endobj
+309 0 obj <<
+/Length 1809
+stream
+xÚ½YݏÛ6Ï_áÇè¹²eÉö㊮ÛØp[ôáZŽí\Ü:vf;úߏ)Çv.×ÜG‡NE‘©ŸáÜ9Âùmöf9{ýN	'vcíkg¹v´ïêЉDèÊX:Ë̹8ënqå+1ÿ£®ºä.§Î/7׋ÏË÷ Às"P %*"ÐΕ繱R¤BÃŒ0š¿¦Fã´Ù¯ËÙ?3ÜŽç(íj°Æž«…ï¤ÛÙígád0öÞnGÎÁHnå	×—èÒù0ûk&x)âì’¬î v=¡É¡å¦hÁéÍWI—nˆlÓ¦ØáJ¥˜wÉ·…'æ9KµIßßíY2áÉõ¾Is¢³¢ÉÓ®n¾S·^S{ØäMÎê7,Zl!ž¬´«©M“2Ý—IDzõÂSóñ_ޔɎ…“†5”u
+¢Ù+ì)òF̳¼íŠ*銺šº±‡@ÒƒJ_[‘D_°maŽemò–ɬX/|5_ƒx•2VnÈÀ¸A³“nßÚ9}P°{±ÍSMŸ„ðËœ;ëº!"O0½'cGÊ¢íÆv{ͤmÞ$U²XQÇi6qÄLXû¡(Kâ­X.­·«¢Ê3â•]$+RómÝ&E:tWÝß.Y•ùÔ^в¨ØÃ¦Å€Ù“
+d=í64lwß® <±àV•!Á^#çÝõòQ›<ɬÇÒˆš!³ŸC+uÁj¤í	vìB?žUUï;:l0ž‹Òi×ÔN#†ÂýÙ:®€HØGs¨¢¨Àå-™ûÂQѵ·©ÑЁ:æÈB‹ç;’–DoÞÈÝå&œJÍ1 pµ,­œ=î…µ`‚–v4R'«³ê‰¤Å
+mà¸c>¯§±GY]Y›Ý%MR–yéšëyz¯Ž®k­Ü@ŽŽ¤Gjz]ËÁu
+W·Aß^×S
+p)‡:F
+ÿÌ„‡¡2ÒÙiÌx}½õœ·5è;j¼b•WôøƒçÉðœÈì+àqj?.bSa¼N_´É­@yƒg츽">‘HѽŒÃ•bFÿB m/CØ
+bþx[|pö-ëY±ä®©¿‚hžŒz¸N^QT^:Ï{LZ¦Ù>Õ	Ïn=FåiìY•A¥\üYwù1çmßëõ»¢{Ï5NMÙN"lÅ8»]Â4Ïö˜æBí
+/|JØN×Ê C>¬Â§Uø®tƒÑárn¯`CŠù–׆;`C0
+…°™>%ÝP€»¾vlJpùÊÓ®ïØ‹b§Éõ0­#m÷sO
+xÊ…\Y¤ØCéçêçØŒõ[`w‰…¡.íÆ~ü|gM
+cA)†)ô çoÄOB	Î þ5wt[9›\jHåÒ\µãôŒèºèÚ/ݪœn	CÞÆ¶ýyO¿ÀǶkøªû±“¼¦^=¬þÚ¼Li‡‡mý¥ØÞµS·Ÿ_½Xœ‘ÆùÇ΃/?çÀ]ú­àwP¿U¤öí·ŠÔ²MÈ|«à><ÈNú¾OH&42„âÀ%p|‹Gðx=ðæx£0A]`¯X´7STgcaµH‹¿AÈàoàœ@\ëA«q ᛤ½­rˆR„ó»¼Ê›Ä<‘Ø5h	²ŽCgÃ3j@gèÙ¥Ù{ô)tFY‚Î@ñ7
+Ð]1ºÃ>QäÐÄe6“œøÉÞñ1®>ï@íªÇwcÒî€;…†‹KÊÝ®Ww¹^Š0+_/2r}ý(¸pT ‘]™TùÓ°B ÏMè©Å
++'A|Ä
+ê~¬pÓ,|H¢ÂÇb	¯¥îÿ4Ì Vû±úi˜a¢ÿy˜áÙΞÅRčüK1Ã#Lü8ó`..7M¿y~2xÀ2ÔÏMrxvøJÙdÍ3qƒTp˜…þ?pƒ”ž+£`\ãÔÇg8¨qêq3ä§ægx¬qÚ²ð&uE=.u†\ôÎ~¿ÊA•иtj‹s(L•R
+™Åë÷À~p¡C*ȧªÇÐ¥€µé3<}úU° ØITH[w¾1õÍ?RAê(MÏ%ô­¼ì]&9Äz_¥/èqd³<-2–)ÖÜvܶl©nÛ‚J70Ã<ìÀÝ·'60‰‰âØã깊VRÞÕ
+`™-ÁfŒ¾R-B	6¨ÌÇ@•%
+W›lêêr`àÇÂõÂà%#+7*zÑ’Ñ@çù’‘¯#W„ácJFŒn\À€ïö
+ ß®üNݺ²TVBV-š—İ
+©Çà%œ‚—+	;àš…²:gµUͬt“§%¾±¹šÚ6g³fWýX/¤ÙfTî
+à¾íe¼¹±0¬—¶`[eç!–/}WEOAX'¨!® ‚àcUúiÒ’²
+endstream
+endobj
+308 0 obj <<
+/Type /Page
+/Contents 309 0 R
+/Resources 307 0 R
+/Parent 303 0 R
+>> endobj
+310 0 obj <<
+/D [308 0 R /XYZ -11.232 900.716 null]
+>> endobj
+126 0 obj <<
+/D [308 0 R /XYZ 56.693 560.885 null]
+>> endobj
+311 0 obj <<
+/D [308 0 R /XYZ 56.693 532.933 null]
+>> endobj
+312 0 obj <<
+/D [308 0 R /XYZ 56.693 526.955 null]
+>> endobj
+313 0 obj <<
+/D [308 0 R /XYZ 56.693 529.844 null]
+>> endobj
+130 0 obj <<
+/D [308 0 R /XYZ 56.693 400.582 null]
+>> endobj
+314 0 obj <<
+/D [308 0 R /XYZ 56.693 372.63 null]
+>> endobj
+315 0 obj <<
+/D [308 0 R /XYZ 56.693 366.652 null]
+>> endobj
+316 0 obj <<
+/D [308 0 R /XYZ 56.693 369.541 null]
+>> endobj
+307 0 obj <<
+>> endobj
+318 0 obj
+[600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600]
+endobj
+319 0 obj
+[500 500 500 500 500 500 500 500 500 333 333 570 570 570 500 930 722 667 722 722 667 611 778 778 389 500 778 667 944 722 778 611 778 722 556 667 722 722 1000 722 722 667 333 278 333 581 500 333 500 556 444 556 444 333 500 556 278 333 556 278 833 556 500 556 556 444 389 333 556 500 722]
+endobj
+320 0 obj
+[278 278 556 556 556 556 556 556 556 556 556 556 333 333 584 584 584 611 975 722 722 722 722 667 611 778 722 278 556 722 611 833 722 778 667 778 722 667 611 722 667 944 667 667 611 333 278 333 584 556 278 556 611 556 611 556 333 611 611 278 278 556 278 889 611 611 611 611 389 556 333 611 556 778 556 556]
+endobj
+321 0 obj
+[355 556 556 889 667 222 333 333 389 584 278 333 278 278 556 556 556 556 556 556 556 556 556 556 278 278 584 584 584 556 1015 667 667 722 722 667 611 778 722 278 500 667 556 833 722 778 667 778 722 667 611 722 667 944 667 667 611 278 278 278 469 556 222 556 556 500 556 556 278 556 556 222 222 500 222 833 556 556 556 556 333 500 278 556 500 722 500 500]
+endobj
+322 0 obj
+[556 556 167 333 611 278 333 333 0 333 564 0 611 444 333 278 0 0 0 0 0 0 0 0 0 0 0 0 333 180 250 333 408 500 500 833 778 333 333 333 500 564 250 333 250 278 500 500 500 500 500 500 500 500 500 500 278 278 564 564 564 444 921 722 667 667 722 611 556 722 722 333 389 722 611 889 722 722 556 722 667 556 611 722 722 944 722 722 611 333 278 333 469 500 333 444 500 444 500 444 333 500 500 278 278 500 278 778 500 500 500 500 333 389 278 500 500 722 500 500 444]
+endobj
+323 0 obj <<
+/Length1 1612
+/Length2 12917
+/Length3 0
+/Length 13735
+stream
+xÚ­yeTÜ’-îîNãî$¸»÷nÜi<¸
+ÁÝ‚[pw'‚»;ÁÝßwgæÎºoÞŸy÷G¯Õ§ªÎ®]µëÔ굚†BUƒEèh’vt ³p°² ”­íÍÜ\•YÔA–n€w#
+„Èlíè i
+	 ´A@€$ÈÀÉ	ààççG¢H8:y¹X[ZôZêÚLLÌÿ´ü0óúOÏûMWkK íûw£“=Èüñ¿¾¨ÀV €…µ ¡¢ª+§, —QÖÈ€@.¦v U73;ks€¢µ9ÈÁÄ °ptØýã 0wt ZÿUš+ë;–˜+Ààê2·~¿ò49ýåb8\ì­]]ß¿¬]–.¦à÷€ÖævnÀ¿¼Û-ÿ&ääâøaÿî{Sut»š»X;ïYU%¥ÿÁle
+þ+·«õ»àhñ	t4wû«¤¿}ï0ï^°©µƒ+ òÿ•Ë Z»:Ù™z½ç~sr±þ›†›«µƒå?0\@–¦.@;«ë;Ì;ö_Ýùg€ÿV½©““×ß·ÿŽú/Ö`W+ç{Nsð{nKk$¶¿EÎÁÂÀÁþ;ÐÍé?}î —¿Dÿ×Ì0¼“0::Øy€ $6eGð{J ýÿNeÖŸÈÿ‰ÿ-ÿ[äýÿ÷_5úoøÿ÷=ÿ+´´›²©ýû ücÁ Þ7Œ#@ð׎±3uù¿ÂMí­í¼þ‡ÿ¨
+úÉÿŽØô½b–ï‚°³²ÿÃhí*mí	ªZƒÍ­ ¦vïúÛ®å ¹ØY;€Þý»™ vöñiZY›Û:üÕzž¸@À%ÿ.ÒßÔÙ4õµ4´˜þu§þ¥ú®=XÓËéØ”¢äü¯Ã_â⎞ –÷ÈÂÉõÀûžƒÃ÷Èö7Ç?ÏJ¦`kO€þ{ÉìþŸžÿFÊÁܸ׬h€M€ïãõ_†¿Üæn..ïªþýâßþÏó߃y‚Ì‘çÍClR3ÒÀ5ø9ƒ?%õ{»9 CŠë4óª»üS#6øËMž«CYë'^[¼fœ^väw‡»ñì躒A§y$¾T=ù˜«´m˜vƒØŒŠQÓŽµ£}Îf×aôxÙ?ínþTS7*z†#hãrA8»c rÏÀ¡¾uBó3O©ÃmǨ‡Àª)8:¦ývpwK×?248ÐuÛ³CÌ”‡H#hŠï—tD‘ö2q¹®3…}tÿà±)¨ŒQÍzœØí;&?ÓkðŒúßhC@“ö[Í?»\ª‘ƒÇ9ò=/€|Nºa¢·žýb`|vƒXHÃðÑTç‚c¸nËœ‰Ðd)Ä»²+ìY²ãŽíÐ Ñ=÷…w+˜Œª_´o÷¢•RÖ\à[kŒ]¶÷d5‚‡™tz báU)§Øå•¢Ë2—é>d7ˆ¯ˆã¶ä§Ì†õÏ]Ùñ3l•
+ñ÷$+LŠ7̈a* ÏŸyœ>  Ü—Áy"fCè^ˆÉU‰´Ô$ÛÔä·ö¶&ÿžFKc2ñàx^¿)ê£lcµ1aî¬ßâLKQ6ë[ø¹T€N—T‘¹G*æ„È]-:°¢ûºÊùP­{^â ªeL÷s5
+ðc¢ù‰Ìx(ßÉŒX×é·1q’ų½1΢XÒÍ~éc£Þ¢a­ÉŽ¡¼¾ãöO î»¸ƒ¨#‡eœÂò—££¯VÄ~96Œj at nÔžT·æò}ãn:™g6}Ž‡’dŒÙŸ–~žÈÄôVD
+{u˜¼Qdr"ºÊYÐþ*…ý~æjc2D×=É6•Âjb†N»~5Š&†ÒÞ3ÅÈL¶a
+X*lY÷™Ø¼*¤¤â¹õþ³]¢µo°¿xî8x¢ÏýÙ8ƒüè÷B[·2àv’ÈßßlúóA,‰ A¹Ú•Dþ°þciïn5Á]é@7 Kœ'Íáû.‡$/éüÌbÙì¥Â½:lªIìçWpYWܐMŒ™«œl\eo<™ÏéòÞr[ùXǬ}…¡¶¹æ¥g:k݉y—‘ý4„ù9¶†y”Êj(’д™‘à´Úò ñç>Ï'Mó3þsEñŽ¥ý­ö•3‘ê6zIÎ:ƒb6Î,?³cIŸ•¾{ä'nÁ°ãÑã¹ôTáØ…Á,Ƕ=qžŸu%#c&ik
+õÝ´ÐVß%T‹MÍ@:ĺ$£’wù÷'r©=Ø ß4Ö¥/îú)£ë•7U¦HTº`EóùÜeÃÒ™ýß`ˆÈΦ.-à;ƒ‚Ü ~6—5L*Ós”Oê
+O¤~l8t_^fÁ.~ãêh“ *FÜ÷þ¾»ï(±Ï¾8=©ÜÊ::q峞sÔt¯Zr ˆ[µ+	8ÚÝu?Û8âúý”i(fQfc»èn2kÞwq…=*¦pÖ× 9»NЩL¦È[)Lº_ä$es ê¢‡2wáw1 !êo/ÉšpÆ
+ѼæG£¤’Ð$ä}àƒ}pÙoJ²({…®ÀîÝÀqU›æuºŸiîAºj…{R‚ŒI'“=…éoy*ókä¤R;-ò~ŒÃ¦,rä†ß’5gMsÊ)_'5Ìæ`]–9öOÂ1(Ì–Êï1îdîÃ‰]DÂTòZËôkÝ3ùVŠ|Ö‡"ÛuZò’°4VOt‚eÛ×C6ljúD]ѐ#$ÞÈŸýü#D¶/ÅPžs‰^W¢F …;£2lš²µ'аÜõç4ŽßW)!›ŠÃòZGW¾SíÞ¹låÒt&’–¶
+¦fB7Ô59m-¡³/x"1{HR^bÉ£((óÅ
+t¦“Å
+®­×!Øòì_ÁGnb%®‘ÁœÍÒL!zu¢¯+çn›a®ûd°^'V–¦,Dð…Z×±JQ7B73­†–s(Ž{¿ë„cGX!ÂrŠ›Ä§t?0Ð3Ìö4YçÇÏlQ USþRÌç."÷!ãñq×Cö¿
+ŠÃ@‹f?ÞòàҐ
+}E[.yPhM©Ûlê^ö+LsÖ®B/¥{»ÿÀ"¿eb×d˜ÚV¯ÿu£ä¸¦<rRT5"aùíí	ÉEí7]	x2ðh¸B_ "„4j¯_6Í\djç%^È4™$Pï᤬7bˆý33ï™y¦0
+䲌ä$KÜÀo_NG6½Rn¡E<äAŒ:¬Üâ^QÕ—æï0ç%¤Ê6`ç’ëbö7E"ÚĹá&`ùQéb¶w‡IVš3#¥¥I‚í…ƒà,'Ç;­9Î3
+H8®¨lÅhPíS§¢âúY•d¼{ö€Z†g†q¤OÒçeºò 6¤ÛÀAd$íäÈÁ‡J?¯ÇOrBTÛ^"Y4ýf):2§´Î
+ªzæ˜Â¥}!}
+ÅG4%Սˆ]òyÕõ·Oî‚:	.å(k,ó ŒGR+öïÇ2áBãñµJë™ÃÇ~ð÷­V©»2ÓUý®­
+Ïö9;Ú:¥.í!BÖ†Â9^Ó©¥¯b©^Wݪá.Q'OÔtŽ®uëµÕ1âÃ?òG½€ÂÒ-pÒj™‹ùRY8£ò.ʱqÈ6PF8xÍ3,>‚´ý…Ì·—-œ&ëLbÇÛóH™[dt éÊÕGˆjŠÔ·Óös!¶‡z5Ü‹u_	ùº"æX±`D—Øè£DðY‹‡²Ð«V~ðØï›œOþ¼u‹¼‡È«5fê¡øEÞ!•Õš%æÑÖcTŠí^#Vt¢ƒY
+ì—f‹¹k ‹¦[â8aÅvǽ>þÂ|!wÛ‹òlý¦ÅóÃÄœ7!誧&Å7Xj™JÁjPOa{	pp¾°¤jÝrâñ½êf&ÿ]°’SùzmHÁÏÓ.G¹ˆÀƒ<£LÚ•Y¹ªæv¾p¼ÓøŒH´:ÎFèjŸã'„³Ÿ˜¤5O[%Cm#ówæ­Øû>¬c(ö–vÌ|!ó2æáƒF¥Sù_ºéoØ
+C´öfžXê×Bù(× wÔº;ç-Êɿƈ Â!øŽÍؼuKY¨øl¼×æM öÄ¢øå›Æ×P%n¨£çGçÁSt˜šß¿ò=&ŒÆÍú±‡ZÈZ&rƒ¾l5‡Ñz!äð 󆯯9£qÀ˜ºÀž}ŽÍeœÓ\ÔP¹Ó!$ƒ7+çû@#¼7iqº‹F¸g §µí.áy¨NÇæÌX1zoriìOu×Y,A(¡D±6EÞŠ}cÙÙÍQ:OÒRÌ"Ƽlp•Ͳº³>ùˆCn	uÅÖAêv½]ƒÐåÏüÛ5«lµœ6&¤rë~;šJƒŽ{RóQÀ*
+åwÖ!/d%dœÅ¢k9Ρaˆ4ñlž¹r®Êê¢âÄép2F„ñÝïÍH5Ô7“-¹ê|ù¸´6‚ýªTç­[´ÛÑÜìj|Ëo¹ö&(iGw,ew=ñ]ÌüYßscªy>A¥ª®`$ÖÑ
+!RðiÅÕð‚†ngâæQiÖ¿ø¸€±slK3ül»m—Ûyµág0Iõ`äœ_ÐË™+úÂP¦7îbÌ®#âèb½pUÆÂüÔJr¹½
+AS!Øùi3ºš£Ã‡Iz=UtÿSL'õèëØ,êkÍÕ}„vJÙùÇΘjW«ÆbÅ?ŠÜûk»AÞð)$.ÁX×T#·Ž39Δ©˜ÔgÇ¥JüGŸEm{ðî§ÃoôÜëÓë\ÃÛVm¶ Ã :¿
+íÛ¥L/ì_G°œÇ·CS+ÃÅ‹Ì)’I:ŽJ>ÅèI9-އ$ôYì<W-
+¥.«|"îŸCnŽ*Ó„¾ŒCtVJ€&“öeÄðä燣ùY9Z{ô)KdùåT¤í抜Û~BÕ ´qäÃñ*\ò—€’_>mÆ–dWÆËµ#ãD®€?3—3:ië!¿È©RÅÚ@@DÒš‘šãvÁåx!Qd‡ŸY~Ô›ð6$t—ìáìø-0‘ôôÔõ;¯ž‚ÍEì±åHE ±o[Qúî¦˜ÈµÈf¸ÔíÒ¤”éåø¨ÕT¡‚JÉ¯yêK`qBÏXŒK<C3mJ‹m¬’’ýF6Ò8Äê–aJÿ
+¤¶ƒþ=(æ©]½>(ªÕŽé+í­š#`éz„/åœh •ר³…õJÔSÁ‡Î3æK”†!Œ‰†²úÙ£Êó(}GØ =¡ÀÊÂm^ouɬˆüPÍé È/©|¤>lO©À«l”ª™ð£yÔ6%”²GÜUGÍ@àz±$ÝýzÑ`PP|10pw@Ì™–,ò´‘ÏÆÜ‡†Ð¢Kë“‘Š \$ ­:Ÿø[Æm œ]Ïÿã-þ<{'xú˜Òü é‘GL‡Ö²8ÐŽF˜°zùšy¬F(ò
+k)º‹å¥£ˆ÷CÜ…ý$Œp|éiçŒh
+ at -èdq¿C¤¸d`û‚æ§/)S0…SEg¼ë9F´s=¤°1Ôê®y§g÷=çÎÁwOm
+§r›ívÚ´?)6*ÓYFãk\EòÐÿÉ£•Àb>†Â€Çºãª}Ï‹)ô‡/Œ/–”L"åáh,,©‘¶Zù$ߊäìx9¥°
+ò\kú’W8•§LЍœÍƒ0m·‰³"büëP‡•ôA1ûR¾í	~ÞtdšHe3yºRÇïµíÓîÑÏêfñã¨åüÛß´×ìeYÉcmÀb³
+=þx6±o<BñÉgH*±eßñ¾Y
+€-£®¾BŒV#$Âånëö;ÈmãépÐÂU)p,gÎKÚþڝàKж{2!:ˆ­ÜœRt º¹_Û¹ð-ƒ±6|çxTíùý‚~U™ŸÏÂIts£‡ôþÎ^9€eÝý63~K”ñ¶¬:OÀ…“j
+¼ÊYøyDÔ‚ñ¦­Æ‡±Ãßàd>ÍÜz42/Âìޱd$ºNa¶cdN	­qà½_ŠùýİPRÖ…½À‰š~0³ï8ïFN¸=0DÓ-g]zÆ…·èï—ÕÆ„*‡HÏ"wô\ê¾5e8rwçjëέÙalío%ÄcÂ2)7¢wZ8h$-ЗLÊBh€k²¤?MuÏV€ÅÙ•…ò02Åvó5?Êu¢´æqšÄ¤tÓî~‘ähZ¡ÍS¼Oìà_©zjƒå
+!…ûÂk8U#Wg?
+Þi£5ŽF27Rˆý,#ÑŽŠ	&>÷Ÿ¨
+Ø–Z/ ÙA½x¡ŠÒG8Ð30ŠS:êÚÞ×6Q@­*L——Fc¶ýÈyhøNÀõìÃ!aUKÚq‡ÈE-¹ö×icCÓû_™}¬ÖÂǵFåI})f·šË6
+„ò#æ‚FÌ¿‰ÀÈ „NÞg:’º·j{º4	¨‡Z‹èNâgðÇÉ'µµŒƒBA¥¡"ö­Õƒ~a<×µ@¼_!
+ÉO°'ù¢‡LŸtu^x9÷œ¡vÚ÷ÏŸ¸®{Êc%¼àÍ~ú²1!Ì^5}¥.ÝñWÑû‚;—²î§ì…¤þu»˜`rîå‹kð¹U«»jZ‰í’³eƒÂ
+î°͐«ëA€ßíµMWǾÁîï³T`«_7â²직œ‹E8ûf-1†ÄüWUú0	ûE¨é67a»mËp)'ïnæÙ:­àý×päú*ËL‚ñ5AÈq#b|Jf•w°æMªwm7ðñ…œ«„‰ÕfÿÎÅ–söÛü­¯Q/Çd‡ã™ÛûŠSÖÜQŽ°ÛµYü|ø9"8/ó7¢8/÷sDÕ KÅbQî51ÙQ	C’¡éè5`QaòKΡ0³ð. ›)J›ãbIÊß0†öNƒ4B…\]¤›DªÖèt®‡–
+iŠhceC#”6èç>?>J—3ÕÆó“B†0ˆGTù*:Êç…R6OÓ›˜ïçr=Ééä×§¨dê!Uk —µÍÇ)«sñ‰AV*9V¤(yÑÆ	²†S¤é»|éãUÆø©Óµ½Å“s½×ÃâWçùÉ$•@Û¥–仇´—YµÎ}úË
+1RËK4KëI"P­¦±‰kµ#nDMˆ~-}è3ÿÃͼbܸT¹FPoÒa<ƒ²f[söÁu•gðƒ"³¬CÝ%/afÓŸ=ü%M:äçV¶›^8iz˜Oø53ÜÃÇÓÐgócu—¼¢Â-pJ…“¤ôoÒÚ·ÁÏÀ†d¶ZÀ÷AãœÅ+XäæèǃÜaºO-õ¯ù̉¬zY=)’ÚXXÂt£ÇJ=€°?æÖWįéhuu‘ôˆ¥äJ0Xy³gºÝkË‚IÜ¿@Ï|)¦p¨]Ò£Tç JÅ#]Îĺ³’8ìp­Ô]±‡(c‰a¼cvÆrÛÃìØ5!Ⱦé'jÒ‘	í©ð9Ÿc㣳l²å+¹†@µ•òdŒkêlQ6¡ò,/;šîʆ]U‘DxR_
+N¡G“Íöç%~üé|¬­ÿ4ÆÔÎQâBWVe8¾ ‰á›x­Ö÷9]V‘1ö
+"Ãrau»´¥Ès¶Meât~¦u¦Ÿ\(Jl²£dˆÖ’ WÝò[¼t<ÑÒ“ž>rV›’*ìÌæÐý‹¨Y˜t%['‹}·T0ã[DÓײ<s>LåW´PÕ±yÓ¢óÏ
+ĈWîd­;%:¨–¢«¤>Õ±KÈT¥ïéiW—@"3ï_ö(Âɸ*S8CÈ_ôsvRüÄòáمͬæÂ-oˆ„“ÃÐü6ñ=XÐÅƍã(µO÷£ 3Ll…ù­Ôø6ŸŽªrTʹ†žkúÌDÌkÂnP#TÔÞ*$þv¢ŽãZ¯¯]þ­ŒŸy¼âÀYjŽe¡`Žb›>ˆ—';ph…:€¶_¾™1BÓ?'»·¯8nÍ" ¦ÝÖñl–tö¬g*2Õëíx7ëE5¾Ú±TðX»U×”ûZåÍWlÛÌ„‚2º¬ëÜŒhG°êeÐ~qÀ$¼½þ#ô }Ïè~ùKÛûÐh´°þ±âÓԁôs>Äò‘
+Çikûwwm~%ü)%ç;Q߃£o'ª;ŸÝQ׬Œë«Ñ ":å©ä\
+©<ûÎh$^GE“lásî,ž‰Mýø³Fÿ¸)~TÑæ˜µÃåU®R…æ•)ØÂ˜§9åÆÊkkÚËú &î/9&JÅM%cŸþxEÝÞW0‡°¿à~ÿä•°-TOÍRÊtzÆøÕ±Ý‰µÇë®e)(Ô-4N'¾”Öïa©ëÊ‚»¦Àçp?:¯-’`éK!òîP 	ÍãšÍ+¯ý𲯳G¾L`Ù\åý¤¥ôd¤¦¬h8n"‚þ³ªyԏ¬ ònËÚ¹úlð÷Ä®*”ë1£õ=K_Îå–¤ôT­–Yê“¶áüþ=”ϐKë’Ñ)ãŸ?gwù”Aª«ã“8b•K­Ñ•ÂH ­’¬¸t¢+O’Gmf)uuåéÖøÍŽŒômAÈ—‹á”¯;è^ɘþ¶K"¡5.Òtío	£·ÿºšG‘v=GpF¼)¥_—¸DªüÇ>m)¾š6•/aûÊ.ŽôÖÄ–>î’`Wh9V¼ù±±NǪy9tü¤!ÐÊE9ì{¼Ë„F±±ºß„÷è¨nëX8 èÙÁö€û›ÃzgÑ]+¶g¦$üiù¢D»û@µTƒKjjì*õ¤Å÷"M3KóæŽœ‡ö%¯->ì×4'æ‹tæ!»wì(ÛŽÞ
+’0H­møÝÇ奰ÈÀÒlj±ÑåÔ„•é	¼£mnå×¼}ZF¦Þ¿þHcàU"#¹à<>¶ Åx2~@‰f³ð“£oÀ§¬j«œDœY§Â@Š?i°ØòûTSÖ!¡ðà7‹LQý‰`7ÓÁÅøQJ+“ãqJ×:):Štsj΄¿BÅ^‰"21E¿ªñÅrs›Y#{%÷EȬßd¦,C/ $ÀÚ4
+éÈzqÏ@Ÿ'®çM¨Ýi‹‡Å·$P#ú©ö+;ÜŽ3ÊåðÄ.ƒE`§[6ç!uô¨¸'3Ní­¾°(Ùr[ˆ×Q©k©|÷‰¯È’ãûzø|[ÍÁª FS	¯¿’(Äî©C—ͤêÏó†ÜÄwãÊ™Ù_𱦞°±úÆ>:•–%/°ÒÝëÕ³lŒ(½{¥Ø'½R>M™!è<Ž”%Æ.ô0£žóÇÓMU×øOMwÁhñà˜7§,BœY5ñÚÝMÆuãä¡AV1Ã?0ž¿*!n,Qú`30Yó•ÂA·UÊ„ÁHÍiƒ,£;§ü9ì©Ô3ö"B/w«ìS­ÂGÑZy~™PåÐæ'–*»IedHÕbƒÙ[-Xx»5&ÏcVoh¨¸0y:BêÀê³çÝØÌJ¨‡»uЩ
+ºÅ,ÿi,6ŒËMR–ÚlX–¥o»˜Mà¼*îé]÷4%kb6Åf´9œÄ”æ+°
+Öл“õK*>Ì·O,SƒÝ2|œ¡â¿Ô†Á$KfϬº–BgŸä1Ú=è-b.÷̾ž!mžYðG¤VK4àY?¥çÁëüÊ1x"þAßHf  ¶­à„ôY7ÑåÕ€Ø!U[•¬—0Á¯<ùaü‰£Ú”„íˆØ;µ7‰:ʰè
+E IÚÕÜ>Ú¤’Ö‘pVЈÏKãÆ!
+šƒïgY“=#T¶eÔf¡@”[ºœûž;¶ºZ÷åv>òœ­xÕZšéO„ï¨O‡
+$û'nc¾ô«øë­Ãs‹s ‰R´~5æC̹F{£’HN”¼–h&Y…ž¼åÌ"Iå-NEÕ4ÕZyer¢¾q¾Û«nøtZ2™;]Ý¥ÏçÇÚz#êx…plõL¼ˆô_¬¤ÖP¤¢¦žÁ›‚_±²”∑¼„{@Ð	¢DÙðOÃÏÔÞŒ}ÜdðSÁø³Ä>O;ðS¯ôÀ-2Ñï)ÆpOMéÑKƶ;ÍÒ¨»3·À§–"•ÇTûuÄX1×?Ö“¼þ¹
+;¼‹UìBP)¿6g&»vI΍=}˜>iK÷b^!`›£øí¯ð¢ÐžÐîæë|ŒöV‚BŠýÃðlY 7…CWWɤçž+_-‰ºpŽÖ¿¤ ð†Æ—–
+ÿ%°‰Þ¦=²ƒŸ!¹{•a‡L£È¹ó¡_ÀNÉ•z<£Ê½[~@5w÷&»×d}ÿ)º×ì­ÌZ!ruÀ5!Jj¦$öù­èѺþSàà"ɾp“àºBRÇb¡0ðÇ€Þ­'e",°Ð±î™í-[GKe~[örûÏ5”1f§ÕÿbfúÖk^üÙ(rûÊoXOÛ)ßFä#÷ô…GWé<Ôä7ª 2¬ê•hÔW~ÛÞô(|/Ov_AHœ¡n?M~ñ/«¿ ìÞHSøÁ¤Ñ=®½Bv€€“Ë*ú­$†©KU•¾žk
+ã¬,Â,%zAÙb…Æ*a4è°/ù™ªH]ãÌj‚“«Mhß~ˆ„¶^F™–uùç ç¶3ݏ—ÍËz›…âøÔÅ…Ä\‡-ø9ð8ˆZHÛ­½ThM~TØê˜è*Óiè\5;Û+¤#g²>¨ýŸþãà6ø}:¡ù4ÔPÞ'[uà‚ÒC¿RŽmûU­^yµçŒÀØÞ«‘”6ÓAžÍ|*î=Ù‚ª»Sjˆï°Ü5)VöAu¿Å4ˆy
+ìæÛ$Ù˜ŠLºK§¿FHŽñÌš á_cÅ?QžžÐp‹ÞŽý ´AèÑ#¾q‚ÁÌÅÇš¿
+ñ'qME2³~%÷&|;Q1XÆC]ªña€#[L·/l}~#»¨Û¬MëiÎúUغ"r‰VçS¤êp…CFwÏ.Ž€á(^[/’ÞÃ5
+É jké
+›ý-NJå5~Ygå8ªú¨â97óõ=ãÊñí#F¡‘ò¡·I=6gÛEO5èGÓ¤‰N¿/èÒgFÓÊ"¬YX¢`<³ì™ùdÃÆf±êð1‚ÖÙFé½™`Pœïoo¬Ò»sT%â¹hýÀ…¬â¸"+¤¢¤£6å<M#'eP¦¦æ7Ø”’Ì}W–‡á{í
+%!o–_¶—9x‹'àÕ.0lRš	I°nÝó&vÈ ß~õ:Ƙ¥F V¾ôppè
+Ô5(…5ÊzS±ÝÔ{Éx†ýâ¿S–ÁQùÈjšNðá; ¦³œß¡ÄVØÖ¼x,Xð¹ÅGͨ~ak±
+ŸS=´C)zÍ
+Û÷ýg³ÌÕóR‚|–­Æc®vZRjQ‡h–Kúƒã1êlvƒ`b¥ñƒW$ú6O©–4q<>þeÒª]úkÝ×1¸„:ŒŠÜåVzÖ¦~þ†â4£ÄŽÉÃ|J¢V°÷»9RdU~œ“&ùæâ§M9§¡0ÒН$¤	M_“É1	ø<‚/?D{hÐáP“¦wôÿ@·Š˜‘\GЩW¸Øt†CÑ“QJmÒ2,¿‡=h|£‚‘û¸^÷I—¿ÈÀmºô ψD‚l©rVÇ8¨¥«Ú^Üxjõ
+o‹s‡0ùVì+®g£Œ,ôæèÛ-LÇT{O€“Ñ¢Coµ¥•UcK`“pE„ãkìuʘïY|ò”¯ý(醄ÙrÃ:rÅÂÈ0?4´gA)÷¹íþ Õº£Ý£R}wgs&T‰‘GÉ'ò¾&¼ã¸KጹQW”.J1zòvè ÎTiyÍñká±Edû‡=»_‰"!bq¢¥ËeÙgð×±9l‹ÄýIŸ½;&·l\Z£¶ö«oµ±BϤ,v¿òFE+[Þw[Ižž©÷ÄênêÆ¬Zü…¾%ê.›O:±CՏ1‡•Ž2cF$µO͸`?	GuÁý ‡™úVz™‹\Éԍp¶K¥ï¤W?~tÚÏ	éG‰÷‰¹Ü4ð^+¨p«SgIU*B‹ó=ý·x,`€“ʝš^жÒÎ;LwƒÖÇ	‹‹àÙ­,GÒý…9¼6~'6íÜýÚx(¸ñ)[€b¼&²é邈§Î£kyþ$ô5CÀÛÐLÆ1FgáìÁXùUÍ]À¶C¬¸2¸–nü3²Ú7ZiÖp?”ƪƃRņ¦Ä²\8³ò…ær?²'¶AÞ\=Åà9b„}E¬EŒájõ÷HV“• FL±'ÓЬ0mÿ9ú-	‰øIN¢½÷€»ÎJq’‡ºvÚ0M‡BJ˜Œ03àö~d;JhRá@^áTv\爐—}ŽûÛ {L}Ué8m^÷º+Z`%oÅåñŽ›)4†EÔ3ûí¹½¾_Kü×®EÐ4‘“ìÇŸä?“ŒwÔµ½ Xp‰ñøÞE”nJxŒ#Hà4-z’8 M.B愽~Š
+Y ZŠ»“5A¸_NJp±Ô<äJ쮐“4s|¹û×)ö™³€`´„¨)…Í÷¼f’uvçt’r£eÕQ!‹²@ÔÙ‚™ä6>§ðþD×i¤Ú½)iÊ©KEš»J¬g.E;-kðXTPøÍòצ»À†ãÂÝ6%NvžÞlûeNl^dc:3ŠÚÚGāYÈZ|:ü%À·4#pCû0~ñ¾V¦7Ç'‘QDíå}1ßuû2བྷr„"3Ô7¥3â©¡†Ól—#n÷È·˜{Q•U®Î·2³óè®Ðš?²ã?‹hÁ
+Ù àÞðìÝw#úZ4%Ù›¬ZG?žÏu‰aÖèÝõÀ™£d³2ÒR¨‰jã:.Ï’’BcEƍ/ºËËø¦°D&êF„ûóâóü¡x‚%CçÊZ` k÷Œ¶®6	4°þF˜e¤50ݲŒ÷µW—ÒwûÁšåGŸ–ÏÝÕÛ«`DZ8àÚÜœâÄßxÓÉ+øÛ ÷æõ4û¬LT‘Š™òÂ–‰Î\ÌV¿[ùðr2ÈÄ6J³Ú±œšFokeû»á<EÞL*ß©8ØÂ'«oõÞÂeéaw*ÅiÌŸ
+ðžì¾KZ:”£·rH!0WÚ_K=ʸs
+÷Q÷#TjRŠœz§	ªœ<U<%[~.¬ŽjdÆ6¬H\>@ƒ»äÌå,	†7Ö»„×þl{_ªK7÷|çÍãöòÈ#FÛè'+Šúvÿ¬7à¹Snnð¾¹T^îO•Ô¥b`1ûoêìÕÒAæöÎJã¸É\üâÒ³êäÊjA³?<œ?êVHŸj	åç(ò¤[vÇz‹õ¥Â)¢™yØ@ï~´@&ošRÓeøÙŸ/v?| Wbž¤¾6di
+c(ïÙ+ççñ5|@<Öа÷9È•07›¿ˆ”†ö€¾ ÖÏ%_ìö–ц>ÈR‹ÏB1ÝwOÏ:ûÖ^²¹Ár‰mÊÞ´ÃCûc¾w»(Õ¿]+Î+	ÔÝpkÈÝ^u¡áS#äôà35Ô…™g]{Ue—“:ixå+k·îŽBŒ&VÐ̉ž
+¬VF[ì«IR?¸Ô%ˆÃÎTõOf«'iæ›®•XÎàó)÷¦ÓLGˆîüA¬‡6ùF"g6úœ—â3³½CûòËw¢û&¥"Xm*ŒsÄ;Íwp\ñÓÒ …^"eþ‡,^³WЧxh–‹ù/8_¹æt·ïññÆ«ßeÎUPþü´bõfôý˜¿÷ö>ßõgï´4E%n½ •9òmTNcBՀ̙±-c IĤ#][B¯¸ÓkÕ㙉…‹èÉÙŒŽ°âg±ÒÕê©y;1“äÈ0—ÞïB©ï”^vœ"ôR&÷i¯<’4P…š€R6Òg€í7:žÂm½mÿ­LQk,ÙF¤ôWþ¦]ÀÃiN5º¶%Ö _b’”h¬€±Î2ÕUö@DüYB}£b|„Ewk¼Oðcì´7ê™t¥ÌøÍÙé}{ß—¦kÌm,>ͦzéý}þž˜D*7‹¥¼—{¥öÎ8ÇÝ!Õü€›‡|îGßqæÞ™UÉ-b.dÔ(º‹µõ/°›uû#ß¾p&™¡ó ŠÎ-K“[¹@Z¸xý’UÿÔúûtIÓÝ­yËóeì&é¬'UÉ
+#­ç±¹ ѝË9.à8ÙX¹sh®Le€ŠLŒ‘#ŸQ’õî&q[UÂ}e3ð'PóŒÝú®¢.©òK²hv¥Š…Ü…ß |œZ"òy&›™D¹wGÿ€_°Ò}e]±y'ןàzƒ¡…’^cQ–f´fP+—)jiõÏdoþŸ£<`N*"€ž¾­„‚.“²bþ4á‡+r›µŸ1 i[ÉvÎýÇGÈ_[È:îZ5f›$§®†M—Lµ¬¶â?%,¯cWé¢ì%ÄÊ8¤¿‘µb«iìµÔˆÙ^Ö9{Èb°]vºÆ@ ×.î›11­ÇëWÁ$M¾2nMòYRÜ}Uµ¹ìo]Õ\¿9ýØÆ!ühê¼€?ËIïoŽ <Žúå+q÷·…Z>B¦‘Àšö…\èO{ S©yWd‹“nÊ·èŸqò/ðí,ùW¿¬UýûÚòEpï„Oz2žFÊô®ý¥!ñùAëTÈ¿…ÁÆ…—Ë¢§æÄ„í8¿›’¾‘ßÞlÔ]b—/ˆ`!·“’TÝsÈšNº©¤–ãÕÖf£Ô܆Ó¨êfݺµ~5ÊöôZÝ›Ð`ê@>z?Ø]岋b¾
+pž¿D3²†û|³Vt–tüf“³Î ™'ú3¨¶”­šÖ«ÁdH}¯OwÉL	ˆþ Œ•ðL…w°@L½OiD¾ºã*4ºk¥aùãsr¿®¯Y¢x-Ñn®‘ánȨÖbGõ†9ºÃ²x¶?c’¹×d@çSɦ~J‰ÔrÈ:šæƒf¡%M‰IHÖAqyŽê~lÛÇtEö\$HäN_îèeÆïf¶@ªÌ¨Ý.”¶.áf#Šša²Ð,Ízê{k¬~ªl€ýÈ(‹˜³üBú†=’g\ƒüœÆnWXöõ²u…‡	Æ™Ë3äï¾ÞŸæMŠËi<܆ün&о›ªUê¨=W`ÈV]<zÔ·ocяÍ{ƒ2-ªù•ê¸HÀa~«ô"ÎrÄ%ŽLF°Öœû‘*S䤡dzå×M‰ÜL‹VÆÕg²Ë
+§å›vK›Çó#,‘ÍD§YÈHºaE¦Ž¦oþ.´¬¸ptèiEbªwzñ˜Kýn†}Q{¡É•Rh‡qÁaµÂ{n5íÙëË|ÖÂÓ›ÂB4®z0Ù߯bÝÇ+æ|U‡ÀÚõÜßö_KƒQØ9+'©_Œ§˜)‘¦Ñµ¶“øÜnaÛÕ4MPBymå?C~ €ŒL³ªæ‘·Ù¡;/™l’^êyõäe¾‡`Qï̍¿@I[ÐShг£"ƒ}9•f	¼Íwã!ÏÕgTZJ#®¥8ðµ=À»ZŒç!‹áMãMŒ¿`!Álhmë…GíPs©»Z“÷ÌÕB2Dî³gbq>é
+’Km5dfB1/:Èy‰®d}U^mÛÏ™£ôŸ~~‹?8U‚âøú6“'º6éµëÜ±44LÐdéÎ0i˜§ÜòÉM¼y±%‚³„‰ËÉÔÛ9CåÖÃa¼‚–lmúU$“Óhwþ6ßÿ]zLçFex<‡ñGnräX¿@¸ð`éYÝ6Ü{ÒhÁŸvsuX[ykGCuäÔªE©ÂyI2áœB‰Ê9jß_UÕѽ,C,C—òqˆ¿ù?R\a7r³¦ûí¡N~}Øö3Žf&ÉQ#÷©nîÔú_÷”˜Å`/\³ëd³*7N/1FÒ+ê‘zI륰¥ãÕ©|.˜~-ŽÕåi?àW\?y5\ì,$R]†S)´÷±!ÅÖø£”–oDzÊÇ£ùzdM&dZì$+ØGx"’ˆ¼'ê>v—Idê½S(†ÍðÙ©mx²âæcAwÍ¢Ÿ­¤ÛMu»pÓ¸Ž"–wÉNÆ{1«ÜáNÔò-m]b-mÔDÒ†nl ~÷ê=–%áìk;±îMmñ»Ó*6.R¦*zÑד+ÈŠ¿Ð+ÿ¢i¤Fg2-Û5DŒÐ·÷›ß›«÷-<Ì(n"ø}X”$K­6z˜ÅìÃÔû“TüJ^Aš'Îuç”XÚS¿µój|Hr¬ö0š\¸dèH²d,À[æü–<‡==¶#¨²…Wú´çqÖ1‰/ú”‹2Å!unÊ:âÊ7©QYŒ¾ ë`½>zN_¿:
+J‰´_yµ-Ü¢EC¾E7ïÊ¡T Éòº¿Þ£ÆÜùäídq¢ûËhW~ç'>>X¯_šüQ?§Ù{2ä­”²@{`Š=’Úá0b Ó¥ÞÔ(+žçØÓ›±JÅÀŸÀÄ,•õ,©Œ§
+é9gQ«Zƒ:eIGtëˆð>Øã[sðÆÄ¹0i¥3íŠ™ú|³ôÖ´öïÉ#ïõ6 š/´c.ºKÄä8¿
+§v8º¡½ùWœÎ7QpuQ?Ä8†è_æP³eœ¬‘ª›>µŒëVu7w©(mÉcOÏŒ9±8Ïþ:ø4ä@£‚ÝÄ[%ÂuÈ¢6`i
+]µ#eæOޏd¯ÉÖ:yPêBCë_bi›ÐT¹ùSþXL¶Ïº¼ÉN¢ Õì&‹´Î'”H‰æ·Ôä@ ¿ï¢¬¢"ÀéCã™Ô¢Ðþl”­5™òŸ×|˜ôÐPcE çeŸÑȵ—ðµ€™ƒ“hÄiØÐwMö¶ÖÇÓ‰OO=¼úSNÑå5Í[[ïJ·ÄqÁ-¡¥	Ô““âBÞõ¿Ñzó›2êX«Á³—ˆò£4Î3àIð&Ö Ÿ¡k¢P0Â“ÖÆÂËu†IŒŠçôyžmij’.vSñÊþ^ÕW,lýb5RpÙ¢|Þcç½5™1ñh«ëÅ?î8Õ ûha…¢
+Cøqšpê<g*NYîÉO~Ök"ÙWÊu÷ƒê.g×Aö™Cº^'£/iYƒD¾.}ä”7Ƽ™Ê^H$æ*¶dÊ•­®m ›V¤#dz,f…Ê›«^G¹Z^vD÷‘iêÄgü¶ÏàœOš"í|V’[¡L+Š­„ó‹Y=}=í]Î?†l:z}øHž±—RÂõÕQƒ§‰íËAU¢SD[¿›ý½´Ï
+ËÌÓËðeø®«+gQõûW¼‚4Ìü‚šñ¬LDL:ÀHKL£ÇãG¶èÔ,Åu—‰üGDˆœ•^Ù§ ¼üñhN]½”*>å’Í
+·”i<eNÓ*sŒ]_ñ‹š)“ƒ'_ù±ÏØHƒ]öüÊÃSßêGn¤Êz‚)]ó’¯9Vº³ÒS̨bv%f=~K"ÇZ5|ÉÂ/£?ÕŽo9°ÞG~~ò¾‘ÿ&Øç“2Ú@û$7ùúà%çØ±Ü¡†¼Ö’*]öØù‹°Ð͏ƒàR7Af˜7hoö=ͤ†<ÞšoËId\õE? Fè+§Ø
+éwµ77Ñ'ZO—’ZÙ=¼¼C%q@p(^µÒ0C:¾óù­ËÏo>Ç/7ßò’?X„Tu÷YûÜ£ê½ÅïV|¯ø¯Âå}±çÿµG=ÁÈ#£JÂLy{R=…°¥¶6W’íVÙ–ÍÑ
+mn ÌnµÆ0;<F'âè¶	.tD—?ÍÔákE/——(ÿ†à¦i±ï~¡e“Ñ÷Ý	dºÆÆ¤±_¸Ñí”ö⢰»Í1 BÖÔŽPÓáÓ‰ªOûî6¬’É×(~Pµ{ÚÉÇêJ¢+q
 Ñ&ªðÅÖ{>8;ï›;®ts¦ÜÆ€CníÔM€]v
+õÄeÂiáut«'΢'Iº¼wÈTTáDhÊd²Il¼kú™òÿW %-
+endstream
+endobj
+324 0 obj <<
+/Type /FontDescriptor
+/FontName /TZLUSU+NimbusMonL-Regu
+/Flags 4
+/FontBBox [-12 -237 650 811]
+/Ascent 625
+/CapHeight 557
+/Descent -147
+/ItalicAngle 0
+/StemV 41
+/XHeight 426
+/CharSet (/A/B/C/D/E/F/G/H/I/J/M/O/P/S/T/a/b/braceleft/braceright/bracketleft/bracketright/c/comma/d/e/f/g/h/i/j/k/l/m/n/o/one/p/parenleft/parenright/r/s/semicolon/t/two/u/underscore/v/w/y)
+/FontFile 323 0 R
+>> endobj
+325 0 obj <<
+/Length1 1608
+/Length2 10163
+/Length3 0
+/Length 10992
+stream
+xÚ­veTœÝ’5îwk‚»C°à\‚Céƃ;ÁÝ	܃;$¸»ÜÝÝ?Þ÷Î̝u¿ù5sôZÏ©ª³kWíª³š†REEÌb”†€X8XÙ J [gGuc°‹8ÄÆðfäA¡¡‘p ; `Ic'  @hš89üüü(4 	ˆ›ÈÂÒ	@¯©¦ÅÀÄÄüOË_! ·ÿô¼ÝtY€´o.@ˆ-ìôñ¿¾¨œ, s
+ ¡¬¢#§$ —QÒÈ Á@c€Š³‰
+È  2‚ sˆÀæ€)lú«4GÖ7,1G€1ÀÑh
+z»t5ÚýåbØlAŽŽoß #ÀÂÁìôÖ' 6µq6û‹À›Ýò7!;È[„í›ï
+Lâèähê ²s¼eU‘”þO'Kc§¿r;‚ÞÜ ˆù[¤ÄÔù¯’þö½Á¼yŒA`G€ÐÕé¯\&@€ÈÑÎÆØí-÷˜èoÎŽ °Å?0€Æf6 at GÇ7˜7쿺óÏ:ÿ­zc;;·¿oCþŽú/ 'G 9+
+ç[NS§·Ü 0
+Û_ƒ"6‡ 8Øÿa7s¶ûOŸÐáïÑÿ53o$ŒÍ `7€Ð…M	âô–@ÿ¿S™õß'ò¿Aâ‹Àÿyÿoâþ«Fÿm‰ÿ¯ûü¯ÐÒÎ66JƶoððöÂ8 ½1ÿ_¬±-ÈÆíˆþ×@-à?þO rNÆom[¼IÁÎÊþ#ÈQä
+4S9™Z̍mÞzô·]lt°oZþÝF Ï¿ø4,A¦Ö࿚ÎËÿ·6ûWæoòüÍ›MBMì³´4Ó¿¾¦G©¼©î¤áf÷Fì?êP„˜ý×á/qqˆ+Àƒ…ƒÀÂÅÎ÷¶lì\ ~n~¯ÿ!ßß@ÿ<+;9€\zoE³sü]úüþy2ø)°)Äì¯9Qw2›½Öþr›:;8¼)ú÷¶¿•üŸç¿‡tš¢,ÌBL­R¾§:UdõKêu¶sÀöÙÖhäåøþ„üöI	Yã/ýòTÄZ;*ðÒä6s`÷¼%ϸÝߎoC÷;	x’MêEÅБƒµLÛÂÇ´íÏfXˆžz¨áq:­°
+§ËËþy{}XUͰà	l´…Ëéô–Á—Ê%Ç—úÆî·iru4^+f-veîÁ!müÞí
+]÷@_oÏïsøŽ-¦ÌhdAcïÄÊ'·/W5¦Ï_Y~
+dčPšvö#°ÞWP£¶SÃm‹‘ˆ’Yž¤s­†™Öÿñž–Ø%Þ—ç%«2pŽÅ©l`® lê×U'*Íã~,2akõç£L»M©µ0¶ýVKCƒ Ó-y+jfµ2káé€ò:ÉM“™àmÕÍ™ÊEµ÷„Jê‚l¡©ýS•è©ÙC?ûôÎöE1óŒb 5.‚Ê‚!™albvm‡6©23‹È¦ªz-êl]ÅÖ6î'õÒ>wj )ëêæVi-"å•Qï›–D`L0ÇôªÍˆV-#K}Ÿö‹vqž$\—ú1iÆÁ[Ð9æ}0ƒ´ùÞkŒ}:prÍÀhDÙ§P…A­œ#Œr[vîÔ÷,° ŠMÄQ²;EoJHƒ ÀIœáR^prÂHé^ÉÚŸÌ&Ú
+osoÂL“̝\äÁ˜c;
+4ýV´å‘o	]ÔAëÇ|©ö°¤
+¨9ïjñ[‚„^(¾ÔUˆ —à[ÊôÚlYo”qᨲª>þ	Ôʯ6‘ÔÏ›ºKª,Ãé¡,ÑÔ
+ßBí£úcг{öÞ¼²åý°
+³=ŒhV¨œàýƒ¨#RÚÑߌ%·@*Î&M,ž9*Ú0 GÀ	m±õs_Ú…IA¥óë¦÷¯G[?˜k¡xÈMØØ_ÆÙÎôU¬çi=ù@'øëŸùAGBëoØG„f`”üfŒëõJʧdš9¼wlAR_H&ó9ŠˆÀx>фО°!Ä¿g;‰8žîIUÁO–m™”†¤nÄe¡û“/WE¥yG	¬ýúÃ=<.ö¡[<`´uûôÓáíÒñ`0hnR‚åø½h§,±m¡TÄ$X†½ûçHbÔæc…ͤs-mË Z›ø¡&*©ö™?EO\Ö çeHýhoË¢+b&ï¬=C‡ûiV![¡ºÖr>¾·ú¢rœùå)¨sô»qls,)EŸ¨FBR‰KE#Xy¹ý’"NÇ(¼½mªÌX_ÜցÎŸA24Ñ¡m.iR¶ª¼Ù°#Ì­Œ£À[ý4<^©$QÍÏ»x;»fgŽ_ha[(Àžkóòžã1ý”ÈȆҡ*Õ3v…UTçUóUüt¶Á7iü	ô8rÀ??Î}IJU©´1$X
+Pß[åœ
+ZÌÚ4EÓjëöYØ
+E“?¡ßA!_-Dïï•/rC¢œH±BÖ]± üäg[6»y?Mô*§S`Ä,;Íò¨! ´&‡‡ë÷ZŸ£Ò˜lÚÂhš¥1"òsjÎuIÁÂ^çX»
+<$&±&|xĤÊêÿåŠ| Z’f¼2¹¾bÒx´!º8±¾é—Öµ_2Æ×¡’§åí…ö®HÌòÖÚ±À'?¦Hm”³Ê+Ñcy¡üMŠF6Íù¨Æ€p|—¥ÚðÅÿTÉaòâð§;ÔQûzñûÙ•™î³Bð©Ï37ÏJžK–éÃ<À]Gº‘šm ‰_3I£n €¼Ôºó¼h„ÎíþsÊ…õêÆåðXùÜŽ¥„YѨ½–2‹…ÿÜ­•WÞÐçO}ÕÂö:zdó?êY¬Û%_P'R¤¢«	Ãê*Ì>ìƒ>þŽO÷Ì\¤×EFU#ŒiϧÁïÊ㡬±£wÔ´ž_Î6NÛíÀu
+spP捌(ŸôT…*©&§š_%½ä/úðJ•äï¿À}6‹×öÏçϪ(UCÌ–ødX*'QÂ,°¦s‚§ón‡Jñžî¸õ>€íñ’†ÑÙ¼Æíu*‰aɵBÜñï_çe,.Íîa¨P`Ÿ•Nî¥B†£HSÂeÁéKÂPEŠ{¿ÃóÎû„î˜[ yëi0m.ö°íáëb&Å#©Ïú‹×‚]YÙ
+¥j¨¬±§îj¼þ†ì›Ç<hûånß骐‰QÙ7 !¦HFjJ&°SÛâk΋Ú•±|àÛ2UêûRi6÷ƒ¹Êû)ú+m
+ªôFØH…¼cT‹WnpQæù|pØLOµ
+åp“;UpˆáÓ*ˉ¾«é¤[+…³rœ'Eð£iÅõNh9ªVÏaLD¿~&}¾l¬ì±ú]R£#ò¾Ó\<¹bר?<²'6ÙDU[ˆæ9üÜÑ
+µ=5Gz#šÍ.L÷pd G’#iÑÝãØûHÈ×'Ž|×qS®ÂÔ–Ÿ§[£.ž¦×v¹
+ Ö¯éüÍB´»ª@¯eÞ.²¼Ç[SÅÉÛ`h”¶2ȍRb‹kÇ¥/‹Q•c/ÞG“k‰,ã™,Ü´FKlŠk3X0ZB‹Ô»Øo>íÞ n{xØDÄ®»y5ÄF¸õŸ<BPç@/SKê{Ú3÷µ¨Ã²S±›?5œØHñ äà”æY¡6s¤¿œÊDÿÂ>Z+³;ôÎ&ûÂ\}Y´{52Ù*Ñø6'¯$ÇËy«}õùÜÅ}Ԝ犥2÷+ÁF+Ñ4—Ä&8¡‰ö§|£p-ÆÉ(¶rßâ´šöŒ©ë…ƒŒ¹CÞº;¦4’¼yµš—ÆôÃΜ²A{uN;…ëË2úkýÆ“ëàø?].âwyÏ™`¾çº2·c!‡Þs™5VbÙ
+á ï1Ë«î—ú?óxWËsh§‡¢‰wì)ëEÒêKŸwtZ¾‹µÑ²)
+y)ã<F)¿‹:j¯_U0JÓ„}<ø¶ˆü’.õX&™‚7úuŸ£(}Ø‚bš¢Ût²=–Þ(s^øg¦[›’fh•(0_p˜­64®9ÖK/öé)½|“Ã
+-à‰áõ0ÆÀ­QC1Â×vZöÞÚÙÕ—àkzœcèAEàmºç–W©já«Æˆ];ÂyM¤›¢¾àúÁ‰äþ48õôQòæi<œšC6~­WË¥*˜­†¬—2=`_Y€ë´ñá…"K»°ÏE‚Ѷ˜¾ð -hfduª»£5ß±-Æ_þX¡?¹/¢kù4]3Õ_ŸCZð~=HÜ¥Ü|ð÷¤ÎÛEÔùœŸÊ”ßñ‹_¥‹*°¹0(â|A—{¡
+mu3ÈèI{.œûû¯YlqÆû~ˆéƒ2å×$ñÈïˆ]øFƒ 0zsÿफbfXîfîoËæ_k·U²1–•ŒßØVk#[1½L$¹qG››¦l¹¿‚ïÜGióPí"³ŒÚ²xˆ8«¾s/îŒpG}¾N‹«ø<Xè_SùÑš”ðƒÛ¿‹>‹óâx¶ç0_ˆÙß–/²*ü»z]iEþcñ×ޏB©Ùë÷ÒEsõ.”ŒTʹA‘]=3ACwŠ 6=•EX· či‰XW½?|hÊ‘Íva%Ì,ŽÇŸßsL¤ÃÓ»„nž
+ÁÙÐ&,6ßùß¹bƒ—·
+cñ&3¡°ÜçJù AÅFRýbì1zðæ	⇁`ÐUË^td=´iŸ[×g¾#r8¼@-þž, ÍÃ~ƒgØv_Ê/"ÁÈ!×ÐŒ‘R8ð›	ôQ$…9³=~îÛ\Y2õVWãÁ»ÖÑÀw2¨	1“+õÄ:,ª¿yŠ…#\øÐ‚8є쥄Ûí?Í€¬ÒÙ¸ýyS¢Q¹eEF"ÙmõÚ¬NEÑ.V3bœúeJB
+É¿‹I±Ý“ì£î.lâ^=ëH©©¸³ÀÁ»J5ÅE¹¬y¡¢®£Ë~^IÄGwꥷœÓÙV(,Õ˜v.b] ùÆȯ类gî¶%@ñ·ëª:ï]£Õ~‘Ú¦J›ì´y¤µo`Á£C›"Ó|œÎSS]‘³øzM±¯ÙÏÿŽ;g[»xÎfÃÖ&Çä8¼ õí¹¨›gͨ’ª`KþÈüL¹þ;‰è$QY’qMÓ£L/(eº«…H³|TH÷š‡Pár¹êÅ·K„[²äÁ%qûAu8—’†cj×ßV`–eg·#î0™+e¬¬Ë"&X´ŠDT^ϜЉ(T
+ežgš‰ÇâÚvªø*eÏä4J[Šò-ÍåTLŽâ80f¾|.Å¢åZ
+|ü*Qwû1cµØ ~Ï7~Îz}ÈæžÒþ£ÛÈPs‹%ÛNŠédŠië·W EÅéAE(gíW>2aÙÀºw؉=OŸ[êlî}kUǧÉúLèÇS3;ŠÁÐ
+{ðòMRXØ2Ñ®ž£¹}w6¶Üñ«…^âj‹m1‹'Ñ4«–ⵆLWS#¹ÖŸdŠ¿†å:F`ýqiÚŒîÀ\êYå#ÏQdœ43éÝÓTõøÁÇl¼áÄòÑgp¾¦èó!]~ßY`°_“‰&eAøšÇœ4õ‘û.šÎ?6½¿ÑÜkµ”Xš÷––:”ŒÛwbyÂͽQˆ;¥úô5z$C‰ši“£äÔ‰ÚžL¨P²ºJÛh­:0VÊ3ÄüWç{h† ÞcæŠöû—àëÁÇäO«œ¤ÖÔÇI§†'æ3íE_j/ÇnùL:®julÅ`êv—f„èÍì™éè¡DÙ˜åD&ÊÌÆ¥vê’RÓäaÚy0„ø‘Ê-žo
+Å	34Q²Rg}l2ßM g~Ä9Ë‚ÿÀ ˹o© þþqfÃÅóã/£òSv¯{ØÑÙh÷wÏÚPÌî|â¿€¨³ãy!{¬¯X^(ƽæSj©k—천w°4ÖÞßeTÕØ¹NÐå+÷¬³Ñi>Î5úûÑZ(}ìð)EnÁ[	Ã>JÐŽ*m'ÊaJ@›œÔÒN?æ!mÿýmMS…=}6ùTô~ÅQ"™Õžò±Jø·ñ#/nC
+¿ÿ¼zhÊÕqwZ®.¶Æâñý AvF‚ÌJ?.¹|DP`n”–Ü»qߣ³}‘òñ\$žk7×b4BŸ*¼YSY€ùùÉ"ÙÕ„,îz
+#<J¥Sç"‡éxÖ~<¾iA;"õدô59áYjv-8hÆãæ¼[³TÎ)LèqÇ=»ôiېò™•Òö _HîµSàä#)	’¹b[Í-ßÓ«<ÏCQ›ÎItƒ9AŸa™>®ú9†wh¥P¢<¸jfÏÐÆK¨
+ÓÜ<ØåÙ
+Qö(˜ˆY”%jt‡è‘%ÞÜb’·aÑkKÃfåK=,­\žêÛö­cÕCdó|!F¬Õƒ%£‘vÐñú8„»­âÑú0“ôþíØŽïÇP*Ûèrwu#Õ¦+&sqÙ4àÓa¦JÚ?å~x	꡺·`¹–íæ/
+aŒ—s7%-Å^hå|Xñ&eV»#!2ðŽn
+Ãc·[MÂ}=0;Sw
+{©…mNͰÑM%ôÞ:’ÊzÊÁù¼zLÒ|[}2t5áûá2ÖΕs·]¥•5Tðü©!ûsÔxÁ¯ÌÖ
+xß°÷MZö×ÙxАsN ÎƒÞJœq†AU,dƒ’âÞÕë—˜u˜‡¥Öõ„,C#k/âÔ	:3ÚYˆúcGÕÊ-Ù˜Bñµ›r)q$¸ž·¥´PühãÒÞ§@ê¾ycÙ7öòÄ0ôºÈ+(6¸s>wÕ§äô:9…‰Äl¦õw2Z€cøå†*7´F##ùú6âDÊ~‚›e$£Ç£îc^vÈd×ÍP<] á+ÃÃiu›
+ö.Èq ‰È.ðð[„\ð{Fý3g°Ôí¯J+щJÙ˧<rL»`•m¢k¶æþÞ~Ñü@ÚÆ}½`τަԒšÂ©<‹”ë{gÕP¥_ô{C¤1ƒÏPkÊŸ¤ËòAܬÎLΓòúéå|gu°XŸrXcäQaƇi–  	5Ä[Ç{TASÛŽxŸ¡ÅÒ”AktŒ{ŠóYÑž\ìZJ)aïË1ÓtŠ]&µ1J´™S
+uŸˆaTè>’ˆg¯k­3•shༀ×ÔÏÌŒºðÁÃÏà/¿×ž©—üHlu·û»P8—߯âx,Ù@Qßzº’åLºÊÆ`[~ 9RÉj[J"ÃeÈÑêe6/ Ý„¤uv¥ÆqžÖ~DiJ‘ÀVîá.Ñh4”éðìò$»×y
+Æ5<Y13á®ô_a]õ‡:vú2~a½«x!"¸Ù+·~ @ˆýHz©]À|rÊ¿÷Š0£tŒÖŒòÅ6f©ŒëüUÎÚs[Ñ¢I¡P*^Z՝eÿdú²h9˜»>ß r¼Ÿ9C¬Í•^ÄU¶g•luì.,á*‘ú¼~®àQÏçôcŒ¯÷«RƒF?·™Jïˆ\¬LïéLx¹ŸtŒÑcYbž>þJÛ`:éÛÆÐ€"‡:×V_[f3¨æ â«™GÀ“Ëôd¿ðk0§ê[½³Ïçt|ÂÀ­XûVŸÝ\MG‡z)ß ¬($lÕüQ,’_êÒ/ýä3ü¢CÒ‘eõ;¥$Üf˜nNҐƒ*™/Õ¯Ãzq-9 'ªDOøB$ÍT¾x“/1ƒ?€‡ï{0Æ#êp۵†²¾×ë$N!mœÕsÃ0*$’î¼Wõ²‹ï, 0wYg˜ÖMS­)Î<4„&«¥wHHâ=kínxfÌ5UûNUp«AöÛr›äyú2‹ôƒ¢˜´tÕ—¤-I'OÆõ3®V
+þÖé÷¨È†ÓénÿÅS.ü§ÛBG%ñõˆzÈ_–@®i†âx'fü^	±:øi˜åkòp±îÕæîÝPì)nOô‘Ãßx¦HõÒZTÜ`v©>#·=–›”Áfð~P%ÿeç½ãò[xý½A
+)½Oqë¯fǾ¼“;zžlJÚÌ‹†j»Çûf'[9ÍS†“ÑÝÞHx­=ÞÚwBAÃüÄ~S=ã!Ù'ÛãÀ%’A«ÁwÑlâ¶f³~Ù
+½îTځaÈúâ0®p<
+xLk“	í˜6¯¿&O’=jPGåÎçûõ)‹P,ª"ÂÝ2¼Ô”á×o"Ò%¸ƒ405É‹ÎbYɈF©e£Uߍ¥ïN!úÅ]:™®âí>O8˜°ÈØ+<¦åmýĝ\¿.î·”d68¸ë-̍¶A5Q«[~H=Ú=^½®lþ-œþ$È<Y‡™©Ç@hÔŠ}qƒ®}xÜÀ*ì¿£cRà~¦…+Þ4´Ýž¿¨ªäé$÷ãI[‹F|BÊ|÷ÇW  gÕBA-w§ýãÌËªÇÆÒº$œª~VmÇ‹Cƽãs‰1]å‡ÖWÛú8ߢ≢sjƒež…BúÇ
+Ôäp“Oû⯜«Ô±LÄ)Ù2›ƒWÏ$îÃ×錛÷$ÖS!É5=õï°•®Yèµn¾Á
+PϹpò_Ò®ò¿Ào°ÙˆJ{t*cÑÉ„ž¶Ôpz[ØÏ'᤾ÙÎx’–è?ÇÀi韗Ƒ$±X ñó‰Hݐœ…S¡ð?ÖP7³c rfÔ]†ZŸ-¢áê™×’+]Ä+‰O†úwüÂ_íšG:œ^ضäÂÝXoÇ»7úæ 2Ñø›ð×=4e»ÃþßuæüòÇ6¯m—芾büVþUO†ø‹"´šç݉kç§í@ö=þqgâ¼Rlׯ¨­¢-kßúB¸NߣG¿ß»›È¯Z˜—͘X¶++î\QùôF”†ª
+—£°¤ªºó´JflŽ–Œ)ÇËÈëC£Sê5k˜@Cš)‚y’çõÙÄL©Ú+ù1Û‡SÜÜ—¡…TOÆÆ®Æfßþ«„á½^i§¬zÊé%æéWW·úÁ3ŒÛðÑö6µ¤¬µTšŸ'·	ª†Žråy¯BKŽK¼(ÎÕ£eÞwf%)à1vÙ}°»@‘Y×IL˜€èIû§_[<oyZ¤«4²¼EQ½ç·?0¼¥í0”åñkù¯È¶û°åÑ=€ñ¤ñÑm‚¯HøÞóâ[míÁG
+Ây…äá×è+Ù%j—¥¦ !ìIK/Î=páõޏ:øKGÙíýsð±?ÕäÏŽT%væt0–¯ñ!–áŠnP2fü:6_1ÔDB—‰lsØ“Åsä㲍Àf£öÁlCÚD@¸q ê.sÖ´F]íò5õPL©²^00÷óO¥Ë±ïF]¸ñmN<›8VØêœOªÃöX!˜ŠïZNÍxKr{Ÿô72ê
+®»†é ŸV¹oñê#F–Z«q.ì¦'¼Ó¿Ë[t	©Ý¡|yò&åt±b·!ÈWZüuªƒ	$xñ‹‡qð9Û&ˆÓ‘œ‚+tCêõèp`£ÜJ)eà«~˜ÉÛ&„ÒVÆPY·|zQ]Ã_ÌÅ^GÅÓ–ÁdµÎ
+Α§èÄ5öëí+Ù®4¾yߟ©A` =£K¬Ó*+—1”äÍn úç=r0>1+“ž¼ØÑHÄhqº†ÍœÜþöËN_`BêÎ`Þ5sǨ	ë5!£Æà"m2‡ÙüŸK¦N~Ys†¥#Z›BM’w~[S0RÓîÒ‹ëU&VÕ3„í™z$‡l‚Õßã7~ØkDÖ+yº‡©çÝŠ¥0QÌ(Fª‘²`y»„Œø³4åà˜Ogxä@»áVýçæsÁ¥8ßf·˜DÓeUyˆ½›kª	l¤Ýgû[gZÝ÷r¢'òPDï™ϸï_*ÖuéPEN:yˆÍ鏽V½×»e‰ÉƒãZ²(nXIÕóf
+ÕÕg~Ñïd[P4ÛŒ+€½qmQÚ^.nëuKÃZáfaÚ}Ö·jœŠ¥6mª˜…̘斴̶©«FɃëÉS]ݬ&oðt‡«¶hgál*Ö=•ìã†k›=Œ8ˆŒS­~dÁqt¾)‰còØ–æŠËŸ(NjØÙ´,0H2I‹ù}+wX‡¡Â©«HÏk<1òŸ_‡+ùZ¹æý>o<$*黵›Æà¤›fèÝ#¼¶¯ðŠ@/Á:Ú~˜|tCªšú5ùœì}Vªñ+à…i›G°²c“‰—CËZ¡|?Éû^œuÁÖãrÿ6²'N	÷Q³h¶%‘èçCò	Ýžß}BU{7êr,×W;ÿåŽkÉ­iy(ƒg†aˆ„"'L³9†œ;bO±ŒHÇV7ÿHä]À¯5•jî(}µîé›Êú"Õ3äKÂbñ»Ãþ>D‘¾–è
+I ¢é»þ®Sñõ8Q[F5#áK6Ü?Æj £–‡Ö©á†“-z‡6æÖ1Êf"¥«:c‰µ}m~êÌÚ Cˆ:~"À¥×;䤵
+XŸlÓc‰rÖXxâǪ.6ÒK°ù‹pždck3·æÿ,ð­^šZ{2¨VçûŸ4µÑÊ[qâ$¬\1+8¯
+‚žÖZl\cUƒY Íd%k­*y`¤9^bp$Xꌹx0~PˆƒÉâ'Kò¾.vߌ(«Gãå
+LJþÞ„»mÝjݹ\'æªÑ%)ê“O­“”Ä™¹®(w0ðã׿õÈVF…E´ÛØ–Òu.WÅPºYŠJV‚°¯ˆæä²$r?òÆT_Çf…vIQ$*ÕÈíÙ èÇú
+ºüÑréÞªGví¦ð!6=R6ËÖ¯ ‹Ë*ñNu€†™çRœÅh.
+uº"ÆÞíC€Ãrµˆ¸‚JÙkLP½ ¬¿‚SÓÕFN¥µ]0µFB¢
+eí§$¾»¥„=/»Æîd
++­ Õ’ÉFGå–ÔUVL…ˆDÁž>V¢ª‰™Ý[‹W+lK>F
+ÏV²²hÚ9=@01C­óûjÜPG-µL¹º©q“ô7¡x”Íĺ>¬_Ϩ´ïóºkGØxß6Üu™æH²„¾ú†YŸûK/qƒ	ŵ*•-:•†é“Z¼=MîO Ò3#¥î4rüÔ¿sø¬Fb”º(¨ÈY	TÊüýëù/ÕøÞãšý
+Õ\¬0é]uĵþ>ÍœR¡ñ-ª”MžoÞH
+Ýäv¦ƒ¡N¡›!² ·œÏFù7oÒþ˜´†U®ÕÂØÁǝº
+ª\[[i¬uȪ×L©}q÷=7dámßÌŸl³•u=ø–6Æ­5>í›WÚö8Z“·ûÕu'™¾?«éÜ–F£ÔXðݧŒþAæ åúúÕn''½ðƒB±,;/|Þ;KLÛäÌŸñDœ 0¦ï½íÞpÌñ4W$œ
+vN™2ÁsÝ„ûl)á-]½R¦2)í¸ý%%Hú"fÆ‹ÑS—Zò§4cK~[$aUØÔB-ýV?´|h-GõÑ©‡aƒ™©”¿^ë§1þç"‘líªœ+€º`Íó®FkÿFÊž0²5mÿQÀàËÏ4úDQ¢rãÖ¬@GRõÜø
+½ö­¨±ñ’Š!†%ÕšÕ†ÈŤˆ)‰óêuÄ¡ÎoÊlšöµ–:Uúü( ¬ÏÞcðeI|nA¯"ÙµƒØÙgŸoOÄ·Hbԏx‰K57죞[7kÎûáE'†ÿ˜£ÙúVÈe·Oe<^[ÄÂrÛë(Ú¦ÙîAlv¶T3ãk‰ÜIm±‚=ÉCÌف*?±’$S§Ø÷mƒ[ɯßN¼›®òw'—5D“¤aíýë*”ºR.«`”"¡Z	Dðýü"õ 9.ÔN
+ös‰„–ëv°7+\Ú§d}£y/r´œÏŠG;…ô×îŠ_hŒÊt»è†ܝEñû%©å¼©;±Õµ=FM,úÁDd„7¾"ÖˆÌæQ%³2hôŸP
+¡u„C¦jMߎ}©rô£Âð£ÓÙÏOË×Z¡{œ>õU1=1÷âõ!ðMµß5(ÄÒrxÒL4àˆ²+…«C­Â«p–ix^˜™u:“²«Í4&ä`‘ïÇ¿æv³À`6FAšHqŠâÕK~œ‚§ïɦ·—ÈÙ¨cH˜\¬1QÝÇŽcö1nXóvt°¹1táâö‰ ÝýÊÂüÞ4…üÝpä”ôºIh;¼u_ŒŒaØ$GÐ+¤ûÆû€?Ý©UañÚg>žûŠ’µpŸµh6{…?’}$€SZôAÞ±VÚN¢É~ÂÄ:ðd",y©š¼ÛÿèöÚã§ì`xRï‘y§>(××êk²ãüZ6°%>Q‰âQ|YÍ0ÒW{dÚ†!9hí@ú¯M‘i‘²E'¤w·Ü¾Š¦ÖÜyÃCŸ]©–Úo1–¨Y	äµdßr*ùUAੁÀƨ‘ñ[\Ôš«õÅ„…ÛSë\Ôsk9ý‘ÌÏÙzž<^ €É‚ÓLŸç€ËB²õj_øuHWJXS¿_ÇMÎ&°‡!Ó½qõ!öAó÷è|Ì»èo¶tþX€¡­v¸±áÏãï·…‡œýþÎß–+”~Õ"|,ÂMVãi*©H±@•Ze³OÇDgmÒðWØ{¹v§Í_b;Ãr#g1Ú™Ac(Â,È:yö½,²JØçç/n•’å4öx>ךþLhÇ8–ú<·-q=·o{
+Ч%8â‹÷"ÿrŸŽšóbÔ«
+­+·ŠÿÛÀ,S¿SIÜC—iÌÓ<ô—ͶvëAuä–,'
+#5íBÄ’Ù¤åÒ?“}ˆd'Qޝªcß`6~Fi0Ö¯kf¹ŸEX¨õ_²d{àû[ŽÚÍGÎìW6_Út´B
+¹8 È›×t5_èLOÍNœUÊåG°íí…ŠMŸ—‰kØs
+¹cYœ}©a’ž““<ç¤în£KMP™]#VðT®vÖ|à
+—Ð…ÙõŸSÝà«ŸŽ¸/—F<³â;xV♫ӧ ù¶ôÈWí~{×
+?è#d	ê܏°|mj?uï‡=„Àˆo’Äèêx×C™n€ˆUvcùꉄ3ù*=ÜÛBÿTQ‹,~˜vmÎ0,'·ˆøL"úpѧQ€ôEÖ"x¦
+™rÏtã¼7d±uÀ™4uÃ1¿B
+ô!ÝÔù¬û)¡¸&5—jŒ»þ­†]}hcÔæ³¶AG¹Oò×ÒÎT±ƒ%&GÂÑOtÒcbB[§e!-q3.ƹ£øžóøU¢r–q™éØØßÖòœu6š/ý½Ëûœ»;ãa[ûñÅïƒ4ÒׯdgÈIã#)}ŽX±’¦7å¿ÔyÈ/ã)~n²²Ðè  (΢sIÙ£è)Ýî«éŠ&bC³ì¾DO1`ïÐÑM
+†¶ÇïI!$mÌzÕÅæòÅS±Eƈk”]ºaGÀ5“Teg™eƼC
+ž\Y[8m_»Ûx>+ä=4_3
+ƒéÞCzoÁuËÝ;Í"ÅV°ìÖ¶¶ÒÐ-…nÎüÔõ!ÜTMe3ÆPÈ98žtH°O+¦ê0Î	r»±ÿ$¯&kÜïÜžyý+MàŒ›A×ñ…W®8 ¯aÆö²p%˜|ú­.7a…Yc”ºæ"ïW›ÈçÜõ
+®,[m]ý¢£G®W)ø'øó«º§ÓpX"éŠÎŒ+žãîhŏjB·ÕÚ™`KjÐS‡Ì0]û³ïú³²-‡ÐµH¨(~ ß@	lçL´”K²gŒé¤I÷Ö‡
+WÓæÎ­6|Ñm|Á•\™yí]/9ÏÛ’õø7U7)©‚è/¿åÔ÷~#3vhTÁò@ßl(U*ƒw;û¬X”èKiøšSô9iG}„q^»åûSúVjæW"
+[ìSƒj at 3Vyî>µM˜1ŒT7”ÄuUáï—ä¼I£/”4èÒ9å”vÈä“~ŽC3Z_宿¼ê(OE¶¡|ƒ|¹ù€­=fA%Ž<þ‰Í
+)lÖ?ÐfuÌÈK°3ŠÕã\`°t:¾@tÊ!:pE -š­)u¶÷{>­ûK}n®€ÍŒWjÉQèÁ^¸àä4RÍ·Ú(Á¹ß-9e,¯ð¯ë0ºÎñ
+Í…ï’B¼æœËSRÄéz
+»6ånª—sÕ‘ÚÙyîïYø¿î(åYžt h<TõþÐl)ä5Ù	¸CŒñ.ݬím÷üɤ?Mºè-o1¢¤¾ BËL¼o •³
+•ų"„ë׃3Àx à]³§Ä§ÎV|Z½ýÌäïdAðå¶fÿFqk
+endstream
+endobj
+326 0 obj <<
+/FontName /CRAVFF+NimbusSanL-Bold
+/Flags 4
+/FontBBox [-173 -307 1003 949]
+/Ascent 722
+/CapHeight 722
+/Descent -217
+/ItalicAngle 0
+/StemV 141
+/XHeight 532
+/CharSet (/A/B/C/D/E/F/G/H/I/J/M/N/O/P/S/T/W/a/b/c/d/e/eight/f/five/four/g/h/i/j/k/l/m/n/nine/o/one/p/period/r/s/seven/six/t/three/two/u/underscore/v/w/y/zero)
+/FontFile 325 0 R
+>> endobj
+327 0 obj <<
+/Length1 1166
+/Length2 6977
+/Length3 0
+/Length 7752
+stream
+xÚuWe\UÛ¾¥AZJš
+Hw—tJI7(±›½aSÒÝÝ%ˆ€t·H—4R›Fº)ézxÎ;÷¼{î}¿õaÍ9ÆýcÌ1?,Z
+mi+¨P
+qæàá䨃ì-\œ´Í!ªZ@À#(`ŽÉÀ rÿƒ~$da at sg"gîüÈëØº ÔÌa ^n ·(·°¨ Ïãš›ï¯@(L ÙC= @g ‚<RrPK{ ÄYÛÅÁZi .0K “(Àú±³ÿ¬
+…:¸Ã@6¶Î f]-}66ö¿€…û_@貁 ®@0Ôáw¥ÇŠ@öØ´ÕïX
+ksy+óïq̶Î΢\\ÖæÀGŒÓÉštæbylTb%µÿÀ	ó·fr Ðòq(w®êöuƒxþl
+‚Xý1’•‹—.äè|)÷¿Áæß˜
+Ð ÀÍË-ÂÍ :€ï,m¹~—Ôqw þAòü†Í!VÞžP€µ9Ø	è
+²>¾0=Ì] g˜ÐÛóÿÿ¾ÃäáX,@›Çcø;û#´þs¯fî½ssrsó ¸?ÿZ™>¨vÿ;\ÝÜà2R“ÑVÔbûçìÿŠ’‘>¦äàâpð
+<:å1£ˆ ß?3þK‹¿tøÕ0ýoŸÜ§|	±†DþçQÇ¿Frœ½	`þÃÆ,€ϯuYÌ[Ç„[€ûÑ5/žÿj©ãÿ«±þYCÁþCæ?å <êáPüVlûps{Øý¿|ðÏ@}àŸîÿò¼t6ƒ,¥!6àÉrR ½Zi€œ-mÿ´Ë_*[ýqP'Ðï›àààù§c²|:9=žÅbõ’òK¨bÐv~t¥9Ìê_ÀoÚÒ{”çzüö¯½5è±A ðÐsµ²«	j¹¬’¦pãØåëÔ=p¡áÇŒ#®s"u©“¾-¦àÿx&œœ%§1d+QaŒ¬†ŒG!-äöVD¦•€0˜ I)œ|Ÿ³ö…º(öó·cînòø(ÒÔ»²î}J‡´¥ç†²#Ú!Pb_ªK£íÇWhÔ¥yåO^íÀYDH®~¾RûhŠ¢M
+´ÉqÛ„¦b)·7Œ_1)a5ì_–·¼™†÷ÈàøN…(b:×YP‰¶´ó^Û¶ªHµ!v°ŠÈaÚ>åƺ_`ÂF#MŒ§ZÂÆ%%óPµ›³Ä È˜ÎíigÀžå†¼ùaQéF±ìQœCOꢊ®¸²¶pÙ4Ì;4Ó:µ>µ1
+úJÔÒÔs•¡·¶4a:´å*ÛÕ¦²º>ŒPmB Ié­Lp‡6ìy½Ô~Ý™—.¨ÛÌo'"ÿâ°î
+!È·­".+ƒf/›j{LûÐìÄŒ•]£ô¼Çs†|ý¶\Pªšß²ÌüñAIqF¯+S…ÏwÈpШER»[g»ðlk_¶
+3ùלwaB΍)Ÿ»t1þ<0•¼0¸Ò*
+b´b£›¡\Ɛ§~háÖÂË S3é[…Gç#/ä()îN¯E^Þ„k/‡ÕûêN/Ù ür¢Â±s™Ôò+Iù·ï+$º|Á¥úI±a=X~â¬á‘_%«3ˆUÎ\	ªøÞ(ÿò(²HWVGÖcªN¸ûÞæR{a/êÀ¾„Ý£í‘*dµ9ǨéD§²-K2ž“ª½®Ã›@[K	N'Šÿü썟8nÄÌ‚~®
+\Ütw#3üÊPir»œðº¢ow^UؘˆÛÒß0Â×Â%~móŽH»tÈŠÊØUµÙ›é~œ<ƒñ4¦5I
+c£%¸q6“rd×~®^Fv÷¨sóù™`§yþÜ(¾É™ZŸº´s¯¾X%ÐâŽâ?i§ÅÙøLûðå€Íf,–¨|¥Øý`…V °.õ"•ä mqzz^„=¾ÁRvÁZñ<¶Éáp|m ¶C_O4\ìy«xW »í¨eø›qa›a`a5–YÝ0ýë˜ù1ås¯¤ÞRÚ'k'Fm#NUr‰1Ę¢ñ1öé«­îÿâ|zm«ÆäÿzD¡âûhVQ⤦ãÐŽ†è{
+lÙ¸á	â.æ%&iÑÝ
+!Ë} õsó¡Åü+ô±Sê=„¬gÖ'.ÆÍ(ww¹…ôðaæj¾–KºõCѹîr	§ö¸zºŸ$¯M©¼kB²€£ä[íÚ‹±öbkJv#KYWÍ	²%<3‹/Êi5ß„®í&Le$p 0õ•Âö½†Ð²¿U-”ð3PF$•N }©@çå9(øä±±HßPBÕE5g»æÍH8cDQ áÁ7éÒSiBµÁ[Í¢ ª{rc“wó•^<åü¢¹8Û0’£Âêß"ø‘³×/¬	Ïs)gó.0ô“ýEˆ²ÙŽeâ›ú|y´ÚÈm¿q[ßôçë;-‰ÑJ¥É×j®
+‰VÎûšb‡ØwÏüüø‘J­ñ.ʨŸ¥»õjÔ±êG–Iï
+K1z{“'“ëÄs¼;p’ˆ;”Ø¢ïïT‰ 8êÀ§«Q–¼
+²øµÏÛ|_êÄÅår7ëÉ#?ÔZ\*¤Q캬òVwaOüˆÙg	àãgÆ yò‹±µeDÙY|KÌ#0ùœ¡YpŽðÕMx’~6f†‚=<72¹ài*‚Üüá*gœÔTîjšj(#Ϥ™“Îí=áâË$“7Zb"l¨XÉR­…dÒy·U\h¸ìáÍ„Ÿ
+:¾UÆŸád¼-µ{á–¸dNcÝ	¡- at oú#8°ùjÑWè.gíIB¬v©Ññ|­9#MëÚ{ÊxÙÆ(ÊŒ4šw ²å´LÉ鯒¹¶:›¯¤]ù†.þ±vTÜ—$V'óc¶Ñ5ÒúÙú頁v¹Ø„ÝOq•ßnÅf}+vêÓe"âjì©æ!_HíðÌU„i½ÿ¡wɍàÆ5(tr¾	J¡|©üܧK÷«g¼¤
+¾ïÊ{íC×’tzÈS‰æ®ú¾˜á3â2èÛ»>M6ÈMý3”þöm¿5±ZÚy]öŸH¥_Þvî|¡À>:! |J²¥þá=ÏÂA=y£ú›¸;¸k.íëcÒ2ªÕ:~‚mË€ì«~•Q5kÅÜ)Âô!xMy®÷Ee™G'ç#ÊêE×HÔøF³ÉgÖ‘Ë‘¿|3ÈUñ‹E¶Íx‰Ò…6kx jS4‚$6¥W[<2á¶_à÷*ôsm‡íH2ï’
+?<¹ÿ)P,F-lýáÔm–áM!fK©Ðp çs8‰ªj²$fK¡ñ5:µIÁ¾ëÜùò€îàG„Nå\zŒcØ‚ÒÏLJ±ŸÇˆÙzOœ”9®<b&‹š
+	ßH›£ËßLfe2SÈev%¸OúFQM at a‡yÆ=(jð;§“žŠ–¥ôü¢WwIì9}
+©X’%=K-|R‡ô‘Œ<]嗍¸ð<«Þû8 at SÙz{­T$XIòûûQ°Å¥ñÌvÐ;äÑË5¤àDeMŒåÒQD˜?X¯¿>Imv¤óõçWÃX6MhÕ¥)Ç<(¦¢ ¯…bG¹¥h¡ª‡"rÞë.†XzñI‘èT$vT~äÌef/öz„ãŠCݵÌnE6-ïå4~ú0þ²¼³"zN\_x0iõzfš$¦¨]Ê'4âCyéw•ÀRñ,p.Ü“ãêàkÏ‚M“Ò'¼§ÙBmãOKµT4E”QkËE«Âß±ƒ=é-”S–jœ	£Ñ÷ý!ùiÖ¤qíS%A5®>òi×Ö{§+üµ7ÄTN±%ò²¼ª3SRþ²m2
+µÜ”Å…Ü6å•~W~®¥ó¤ï4Ñ(sSƒè>ã¿KõþbAŠe“ðü=|O%ŽþHK> ==AMyh›!µzócΜí˜Ý„g¥¨¢£ºx¾2 º'4ãÉóJýô[>QIwõäd¼)Ÿ¼…	/ÝÇÝO××ñ€!{)Mò#‹ú
+ª%¯™òÌÓý9±'²ƒ1뼌¯Õkö³ÏÑJãÍ<6î‘jèl|o»u2ƒ”ZФïØ>¬
+µ6­2suµ
+yX¦Ñ£á¾çú"ŠÍn¨ùêÓv®G(’¦@ƒù ñBUùÙéè!Ó³!.¾XåÁÁàî[žC“uä°2:>WSµŒUäš9jzAsâOîZuÈö9é’ðñNž÷
+KhÃÓòT®Ú
+‚äu º
+j½™KÒ†¶&Ö‚>n!UúgE†2êñσ
+TK’w6È.ºPØ	`,ŽË†90ÎÂþ­šæ´­ÖO‚Ä‘õUŽwzÍü=ý:õvdŠÚ8œýkþ"áîm¥2†m‘µ/¥
+r’•'­áùe½«”‘L›ãÙwÝO,aþC/»“_„Ê}Dlfy‚dãƒ4å½*À_::,mâY¹]ï^a…¿œÇû0 Gæ]ŒºE³ìôv:É–-6;xIº/zvûvG±O0f·7Ä\ô †˜«dhS-8–ýŸ^‘íwYûPõÐâØ)tšŽ×ñ.¾L®	KÊoñ +ÑxľÐß%<$#qˆ§DÃ(	Œ‚ۯب½>‹ÏŽ@ˆózy%¦fØíåâ±Z{Å%õ2T’øÐªVe¶°%ÌÕ9
+(­ºÈÍsT°ÄB0­m÷‘k×wEû¨ُãm-š
+Qð’"z[”2RñjÄ·V²´Ž…oœ¤¯ž—`´í1ˆ&žômBKΙη7¥np®ÌNÑ0ß"ä£ï¨±wŽÇjÈøH
+–©ÄÒÜÍg×Z¬yãTÀHm‡M¿×†	È˃.ª‰Ý£ÜÁÄqÓͰ¬Iñÿ6ê’¡lý®ÕV ¯)ÓA ßN%02Ò{cßï±ùÝ`èk52½ë¤ƒÎVé|WâÆÓY¹ŽÕ¶~œÇøW–
+ôÈŸB¼¾Ý¿/óêêÆ2fd™P;
+ÔÒMÒ¼“”ùá‚+¸ÓSÚ FuߍE	Œ
+Æ×.ÜÙÚV#÷q=/þàä<œ£ºëÇ”kKÁÇnn“’±N?m«WKÛWï*=$Šòø³B7kYc—vÔùn;#‹îÆ­âö+–ÖbÒ£°sð82:ª'výžó‹S²YZ¬˜x^Ý}ÇM(…™¬Ø/ùñ›H	s¢ûq†ÈS¶Ê4JgÎBv=(7³¶²˜>ÂÅ3Ò‰Åã4öœs]T«‹‘¬ïnª)/	¥„õ#˜|{¾eä[pk5‘¯|FCÝ}T)'ϯeVÈ->4¦ Gš2¤™©t£Q²6O;(¥¼rwhR‚!¨‰[À2噑¥ñ”ˆ<ÿN]*ÐÈ­g¾lud¹¿d`=ØÓw[_aX´ ÅérŸÞºL|¯kDˆMñ\õnu½zÓ.˜é´ñaò’sŠ{ayBi?”	3áª Þ<;H‘sòŠVi?¹ícojco_ßÈ6v'÷€òx›ÛÇ9‰[V…í4Þf^ÿ(µÞMLSqžÚˆ2ãÔ©r…ÍhÏT­ç*ÙÓ²‚I<.·,šÞ9­êÚî·šd» vµuºéU)Œ'§9ßQ?bÝy›I}ú–¨X?“ðÑ¡#åÀ±ÜEb¥Qr°V,Ô˜³©À¿Œ`MÞtqÌ&e5¹¸?]†T9û¹Ç)¢ µ:©‡ãª–YÕ›ú;6Ó2ŠL¨k&{3©ìr“/ÿ®/1¼ÍB7EA
+éôk7Í@ýóVA3N%
+$Ô²çí#%/ÝL©Î7é³ötoôR~®My`i?÷ýaë5ð÷ž,²±Áéêûað”ç-@î¦O,äÍå •	ßéùVŸxæˆì^¿¤CRGXŽ+½ü D)1’Þä© dÊ‚Q郬Y{:rõV2ÕT	OT¿ÐjŠêî‹§÷#)8Ĩ­§{7‹á
+ü鯲Ø"#ŸüÇõZ ¯AëÖ>J¸$¶ô…"ãQeÓûûˍòù¡WŠø‘ç,wJ¾9íÕòH·p%Îk>¦2¬ª—ʍMð²:6ÂlSŽ1ÁW§f¤¬
+y”|B"Û÷R;3¯¾¢é›—É®aTÏF¸ÒY[žÐm¥…¾Q¿C-˜5ŒpKþ¶ÖÉÛô•yßéTÔX®+¯ºZb_a¼ËUë\‡.}!Úo]/:‘.ß5…½&1tÜoq`Ö0­ÂväŒÒ8«¶ð6$·@Þ`€Sñ	R×·:lXfâ;oð§ÈuÓŽã.p-Ê|ÚÉñóÅmqtSk4+Yá‹Õ™:/BÚˆ˜ÇæÍÔ=ŠÌ¿¼¦4Ô\=h#Àhà@0²Í<ãá
+?ó{êüëםÓ:Û¢Bƒ^÷#¦^ñbß'Më‹eÍW©=À…¾=nе ÛU½9'­ÕX›2úÄ>Gú˜™µø/ø¿~ñ=Ùˆ\R”[Ñ.ï¹HwÌ”xUŒ¢2ÐU0¦JhI†ÿL´’Á‡½±¹VMm.Û-:v‹§{ŸŠÀ­Æî+ØçûÓNêºÔl½.œS¤Þ“ùô³Oõ1ùüÇšèýex¢
+ùœw"iœÞÖO¸TÙÓ>ä¬ãNFŽ”rRŽ!>’³|!!Ë¥}²"„,SßU=n1~µJVâûÃŽ¹Ø„àYðøÁs¤5‹tþçókçõPQ«‹„‰ÓS>qo1åYêµðcâí˜CøO]CÈVV	›kã¯;ƒýç79xz¯î—(P*gº?¥`“j¸ãï‰`.ßêØ}Ó#$ýygŒ¥àß0Òlå~b at VsePYÖ.ìQ6<ŠÂÅÔÁüIƒŒO7ŒÿDý†Mt}ùjf‘%bBëuMxÒaNuþmŒUlƒxOõu‚B^å:̇ȀØçµc)ëÚ7L»ÉÈ]*–§N•V¬30µFCk¹ƒÅ˜·r…™ n/’‚))‡ˆ[ÓÉýhk¯q`Ñp>fó“•uíÂç3}Èh
+…¬Â3o’$p*êÇSñ)êÕϺg#aõ)Hýêa¶^‡YG7vP]Èh>Þm—‘úÐŒ;²Í*€un€2IFG¹e!&žHUÐÖž¼ëí\ÆG\ÒE`ÕÕy½D‘'O®.Ñ„ã?c›èN÷eÿÚÈ^Ÿµ«i‡1£òt­zà#'!±3{që­¥ò˜Ö)ç9½2Bþҏ…iñ+ô§Â×ábøÂG2­a³¦¸›F32hra‹iOy½<)aÛÌñLehˆZ Eð7ÍE÷ˆ&«O]1u:„eLŽMºHÍýZ-¥:Ç~æ"Ný¹ Üµ·¿]qf}¦É¸XjY ø¼P€d·?õAVŸb]òȝxâE§@ØC¾àÎú4ø.±¦ª*eKaTaRhw€«Ãèën•
+?3ÅÅSÎìס]EJuxFÝ›Aò§TÓÙ?¿rƒO}äx¶…?÷Àa(Aiy›Öî÷ÉyÈ‹óbÓ¨)Tç›^·T­1‰"yÄ—«Ù ›_åÖ„i$ÓwÛß~4A¾ÓzúôS‚™©~μéŸMB™oÿ1
+?÷!Êz;
++Ü
+Ç}nÚÜݎ㫸~¢ïG\çCÑÆÿ•üžoµJ ¯\Â̘Ÿ&Jî®°Ïâ`onÜ„7ÀˆÄ~9ž'œx¤×¿bÍq¨Md¼Wd~Û6.¯¬8~OŒ7<=1ªáãR曹ïΟM‚]6³ÿÖñ(EQ18Æ;ÀÚLGéØ!ÎáÕ3ÞíüDTF=€ŽcÒɹ5Ÿ§Åeœ†>µUªþT¡‚á[	îœOêâ·èÆ	kL¥é13
+M­’ömŠ
+º]ZYm¹ÉlõŽ··¥Ât{Ý\tÑÓÏä^Dsj4 Í\´ÖõeiŠó¼­çiA£&ÆXÚHö¤Z²)Î<K/ŸpCa at U×A©)Þã#G­D@¯+9@B¼H¶oÏ=Y˜:f9Ù®äµ6dY«O“ØL-õ”Y«¤À~¦Á[€úͤÈû6[ëV[Q>±n
+ûÞ›IÊÐ~‹w3³lbK‘ŸÛ1¦ÈöâÿAÊœÖ$fŸQ7p^€Ød¼ùàG6u(¢Rغ]€
+OÍàóó,·ÅDQ 3­2eb¤ï,°~ø²¨ñ?L`;ò”,”ˆºëø	2ž›>v×Qÿ^“
+Îä.zþê30›]‹½”«†íhݏ±\?KéG…Ÿƒ§${Ý–÷q'»¡Oï´VjU¼b‰·?¬aá1Æ¢œþŠªtt×ò1©AòÁš`lBô_ã÷Êe2,Î*tnרE&˜?8ë­òëö>1xßqŸãØwv-ͳÅL˜sІUØ“†ÕF‘“êVá‘Tk7ÞX³GmÜq­">iª>‰Ó[Ù|b»l=²¤,rqq¦h8±¯gâ7yÞ“R†ü÷4Y¶ÂòHÕ‘ÎRU:6“ÇRÃŽ>ÙÜÕw|>¡JaÊÜÐíF Ô•³š+ÿ%^8‰–úbô²ZTwx¦ªÀpJOnQß^èîýZ‰Õ]AÞ—æö/ՁOڝ#Ö»wÐÆ<¸_¬åuº¯«{Ꮩ›Ôt-2ÓäΫ).Y}ú¯Ji¾Ù«i¹<‰~t–ÙµÉ	‡&~Ù£È8/ªò­¥Z¤-‰¶=åk©¬ÓQ¾ê½30¢¨ÒúÊüYåà¬ifm¥P~Pb#£O‰s)“ÜÕÍ“¸º°xôþƦ†ó™uÀp|£¸c¾dP‚éæÅ5:ƃÊK±ÀuêzIb”Ae»‹O'ø½ïsÏõb+ò‹‚õRЬ~b…%q
+±áÌ%<	/KŸ@Æ›Ø èƒ7øQìélA4ä4ˆx»ìÊuñ÷'™£=OTáMÌšÙÕt6Ÿ¾š'»î1kêÏ
+™~dŽ‹•ô'RÏBÃÒ•¬I›_U¬Ý]äÕWŸ¥{VHEòEQH€±–jS;º°ÈŒ6`έDÛœ´v–%]0Ïžr€fÑ• <—ÌxçÀž “tLÎc“þÊÖC/5`&”æï);5*⾏¡Š)é9] ]ï™—+8v¶u	Yá¸%ýB¹mÜ¡öj=w"Z6DO9±$_šÚ¨5«@ÒzFºó2§"vÃz$%4ùòí}¨u¥™	ü] 5N2ýwaf%‘wظ¸o¦¥Aƒ9›¯`¡?¯úݤ®ÓÛ§Ö  š²p¼É'†ïv;>ÌŸÖ:o…'<õÂGêú¬”ÚmêßDgMⳑ×pežcëØÕ&¥ÜȆi€ÉNŠÞú)[äÛp/Aø»$îàÂìÜ‚
+É*jF¦èé#°ä‹Î{òŸ1)&½x˼œí	ª2ò-¥÷û#ÁF—”EàÍúå—Æ‘$Ÿù;Ž×Õ½Ozo'Ó˜„¬¾[G¥±˜ýëÚ\ÔuhÞ}Dô¬ÙŽ»
+bQƒiӆǑñã½É´7&·†ÕlºËJ‚q7ÕÒâ¯Ø ¸;;ë_ïVs;ðэÓF¿í'„ÈŸ²êcÑ9Òáí¥ºŽ˜9×åP%@­ÀÍD²µ›$DìË2ŒðKõ´Á.9óLI“C¿“¡‡gê`SÜ«{8MRÚìÎ;Iùr‰ÞÝV‰wÑE‡.ÞêºDw™)f{ý‹ü,aÏ	­g‰¦“厣×xÌ¥g‘ÉËNwÖ§9‰°3þZo0)„<d»Ì‚¶r_(³üÕq“§øû&hù\ÃRÆð&Ê<íy%ç„eÎ8^@wšÃR²tNù®˜ ³ݐ=ëÿDX6ß ›õÌOråÙ±ƒÐJ£‚®pe,¸ø™#Ý×S¦ûÜ3Y)áº{5S®!È5/
+e6#?ŒÜ킵}“"{ð^“ÍnëÇÌÂN#=“j`û±û*—2•¨n„"+ѯªã¡¯†\>³Î¾àðñ¨cY`5¦°Ñí{r̽Ógyêlî©)Ú=ëzñÁ<&²GТ)G‹ÇìTÑuÐû.1ÚvN¬5h•óC‡ NíÔ)~lë\©ðŠnxCpL¨5z…®ÎMj«VD­ë,½‚åC¸
+©¹™­k&JÂÞ
+Ï;~ú?Ü %Ì
+endstream
+endobj
+328 0 obj <<
+/FontName /ZMBSGR+NimbusSanL-Regu
+/Flags 4
+/FontBBox [-174 -285 1001 953]
+/Ascent 712
+/CapHeight 712
+/Descent -213
+/ItalicAngle 0
+/StemV 85
+/XHeight 523
+/CharSet (/A/B/C/D/F/H/I/M/N/P/S/T/a/b/c/comma/d/e/f/five/four/g/h/hyphen/i/j/k/l/m/n/o/one/p/parenleft/parenright/period/quotedbl/r/s/six/slash/t/three/two/u/v/w/x/y)
+/FontFile 327 0 R
+>> endobj
+329 0 obj <<
+/Length1 1626
+/Length2 7736
+/Length3 0
+/Length 8565
+/Filter /FlateDecode
+stream
+xÚ­TeX•í–¦ST:Ütw—twƒ„ÄÞÀ¦ö†½é.i)éîn¤	)Q¤;¤;Aýæœ3×73fΏ÷ºÞgŽîµîõ<tTÚl’@ˆHâgãb稁,\`Z5ˆ
+›*<Úù°è褝Aæp0ÄQÆ胀 %€›À%$$„E†@=œÁÖ6p £®–>ë¿,¿C ÿð<fÂÀÖŽ úÇW=ê r„?BüŸµA  ܰۃ Òꆊjò Fy5]€<ÈälnÐp±°[TÀ– Gˆ	`qØÿu XBàß­Áر$a s 
+²?¦Ü-AÐß.V äì †Áÿ`ÀÚÙÜþ88 v´´wþ&ðh·‚ü!u†<F8<úÁ4 08ÌÒ…«jÈÈýÅncÿ]~t V‘@ˆ¥Ëï–þøa½ps°# ¹Ãײ €`ÔÞÜã±ö#Ôü‡†ìhý/¬ gµ¹3Ѓ=Â<bÿžÎ¿úü—îÍ¡P{?ِ?Qÿä †Ã@öVìX\܏5-Ᏽ­ÁŽX¿wEÑÑ
+àâüËtþÃç
+rþ3 Æß;ÃôHÂq´÷  AVXjøcI ãÿMeöŸÈÿ‰ÿ-ÿ[äýÿ‰ûwþË%þÿÞç¿C˹ØÛ«™;<.À_oàñ‘1w<¾3 Àï‡ÆÅá¿¥˜;€í=þ·¤¿Gëƒþb+±þݧ7‰¤£õ£,œìœÁ09°;¨†[Ú ¬ÌíçõÇ®ë9ÛƒAºþ)€‹“óo>°¥ãoøþr§ÿ(Õò2Šjòê,ÿÃãú'Pãq	à:ÐGnÿÙŠ*øÏÃo))ˆ;À‹‹_ÀÆÃËõx÷		ñsúü%ÿ qýë¬jw»ŒûæäúÓý~ÿ:™ü
+FÖÑü½6ÚpsGàã¦ýÓðÛméâìü(ðŸËÿØõ?ÎvrYbÍMC,E‚mSÒSá5ÄÙ£2F½Ý\È!Ðâz‚<ÿ*H—_JتP¹Ù]u{øð¯©=èý¦ó÷¡n"{†®$ÐQ.¹
+SOî}› Ë÷@ÓbœÔ}ý(¯ão*+(¯ù9õ¾¯jj™Ý¡QŒ·ñ8c_3ùÓ¸æùÐ^AŸúZ&×Ŷ?o@À«ÉßÛ§Oع¾bøøip ¿ëµgóKV&ˆ9±oâÕ{¸‡™óE½å/Ô[W(‚î'èk¥9iö8à‡Ö4U«Ê%f¿tŽ>–Jöµ©êª«sÕD½@“()‡«"M—ꝯµòN(M?NQ ÔǦQ•¢ÞêÆv_G€£„~ںšàäã¨AU⩨if·îÆßE`{‰R¢ìÎûÉSŒ›/ñsA@­…/ŸÚÝ+‹´ï‘ Ž‹ž]Da©·B‡(†iž³'CÏ,Ðæ
+ÊD1N_FË6´Í¸Œ1ø…¦d	«äÍ{2ž,Y¦ çà¡I\ˆÄÅ3}2xW¹j!L<TxE·œ-ÌV5±3o‹éE<žŸ&Hý¾œdpa]Á¶ô öâa&ˆ”}ä‘ü[á–׿äžIƒÊ¹ß\rþ”£(ƒàhBG˜…¬ø F‚x	¦NÊMhBzˆû–ˆ²×ÀôùƒÉ)9‡É)»”ߨ{åë˜á?UyÕÁÓx‰9Û:.béäýêðÅN_—ԝ1(2"¶ìØÛE$š½ùý$è.*lü]ð;0º2ÂuÙÉ
+¾ŒËűH|Õ’ð+ð˜bš.ŦØO<|1QðhúX$k;y%”!‰f/×S|cfüÕI7ñíöª'h]0›	Ûk³z‚ÙëØ5újî›ãÎÏ•+
 “_¯ß]Ä}ðΈ­^±ÇöY-ç)è¯Kß=´ayó˪kˆš\1ìVtQ©ùát鈛M›ìz¸•ò“ײÒûÅd0Õ¼šEýs77!ýœ^â	ÂV÷gqY³}!æ±LfI‡%<nñ¶/ÄÄ™kœ¯çÉh%𻤴ç9vaYÐb¿NªKi!7<WÚþ«˜ÉˆÇ¥Œ@C…²#ž{£Û:äé„û‡^’.S¢• O›Ùù¸¨‰^2'òC²
+\i¼ø;»ôU7ú¬ÿ‰;jgä.Þeh‰Å¹Æf퇶jwùq„–(UakëFBÖ›ú–X„mTÀÑÓ,˜ÿ:wï’¨ª:ôÐr„Ý’dÎÿËIĉ®LY«þ‡aü&®Ë¯Ù~êˆ;_œŒÈR)`kmTê0F›ÆGJ£Üb‚cÄèvÒy"«·#ëbF¶©¼B™&ôšN9bL
+þ“àÓ	gz'ÒBÇ_’0ª¡Mbh±ê« 1q¥kO…ƒ96ºvdÔ^o$”ÍÉ&µ'ù,Ê>}‡Î^Ûß
+Aá·ÊÂË’¯~›’hf¢ç¿£%ÞcdïY¬Œµâ—H/L³’¤u7õí\º¼Q¸
+Ù2ø†”3,DŸË¥df®›˜òÎd¦Óm–í3ºŒÊŝ°êuwKile¤TI¥yŽœ´¹²ëÉoL¾M¢çd²oc¶ÿúÙI¡ë çiFˆÁ™öÓCÁª2§Ü›×6t|‘Öž
+îüƒs‡o;úz­ažóïwLP‘ÞľÌoi›™Õ$TwR]7-§:ú"Io×ÕW\Oe´@Ñ«E¥ö^=l#–f½[®Ì{Z>w­IO¿áå}s5y–˜è®v¿9‰
+^î[ü§l¿b/D”íóƒN«"e–—¼ãoB´øxƒ#“œg>Ý Á~ÚcÉÖE r/6Z®=‹_íÇyNä
+’¼¦Næ ØâÏÄ?5p[3‰øÝ97Î]óyM`ËÊ4¿Þ:˜s±
+’¬[ÅÛ±Iö«h|µ¼êTvg<Ug<KM±k@.,+tjÝ+’P/õÜ£ÎVr›ìKä÷và–*&_RWºþd¤€ÝMî·aw(çùy£æÍ°Ëd’àÈÏvÙ—Ír<Ž] 3â²+ùáNBë$[»&4ÿ;£2¹dH
+F¯·ÏM>‰g@òð¡Ì =Þ[îBÝ!'s÷Ië˜ü@>3¯…žXê
+*ÆåX¾~cÃVBîƒÃ«E£áá·Dð,us†šËRlºµL;vØrzØ	~+´òJ£ºq»{UZ–{_|_ŒÉæ–ªýf¼?ðn«bõÄèî]°8 æÒŸµi®²ëñRv‚ƒnÓ—5÷Ê—µ†ØU.+bûÚIøó¸Í€!ÏHÕ}ù¯Ðúu笶ŋs‰TN“LJÝZžßä,Ñ7B£vʏô Iô$üBéH³UPŽþ5j?Cá<ÉIL6ïÁNøš‘;Ê#f3ˆùTVéfS;þ´aØùãAn«¨ï&Ó3œðÈúM”Ѳ¸_Gaõ§˜a ob"–ÜÒ$¨œz
+"Üî[3¯ïÂFÈÖÎÒóŒÝ\’Ó"Ò‰³&7Îâù(Å	iºæ@ÿ:Åù$´êÓ!CÏcÎÒí¬å5ëz»¹pA@…EOêg30›/l AíkÿðDϺÍ+o£1Þίîùg}ÆÇÆgûÕ"cÊþß>Êj/ÅàÿðrðS5Gb
+“W~²Ua…òBïjÛ\çà”ˆH:j-\ah¤&ÌÚâ¢mZEûŒCä­ÁFmR‚HùXeŠd­ËæÄ‚mMŽ'»çlµGŠ˜&,ôû/’ᤝð>‡j¶4ÐÚÝE(V‡|l.ÄÊ(x\ՁØ'#¢qYÁ³¹[/;Jóä•Dæ8:±[枃ÄföÓöoh* ú·’½•ÛQœ]}ýµ
+|0§<—q!̉ eâ§,‡£yž?åž–	ê0©qèÿèž°™t*Èy ¾Ž#™®H÷j›2?«o\Vþv-q¬ŠêòµL	PC²«G5!^µ¼PR×Éá EqÁŠW`„ú‘Üq>n¡˜ã£÷ã¥l¿ KxÀ¼YpBX›ÇZ7îàV„x=¬W .;œß±#Ÿ  Ø=ØAyy•ÑÉž;±Â+üÒöËÏ6Žè–0§wŸÌÊwzDΙìôí>OU,¹3¡ Ž§¢ÙÑŒGšrâßEU%wŠq£Ó&nÓnñœI›ÎI
+Ao(ºb,‡?ž[þº?&—À›“_ñº& -½@<TÁeyG7Á¤Ü’+â›Æ­P3äºi';`.é¬>ì5¹–ÅùÊ%•*±ßtfˆÈÊ-¢P0÷¢s|!klìF<ƒ±-<ñ—‰h\­kA`*J[Š‹ÆªÚ>:¿¡+¶nö0+Åç_ýcnÿT½W2w+ãÇŽ¯æçOÔø>NT8Ÿ•ðK¿à«'”˜1ø;«•fuiÂìˆeñªNäސâuèî™úFHWÊ*ˇ\A`Úì&Rhk»ãPš)~2ð2Zó®Q|E[ì¹Ì-ÛڞƦ¾=[]#:Ã?¨0#
+ƒ"{ŸŸdSq‡á±ãHœå«„ñ°¯GÑ*âý	¡íz+íšx.­‹'6Ù3%¶£Õ¡]?ç€ù´Zá˜öå[óðáèÞãÍ"ô¾}%{´J~fVˆr±†Æ/1¯b“qúɺ2!"À¤MwS½ø×*>KŽôh0¦§FÇô­3eϹÕf“û7¨y&»„i#?£Ë	Œ 7 ¶;øHËëQk
+ÿŒöï—tÛžÕæ¡µ6< d½m¤®mŠ#8ÄĽ®NÔ‰ð–ýE‰<KþÂy¯o4¥¶Wû3sDòð®1?Mï8ÃJØÑ´šìR
+¼ˆæ+WœÃ½ŒCU‚Ryd°È„{÷«Â;À·UsQLù»“ŽÖgø6“á:YoÚ¬sè"Z’¢Ü>—idw§9Ó0cpxvúžÛa÷Ô®B‡Áìû̘¢Ý4œº­Ç3)¯"ç%4{
+ÔE2Ø;µ|ÈÔƒ@q6ŽÉÈ@ÄØ¦r at A)0
+Ü‘³HÀkÛ[òUVTò‰fÀ°_¯;lÚúZÈuÜ©•ªM¹ïKxns<5Gå’QÀŽlí77äg£Z+x\ÙB©?Iâ^Ê}ràÌo¢
+ÿ$”‡6>¬¥b6Ö.œýD>Sp’›aò
+r [ŸÙT
+Š!]´Ìq°4´÷{¸€zlkÛCWoø”> :%–œW¥¸€º`˧ĥ¿A-Í–0.“»¨Útèåâ„z'uuꪲUŒ)?Iþ$äj JWȏèÑÈnk‰°s?¢®+ê|(n¾nÄÆk”͐úžóN²Ä¾7åLïIt)QÑj¥ªë+)‹è(íô*}4ž°ðÁ¤ÜãΈ‹²pk<æªÝ>¥…Y¾#?¦EsÓ'‘Ý‘…Ùo‡>škߨ¡ÚòB@Ž·-†¯íâ0E"ZO×G&ø—zÓ.[‘ÇW#¶ß+ÅÝûÜYãû°V¬¥ÁÓI9B›˜2ÀŸFm‹,2Cʧšê	£eqh³Ôð²ZEæF1 ?ÍÌÊ.ž~3:;Š*•	š€<1-2X[÷õÇuÿ©’1Å)”ÛµG.±H¶۝ÏMýR³?÷³n&û»»ß'#àÝ ù­ÄÝú>ý‘ä¼Bñ.å°oMÊ«§(0ÃÅ,öÇÔyM«Â€<,ÎÎE»fà^™Ã´Z4ë®21w@ýç sÒäžÊ@£“o¤‡RÝÂýŠp80*(T¸|È+0	$Ù6+fb~ÆÑ&õ…e¦XBvDúsŸQ1JdÑxLù»íK™®¾B¤û¨ëçjmûØ–8Ö¶··Ùe‹\ûR®Óa|Êý§ãxbC%t°	’ƒÎbNïÖL¸ˆõU¤KJ&<F0+Ë|B-Q2s+H4öèsõ
+Ú­ì-މÇÏým…žL¡;¢8%nþƒŸ”`±ÓP‘ržöÏœqñ­÷Sú\Æôh¬¿ŸGº93O$¥¬0jô½ÕÔSÿ‰›F#ÊKÖ®DïîëP>ðˆ_
+8Ò1ꆬ̷ê­rQ‚j2òŸ›õjá“«‘a|ES!ö•RŠ6TiúHD—â—*›[ëÐYà:^kFüÙ–õáLc¹“˨|“èÄÏ·=êi-ßQÞ¶ZŒ)bÒ2êèÁ—V'u%Ëñʯ°êL,
+ž'=®Kf[ç™’vÜúOuDV˜q瘔ŠÑÝóó(¾­O¯?gòçA׍/Ó¢S\L|*±nÕcgýö²ӋΧ;XØ2-•	Ìû&ó•Ú<Ë9'̵qeg¾V’J²–ÐÕ¦¨mtw…
+ë&ÜÝ^¹ÒUÖߌñÂûúvþèðY]íz’&iV΢p4~ØG39—=Ü1KbÂ$åÆ\@;M8²Ï¿€8Uoü‘¢eg³mÿeîƒïpDþ_®^=Ó\¨¯z×$ùF­¤(¥èŽ‹^ûü8‚>~´Džoˆ9ñ:¦­À|³»ù‡@ÑmdÝ.Ì•ˆ#ƒR72‰Š4u´AÆ!÷¥Â°ÆeBIò"[‹­Èí²÷XO©NljúNNp±P[MèTJE®káÒèg/Ç´eóBz’ÅO„±9Cö §€¤Å þa)Åöb`¦¨qҐeç¼F—Ù™ßyÜ•Ï&& \îÆÍ–>2]¸}xt˜<#¦CdœZ¯Ë}Ùzà¶â^TݵœI Ï`$m«Þ%^Ãæú¾zGŸXßTž)ÙΊҶ-ï‹}^Vì1Q¦³¾NSúyÇ>ÿ ÕŸû1žÍ‹.OExØWsÿ+±a[L!‰;"©tÑ—û@‘c7çZ–ªAº.Ê¢9hÕ7毢
+´«¼šëÊ&˜¸vŸõg¨|¥¿nò¤	C×úªR\Y „Ðj:­HñÆùkxDaÞ
+wõ0ó9G¿ahüzL,¸º°6f}U/­¯µJýÄS©k&L¸C°W†<­oÂÂÿÅáþ‹Š¢sß›<Q™&†j×";Hä"ÃÜïψ]¸ií™.' bÓU$m<4¤´œ–Fðᰍl™/¨	[F¼³­ÕÓ쥖„H•ð[×&qt[îˆííõÒ¼ââH_C%ùÑ]jêáC:dAîë™ÅR
+tŽh‚‡Ð›DÈ0¹édú`§ƒÕ7‹ôžŠ[oÞŒ±*42ÑmÌ+}•ÊL\ŸIûؼèùJG5ÿâs+¾þìfö¯ï17rö„N0êpjqSyTiuîx›©Š´ÎúŠ¥ j{º>ziœ³¨`…öà…#/ôÊQrŸÀMÑÂ÷Åçã?I­æèӏ”,ºÍ«YéÈh úX¶ýQ¤*…Þº"i­ŸŸ
+!¶äè‚z9Ì=¾ZI§ÂóxÇŒŸ&ê†aÍõO„¶2ç<å–¯¹Ë?¶ó˫ٯĶâqHGŽ$$ß^H¤ð{ë+L{c4q|?æí%•Rè+£Qy…ƒÙìkaýÍÆÉ<¦UØÒ)3È·‘1¾5ê-÷˳¥d|Xaf+Óœ‹Í=«ÔqéL#ßÙp›öc[É-Òí
+mj½Uñw¨ÜÏv|õh±Öì·4ƒ¤º‹¨’bú”aoœ‘æ9ÔíIÝXÓäŠMzOwº…µLå|~À•">ø¢|J¿¾´Ý€—¯ŠNêÎÜP¸Ý$¯`57åA.ŸËA$	zæº*ÑÁÆ1|ßÃÍäç}Ã]Â{NüíÕ#Ó5ÉYxÅElï¹3ôŸöš!“ñâªqI’kI:*;¦f5Hõ0ŒP:ºìÔnš«0­ÃÕÃÇ–/Œ$ì¬Sú‰8äÛÞ#Ê!WÌD™ä5fÕáÐÝÔüG‘]ÅžË]†Ä„#Ø.­o
+,V–&O²#D­»Þq‰Ù>'IùRÔ†5;eÅrd;Cì}yöºÜGÖã9iú:[ø{ìÉ7¾µ²KB¶ŒõLå‘e†šžßËáÚ®»/
+”†DUúÈIRÚ)B­
+~ÝãÂïit³7HNÉ-÷C‚9j_Q†¡Î<=jxó„x¾ !Ià
+Ôý0]ïÀ+föœš6´ç-‰­÷Ó{á±3¤øD7ÌFíÉ÷÷Y§š—©Ôž»™1wU®Ä²$}½±cÓo6[cõH×{YŸ¥k °~2öX¥.Ìú­Ûzœâû/i½ÉÞ%ÔLXîK‰œ1)…ZÃmiq¾÷öŽœH@È",¢¢¥R«}b²Xñv-þzséZÄ—Æ}Ô‚XÏWJà:¨fmA€Lp~öÜ<â^GXjy²°[!‹$ÐÉíˆUY&dzND
+ÆPOù®²qm°><„°öó%\45¯To¤«y£k•öí{—èôƒöOû‡qoíÝu52¦àá'Ns‰až{™€úN£)Š9µÐuôc°Ž8þ³$ƒÿg¾Û_å÷
+»^h/!fÞµs¦–èÁ£^X%´A‹+Ò™P…j×ÏØXSŒå±é#øAHÇšÖbäãb< ãÆè,̪žå…?_Ên1ñ¡ú¤²ÏG¸jÝ”âʪ¼íÝ”tÍ]l·ŽØB2Œd`ÅÆ›Þ³òè´åës—ú¿¼~±Ç‰ÃÄUXµ„=¿0Á[b&U9mTq°^ctE;IÏ峈1—]KE2ZÍÒèÉZrGa.·fäó]¨Á6[·¯$ưWÏ ›¼VÝÇ{æ¨F@¹OAàvâM }WGÛ½¸
+¸ÝÖ™(u‡&§Ÿۏô×ÛÃËDÆA¼zÁiXðÐZ`wX ˆICÎî.ò,Dyå£â¡¬*©o¤  Z?²À)uET¯†+Oá>ŠÅpÏ ÅW£¼7[Z›nZ—'ûdî
++‹¤Ú÷ˆˆ`O,Î3O­F|²—î~UáÜEnb
+Ážâ%ößéµ6!YЛ‰åûDÇÇ­¿>óÌŽ–¯£¤§=ÊOŸq5˜WKÑè>'û˜dðÇg¼>áed0IÚ[/¡凌oV‘êÃE‘Åy—@/¾{9eZY.ušvG֝zd8Ú@ñ†è‰“Æ°?ÊÞYÆ%
+®¢5ÀJ“
+qŒJ˜®’Ã?Ò°õ
+	îõ‘ò›³3ýí´Ö‰Övº-“Û<:ÖÐ )šå­­Õ>¡ec_StÜöÑ®'ÆMx¿–ù#u[CÝÜíg¸ö÷ß[2‰yHó@ëy r„N4ì¶Û¯¸÷FYû9X‚’†eºè¶ÔûGìÒ#Ýiëe6ÅM¿Û¼>¼^’ďNN6Ã[O$"´²0pnÈÞìÅ‚@ªèGüµÑÇ|(,xvŸ—é8Pƒælv
+|ÁÒ
+'ï0F:ʝ«•ª…IOÜÜÄчíZԆ̍ð¹Q™@þÓ<ÐŒ7Y’Ðqº¦O?÷^ïÎ`H'¤2UeeK\WÖ&"ªÈšÍ®HMÞ1•2ʐ€a3&®3ïß?—hæ>:†G5v+¼ì$}ñ, ‘Ô4yÛBqmR»ý ñFL×¶ñ`÷†Ó{³‰*¾ÛÝ—T~U«ìÓ4…ß±3s¢ß9~±¼Šû¹|~å9¯Š»éÛ»éatsÓ´.Bu‡Œ@ŠØ#p€ÓLà“WvÍòanðž2Ù¡˜†›§´Jô!6ÎTlƒ’²qÝöïóŠÍŽO’;ß¿“Ôiü¨‹„Û®~ˆs¶‚§_®SÓµåôì}à™Wý/þ ‚Tã]Á»¤UW^Wt~Ê=½•‚$¤ýfIz~ 5Q“ki,Gʓ֩Ep]ºÑ¦Ö#ö«cÃò^B°ÕÅŒ½Må{P¨ôùMÑ‹'Ïӝ-¾„2>,\‚—¢Ä·ðÍÜ+™xré'©šC·ÍñS?&Ê$䦬Œ¨UXÅ¢|:
+V?“’u‡Ð‚.…®6žÐ
+ÐajÚ!!8ø˜Œ‘ÛQ1âuýö.,ÚïÖO‰DFðcž7_®áDŠ_ƒØ~
+Î*8¥™"gò>',s䘟o
+ïhw|¨àŸd`šL=3ºávYÿißDd{Iß~€	ά4ÖT+Dá²&ã˜t1†kÔL£ÂÔ;%N¿tê´ð°¥åd	F2V°Qºœiw|r[d q¹,‰_ö“º©T½-Œ–ž=ŸZù…þÞUë>­KÈ×k3¡(IO)S”ÚE6´<äÙM¨ÈbVeaȇn)ß<Ÿy­O–Óm
+ôaiçeZxò³´î’«¨ÕûJT´ìà-Ÿñ¢¹•$ózwÃt‚Ж!NCæ2ÓT’Ð6)±ê«|‚ÆžD•yä=ötA®"ƒ’|ê_
+¼(sïMÚif‰Þ¹x9­tÆ7:KšfL¯±«Öˆß빏¡ÄGà1¿o"ÆJ"àÓEy­ÌÎqœÞÞ8/KÕÊeÊä¾+•;^L#;Ï,ÕߺóE"š+u,„fL¢Š)–:à´ìHú8ú¥cÿ߈iüöµ&Úª¢Ø¾àeå˜VKÞCÃg‰Ö.ÂÍÃð¤7+ÓS­¦`¦ìýyþ‰×ˆý´uGèiWß±S/J],G0™œÕ{”õ^ee´†,Ÿø¡uä^Ò`‚q6o— <q-à{»‚1	ÑÞ¡Í-PÓIp˜£wçϘo€þá$û¾&jã	”º¡~‡•¡k½ÙŽDëÈ×(¬‹vC.´³OÜ|CïIÑX{&»våý@ùƒ@ú‘ò¼ãgì^y˜9…³
+  OíŽÆ 3„ñctïšôCКÔ¾B¢ëg#8tö™X=¹éÚ×ÜÎðsÉŠó¼Ð¬ý/ƒgiú*«
+·Õßîâk}4ñ9Y8ø´tfòØ@‡TÂo3¾_‚™»¼ŽjG>ßß”)¡$b63E×	ãÏĆ)ËG½Û^‹Ü¾uÌþèlŠNöì5Æ««C€‚ƒëÅŠÐ{œ±aꯄXü¤]{Í`ÍV."ÍñvÚ)²³omÊ'«l°ý½É×}
+ÌTÚ·¨u©;5ßÜ!Š
+l©ô¥N¨û*¶¸×z#ƒßQ­;ÖråX1N:õ²E19	¤ŠÅª•´¥+eg^fèMµ/Q
+rÊâ/¿,™ÙÊcÞ®ªÚÓÇÍUWtïj[<éŸCŽÜÄO
+dìY/‘–&ëY²÷FiB¦È¾„EyôâLÛæ3WiJúšæƒƒ˜I»ZáÿçE5
+endstream
+endobj
+330 0 obj <<
+/FontName /DIXNGO+NimbusRomNo9L-Medi
+/Flags 4
+/FontBBox [-168 -341 1000 960]
+/Ascent 690
+/CapHeight 690
+/Descent -209
+/ItalicAngle 0
+/StemV 140
+/XHeight 461
+/CharSet (/A/I/M/O/P/S/a/e/f/g/i/n/o/one/r/t/two/v/w)
+/FontFile 329 0 R
+>> endobj
+331 0 obj <<
+/Length1 1630
+/Length2 15107
+/Length3 0
+/Length 15952
+stream
+xÚ­¶ctf]·&›ûŽmÛNÅN*¾cÛ®$»bÛ¶+¶m'Ûùò¼oŸ>=Î×ý§ûüØcì5qM\sͽɉUè…M쌀v¶ÎôÌL< y#'e;y;n9ze ™àKÎGN.ê4t¶°³3tò 4€& 1 1€…ÀÌÍÍ
+Gµ³÷p´03wP©)kPÓÒÒý§ä€‘Çh¾<,Ìl_/®@k;{ ­óÄÿµ£
+p6L-¬ QE-iyI •¤¼@ht4´(ºY[ä,Œ¶N at j€©#Àú߀±­‰Å?¥91|a	;Nö@c‹/7 »1ÐþÀèhcáäôõ°p˜9Ú:õÀÙ`aklíbòO_rS»%dïh÷eaó¥ûS´srv2v´°w|EU“øwžÎæ†ÎÿÄv²øRìL¿,MìŒ]þ)é_º/˜/­³¡…­ÀèîüO,# ÀÄÂÉÞÚÐã+ö˜½£Å¿Òpq²°5ûÏè Ž@3CGk “ÓÌö?ÝùÏ:ÿKõ†ööÖÿò¶û—ÕÿÌÁÂÙ	hmÊ ÇÌòÓØù+¶™…-ã?³"mkj`fú·ÜÄÅþ?t®@Ç5ˆêŸ™¡þJÂÐÄÎÖÚ`4…c”·sþ
+	 ú¿c™á¿äÿŠÿ[þo¡÷ÿÜÿÊÑÿr‰ÿ_ïó…–p±¶–7´ù€ïÀ×’1´|í€àŸEcmèøÿó1´±°öø?yýWk
+à¿Óý?€I;~µEØÖì‹&¦-œ$,܁&ŠÎÆæ SC믞ýK®fkt´¶°~qû¯¶è™™˜þ‹NÕÜÂØÊöØÿ­Úšü×
+¾èúWþŒŠÂÊ*Ò´ÿ›û/CůApVõ°ÿÊíTóÝÎäþ±sxÑ3spèY¸˜¿îßWBÜ,l>ÿ›ÿbþÏówCgGw€ÎWÝLÌÿªþ<ÿyúñ_`ÄmíLþgC[“¯iûŸ‚ÔÆ.ŽŽ_$ÿk|UýçÍ=è4†[Y´3æ
+¶LIOu®ÁÊÓéëaüi_\¯Zç_e×í—¶Í]nðVý“¡a’ç£ÕcáÔþ}_†æ`¸Óš²;x‘‹ïCJÝ›‡ºAÑÎI{ȨWŒ˜úW#Òër^nB›ƒIý`g\IY¯è
+Š`²Õæò‘ÚŸÔ5ϝìÁÉ×øw]FJÈ·šüÓ¿	Ǐ”ý#CƒÝא½ûx´Y1°ä¼†X¾I§Ä‰ÎŽwõƐ/®œNÍU¨	jnžx¯‹.Dd÷ÑÛh̩笄fŸÂ {LB‹F1²n¡!ðÑ,ñtD£¢Sª2zµ‹Ò—9VÏêxR¬Ò—¹£-à"%SHØ7?PÕ©„¤úçÓµCâL¤Ô™¸PR•´Ô#ø§8ÙjqÉŐ"„jüGÊw„
+£ôڝ}aø»@*USþÔfþU¤ä· §b>t¿sàcÒ²¡ùù ý¢\Ê-¸Ë‡–¼Ñ€)R6aY1;¸	-˜Ò݉Zí&{±GÎú‚Š*µaÓ@Ä)M~ë}›¤×Ü­ÓÙ•"Έ8'h0uÔ× [´ãQ?¨%ÕuR"+-ŸãË–¤ý÷iÞ¨z ¡N'âXw»/£M$9½;œc7‘— ðpɆ¹Ká*¨–›<Šân…4=PóMfô^ŸÑŒÉúD¦J¶ÀÛ®­cZ÷”.nc´¼ã'÷6±-ú
+¦î–Xî¶žÓjAAn¿ëíêš¾›“]‰Aº×I¸ðìÒÓ蕊¥5S¨k_Ÿj¿>å
+•±–k^`d5l\E ‘Ц:!ЩÔ(ƒWêžíê®jµù —¡4f”#׈ä•õ¦í®”4!-×ð“ª+”Ë«d·A±	)Ñÿé^뤎òàêdÎ|Ÿ§È*¢hâ¾ÓDC¾>/Ðxª$Aƒgµ 5QÆÖÎÚU‚3É‘_õ…h©>ˆW Ï©|Û¿`³euÒ·u·ÀdÛ‰ö¸‰Y3赤…8S*0DaúÜ™ïÍ·¨„Ä‘ÿ‘u"÷S÷¯å@ì0ôf·4{9D{^¾•Zi.­'EOF—‹³ŒÞö/·Ý‰	3Ùº¦ß&ìܲÙÉå¦t_ІØ;klÁéÄy@ýÑÜcO¦º¶É·
+¦·è€®0âRplEt°ÉCÝhoÃb_§{.Í*LÑÂÍ·bI¤"ÚØm
+ä²ûROGÕš8lÏIê
+Ë­‚;ö‰ò„J5fNÞ¼«õ¶w¡—˜7ɿ鍠Ôx=N¬Ìkë§>urià`#¿,ñé¦qp—#X§kØiÙ­R|W9S´{µ&ƒùðwøÙ¨—¹¦µSP#C\ Iãê#´æ}d·Ç‡¿Ìç‚[‹æÊe¶º³(r}Cl!8Yznä)|ï
+ ;—ê‹g‘7ÖC­²“ Ô9œê;J<î-]3gµø”ÌWY)£˜›éáÒ±
++ˆ—kó
+ñ\1ÒÁI¡„Ý묁–êG/g„ª™Õ8|_€WçfòI%—íyƒ±“ªú$¥0æô¡ç~¶§“½9+B£°Äi÷§j¾zhÍtœ}‘N¯k`¼Î¥<}Ñ0”äB䉉כÖ3Âgœ­ËðxùEDƒöà_Ì>邕䨈ü*ÝYÆIBŠnShIžóÆe±q
+‰,jwá<¸pœW²Øu£eíÇ•õBF½Ýá}Œ±3q‰ÈîêqB¦é­VãèÌ‘C}—äþw„
+6=:TÝê¢(*•Èï4Ð7O<Ñ9±/øL4ùêëÈ#ëc@ÛÀ”ºÕ’æÄ=}ŽÃåUõÜØf¢k*<D³ù¹	N][&lnœi
+ÞŠdŸõŸ;»à¸¾ùÍ¥û3‘ı†vüõh(ep1âèHû/çJa8Óªl?®ÅœfYi‘ýô‚û-¼hê°sfS&bÿÎ'íêBó#bž,Þ™	úÚOqGáIîP·eö½âŸÆ
+ù[\I4*ã~’{|?i5dԝàTÞ¤=БJ¦–+oîšÿ•;s¬’¢2T¢…ò´É/Q¨Su≸\iÞ(V&PMá‘2|ºj¹»ñD;×K0„–Á'àŠiæuúý¥HG¼Ö :½Ä-¯œ 7ÃöØ.êðimfSa<¹uò¾’áüú@ ÚõỐTjI9…¸T×6¾!ÉŪú÷Y­òA¡PþœLÅEô§Ox“(ªÖúÍE’ïżÌõoçÔhìýÄxªY˜5!ã#¡ØÝ¹ìt4–µ_’âÆ-¤¤SO>p¡+}yÍíü„ÖÄì‡iÉŒñ8 ŒŸÊ¢¾£‰'U“Ã8à€ÖO­ø—B¶Â[¬zJ
+؉ž¨V)~(¢ý•Ù‡¿øfG;Ö§W„UFü¸¯þéÓ%Ó "pI¨ÉOCä-VзmÕê3F6ËwIR 뤆5f”è·HMDµÚr'ºà”1ê9Þlä‚Z&IúöJW˜ÍuÎÕtœÁMõEt~Ö‚½=A¨ì)mëÒ¶­¥,ë$•¥‡Fþ$£(¤Ã¶ÎÏ(^¹?ð‰GÆb—L€^XÐËJ?€wJ ˆ/™ÂcuŠ474òÑôºìâ{8y¢í‘H—ŠÒÈρýJÊlÿ@1_a\…YMH©¨´þ€rT¶ÌÜyÉõ=ÖÞQ×›Ž„Ì ƒ‡.szQŠ…|_ã'•ñ(xœ¨Ž˜…qÝú¶+â»À¶““NKðD«§å•AÙt]åæ0m‚7þ]õÌŽ¿±œ\ï_.Ðþoìλ+ͯU‡ênbI,I½²l^êFڦѺÁŠz{r¿ˆ!X{ØùH±|õ3Ý'Íð«´c|ü¤k©êäU+K}ub°7±<p­Ïà¬o×¶º[½äx?PjC¨
+R1Bs%4
+ÈÓùj‘êÖf©å/üh–j›ÛX¬‡Û»˜ýjÏ$!GgI/®è$KwËø¯1¸>W&ÞÂ.¥¯ü¾D¬?fÐFØ+‚*nÕêaôÔ`|§ƒÓ)íƒÃàå‰HÔp/‚°c_yºÍ êÁ­a'8áìàµÀ÷.ž¼›§™§wQs`ªþúÖÅáœVà’Æe‘h[²Lî°iœ—e’†›Ò•MÚ—áiahy}uO^…ÿ¶ãÀ^žU\I+†ÌŒ²@ô2%±Q£O+:ÊÌ­2“c—–x
+k-â:z|rZ´2z"Pò *oÉPÏtIGÖ ¨yŸÔÚô™Ñ%ÿãpãÂ5ÍщD®€Ðoÿ|]2ŽÍÝãHaT´'<‚Õ‹ŸR£(%A†€ ÓK‰4hD¡½IÈ1„Gô=%i¨¼Ô æÐî'åØdÅžÂa©Å$„Rî7§8b«CižPDvÓ$H°—ƒ§Œ<jê 4åëÙ÷â%»[j
+“fœ=†mV'Ä©kþãë8c;NâÙÉ÷NBÙrFe¾Ê
+þ
+‘®F4†É;g0[8ÁD@Ø\‹°¼fÊÝ"ÆåL*m|M—|èP+à?´0
+Ky9\½µ€ÀðuÊ —™?æ„ñ;ÂÊŠ@QlBÉ÷ŠÈp¨EfêN8="Iš~oaivë: ›ä5ߨ3°:U¸Š…v>S°Nªw2ühžÆìÕù)é^i™{8
+7¶AíüÎuþõFLƒ–2‚Ä*ŠvLkšw£“	®åù§6²y֡빋ÇZšDåÙk†½´e+çG×÷ŸÞÔzúWD[VÞ*lJI÷ƒÝt?‘‰a[âØö54$E}tS æˆ'‡Dí.ÒþMhM´Nì.o.Î"ß§_¦<YEű÷@4a)ßfÏP&PMx­¸Fާ|âÿ@ó;üs#”Â5¯0dUÛ"ÝY7[rœ0}ˑ䕹*XûÅ-ÕÞñ¸ÿ­•6–]} Õyß 7g$;âÄzô5}ƒ}.sDÕÚkùæ3Û.¬’L1¥tªJG›»¢YqÅߨn6Lì ÉWÌQ ²“9é=ìûbÀ#ލ(2 4°×'ÌÿBYíÙBü‚l°ºçg¹,6–%% X›Ó¹êY4Ñ{auAf$ºš4ũ#!'lîôÕOŽ™	|";AN!ÃJúï”ó|ŤåãøoóG
+)3®m“µÒ+ñ˜=]@euüRÈîk?3~áŒf®ô3f^f¸ÂØÖ&寶î¼Æ»³*àJ&”i¼ÚlFm[y]õô<òªÁ`hÞÔÊ|äø‘'i
+ÂíôÓª#4àö Œî¶æh+UðÓ
+ôL¾û[®kÖ«SŸÌ٩˪Vú­BM„ŒÃÓWÔï–éÝÛM—¥·q±ò\jƦßȓ֊ȝ2øÖÈ#ݳEÁ.wÞ.ækK{a¸pÓTžÞŒl¹Y|iÚ¡Yf¿æïÙ.ºõ=QÜWã*,°÷ü’­ü«8+:LƒÒDúò„ÂÖâÚ:tm½hŠm¨O¬%k®€œu -’ÃÓÙÐÈpʲËß•\°×࿼µŠ¹ù5ŒßÊ#ŒRëëIïûÝ+›Oí:[¸h£³m4n)ª_áÉ”½'M#a:•™ó—¡xîŠ!»Ï…©~ôÈ€[ˆM"‰§,¹-?ˆ/©Ò+u!“áËgüᣊÎqÈõò­†š±‹x¢¾psÂihKÍ¿TõK*B¦SŠ”•7D¦yÆ]|‘ó4ôÓG×Iqp籇ìuôäœøAYeâ‚1(º³á2㳬ÁML(>D‹Gb³âÆ·fö.Mú-• ƒÆh2øá)‡¯ÇŸ¿õ@½móÖ72ÒÄ	Ã[‡ú—í#†l	>eºŠ°ZÆgœ’U¸ÔGêÙ‘¤mÂÂàí„Æ<yigZDTÖÈwÄuÞTúï!¢1Å€j~¥“„Ä—Üc*@çì? ¤9¦4ZäéæÅÏ„!Ï>¿k»Eö[|î;V•}&—É(×=¹ϳgÆ^w菁eñá`aÉÝË…Ž+>–]ÛßÊê?CªcÌ{ø.Tµì‚,À"Ç’®TY
+ÛÂíhÈUש¿O‹àåtëáÊô"n¬FAÁS;½S¼ýE@™ï§ñ£âÑ7Z”öÌܹ^ÔPÈð¸íÅ?%(Î7Ha“6!ÿr-Dª‚	ŠbÆ_*‚ùÀN½(ú‹à,ª°Ü"`G
+ø´m«ôå¶#ëÑF8ZùnÞÀ\¿VkvÛ.¶ðY»ºQË[]u˜TŽRz4Ë)yÞà'€?€vÒmÕfjÉD"èoòy·ÁûÓ+µuo|¾†m]òõVÅ´N ´ê\ß~aCuW?Іþœ"ô"»9;³Î²ÊŽ¡Ó 7ßÒ`±ßz™Ü‚P­€…ÝUv·cƳfUü‡s~€ÖØmü£˜85™¿14Žy½£ßÒŶx3/7ÚŸäác¦–ùl¢%<$ {ªHÆ-rw/>e§— ŠRfO"*¸0§ª¯]¯¦#;E¥wüæ&;òÞqGšIGCIÿ"nr?Ô–Üm‰(F&oِ-„¨z#,ÂÃD}/^.ÞfÔ%<¾Šf‹‘OþŸ‹•:#èÑŸB?”y—<¤øö)Η#3Ç6•*ÐT{ÇÞ~ŠÝí…o ­“A½ª	hòI$BÙÀ9ãþ	»’Ù¤P©LU¢]ÅÄŽÈ-ÛDNh.ύƒå„Õß—rÔ)h¡¼E*ߊ–yÔ–74ìp«“‰ë»UïÑe,>úYʳÛQ=×¼Ÿ²=[QèÙH¢²ÁÂë‚…Üè…QšÒ
+Ÿ:YÂHç¦%q%’e®"–˪Æ¡ó!eZÔÿ)Y'…çÔ^WEY3üA2ž`—Gç·™ÂW-ª$¢%]WØ;±[ïí¯ ¨áeƒ³‘!,§¹¾¾gxv*ï³AÎaZ¦ð’b³-)./äžs´VõÀã"Pø@„6SËêGÁ¯æ8€v,rGû:§D$³Y{;í=
+³¾èÊ&lCdÇqìÕŠ|êøi¸Äé…ßÉûXoãRî½Êãu›mÌÆ]T¨Ò³í¥è¹×þtf:‹è÷³ƒæ=9<ycÛa爭"‡%ÏqëÅu>!³ZeEÂO„w
+N‡õ³	¬ýƒä¸2jÊ8iÿ5.Ö1&XKMVš>bv%‹_YÙ
+UØí€ÀŸy³Ey®èÚ9§…k LUÀNwlÀ–#0
+c“WBµXÒ|/[/Ð
+,vŒÞY× 9èS‰z,_<!§VçǦîQgqfÖØ:YÄV%Å”œ£ºzŒé¶"»YZí|Ñ#IÁ?Ÿ•ÂRœù€áÑyœ)&:ÏÛ¼”äՐçóÝüÙ_ýû$©ød—‹Xû¸+ÛäÝaxz©¼Aš¬>=ZÆ[A §¯Ü}@\È–{NñÏ©\Ì3Æèè•L¥„!Bc\‚%rI–Z.nŸâš„‘ùjÉE©år‰VJ?	>BY|•ŸÄZg|›‡™!~ÈßÛùòœ†c[\¡Y_Ò;hÂÒ™RPb\Sx¤«Uú§7¼Xõü …«Õ¤‡[9âP1³|¬Z'Ù±úêóœÝ‰¼Ã\ôjÇ?бp¬ÃgõA“$?|ŸJá©é´À_³"Á(P$uˆÝÃE#Šqƒ½øÜL‡QÉ•|kܺDëWI›2§Œ=«Ý+^a€
+µÇm¾íˆ¢«pÙ$Ä	~¸¯Ž®„n1Zgßΰ”«é7\©ÍõzϨÆT­ÿ¨g°Œ£_dÅ!A:Xɸeãx‡9õúÃJAk-ØîÇßúÙ.AÚïd;xW¼i5ˆ•‹+[€gü÷3—÷Uäݲ
+âJЮQŽƒï
+ÐÌÏ)tØá#ª]©S|ÉZßPêÎl
+äèøÁ®‰æ¼Ý@s¸àÅbèÈWwdEjÊït5qì…TPî{@†ä¹aŠ3÷]½cN&UÆY\Säõ æð­Á†{²üÅazñ #ßBóMølÅ›Íh=gª"€x¹Ôäá»ö‰mpÝ Q× ÷èt¸‡”¯É‰¿ÞZKR,b /w$Æ`Á
+¢ûU“–1^Ãá†!¯%¿¹L¼fEءؚúeÅ×Û\oØ–å(Z¨™0Ö8fP™PºÛ}q)Ä^7ø4PZoY$³¤ŽþîÂg
+·¨)£é'œª©tÔ¹Šnç¿–”a—n^2UvѶ$ž¢ã%!þq3çf%z˜ù=Ò1	à.OMŸ¡ÎáåÖNï¹T:3"+RL_;¯Se×#¡#;ƒy8àÕp•ñ&]çÔ݈Kca&Zá+3‘½ ÿÞ®ƒ§ö·€ŸÎŽàÇkO3Òh¦‘`›X}90ivp’ê×TÉSÖ›†<ãcÙ/Æáӝ}v°òÖùùVË3™ìL °ò®×$™sHIýÑ»i©vÅõîvÃG%˜¸8þœ@W^Ä\
+Dþ™Á”ÝÆÄÊPdþŸ (dŽ@#ã+¸WÕžÐKc¼Æwi§)_YÅ·vçKÍV^˨a±«rŽçð#ñKè
+}bêë¤I¯µo!ÏcyuÍsO…MAëCªi]Ô’ªÜ
+à$i#O’}LÀ~äa·g-תÓ1ÝqC{^­CÉ•­¢¿f0
+Ò[bA<“Òì5¤³%]Ð/Ø|qǦŒçBž-fÝüõß°=ÿRªH*ñذŠPOm´ÔèEz`¡	'ÞHAT…Ž¿—0+¸;úcœG”%K}nIn¿‹¤Ã¹Sè‰8yÔ‰ŸÖxŒÜÝÆø‰ªfctçÁ•h£«H£‹Ê›7/¯cbÒSúl?1¹gûR9Ó…ô½0Q×Óܸ>°H˜€9<õÙ‰ás£Ýø„Yë–0> Væ8½x¦f„1çðw ÁxkVµ†ÔÒò[VďF«°ˆBÈCs‘»l¡ê„n	R$fêV;œÄ'TZ>­´°Šûl†‘~ñ{¨e‹ çñåʰ‚ÑŠ·
+è°Ïm[›«ÙÛá¤U6ÒÊg»¼ÞŠãŠ’Ì"̇bs=lÊ	K‚š…‚èä™~ïXm_+Pò
+XÍU•G}¢P}† 7åïzðÌë˜×׍©
+ôàðÓlÏõCb̳	IÊ4¢ÙêiP¯ý0Dž”¿ ád|d¹—ÁIŠÉ~ô~m©?Î4kBH3&+À{Øâæ;§Ž¥à9‡ˆ4·DU»|ëZÈȏQºh6½pWõáœ[;™IÇxaý;F*PÛ
+{Â(ÅòxȘãÑêZ-¯g@ªƒõ­và%GÖšñuW±æö’¨Éq<®à™üNK’já2J,Ä·«Bû%G{Ê`P'½VÁK¡]Tw`E‘½Þ„(¬·&Ñ1Í=¤’À\ ¸cðX5EŒ–äÖá¤K$6°œHüó:Ú3fr†Æ–5kœ¬ÈԷ׃9Í'öEk»‚'Úbnb÷Žî•Ñö™Ãv×#‘_C%'ÀDß½q÷‚W±Ü·aÄ—›™òÉѼMŒ<U7:¤^Œ*l¤xÔâЫªÃOTÂó´V?	ÍÓpí·ïPçŸGµ5ÓM|ùÔ´B¥½qÊD³„Ùo-Q泎 ´ÂÑRÓ
+)ÒÔŽæµgOò¿×°kjB™Ó€;owEÀ$m2œÜ-ÿÍÇu‚¡²ï‰?ŸôxÝù/T#Ȇ!ßD
+”ûllƒMf	5îT*ºfsʦu¡Eë°ƒÉusú$Óà§{?Xë)â–§ô½_Ϲ ÕêTF
+ÒWQl
+Hï¼¢^œo\>p»TÕ®n
+”<ÿ¼mY1‘Åþ°_€,D#ƒ¢V hôEžÚ꘥.?pWÕÙx§A΍Òk»þø+?cBå«)O æcçËZy…VXt¹ÚK›!I%$@‚ú«ŒY½”ì<&Ƴ¶3<_׎á°a珎ü¾ ƒÐw×L'ÃÈLÇ·âÍÊdAâ»ïlß=±Yçl`íħ䂧_ž6~ß#֝ik5àNço¤ùYóÂ…ϳ
+4Gµ>—Çç)Û¼öØR`óîf·ÙutçƒÕ•D{ÆãWlä¡Sòæ‘—r!ú®ÙÆÈ}|‘øƒŠÔ“ù>"älϸ,Ü¿>L(ÙÑÓ÷þIÃ%´í)÷×½‚¿¶ÐÞ£Ž¥ÁÈ
+©ØÚó©Ž!·N2Ñ,ÚzޱB8%Ãþ:‰Šþ;b{JÁ½èÉk)xå¬+¨5»e:oýaïw5a±ÔYÔ¾í~䘋ož.	s£0QÃ& Ó…J0^÷JæúTrÉ|_¡)M^ádÌy󬣏Ë7Œ¬$ÈJ$îjÄß6Šˆ·Ý÷{ÓYÏäþ›%áÚ8jÍ‘›š@AA]Ãê3æ5…2ð“øÖ㈑Vǰ^7´€¹U¿¨Ó˜¥	ÏvÛù‹M
+s3-b#íCéCQa#Ê"ˆÁlÓ&,Š£¶1:O-5_o"ª2 H–?§~ªGÝŠmãaO·½"x>òå».“§·¿ÅëðùErŸtÖw]!UÛ¨¶où‚Š6Ÿ][¥™Ñ'Š%nOxøXtÁáV”Ýì"áób§ÔBHK[»ìõëH8mrÛ<Ñ»!xQ@.Vè*@ª+­7>Ø/,¢âáì·TqÞM{IÚY•4NÖüy	èFëú	~´FˆÒ¼©Ÿa"ú^Ò[H§UßH‡‘ØÉü’b$xÆ#ñ¹žrâ¦íBó=«E_èaíð|ÓÜÍ\6>J
+ƒNL…ב›¸l‹É“ÁÝ‚¯*vò/<;3ÚÙ®…pzq¢;Œã´DiNÎWLä â«oc¦¹ËÓ.G{Oh×âú}øV¶v
+Ç@¦ë‹nMC âüáù¢÷T(…<®±}“aö3äö丐
+>N™T™cRLØÙõDÛweÊ€qÉkáŽ'ÈöªãË`ϱlmF½µœû‰,F¹éyYªÇ‘Þ­¾‡£A	ûÚò/øD„Â>Ïù¶€=2(ŽkÈ6¾¡ï[¾˜
+»…úŒº4Óv|±©‰6¬1…êÐk¤Bë§Æu0enSÒkYê™,æ\¾×¿‡£BúÖá;HÐnˆ¹|•¬ŠìX\¦Q»ý–lÞ­×WNÕ]ÕbgE­)#•=¼T¾[8l°rA_D-Áq+l:îtO»bkX"ã€Ìx Ì4U‚Ã
+y‚ƹ]µÝd¯4 ÓYö¤0ï·k8ÉÕQõ÷"\í5w¢])ø†p’oþ°%{áqA[ÜÛÍž{PtܯSòêãWNsÏGíé¡åÚ\úÚÊòþÑî_>ÇIûØD ÑÙ¨þNð¡ 0ÛØE)ðÜÕ
+­è¯ò1Ôô6†]~£ˆêƒmfrªþþ™›a÷ÙN3lráЊiYºOIN¦˜èîFV-ìÍK´ë:k‘Så´ù@Ö j¢ n¹9öCšÊâ·„‡d·ÑYã®6œ…ÒCE¡j|Ö+9¹a‡Ætþ›Bu~ £Þ2ävÉr\1ʼS53¶0†šÛáD-Œ—Лð^dÕüàZ2p¡‰É€¡³=àG+F÷,Ý6¿¿–y³¼Œ$!â™9¯š*DQGw©øX_ ÓýçwúM…©ÂßãÞŒBËŒø5°V&üBïÙès­h{€g7G	³?=Ê«`¬Í"(y~Kî9t¶|0N¯çžÞ\ªÅØ)™q¹Çcô‘ÄH¼3fõáy÷ᆼÁðzN2ŠÄè
+Mà‡×·xaYdÂV±°y0jëx;p•!£ý“ÛóXÇ.+y‚Îïí‡Ï¯°u¾ñÆwmùUÓÀÀé'À:Pƒ¾C(ð”‹ë5/k8.’qÏ!ÿ.¥¬ú$"*øEÑ÷V5¯óDûƒD-hÛRÑÿ³U¶;˜Ü•çÌZ+CVÎ课A%Ë$ãѵn[L”	ap¤¦o^Cÿ@:ãd-5¾júHù"}ÎGÈ=£,fœ-Ua ãð}š•ž¸R3óú‘kEøý\éfØÐ">h‹'¦9*X(;Þå鮍	ts¾42l7fËŒ7˜ÒYb9€£•Ø…¨ÞßÊ"YXë?g@«2jÄ‚ÂÌŒlØ[FÀ?ýܧëF7µf³<ä2ÄŸë£T•äÖ	αb†åN7ƒx†™³£° Ê©f)Oº’JP%”¤ŽáFþØòz¼·ò×Ðz$öeÃ+—àî©…¤¹³ù‰B/RÉÐȁò·*!“Šäˆ19)¹†Ëm˜ïßkõ’})Œa=ç2t9¾¼¬ ßt4²8‰Óq‡rʹàR
 ÖhÌÐÌ8¦¸·elj•´Îìôç3uʾ»æPJàIŽ$â²t„uo~0ùuÅ9´}I?Ÿ<â«çAfŒ¶©°Ã›k)–Éõq‘ñ¦4Ÿ…Üfâè—¸¨¦
+n§3±"ìÉqhº‡“é  §O.Æ!ÔèbS½K×´
+µLɵúÁY;Qs eE±b6ãÔ聧24’UˆE‰:£–û,™Í~Ô°¡¡+6¿fªçÄ\£›×-%°¢Áõ‡o¹³¡›†½«ÕžG¯˜ÜZ´ª5¿Bß„zd%…²šåØÎGú~ëÈ0&n·õð·eþBüQù†£bMˆMB<éš
+_»Øê»=¦èþjÎË4ϧGÓ«©spïÝ-àº3¾7/¬‘|‰ŠfèëÂè1ã³(Kø}¾œ­lbe—¶æm at vü’ yôQÙÅ7÷F&›¼z¨8ÙsÂ:wñ!¦’q²Ù²êOô6w‰^z úEß,n°°ŠÙ¯cÏŽ¢r¶ü6íZfŸˆRdA±‡Ñ1¢IÈ¢±Ÿ¬sþç±(Æ^©	ŠÎb‚Ûì©ÝV)µKF™Î†kÐÅV޵p rÜ‘h‘|?`×Ǻ
+®öye¨ã"Ê4 ™EÁ—bÛ><ŠÁ£%Eig®G Žâ[ûVzÀÆ2ìSGŸýœ¨½–ú.uéFû¹ÏÁ!L!h›½50»Ñ‘¸äëÑÒ㹆ý
+!õ†¢äMžâ	¸>¤S[›4H²Â \ ¬‹œçƒ;$4=a¯}JÉ«Å;õ¼RÁ"
+^rpõÝû\¿²Gàó¢B¢¦“›ü¸b¹dŠáq€/Ì`±™÷Ëõ| кY÷Fô¢qžÜZG±SqŒqŸÔ9¯ô{àû±)ÒÚC¥º	¨r!("ù0ÇËr‹zfU•éŸcV©b1½d†ÔâÃz§G5kN¥	ñ’ÖnÞô„Wü•Ó\¦L•rºš-EY^þi>y"ÉK[ï÷øÇ6)ueùCµiÊ:ðΏ6ÛáƒÛ«Å-.®.õºì^e!G€Ç ¸µ®0Û†4mDr%:*YGzƒÔœGjÎñ׉ßbm;MÝs
+x¯‘*š,ÁVœŽXX ™*”Á`SÙŽŒAJ"C9B×2²p%ÇûA€EÄ4hAíØêF½hžò‹½ à—2î òfUå
+o²Ðþó0šuËDub¨¿Ç¯Ï}ÝIéBÿÜ^×
+‘5µæÁ\‚:t¡94ÇQÅM[ç^´Q¯õ;®ÇÃü]vIöÍs5þßajg/áHãƒÕKœÒW+²þVÕœhf՟ʹ«.ÍO+«˜³ŒÕü5v+´\›¹«OsâW¥su†›F\“bax˜lÓP`õ¯·­7¸“Ûñí¸–./I‰Í*wi5¨î-ú·mAä|Îa½ÿ0Ìô8óQ-/s±4:)ïOŠãÞ„&-ÊîÆÉDë£wé4%=ܸ+àõÒáRßQ¨k–åo‘€t’tō¡$¬o2âB¢¦ PjH;p´/øGPÀü}­’ïßW at e}m òèªÐ/ÛõšŠŒ[êoö‰„a|guc7ûê¬®£Ž–ЫLœ’Ø ƒù«[Ë”ZmdG'
+\k鈄‘(~½äâLR–W+Æv<¾DÉÊhwéã÷~r|8X—Ï[ü–rRDï9#kbzYƒ¥ü=î$üJš@¿6'ë$Ñô¼]ýùùO#QÖPÅæE%C–è—+•ÅѶ a{¼
+O0i6ם»Ç%¬ïc«jUì5EpŒnê± ³»¸ÚÑÚ7?¡ÊñÍ
+1â±QýríÝe[†ÜAý•|'u]Ò9H÷º<
+ºMÜ·ÑSuc£u«q´)G'qÀƒ9X¢oÄyÆgwÊkôÅ;”M3zFÐÔ
+ßpkÀ®—¸6Ûæt·‰ÜçáSg€«¥õǹiJ>;/‡ŒF{g’Mi4 s§xar¿r̉XÆ´&£á€^ß ÉÂEÎ0ßmzfÕ;~öD¦.LŽRéõÇWâ„ÚWwLô‡qlØàe¼ÔNðŸÐ(»>}RS½y¿´K½ó»Mµ˜æÅ½¼%µJÔ\GNÛ²?ÏKü®âû²ÌeB,¥p±g—öýn Ñ šgÏœëÂêiÓiì6ô€‰å+Š»ÍØŸJ¬­Á-›î’R5ü‹6êÝåТµGw8q¼p/ær
+Vù\Ô£³'Ô›¡ò<7•Œœ ô€›±c>èe›L¯©êw‹Í 9Kïu6á̦ORóŠ .à÷jºéûø&nø‡ë¢[cÇ"ÛÙÙôrå±ë
+:óýc…6#8[+	IqtISA'†6kÄôO|¾èl"íô+n>ÎaÓB“ñh]Wk{›Ãñ	<A3ňYiÝ="K…XÍŸÚ…ò6gqCYë5ùVõ‡5™'¤„Q¹[=À0ôö‹zZÐ’¿4HmÇT/n á‘ÐNʐ!?Ž\èàö'Ø~ÐOzQˆ³ú:ÿJ*–Ï,‡üSq;ËÏø©ðFfºÃN-jÆÊîëwRè±Ü®#¼ýð¹0Ë‹
+êïMaxIâ󆧿‘»-U¢
+1"ó-ßB»qg³iï#¸8{`~æœYVqm—" Ï¦ ž¿â?eÍ6"Ûêv;{úæœÚAѽåê2ºb¼\ò83
+UQÁ׿cCŸ °^Å{§<Ž-òõ7LÚ÷ñ·‡š–"îWûåLo‡Ï–™Šè¿zºýìè(Ñé¹0¸Ü‹ÄE*œÛ6E9;»œŸH%¶‡û®½ëM0–Ôø_ß+¶0‡ûªj2ïo©G+GËê‡SÑ•)Iè3V䡹.¢aÊNØŒÅôúBkÍ¿¹áH,…sÉfbr^^ø£§$ÏÛ¡„²0‘þtk	ãCJTÛWéK´<<HOBBOwJÊžZØ5̘¢“'.y|OlàH3€'fFہ^J'T!Q9馍¥§çÀoš`BC`ÑQ6ú©X)sÛ’¾"ڐ֭Jš˜\©*¸|È
+z¯Âø#,߉ú2µx&Ï…ÚýÈÈny’Ap‚÷˜žI¦†ÛJâ–갪ؾcFo»b¾Ò»£ YsÝ“øãÏ‹…Ív\ÜžËÎ4´ú³O¹Œäñ%—¼ÜÍ Êòh Ô¶ŸÙßÝ6†Jí§¿›yÅÁ/ÞB’ƒùî;ÁÉ*àEø"œÂýO¤t#%ä4ÕÉÎýÞ_úÞ!ÍÁ]E…øXÉrúFVgÉ®FWÛ0þw»GŒ·Õötæ¾#·î™ßl–¸öiÑ}Y³ß‰šs'êg¦úî6°¢N”ïzñ? ¦Œº‰$6à®uÔ²?äáHâ<Ÿm©©eúðÈW+Ë„‘úìÉ~ҐX®w*ƒÌ_y2”aQeE¼”âŽ1=+4´þæÒÜë)ÕÈ5gÎÑîغ-//\˜é<í/&¬mšy8aÞäçY$Ä
+s® ´%ݬ⨅Qª	ã!&<‡í\×\-‡Þåiú›`T¯‚Rb7í$£Ô½#܏i\ÌÒØ§º}MZäôË}ÑïØ€MÐÕÐâ!è=.r2VCùq„œyw8í“(IPÜK`­Ý>}¼~ñ‰B£è8t–ìuäÛÂV¾ˆÝžr6¢ó™Ýåªz•°mfH³ùàc€°w"±Åí‰,ÕJζÈV¦¢'îç öÊ&ýíBFº¶—r¶r4ùYíVœ
+ûçºÔ¿Ä'…®\$PÑšFý©Q6*å×^õgsàf!|Ñì/„ýŠ0é|ÇŒÑêCó΄Hø^þ-oÖD¶Ù½›S*š6ìû“;D{WÝCQfhаS7u…Ö¢öeúÀË
+­ÖrF÷}Qš¦Ð¸5W¨‘
+5ù¢ÈYJ;RDò%ÿVÊÙˆ{”p“´]ÅÄ¿'Šã„«¨G“øòôé°0N-ÜFïQîŽ|³mk$ZÄHI¯Ù÷W|s>9µÊ­Šø;R56JÞ|ØMèæBZ•Híܝ_!TUcúpGçÎmb@^í%Ö³p"¸ç²˜w’(Gr	³QÊó‰eGO÷ÍÔ3Ú`ª@›`ZÉ¹ó´«NæË+C8°©	À•žmWü&è”+ðdl¡C¼æDX8âå……Š^¤ƒ
+:5ëí,·}(ßËøS¿Åž¦ñJ"¡Æf¾XØù3ï“Kyææ×0ØŠ'1ˆë‰G¹›ÚçU36ÑMJn0…+Ä“ÚMcB,ðÇ·>w9ûÓ3ªœ^	úîÐä?#Åüó¿	]6OMø45ÓÁÐåÐpWI*Ô*¿(@1îþXŠÞ[·Û žçT>ɹ/8öš<÷ÿ|u`K̏äW”ñ<ŽµÈ«:’ða‘øô »ð+`WçK†éiœq”‚Â(¦_?~O™¦kЫ’w°„:\ªš9¢¨ÔR
+	îW.eaêlÐÄqó\_8Ýw˜Ùóiø„£ö0jùcׁR~nní'	QÃÍZìÅz~Oo³á:h4ªM[;ÍM½öfG®á—{d±‰~Ï5³—K¨ÇÿcÊÌÓIEiù­½w8wøãDõ3•Sí'œ^×ȏøpçÁá áymC½†Îy›9	iÔ½pò‡UsÛ!¬6ZÇ®ç0F=™ªË«‰EM$DÍúG.½u/’-¤w¿6”¾Kœ^3hèÐ}Ã7Ôãœo|HfYEp©ç£|P[˜üLo‡ûì×¼i.¡?¡EÀOHZ€ný}ѶHÖ³f‘\ðȹåH8¥¨äÙê,(jëÝO£˜y®´möÙ7¸‚#rÃ~œgJòµáÈ*k,dATKL/<º ƒ¶Ë¯ÓŒµgp‹˜5nÇsKµï1ÝcÌ´1åž­æßÜ…Qhtå1E˜áãp—i~¬\ùI-]²*çr¤EžF‚ª­þ®AËê(«ŸQЧM•‘¦AÅš>§4ŽNVÛE¨Ð¯?Ɔô=ã g¨g º’MëZ-Zª`%å"Œ…Ò¬”å#’íZ„罚ìó”­5ØÑ:ÚŠL9´ig¾ø“ÿÍ]ÒFÆ
+ƒ'MÓMÃBé!/r¨âxŠ‘¼©úYbÁàëÔÇEÑ«ªü”§°lÇÔ)!vŒm+[yÑÕmìëÏõ¶7êÆAâD†L›¯Ûåü'°Á~óú|bY‚I{1%\ÐTBèÞT5º„O·
+FÀyó(c·Îð:y†ÛøBb
+ý<ŸmUEúWàM•“©c3c«ae—TÉ’ûÆ<¼ûÉ
+(¬É‚v›^PÛ-ž8è)*X°©À,b*ÏšŸ
+º“å+Õm\S(ÓÛi¾G(ž!Üq·z…Š'_XT¸ðRé~¤u¦®Ží`—ÆÓA
+L±
+Fì§mæÖ`ç§è¾xeæZqàÙ.,ý1ˆ }¥‘PýÈ3cèØ·°¤?
+r)zd)·ŒÒæ^æUÒ#6ì ¼ú#øh’µÔήxJÏt
+äß·74€¿yF-®e÷|£yäË r€7úŠï6:ލõÔúeÓpн˜X
+~+‰^´ÞúSƒbà‘µ{²¥ýŸÜ°££eåQÐÚˆ¼9cÛëéòãxEÐh®Á!UÕÅû‹a8x)‹0ìB•ÏztÌòäKö©Eí\Œ":«áÝ?»¼ü‚Ì÷~–]ªP·×:%)™
+‘‡Œ“ðn?êÑSAÚ«{e¹ð/n¢C!íàïoÊ¥ù‹¸Õ	’bAÛ]}ý6’`fª‘k*<–\<^Å-ϐãÓŠ1i'ôÚ5ëÑbÉÑã
+u~M›3CÒ÷"
+EôÈðj¸6xE¸ÎD„„¬SöˆK¾™hÄQGb—,X²Oďzª–e¡šdÃÌ7ã…1†ö1hsk¤BAËI3ÃÚ+òJ"X 	ü^¿M--M¨Æ›ÆËº|¹3V‘-Oûv"þáôéºxho÷ š¢bKq¿ZT]…º;ýMüë>‰ˆ%b»jÐbâãL¥H±£¢“Žhµ¡Ã‘.¸!ØÃFýÞþÀýµ7Ïœ¼¸BÚ_¬gb»zì'A|¬ëôû„YBAl1æqì t,|Æ\÷ãe§4ƒæ44©®º=\ i“šZ¿p*{”nä5ÌwÅ» ’øø e²cPÚªd¤
+©½¶ONµt§:Ã	%Œa`CZç|ª¾Å`(ÜDÐç<$œýø:.ÜDá…PЍësÐ1Î;ếc²Gzê!]œ¼8ÐîVL_]yÇì2µHgéŠXÊ2|9r¡‡oጞ&ÑòâcfjºÊÍ¡Séíßà³óö«ˆ¤IO-÷¯ TK,h%PkÌ–{åLýçZº\$Ó¹xAO">å~ŠÛ>‰µ¡K4	g¤³ÙU)Ø!L¨£&4Ð7?üöÏ)ìäl0ÖwðJêœt¤õó;ç“3{ífBˆ§©©ge‰ÌüÑ
+òsn> ’Yb×d
+¶ï5;Z.å+†Vw,½1Žà*rÀ¾-Ž!K[+²¥€mƒIø[‡mèG‘dÊ”¦Ì¼éÅí|‡2ýÖ½ÙkØIÊú“‰ðÀèb’]3}	´1þÜ$Œ!ñE¿¹ë÷ÖjžBÄA‚‘ÌåÂd¹‹MÄÑ1‰R1°žÎ‰ã6s/®ƒ;m{P
+1­Åyzܨ2Ók™€ÝæÁ'÷wº—×qZ³ø„__Ën²°QZY@×µ‡OTDþhKoŒèšw}ü:-êTÏQi6Mmå±Ä#úƒºÉà"wa{M$ú0irÖDµr…Ѫe­ëI~<£J™ÑvN[†Ù¨¥pñtÎåù/wôrê¹*Éøá¬I8©ÂYþ^ì䍐"SÿËöÙDuËÍ÷£¾Áa–»Û)LÌî…:‘ù2ûžà–ßè|5ʊ‰Ýúyúü®'i+
+3¶È2¿Å@Júú°ÈÔ©² {õ=!FV¥Ø*¢çícB›õeº¡5$4†´ˆÍWÍÑqcTŽBmµÉ0ºJ‚"Rî ËíŦVщQ9ÏùÄ]¶&¨×PhaΘl+¬cÑX™½q³…£žÁæÒ¦¥ÓªŒ/™Ž7‚Ød°ÈHøö?,s°Wkœ`@%9ˆ™zNïî$íŠÓ¤*)è&Ñûó’8\,		÷p?6匝ú†E,b¯\N\p ,aeÖñ%•°¿q<cõO©} 4LÀ„Áaëðâstm>v:1tûÂ)ô\*é"ž>„Ÿ†öu§]gÌâoÜÎᾪô–ˆƒÃG¾rñºŠÌ_; E$QŒ;}³ã¡ˆ7ù#Ý$™.šÈc[f™#Œ*¿!¹"–aŸ\xqJ>Ê7ÜõBpÑõ§–8Jb»?ž‹Âú÷&#‘w`!НdSþö¶÷¬b핲ècŒLŠ!½_áÐΨ¹Û©w»^ö/…–
 ˆçdJì¥R6Ñ©ÇÝ>΀ûvǁ•t|œþ«øïÐú¦â¦w06ç(ƒx^°á7ÍX]9›Œ÷2ÂÛ²-¤›üp‡éàž®?£M€"8ñ¾]D«åU¡­Fa=eüTœ
+¾ß×MïАYä<"í!¯þ±…ÆhêÉæ3?P+ƒwéŒñÎcê¬i,v‹.tk9k¤®¤UËÛAp“©ÁËJ—=š…@zzQ4<òR§ðzrTìr)¥\Ðc*–ð&¢Ìò9·+ÉH]½YSyä¦{ää+Œ{»6"ÞûLïŸXÕy+¹ÇN7ÐY
+öhöõ W
+¹ †[­1œ‹¶)EN³õ3yRÑÌIÉBŸBZIä{žÜzýqà;³&4#n“Åpf†º`¾òFiŒZÛ:ZuU~E­>ó2abîyx`T—/e«GÑQ{cß>Ìès¤3VÚ±5úlÊ“±_Çkño AèڏCdà&$Ôâו«Ö?Þ!–bæ\ÕÀ–	©1û
+Xï&l8ªï*ď+‹Osµž(×Þ¢ákFDC!W‰¡¸f{Ÿãñ-a!®¨˜V¾0¢?3ð S›Yš‹-¬ÐQ†3@Ö{°h,e|PMµ«T8ÈÓµÞ‰ýKË~y!«p:{lËB6îý€(<ŽBŠÍgø„18r¼U’%~þÇ5ŽGQ‰,¦œfë7g4þsXƒÁÈÙã+ÿrl_d1ˆïnì•ç…kX¤µmÙE{ž)ÉåRîI$U»2NÒªoç£AGsSîB|ºD+(þ Rvj
+Vïÿ’—~ä
+endstream
+endobj
+332 0 obj <<
+/FontName /PARFSI+NimbusRomNo9L-Regu
+/Flags 4
+/FontBBox [-168 -281 1000 924]
+/Ascent 678
+/CapHeight 651
+/Descent -216
+/ItalicAngle 0
+/StemV 85
+/XHeight 450
+/CharSet (/A/B/C/D/E/F/G/H/I/J/M/O/P/S/T/W/a/b/c/comma/d/e/eight/f/fi/five/fl/four/g/h/hyphen/i/j/k/l/m/n/nine/o/one/p/period/q/r/s/seven/six/t/three/two/u/underscore/v/w/x/y/z/zero)
+/FontFile 331 0 R
+>> endobj
+317 0 obj <<
+/Type /Encoding
+/Differences [2/fi/fl 34/quotedbl 40/parenleft/parenright 44/comma/hyphen/period/slash/zero/one/two/three/four/five/six/seven/eight/nine 59/semicolon 65/A/B/C/D/E/F/G/H/I/J 77/M/N/O/P 83/S/T 87/W 91/bracketleft 93/bracketright 95/underscore 97/a/b/c/d/e/f/g/h/i/j/k/l/m/n/o/p/q/r/s/t/u/v/w/x/y/z/braceleft 125/braceright]
+>> endobj
+191 0 obj <<
+/Type /Font
+/Subtype /Type1
+/BaseFont /TZLUSU+NimbusMonL-Regu
+/FontDescriptor 324 0 R
+/FirstChar 40
+/LastChar 125
+/Widths 318 0 R
+/Encoding 317 0 R
+>> endobj
+141 0 obj <<
+/Type /Font
+/Subtype /Type1
+/BaseFont /CRAVFF+NimbusSanL-Bold
+/FontDescriptor 326 0 R
+/FirstChar 46
+/LastChar 121
+/Widths 320 0 R
+/Encoding 317 0 R
+>> endobj
+139 0 obj <<
+/Type /Font
+/Subtype /Type1
+/BaseFont /ZMBSGR+NimbusSanL-Regu
+/FontDescriptor 328 0 R
+/FirstChar 34
+/LastChar 121
+/Widths 321 0 R
+/Encoding 317 0 R
+>> endobj
+180 0 obj <<
+/Type /Font
+/Subtype /Type1
+/BaseFont /DIXNGO+NimbusRomNo9L-Medi
+/FontDescriptor 330 0 R
+/FirstChar 49
+/LastChar 119
+/Widths 319 0 R
+/Encoding 317 0 R
+>> endobj
+138 0 obj <<
+/Type /Font
+/Subtype /Type1
+/BaseFont /PARFSI+NimbusRomNo9L-Regu
+/FontDescriptor 332 0 R
+/FirstChar 2
+/LastChar 122
+/Widths 322 0 R
+/Encoding 317 0 R
+>> endobj
+142 0 obj <<
+/Type /Pages
+/Count 6
+/Parent 333 0 R
+/Kids [134 0 R 177 0 R 182 0 R 205 0 R 235 0 R 260 0 R]
+>> endobj
+303 0 obj <<
+/Type /Pages
+/Count 2
+/Parent 333 0 R
+/Kids [283 0 R 308 0 R]
+>> endobj
+333 0 obj <<
+/Type /Pages
+/Count 8
+/Kids [142 0 R 303 0 R]
+>> endobj
+334 0 obj <<
+/Type /Outlines
+/First 3 0 R
+/Last 7 0 R
+/Count 2
+>> endobj
+131 0 obj <<
+/Title 132 0 R
+/A 129 0 R
+/Parent 111 0 R
+/Prev 127 0 R
+>> endobj
+127 0 obj <<
+/Title 128 0 R
+/A 125 0 R
+/Parent 111 0 R
+/Prev 123 0 R
+/Next 131 0 R
+>> endobj
+123 0 obj <<
+/Title 124 0 R
+/A 121 0 R
+/Parent 111 0 R
+/Prev 119 0 R
+/Next 127 0 R
+>> endobj
+119 0 obj <<
+/Title 120 0 R
+/A 117 0 R
+/Parent 111 0 R
+/Prev 115 0 R
+/Next 123 0 R
+>> endobj
+115 0 obj <<
+/Title 116 0 R
+/A 113 0 R
+/Parent 111 0 R
+/Next 119 0 R
+>> endobj
+111 0 obj <<
+/Title 112 0 R
+/A 109 0 R
+/Parent 7 0 R
+/Prev 43 0 R
+/First 115 0 R
+/Last 131 0 R
+/Count -5
+>> endobj
+107 0 obj <<
+/Title 108 0 R
+/A 105 0 R
+/Parent 43 0 R
+/Prev 103 0 R
+>> endobj
+103 0 obj <<
+/Title 104 0 R
+/A 101 0 R
+/Parent 43 0 R
+/Prev 99 0 R
+/Next 107 0 R
+>> endobj
+99 0 obj <<
+/Title 100 0 R
+/A 97 0 R
+/Parent 43 0 R
+/Prev 95 0 R
+/Next 103 0 R
+>> endobj
+95 0 obj <<
+/Title 96 0 R
+/A 93 0 R
+/Parent 43 0 R
+/Prev 91 0 R
+/Next 99 0 R
+>> endobj
+91 0 obj <<
+/Title 92 0 R
+/A 89 0 R
+/Parent 43 0 R
+/Prev 87 0 R
+/Next 95 0 R
+>> endobj
+87 0 obj <<
+/Title 88 0 R
+/A 85 0 R
+/Parent 43 0 R
+/Prev 83 0 R
+/Next 91 0 R
+>> endobj
+83 0 obj <<
+/Title 84 0 R
+/A 81 0 R
+/Parent 43 0 R
+/Prev 79 0 R
+/Next 87 0 R
+>> endobj
+79 0 obj <<
+/Title 80 0 R
+/A 77 0 R
+/Parent 43 0 R
+/Prev 75 0 R
+/Next 83 0 R
+>> endobj
+75 0 obj <<
+/Title 76 0 R
+/A 73 0 R
+/Parent 43 0 R
+/Prev 71 0 R
+/Next 79 0 R
+>> endobj
+71 0 obj <<
+/Title 72 0 R
+/A 69 0 R
+/Parent 43 0 R
+/Prev 67 0 R
+/Next 75 0 R
+>> endobj
+67 0 obj <<
+/Title 68 0 R
+/A 65 0 R
+/Parent 43 0 R
+/Prev 63 0 R
+/Next 71 0 R
+>> endobj
+63 0 obj <<
+/Title 64 0 R
+/A 61 0 R
+/Parent 43 0 R
+/Prev 59 0 R
+/Next 67 0 R
+>> endobj
+59 0 obj <<
+/Title 60 0 R
+/A 57 0 R
+/Parent 43 0 R
+/Prev 55 0 R
+/Next 63 0 R
+>> endobj
+55 0 obj <<
+/Title 56 0 R
+/A 53 0 R
+/Parent 43 0 R
+/Prev 51 0 R
+/Next 59 0 R
+>> endobj
+51 0 obj <<
+/Title 52 0 R
+/A 49 0 R
+/Parent 43 0 R
+/Prev 47 0 R
+/Next 55 0 R
+>> endobj
+47 0 obj <<
+/Title 48 0 R
+/A 45 0 R
+/Parent 43 0 R
+/Next 51 0 R
+>> endobj
+43 0 obj <<
+/Title 44 0 R
+/A 41 0 R
+/Parent 7 0 R
+/Prev 11 0 R
+/Next 111 0 R
+/First 47 0 R
+/Last 107 0 R
+/Count -16
+>> endobj
+39 0 obj <<
+/Title 40 0 R
+/A 37 0 R
+/Parent 11 0 R
+/Prev 35 0 R
+>> endobj
+35 0 obj <<
+/Title 36 0 R
+/A 33 0 R
+/Parent 11 0 R
+/Prev 31 0 R
+/Next 39 0 R
+>> endobj
+31 0 obj <<
+/Title 32 0 R
+/A 29 0 R
+/Parent 11 0 R
+/Prev 27 0 R
+/Next 35 0 R
+>> endobj
+27 0 obj <<
+/Title 28 0 R
+/A 25 0 R
+/Parent 11 0 R
+/Prev 23 0 R
+/Next 31 0 R
+>> endobj
+23 0 obj <<
+/Title 24 0 R
+/A 21 0 R
+/Parent 11 0 R
+/Prev 19 0 R
+/Next 27 0 R
+>> endobj
+19 0 obj <<
+/Title 20 0 R
+/A 17 0 R
+/Parent 11 0 R
+/Prev 15 0 R
+/Next 23 0 R
+>> endobj
+15 0 obj <<
+/Title 16 0 R
+/A 13 0 R
+/Parent 11 0 R
+/Next 19 0 R
+>> endobj
+11 0 obj <<
+/Title 12 0 R
+/A 9 0 R
+/Parent 7 0 R
+/Next 43 0 R
+/First 15 0 R
+/Last 39 0 R
+/Count -7
+>> endobj
+7 0 obj <<
+/Title 8 0 R
+/A 5 0 R
+/Parent 334 0 R
+/Prev 3 0 R
+/First 11 0 R
+/Last 111 0 R
+/Count -3
+>> endobj
+3 0 obj <<
+/Title 4 0 R
+/A 1 0 R
+/Parent 334 0 R
+/Next 7 0 R
+>> endobj
+335 0 obj <<
+/Names [(Doc-Start) 140 0 R (_app_procedures) 227 0 R (_backgound_list) 278 0 R (_backgroundstruct) 208 0 R (_batch_wrappers) 289 0 R (_create_status_table) 286 0 R]
+/Limits [(Doc-Start) (_create_status_table)]
+>> endobj
+336 0 obj <<
+/Names [(_diffstruct) 217 0 R (_header) 192 0 R (_image) 188 0 R (_jpeg) 198 0 R (_madd) 228 0 R (_mbackground) 231 0 R]
+/Limits [(_diffstruct) (_mbackground)]
+>> endobj
+337 0 obj <<
+/Names [(_mbackgroundbatch) 290 0 R (_mbgmodel) 238 0 R (_mconcatfit) 241 0 R (_mdiff) 244 0 R (_mdiffbatch) 294 0 R (_mdifffit) 247 0 R]
+/Limits [(_mbackgroundbatch) (_mdifffit)]
+>> endobj
+338 0 obj <<
+/Names [(_mdifffitbatch) 298 0 R (_mfitbatch) 311 0 R (_mfitplane) 250 0 R (_mimgtbl) 253 0 R (_mjpeg) 263 0 R (_mmakehdr) 256 0 R]
+/Limits [(_mdifffitbatch) (_mmakehdr)]
+>> endobj
+339 0 obj <<
+/Names [(_moverlaps) 266 0 R (_mproject) 269 0 R (_mprojectbatch) 314 0 R (_mprojectpp) 272 0 R (_mshrink) 275 0 R (_overview) 185 0 R]
+/Limits [(_moverlaps) (_overview)]
+>> endobj
+340 0 obj <<
+/Names [(_status) 201 0 R (_swift_montage_api) 186 0 R (_table) 195 0 R (_types) 187 0 R (lstlisting.-1) 189 0 R (lstlisting.-10) 239 0 R]
+/Limits [(_status) (lstlisting.-10)]
+>> endobj
+341 0 obj <<
+/Names [(lstlisting.-11) 242 0 R (lstlisting.-12) 245 0 R (lstlisting.-13) 248 0 R (lstlisting.-14) 251 0 R (lstlisting.-15) 254 0 R (lstlisting.-16) 257 0 R]
+/Limits [(lstlisting.-11) (lstlisting.-16)]
+>> endobj
+342 0 obj <<
+/Names [(lstlisting.-17) 264 0 R (lstlisting.-18) 267 0 R (lstlisting.-19) 270 0 R (lstlisting.-2) 193 0 R (lstlisting.-20) 273 0 R (lstlisting.-21) 276 0 R]
+/Limits [(lstlisting.-17) (lstlisting.-21)]
+>> endobj
+343 0 obj <<
+/Names [(lstlisting.-22) 279 0 R (lstlisting.-23) 287 0 R (lstlisting.-24) 291 0 R (lstlisting.-25) 295 0 R (lstlisting.-26) 299 0 R (lstlisting.-27) 312 0 R]
+/Limits [(lstlisting.-22) (lstlisting.-27)]
+>> endobj
+344 0 obj <<
+/Names [(lstlisting.-28) 315 0 R (lstlisting.-3) 196 0 R (lstlisting.-4) 199 0 R (lstlisting.-5) 202 0 R (lstlisting.-6) 209 0 R (lstlisting.-7) 218 0 R]
+/Limits [(lstlisting.-28) (lstlisting.-7)]
+>> endobj
+345 0 obj <<
+/Names [(lstlisting.-8) 229 0 R (lstlisting.-9) 232 0 R (lstnumber.-1.1) 190 0 R (lstnumber.-10.1) 240 0 R (lstnumber.-11.1) 243 0 R (lstnumber.-12.1) 246 0 R]
+/Limits [(lstlisting.-8) (lstnumber.-12.1)]
+>> endobj
+346 0 obj <<
+/Names [(lstnumber.-13.1) 249 0 R (lstnumber.-14.1) 252 0 R (lstnumber.-15.1) 255 0 R (lstnumber.-16.1) 258 0 R (lstnumber.-17.1) 265 0 R (lstnumber.-18.1) 268 0 R]
+/Limits [(lstnumber.-13.1) (lstnumber.-18.1)]
+>> endobj
+347 0 obj <<
+/Names [(lstnumber.-19.1) 271 0 R (lstnumber.-2.1) 194 0 R (lstnumber.-20.1) 274 0 R (lstnumber.-21.1) 277 0 R (lstnumber.-22.1) 280 0 R (lstnumber.-23.1) 288 0 R]
+/Limits [(lstnumber.-19.1) (lstnumber.-23.1)]
+>> endobj
+348 0 obj <<
+/Names [(lstnumber.-24.1) 292 0 R (lstnumber.-24.2) 293 0 R (lstnumber.-25.1) 296 0 R (lstnumber.-25.2) 297 0 R (lstnumber.-26.1) 300 0 R (lstnumber.-26.2) 301 0 R]
+/Limits [(lstnumber.-24.1) (lstnumber.-26.2)]
+>> endobj
+349 0 obj <<
+/Names [(lstnumber.-26.3) 302 0 R (lstnumber.-27.1) 313 0 R (lstnumber.-28.1) 316 0 R (lstnumber.-3.1) 197 0 R (lstnumber.-4.1) 200 0 R (lstnumber.-5.1) 203 0 R]
+/Limits [(lstnumber.-26.3) (lstnumber.-5.1)]
+>> endobj
+350 0 obj <<
+/Names [(lstnumber.-6.1) 210 0 R (lstnumber.-6.2) 211 0 R (lstnumber.-6.3) 212 0 R (lstnumber.-6.4) 213 0 R (lstnumber.-6.5) 214 0 R (lstnumber.-6.6) 215 0 R]
+/Limits [(lstnumber.-6.1) (lstnumber.-6.6)]
+>> endobj
+351 0 obj <<
+/Names [(lstnumber.-6.7) 216 0 R (lstnumber.-7.1) 219 0 R (lstnumber.-7.2) 220 0 R (lstnumber.-7.3) 221 0 R (lstnumber.-7.4) 222 0 R (lstnumber.-7.5) 223 0 R]
+/Limits [(lstnumber.-6.7) (lstnumber.-7.5)]
+>> endobj
+352 0 obj <<
+/Names [(lstnumber.-7.6) 224 0 R (lstnumber.-7.7) 225 0 R (lstnumber.-7.8) 226 0 R (lstnumber.-8.1) 230 0 R (lstnumber.-9.1) 233 0 R (page.1) 184 0 R]
+/Limits [(lstnumber.-7.6) (page.1)]
+>> endobj
+353 0 obj <<
+/Names [(page.2) 207 0 R (page.3) 237 0 R (page.4) 262 0 R (page.5) 285 0 R (page.6) 310 0 R (page.i) 137 0 R]
+/Limits [(page.2) (page.i)]
+>> endobj
+354 0 obj <<
+/Names [(page.ii) 179 0 R (section.1) 2 0 R (section.2) 6 0 R (subsection.2.1) 10 0 R (subsection.2.2) 42 0 R (subsection.2.3) 110 0 R]
+/Limits [(page.ii) (subsection.2.3)]
+>> endobj
+355 0 obj <<
+/Names [(subsubsection.2.1.1) 14 0 R (subsubsection.2.1.2) 18 0 R (subsubsection.2.1.3) 22 0 R (subsubsection.2.1.4) 26 0 R (subsubsection.2.1.5) 30 0 R (subsubsection.2.1.6) 34 0 R]
+/Limits [(subsubsection.2.1.1) (subsubsection.2.1.6)]
+>> endobj
+356 0 obj <<
+/Names [(subsubsection.2.1.7) 38 0 R (subsubsection.2.2.1) 46 0 R (subsubsection.2.2.10) 82 0 R (subsubsection.2.2.11) 86 0 R (subsubsection.2.2.12) 90 0 R (subsubsection.2.2.13) 94 0 R]
+/Limits [(subsubsection.2.1.7) (subsubsection.2.2.13)]
+>> endobj
+357 0 obj <<
+/Names [(subsubsection.2.2.14) 98 0 R (subsubsection.2.2.15) 102 0 R (subsubsection.2.2.16) 106 0 R (subsubsection.2.2.2) 50 0 R (subsubsection.2.2.3) 54 0 R (subsubsection.2.2.4) 58 0 R]
+/Limits [(subsubsection.2.2.14) (subsubsection.2.2.4)]
+>> endobj
+358 0 obj <<
+/Names [(subsubsection.2.2.5) 62 0 R (subsubsection.2.2.6) 66 0 R (subsubsection.2.2.7) 70 0 R (subsubsection.2.2.8) 74 0 R (subsubsection.2.2.9) 78 0 R (subsubsection.2.3.1) 114 0 R]
+/Limits [(subsubsection.2.2.5) (subsubsection.2.3.1)]
+>> endobj
+359 0 obj <<
+/Names [(subsubsection.2.3.2) 118 0 R (subsubsection.2.3.3) 122 0 R (subsubsection.2.3.4) 126 0 R (subsubsection.2.3.5) 130 0 R]
+/Limits [(subsubsection.2.3.2) (subsubsection.2.3.5)]
+>> endobj
+360 0 obj <<
+/Kids [335 0 R 336 0 R 337 0 R 338 0 R 339 0 R 340 0 R]
+/Limits [(Doc-Start) (lstlisting.-10)]
+>> endobj
+361 0 obj <<
+/Kids [341 0 R 342 0 R 343 0 R 344 0 R 345 0 R 346 0 R]
+/Limits [(lstlisting.-11) (lstnumber.-18.1)]
+>> endobj
+362 0 obj <<
+/Kids [347 0 R 348 0 R 349 0 R 350 0 R 351 0 R 352 0 R]
+/Limits [(lstnumber.-19.1) (page.1)]
+>> endobj
+363 0 obj <<
+/Kids [353 0 R 354 0 R 355 0 R 356 0 R 357 0 R 358 0 R]
+/Limits [(page.2) (subsubsection.2.3.1)]
+>> endobj
+364 0 obj <<
+/Kids [359 0 R]
+>> endobj
+365 0 obj <<
+/Kids [360 0 R 361 0 R 362 0 R 363 0 R 364 0 R]
+/Limits [(Doc-Start) (subsubsection.2.3.5)]
+>> endobj
+366 0 obj <<
+/Dests 365 0 R
+>> endobj
+367 0 obj <<
+/Type /Catalog
+/Pages 333 0 R
+/Outlines 334 0 R
+/Names 366 0 R
+/PageMode/UseOutlines/PageLabels<</Nums[0<</S/r>>2<</S/D>>]>>
+/OpenAction 133 0 R
+>> endobj
+368 0 obj <<
+/Author()/Title(Swift Montage API)/Subject()/Creator(DBLaTeX-0.3)/Producer(pdfTeX-1.40.10)/Keywords()
+/CreationDate (D:20110614204133-05'00')
+/ModDate (D:20110614204133-05'00')
+/Trapped /False
+/PTEX.Fullbanner (This is pdfTeX, Version 3.1415926-1.40.10-2.2 (TeX Live 2009) kpathsea version 5.0.0)
+>> endobj
+xref
+0 369
+0000000000 65535 f
+0000000015 00000 n
+0000012366 00000 n
+0000100075 00000 n
+0000000060 00000 n
+0000000086 00000 n
+0000012486 00000 n
+0000099966 00000 n
+0000000131 00000 n
+0000000166 00000 n
+0000012605 00000 n
+0000099857 00000 n
+0000000216 00000 n
+0000000240 00000 n
+0000012725 00000 n
+0000099783 00000 n
+0000000296 00000 n
+0000000320 00000 n
+0000012967 00000 n
+0000099696 00000 n
+0000000376 00000 n
+0000000401 00000 n
+0000013210 00000 n
+0000099609 00000 n
+0000000457 00000 n
+0000000481 00000 n
+0000013452 00000 n
+0000099522 00000 n
+0000000537 00000 n
+0000000560 00000 n
+0000013695 00000 n
+0000099435 00000 n
+0000000616 00000 n
+0000000641 00000 n
+0000016332 00000 n
+0000099348 00000 n
+0000000697 00000 n
+0000000732 00000 n
+0000016940 00000 n
+0000099274 00000 n
+0000000788 00000 n
+0000000817 00000 n
+0000017609 00000 n
+0000099148 00000 n
+0000000868 00000 n
+0000000901 00000 n
+0000017730 00000 n
+0000099074 00000 n
+0000000957 00000 n
+0000000980 00000 n
+0000017970 00000 n
+0000098987 00000 n
+0000001036 00000 n
+0000001066 00000 n
+0000020757 00000 n
+0000098900 00000 n
+0000001122 00000 n
+0000001149 00000 n
+0000021000 00000 n
+0000098813 00000 n
+0000001205 00000 n
+0000001234 00000 n
+0000021243 00000 n
+0000098726 00000 n
+0000001290 00000 n
+0000001314 00000 n
+0000021486 00000 n
+0000098639 00000 n
+0000001370 00000 n
+0000001397 00000 n
+0000021729 00000 n
+0000098552 00000 n
+0000001453 00000 n
+0000001481 00000 n
+0000021971 00000 n
+0000098465 00000 n
+0000001537 00000 n
+0000001563 00000 n
+0000022214 00000 n
+0000098378 00000 n
+0000001619 00000 n
+0000001646 00000 n
+0000025050 00000 n
+0000098291 00000 n
+0000001703 00000 n
+0000001727 00000 n
+0000025293 00000 n
+0000098204 00000 n
+0000001784 00000 n
+0000001812 00000 n
+0000025534 00000 n
+0000098117 00000 n
+0000001869 00000 n
+0000001896 00000 n
+0000025777 00000 n
+0000098030 00000 n
+0000001953 00000 n
+0000001982 00000 n
+0000026019 00000 n
+0000097941 00000 n
+0000002039 00000 n
+0000002066 00000 n
+0000026262 00000 n
+0000097850 00000 n
+0000002124 00000 n
+0000002161 00000 n
+0000030202 00000 n
+0000097772 00000 n
+0000002219 00000 n
+0000002264 00000 n
+0000030446 00000 n
+0000097657 00000 n
+0000002316 00000 n
+0000002350 00000 n
+0000030568 00000 n
+0000097578 00000 n
+0000002407 00000 n
+0000002443 00000 n
+0000030872 00000 n
+0000097485 00000 n
+0000002500 00000 n
+0000002530 00000 n
+0000031177 00000 n
+0000097392 00000 n
+0000002587 00000 n
+0000002620 00000 n
+0000033752 00000 n
+0000097299 00000 n
+0000002677 00000 n
+0000002706 00000 n
+0000033996 00000 n
+0000097220 00000 n
+0000002763 00000 n
+0000002796 00000 n
+0000003146 00000 n
+0000003388 00000 n
+0000002849 00000 n
+0000003265 00000 n
+0000096703 00000 n
+0000096358 00000 n
+0000003327 00000 n
+0000096187 00000 n
+0000096876 00000 n
+0000004865 00000 n
+0000005015 00000 n
+0000005166 00000 n
+0000005321 00000 n
+0000005482 00000 n
+0000005642 00000 n
+0000005803 00000 n
+0000005964 00000 n
+0000006124 00000 n
+0000006285 00000 n
+0000006446 00000 n
+0000006602 00000 n
+0000006763 00000 n
+0000006924 00000 n
+0000007084 00000 n
+0000007245 00000 n
+0000007406 00000 n
+0000007567 00000 n
+0000007728 00000 n
+0000007888 00000 n
+0000008049 00000 n
+0000008211 00000 n
+0000008373 00000 n
+0000008535 00000 n
+0000008697 00000 n
+0000008859 00000 n
+0000009021 00000 n
+0000009183 00000 n
+0000009339 00000 n
+0000009500 00000 n
+0000009660 00000 n
+0000009821 00000 n
+0000009982 00000 n
+0000010205 00000 n
+0000004470 00000 n
+0000003486 00000 n
+0000010143 00000 n
+0000096529 00000 n
+0000013938 00000 n
+0000012185 00000 n
+0000010316 00000 n
+0000012304 00000 n
+0000012425 00000 n
+0000012545 00000 n
+0000012664 00000 n
+0000012784 00000 n
+0000012845 00000 n
+0000012906 00000 n
+0000096016 00000 n
+0000013027 00000 n
+0000013088 00000 n
+0000013149 00000 n
+0000013270 00000 n
+0000013330 00000 n
+0000013391 00000 n
+0000013512 00000 n
+0000013573 00000 n
+0000013634 00000 n
+0000013755 00000 n
+0000013816 00000 n
+0000013877 00000 n
+0000018213 00000 n
+0000016151 00000 n
+0000014049 00000 n
+0000016270 00000 n
+0000016392 00000 n
+0000016453 00000 n
+0000016514 00000 n
+0000016575 00000 n
+0000016636 00000 n
+0000016696 00000 n
+0000016757 00000 n
+0000016818 00000 n
+0000016879 00000 n
+0000017000 00000 n
+0000017061 00000 n
+0000017122 00000 n
+0000017183 00000 n
+0000017244 00000 n
+0000017305 00000 n
+0000017366 00000 n
+0000017427 00000 n
+0000017487 00000 n
+0000017548 00000 n
+0000017669 00000 n
+0000017788 00000 n
+0000017849 00000 n
+0000017909 00000 n
+0000018030 00000 n
+0000018091 00000 n
+0000018152 00000 n
+0000022457 00000 n
+0000020576 00000 n
+0000018324 00000 n
+0000020695 00000 n
+0000020817 00000 n
+0000020878 00000 n
+0000020939 00000 n
+0000021060 00000 n
+0000021121 00000 n
+0000021182 00000 n
+0000021303 00000 n
+0000021364 00000 n
+0000021425 00000 n
+0000021546 00000 n
+0000021607 00000 n
+0000021668 00000 n
+0000021789 00000 n
+0000021850 00000 n
+0000021911 00000 n
+0000022031 00000 n
+0000022092 00000 n
+0000022153 00000 n
+0000022274 00000 n
+0000022335 00000 n
+0000022396 00000 n
+0000026506 00000 n
+0000024869 00000 n
+0000022568 00000 n
+0000024988 00000 n
+0000025110 00000 n
+0000025171 00000 n
+0000025232 00000 n
+0000025353 00000 n
+0000025413 00000 n
+0000025473 00000 n
+0000025594 00000 n
+0000025655 00000 n
+0000025716 00000 n
+0000025836 00000 n
+0000025897 00000 n
+0000025958 00000 n
+0000026079 00000 n
+0000026140 00000 n
+0000026201 00000 n
+0000026323 00000 n
+0000026384 00000 n
+0000026445 00000 n
+0000028997 00000 n
+0000031542 00000 n
+0000028878 00000 n
+0000026617 00000 n
+0000030140 00000 n
+0000030263 00000 n
+0000030324 00000 n
+0000030385 00000 n
+0000030507 00000 n
+0000030629 00000 n
+0000030690 00000 n
+0000030751 00000 n
+0000030811 00000 n
+0000030933 00000 n
+0000030994 00000 n
+0000031055 00000 n
+0000031116 00000 n
+0000031238 00000 n
+0000031299 00000 n
+0000031360 00000 n
+0000031421 00000 n
+0000031482 00000 n
+0000096993 00000 n
+0000029900 00000 n
+0000030035 00000 n
+0000030084 00000 n
+0000034239 00000 n
+0000033571 00000 n
+0000031681 00000 n
+0000033690 00000 n
+0000033813 00000 n
+0000033874 00000 n
+0000033935 00000 n
+0000034057 00000 n
+0000034117 00000 n
+0000034178 00000 n
+0000095655 00000 n
+0000034378 00000 n
+0000034741 00000 n
+0000035045 00000 n
+0000035368 00000 n
+0000035740 00000 n
+0000036215 00000 n
+0000050071 00000 n
+0000050475 00000 n
+0000061588 00000 n
+0000061965 00000 n
+0000069837 00000 n
+0000070221 00000 n
+0000078906 00000 n
+0000079180 00000 n
+0000095253 00000 n
+0000097078 00000 n
+0000097147 00000 n
+0000100146 00000 n
+0000100380 00000 n
+0000100563 00000 n
+0000100766 00000 n
+0000100960 00000 n
+0000101154 00000 n
+0000101353 00000 n
+0000101579 00000 n
+0000101804 00000 n
+0000102030 00000 n
+0000102250 00000 n
+0000102477 00000 n
+0000102711 00000 n
+0000102944 00000 n
+0000103178 00000 n
+0000103408 00000 n
+0000103634 00000 n
+0000103860 00000 n
+0000104070 00000 n
+0000104232 00000 n
+0000104428 00000 n
+0000104688 00000 n
+0000104953 00000 n
+0000105219 00000 n
+0000105480 00000 n
+0000105686 00000 n
+0000105804 00000 n
+0000105928 00000 n
+0000106044 00000 n
+0000106164 00000 n
+0000106257 00000 n
+0000106372 00000 n
+0000106410 00000 n
+0000106578 00000 n
+trailer
+<< /Size 369
+/Root 367 0 R
+/Info 368 0 R
+/ID [<57EE3A74C467C6A64C657804FD027B5E> <57EE3A74C467C6A64C657804FD027B5E>] >>
+startxref
+106898
+%%EOF
Modified: SwiftApps/Montage/docs/API.txt
--- SwiftApps/Montage/docs/API.txt	2011-06-15 01:00:37 UTC (rev 4616)
+++ SwiftApps/Montage/docs/API.txt	2011-06-15 01:47:31 UTC (rev 4617)
@@ -1,6 +1,12 @@
 Swift Montage API
+:toc:
+:icons:
+:numbered:
+Overview
 This is the API for the Swift Montage wrappers. Montage is a toolkit for
 generating science grade astronomical mosaics. The image file format for
 Montage is Flexible Image Transport System or FITS.
@@ -13,7 +19,6 @@
 NOTE: Both the Montage binaries as well as the Swift binaries must be included
 in your PATH environment variable for the wrappers to function properly.
-[[X1]]
 Swift Montage API
@@ -23,21 +28,24 @@
 These are all the Types that are declared for Swift. They are located in the
 file Swift_Montage_types.swift.
-.Image
+Image
 type Image;
 This is the Image type.  It is used to declare the raw images, projected
 images, difference images, rectified images, and the mosaic.
-.MosaicData
+Header
-type MosaicData;
+type Header;
-This is the MosaicData type. It is used to declare and map to the FITS header
+This is the Header type. It is used to declare and map to the FITS header
 file.
-.Table
+Table
 type Table;
@@ -45,13 +53,15 @@
 metadata is generated. These are tables that the Montage functions use to read
 for the next stage of the workflow.
+JPEG
 type JPEG
 This is the JPEG type. This is used to map to the jpeg version of the mosaic.
-.Status
+Status
 type Status;
@@ -59,7 +69,8 @@
 file are generated that have the information about the coefficients that will
 be used to rectify the image.
-.BackgroundStruct
+BackgroundStruct
 type BackgroundStruct
@@ -73,7 +84,8 @@
 three coefficients to rectify this portion of the mosaic of all floating point
 types.
-.DiffStruct
+DiffStruct
 type DiffStruct
@@ -96,9 +108,10 @@
 NOTE: Currently the options to the Montage functions are hard coded and the
 user cannot choose which options to run.
-.mAdd
+mAdd
-app ( Image mos ) mAdd( Image imgs[], Table img_tbl, MosaicData hdr )
+app ( Image mos ) mAdd( Image imgs[], Table img_tbl, Header hdr )
 This app procedure will call the mAdd fucntion from the Montage toolkit.  This
 procedure takes
@@ -107,7 +120,8 @@
 a single FITS file that represents the mosaic. All the images that will be
 part of this mosaic must reside in the same directory.
-.mBackground
+mBackground
 app ( Image bg_img ) mBackground( Image img, float a, float b, float c )
@@ -116,7 +130,8 @@
 three coefficients. The procedure then output the background rectified image
 after the coefficients have been applied.
-.mBgModel
+mBgModel
 app ( Table rect_tbl ) mBgModel( Table img_tbl, Table fits_tbl )
@@ -126,7 +141,8 @@
 fit them together. The procedure will then output a rectification table of the
 coefficients that must be applied to the images.
-.mConcatFit
+mConcatFit
 app ( Table fits_tbl ) mConcatFit( Table status_tbl, Status stats[] )
@@ -136,23 +152,26 @@
 input. The procedure will then output a table of all the status files
 together. The status files must all reside in the same directory.
-.mDiff
+mDiff
-app ( Image diff_img ) mDiff( Image proj_img_1, Image proj_img_2, MosaicData hdr )
+app ( Image diff_img ) mDiff( Image proj_img_1, Image proj_img_2, Header hdr )
 This app procedure will call the mDiff function from the Montage toolkit. This
 procedure takes in two images and the FITS header file for the mosaic. The procedure will then output a
 difference image representing the information of where the two images overlap.
-.mDiffFit
+mDiffFit
-app ( Image diff_img, Status stat ) mDiffFit( Image img_1, Image img_2, MosaicData hdr )
+app ( Image diff_img, Status stat ) mDiffFit( Image img_1, Image img_2, Header hdr )
 This app procedure will call the mDiffFit function from the Montage
 toolkit. The mDiffFit function in Montage is the combination of the mDiff and
 mFitplane functions.
-.mFitplane
+mFitplane
 app ( Status stat ) mFitplane( Image diff_img )
@@ -161,7 +180,8 @@
 the mDiff procedure. The procedure will then output a status file that
 contains the information on how to fit these two images together.
-.mImgtbl
+mImgtbl
 app ( Table img_tbl ) mImgtbl( Image imgs[] )
@@ -170,16 +190,18 @@
 from. The output is an image table that represents these images. All the
 images that will be part of this table must reside in the same directory.
-.mMakeHdr
+mMakeHdr
-app ( MosaicData hdr ) mMakeHdr( Table img_tbl )
+app ( Header hdr ) mMakeHdr( Table img_tbl )
 This app procedure will call the mMakeHdr function from the Montage
 toolkit. This procedure will take in as input an image table representing the
 images that will be combined into a single mosaic. The procedure will then output the
-.mJPEG
+mJPEG
 app ( JPEG mos_img_jpg ) mJPEG( Image mos_img )
@@ -187,7 +209,8 @@
 procedure will take in as input as input a FITS image. The procedure will
 then ouput the same image in jpeg format.
-.mOverlaps
+mOverlaps
 app ( Table diff_tbl ) mOverlaps( Table img_tbl )
@@ -196,10 +219,23 @@
 will be combined into a single mosaic. The procedure will then output a table
 of all the images that overlap with each other in the mosaic.
-.mProjectPP
+mProject
-app ( Image proj_img ) mProjectPP( Image raw_img, MosaicData hdr )
+app ( Image proj_img ) mProject( Image raw_img, Header hdr )
+This app procedure will call the mProject function from the Montage
+toolkit. This procedure takes in as input a FITS image file and the FITS header file
+that for the mosaic. The output is the projected image.
+NOTE: The mProject app procedure is for general projection. There are some cases in
+which the faster mProjectPP procedure should be used.
+mProjectPP
+app ( Image proj_img ) mProjectPP( Image raw_img, Header hdr )
 This app procedure will call the mProjectPP function from the Montage
@@ -209,18 +245,9 @@
 projections (e.g. TAN, SIN) or where they can be approximated with acceptable
 error.
-.mProject
-app ( Image proj_img ) mProject( Image raw_img, MosaicData hdr )
-This app procedure will call the mProject function from the Montage
-toolkit. This procedure takes in as input a FITS image file and the FITS header file
-that for the mosaic. The output is the projected image.
-NOTE: The mProject app procedure is for general projection. There are some cases in
-which the faster mProjectPP procedure should be used.
-.mShrink
+mShrink
 app ( Image shrunk ) mShrink( Image original, int factor )
@@ -228,7 +255,8 @@
 procedure takes in as input a single image and an re-sizing factor represented
 as an integer. The procedure will then output the re-sized image.
-.Backgound_list
+Backgound_list
 app ( Table back_tbl ) Background_list( Table imgs_tbl, Table rect_tbl )
@@ -239,7 +267,8 @@
 format that can be read in by the Swift readData2 function into the
 Background_struct declared type.
-.create_status_table
+create_status_table
 app ( Table stat_tbl ) create_status_table( Table diff_tbl )
@@ -255,9 +284,11 @@
 and is where the parallelization is taking place. They are located in the file
 Swift_Montage_Batch.swift
-.mBackgroundBatch
+mBackgroundBatch
-( Image rect_imgs[] ) mBackgroundBatch( string dest_dir, Image proj_imgs[], Table img_tbl, Table rect_tbl )
+( Image rect_imgs[] ) mBackgroundBatch( string dest, Image imgs[], Table img_tbl,
+                                        Table rect_tbl )
 This batch swift script takes in as input a destination directory for the
 rectified images, a list of images that will be combined into a
@@ -268,9 +299,11 @@
 NOTE: mBackgroundBatch calls the mBackground app procedure.
-.mDiffBatch
+mDiffBatch
-( Image diff_imgs[] ) mDiffBatch( string src_dir, string dest_dir, string files[], Table diff_tbl, MosaicData hdr )
+( Image diff_imgs[] ) mDiffBatch( string src, string dest, string filenames[],
+                                  Table diff_tbl, Header hdr )
 This batch script takes in as input a source directory of where the images to calculate
 overlaps are located, a destination directory of where to store these
@@ -284,10 +317,12 @@
 NOTE: mDiffBatch calls the mDiff app procedure.
-.mDiffFitBatch
+mDiffFitBatch
-( Image diff_imgs[], Table fits_tbl ) mDiffFitBatch( string src_dir, string dest_dir, string stat_dir,
-                                                     string files[], Table diff_tbl, MosaicData hdr )
+( Image diff_imgs[], Table fits_tbl ) mDiffFitBatch( string src, string dest, string stat,
+                                                     string filenames[],
 calculate overlaps are located, a destination directory of where to store
@@ -303,9 +338,10 @@
 NOTE: mDiffFitBatch calls the mDiffFit app procedure.
-.mFitBatch
+mFitBatch
-( Table fits_tbl ) mFitBatch( string stat_dir, Image diff_imgs[], Table diff_tbl )
+( Table fits_tbl ) mFitBatch( string stat, Image diff_imgs[], Table diff_tbl )
 This batch script takes in as input a directory for which the status files
 will be put in, the list of difference images that has
@@ -315,9 +351,10 @@
 NOTE: mFitBatch calls the mFitplane app procedure.
-.mProjectBatch
+mProjectBatch
-( Image proj_imgs[] ) mProjectBatch( string dest_dir, Image raw_imgs[], MosaicData hdr )
+( Image proj_imgs[] ) mProjectBatch( string dest, Image raw_imgs[], Header hdr )
 This batch script takes in as input the destination directory for the
 projected images, a list of raw image files and the FITS header file
@@ -325,5 +362,5 @@
 if it is possible to use the fast image projetion algorithm or to just use
 standard projection.
-NOTE: mProjectBatch calls the faster mProjectPP app procedure if the image allows
-it. If mProjectPP cannot be used then the app procedure mProject is called.
+WARNING: mProjectBatch currently only calls the general mProject app
+procedure. It does not check to see if the faster projection mProjectPP can be used.
Modified: SwiftApps/Montage/docs/updateAPI.sh
--- SwiftApps/Montage/docs/updateAPI.sh	2011-06-15 01:00:37 UTC (rev 4616)
+++ SwiftApps/Montage/docs/updateAPI.sh	2011-06-15 01:47:31 UTC (rev 4617)
@@ -1,2 +1,5 @@
 #!/bin/bash
-asciidoc -a toc -a max-width=1100px -a icons API.txt
+echo "Generating Swift_Montage API html file"
+asciidoc -a toc -a toclevels=3 -a numbered -a max-width=750px -a icons API.txt
+echo "Generating Swift_Montage API pdf file"
+a2x --format=pdf --icons --no-xmllint --dblatex-opts "-P doc.publisher.show=0 -P latex.output.revhistory=0" API.txt
