[Swift-commit] r4720 - trunk/docs/userguide
jonmon at ci.uchicago.edu
Thu Jun 30 19:01:43 CDT 2011
Author: jonmon
Date: 2011-06-30 19:01:43 -0500 (Thu, 30 Jun 2011)
New Revision: 4720
Modified:
trunk/docs/userguide/app_procedures
Log:
o updated docs: renamed readData2 to readStructured
Modified: trunk/docs/userguide/app_procedures
--- trunk/docs/userguide/app_procedures 2011-06-30 23:59:17 UTC (rev 4719)
+++ trunk/docs/userguide/app_procedures 2011-07-01 00:01:43 UTC (rev 4720)
@@ -18,14 +18,14 @@
In this section, this example SwiftScript program is used for reference:
-type file;
-app (file o) count(file i) {
- wc @i stdout=@o;
-file q <"input.txt">;
-file r <"output.txt">;
+type file;
+app (file o) count(file i) {
+ wc @i stdout=@o;
+file q <"input.txt">;
+file r <"output.txt">;
The executable for wc will be looked up in tc.data.
@@ -278,9 +278,9 @@
For example:
-trace(@arg("myparam"));
-trace(@arg("optionalparam", "defaultvalue"));
+trace(@arg("myparam"));
+trace(@arg("optionalparam", "defaultvalue"));
$ swift arg.swift -myparam=hello
@@ -289,7 +289,7 @@
RunID: 20080220-1548-ylc4pmda
SwiftScript trace: defaultvalue
SwiftScript trace: hello
@extractint
@@ -319,7 +319,7 @@
For example:
-string v = @regexp("abcdefghi", "c(def)g","monkey");
+string v = @regexp("abcdefghi", "c(def)g","monkey");
will assign the value "abmonkeyhi" to the variable v.
@@ -341,12 +341,12 @@
For example:
-string t = "my name is John and i like puppies.";
-string name = @strcut(t, "my name is ([^ ]*) ");
-string out = @strcat("Your name is ",name);
+string t = "my name is John and i like puppies.";
+string name = @strcut(t, "my name is ([^ ]*) ");
+string out = @strcat("Your name is ",name);
trace(out);
will output the message: Your name is John.
@strsplit
@@ -357,12 +357,12 @@
Example:
-string words[] = @strsplit(t, "\\s");
-foreach word in words {
- trace(word);
+string words[] = @strsplit(t, "\\s");
+foreach word in words {
+ trace(word);
will output one word of the sentence on each line (though not
necessarily in order, due to the fact that foreach iterations execute in
@@ -415,9 +415,9 @@
the same order as the header row and separated by whitespace. (since
Swift 0.4)
-readData2
-readData2 will read data from a specified file, like readdata, but
+readStructured
+readStructured will read data from a specified file, like readdata, but
using a different file format more closely related to that used by the
ext mapper.
@@ -425,32 +425,32 @@
and the value for that position in the structure:
-rows[0].columns[0] = 0
-rows[0].columns[1] = 2
-rows[0].columns[2] = 4
-rows[1].columns[0] = 1
-rows[1].columns[1] = 3
+rows[0].columns[0] = 0
+rows[0].columns[1] = 2
+rows[0].columns[2] = 4
+rows[1].columns[0] = 1
+rows[1].columns[1] = 3
rows[1].columns[2] = 5
which can be read into a structure defined like this:
-type vector {
- int columns[];
-type matrix {
- vector rows[];
-matrix m;
-m = readData2("readData2.in");
+type vector {
+ int columns[];
-(since Swift 0.7)
+type matrix {
+ vector rows[];
+matrix m;
+m = readStructured("readStructured.in");
+(since Swift 0.7, was readData2(deprecated))
trace
trace will log its parameters. By default these will appear on both
More information about the Swift-commit
