[Swift-commit] r4711 - in SwiftApps/GOSwift: . pykoa pykoa/tools sbin
jonmon at ci.uchicago.edu jonmon at ci.uchicago.edu
Wed Jun 29 13:20:06 CDT 2011
Author: jonmon
Date: 2011-06-29 13:20:06 -0500 (Wed, 29 Jun 2011)
New Revision: 4711
Added:
   SwiftApps/GOSwift/pykoa/
   SwiftApps/GOSwift/pykoa/tools/
   SwiftApps/GOSwift/pykoa/tools/koa_goswift.py
   SwiftApps/GOSwift/sbin/
   SwiftApps/GOSwift/sbin/remote-cli.py
Log:
o backing up files for goswift
Added: SwiftApps/GOSwift/pykoa/tools/koa_goswift.py
--- SwiftApps/GOSwift/pykoa/tools/koa_goswift.py	                        (rev 0)
+++ SwiftApps/GOSwift/pykoa/tools/koa_goswift.py	2011-06-29 18:20:06 UTC (rev 4711)
@@ -0,0 +1,43 @@
+#!/usr/bin/python
+import os
+import sys
+import uuid
+import datetime
+import readline
+import time
+import signal
+from optparse import OptionGroup
+from sqlalchemy.sql import text
+import pykoa
+import pykoa.tools
+from pykoa.constants import GroupStatusCodes as grpc
+from pykoa.consumers import guc_util
+from pykoa.koaexception import ToolsException, cli_exception_handler
+from pykoa.tools.url_parse import SCPUrl
+from pykoa.tools.koa_ep_activate import check_explicit_activate
+from pykoa.tools import koa_cancel
+from pykoa.tools import koa_transfer
+from pykoa.tools import myproxy
+from pykoa.tools import koa_wait
+from pykoa.data import groups_dao
+from pykoa.data import endpoint_dao
+from pykoa.data import creds_dao
+from pykoa.data import preflight_dao
+ at cli_exception_handler
+def main( argv=sys.argv[1:] ):
+    guc_util.init_guc_env()
+    conn     = pykoa.connect()
+    user_row = pykoa.tools.cli_get_user( conn )
+    user_id  = user_row.id
+    sys.stdout.write( "Executing Swift on: " + argv[0] + "\n" )
+    return 0
+if __name__ == "__main__":
+    rc = main()
+    sys.exit(rc)
Property changes on: SwiftApps/GOSwift/pykoa/tools/koa_goswift.py
___________________________________________________________________
Added: svn:executable
Added: SwiftApps/GOSwift/sbin/remote-cli.py
--- SwiftApps/GOSwift/sbin/remote-cli.py	                        (rev 0)
+++ SwiftApps/GOSwift/sbin/remote-cli.py	2011-06-29 18:20:06 UTC (rev 4711)
@@ -0,0 +1,542 @@
+#!/usr/bin/python -u
+import readline
+import shlex
+import os
+import sys
+import subprocess
+import signal
+import setproctitle
+[gsi]ssh commands all run this program.  We get the original command from
+SSH_ORIGINAL_COMMAND
+XXX: We are losing quotes, or at least token separators using
+SSH_ORIGINAL_COMMAND.  We should patch sshd to url encode the arguments so
+spaces are included.
+Note: Do not import any pykoa modules.  Those will stay cached and
+could cause problems if you change them on a running instance.
+# XXX: Use /usr/local/koa symlink
+g_base_dir = '/home/koa/live_version'
+shell_aliases = {}
+shell_aliases['exit'] = "exit"
+shell_aliases['quit'] = "exit"
+shell_aliases['?'] = "help"
+shell_aliases['h'] = "help"
+HELP_BANNER = """\
+Type '<command> -h' for basic help on a command.
+Type 'man <command>' for detailed help.
+Task Management:        cancel              modify
+                        details             status
+                        events              wait
+Task Creation:          scp                 transfer
+Endpoint Management:    endpoint-add        endpoint-modify
+                        endpoint-activate   endpoint-remove
+                        endpoint-deactivate endpoint-rename
+                        endpoint-list       diagnose (beta)
+Other:                  help                profile (deprecated)
+                        history             reset
+                        ls                  versions
+                        man
+prog_map = {}
+# Builtins and other scripts
+prog_map['help'] = ""
+prog_map['versions'] = ""
+prog_map['history'] = ""
+prog_map['reset'] = "%s/bin/koa-reset" % g_base_dir
+# Note: This block generated by ../pykoa/tools/script_map.py
+prog_map['cancel'] = 'pykoa.tools.koa_cancel'
+prog_map['details'] = 'pykoa.tools.koa_details'
+prog_map['diagnose'] = 'pykoa.tools.koa_diagnose'
+prog_map['endpoint-activate'] = 'pykoa.tools.koa_ep_activate'
+prog_map['endpoint-add'] = 'pykoa.tools.koa_ep_add'
+prog_map['endpoint-deactivate'] = 'pykoa.tools.koa_ep_deactivate'
+prog_map['endpoint-list'] = 'pykoa.tools.koa_ep_list'
+prog_map['endpoint-modify'] = 'pykoa.tools.koa_ep_modify'
+prog_map['endpoint-remove'] = 'pykoa.tools.koa_ep_remove'
+prog_map['endpoint-rename'] = 'pykoa.tools.koa_ep_rename'
+prog_map['events'] = 'pykoa.tools.koa_events'
+prog_map['goswift'] = 'pykoa.tools.koa_goswift'
+prog_map['ls'] = 'pykoa.tools.koa_ls'
+prog_map['man'] = 'pykoa.tools.koa_man'
+prog_map['modify'] = 'pykoa.tools.koa_modify'
+prog_map['profile'] = 'pykoa.tools.koa_profile'
+prog_map['report'] = 'pykoa.tools.koa_report'
+prog_map['scp'] = 'pykoa.tools.koa_scp'
+prog_map['status'] = 'pykoa.tools.koa_status'
+prog_map['transfer'] = 'pykoa.tools.koa_transfer'
+prog_map['wait'] = 'pykoa.tools.koa_wait'
+g_version_set = False
+g_manpages = None
+g_sig_save = None
+g_preloaded = False
+g_user = ""
+HELP_COMMANDS = [x for x in prog_map.keys() if x != "report"]
+def get_man_pages():
+    # Lazy loading
+    global g_manpages
+    if g_manpages:
+        return g_manpages
+    g_manpages = os.listdir(g_base_dir + "/man")
+    g_manpages = [x.replace(".1", "") for x in g_manpages if x.endswith(".1")]
+    return g_manpages
+def preload_modules():
+    # Note: For extra safety, we do not preload pykoa modules.
+    # We don't want to change these on production and have to
+    # boot people off the CLI for changes to be applied.
+    global g_preloaded
+    if g_preloaded:
+        return
+    import uuid, re, ctypes, logging
+    import gettext, locale, optparse
+    import sqlalchemy.sql
+    import sqlalchemy.exc
+    import sqlalchemy.dialects.postgresql
+    import psycopg2
+    g_preloaded = True
+def setup_child(short_name, args):
+    # Use separate logs rather than the remote cli log.
+    #import pykoa
+    #pykoa.config.configure_logging(short_name)
+    # Set proper title for ps instead of 'remote-cli.py'
+    if args:
+        title = "[%s %s]" % (short_name, " ".join(args))
+    else:
+        title = "[%s]" % short_name
+    setproctitle.setproctitle(title)
+def completer(text, state):
+    cmds = HELP_COMMANDS[:]
+    # Auto complete man command
+    if text.startswith("man"):
+        cmds += ["man " + x for x in get_man_pages()]
+    if text.startswith("help"):
+        cmds += ["help " + x for x in HELP_COMMANDS]
+    options = [x for x in cmds if x.startswith(text)]
+    try:
+        return options[state]
+    except IndexError:
+        return None
+# Note: only called for shell mode
+def line_translate(line):
+    line = line.strip()
+    cmd = shell_aliases.get(line)
+    if not cmd:
+        cmd = line
+    return cmd
+def do_version(args):
+    if "-v" in args:
+        # verbose
+        print "SVN Version:", \
+            os.popen("svnversion " + g_base_dir).readline().strip()
+        return 0
+    if args:
+        print """\
+Usage: versions [-v]
+Display versions of services supported by the server.
+Type 'man versions' for details. \
+        if "-h" in args or "--help" in args:
+            return 0
+        else:
+            return 2
+    print "transfer/1.2"
+    print "transfer/1.1"
+    print "transfer/1.0"
+    return 0
+def shell():
+    Read commands from user and execute them
+    # Read history
+    readline.set_history_length(1000)
+    load_history()
+    readline.set_completer(completer)
+    readline.parse_and_bind("tab: complete")
+    # For some reason, - is in the default delims.
+    # Reset it to default bash delimiters.
+    readline.set_completer_delims("\t\n\"\\'`@$><=;|&{(")
+    print "Welcome to globusonline.org, %s.  Type 'help' for help." % (
+            g_user)
+    while True:
+        try:
+            line = raw_input("$ ")
+            # readline automatically adds lines to the history buffer
+            line = line_translate(line)
+            if line == "exit":
+                break
+            args = do_split(line)
+            if args is not None:
+                handle_cmd(args)
+        except KeyboardInterrupt:
+            sys.stdout.write("\n")
+        except EOFError:
+            break
+    save_history()
+def connect_to_db():
+    import psycopg2
+    from ConfigParser import SafeConfigParser
+    s = SafeConfigParser()
+    s.read("/etc/koa/koa.ini")
+    host = s.get("db", "dbhost")
+    conn =  psycopg2.connect(database='koa', host=host, user='cliuser',
+            password='cliuser')
+    conn.set_isolation_level(0) # Autocommit
+    return conn
+def load_history():
+    Load history from db.
+    If a user row doesn't exist, add a row so the save function can just assume
+    an UPDATE will work.  (Postgres doesn't support MERGE yet)
+    conn = connect_to_db()
+    cur = conn.cursor()
+    cur.execute("select history from user_history where name = %s",
+            (g_user,))
+    ret = cur.fetchone()
+    if ret:
+        # Could have a null history, if they logged in and died
+        if ret[0]:
+            for cmd in ret[0].rstrip().split('\n'):
+                readline.add_history(cmd)
+    else:
+        cur.execute("insert into user_history (name) values (%s)",
+                (g_user,))
+    cur.close()
+    conn.close()
+def save_history():
+    Save history to database.
+    We just make a text blob, lines with '\n' endings
+    n = readline.get_current_history_length()
+    buf = ""
+    for i in range(0, n):
+        cmd = readline.get_history_item(i + 1)
+        if cmd.strip():
+            buf += cmd + "\n"
+    cur.execute("update user_history set history = %s where name = %s",
+            (buf, g_user))
+    cur.close()
+    conn.close()
+def restore_signals():
+    # We don't want to inherit an ignored SIGINT mask, at least
+    # for xfer and scp commands that the user may want to cancel.
+    signal.signal(signal.SIGINT, g_sig_save)
+def do_variable_set(v):
+    key, value = v.split("=", 1)
+    if key == "v":
+        return do_set_version(value)
+    else:
+        sys.stderr.write("Unknown variable '%s'\n" % key)
+        return False
+def do_set_version(value):
+    global g_version_set
+    if ":" not in value:
+        sys.stderr.write("Please specify your user agent string when " +
+            "requesting a version.\n")
+        sys.stderr.write("Example: v=1.0:MyProgram/3.1 <command>\n")
+        return False
+    try:
+        version, user_agent = value.split(":")
+    except:
+        sys.stderr.write("Invalid user agent string\n")
+        return False
+    if len(user_agent) < 6:
+        sys.stderr.write("User agent string too short\n")
+        return False
+    service = 'transfer'
+    if '/' in version:
+        try:
+            service, version = version.split("/")
+        except:
+            sys.stderr.write("Invalid version string\n")
+            return False
+    if service != 'transfer':
+        sys.stderr.write("Unknown service '%s'\n" % service)
+        return False
+    if version == "1.0":
+        g_version_set = True
+        return True
+    if version in ("1.1", "1.2"):
+        # The existence of this variable is checked, value can be anything
+        os.environ["KOA_API_11"] = "TRUE"
+        return True
+    sys.stderr.write("This service does not support '%s/%s'\n" % (
+        service, version))
+    return False
+def do_help(args):
+    if args:
+        print """\
+Usage: help [command]
+With no arguments, display available commands.  Help 'command' is equivalent
+to calling 'command -h'. \
+            return 0
+        else:
+            return 2
+    print HELP_BANNER
+    return 0
+def do_split(s):
+    Split @s into parts, using 'quotes' and \ escaping.
+    On error, display error to stderr and return None.
+    Save original command (with quotes) to KOA_COMMAND.
+    try:
+        os.environ['KOA_COMMAND'] = s
+        ret = shlex.split(s)
+        return ret
+    except ValueError, e:
+        sys.stderr.write("Error: %s\n" % e)
+        return None
+def do_history(args):
+    end = readline.get_current_history_length()
+    start = 0
+    usage = """\
+Usage: history [N]
+Display commands used in current and previous sessions.
+If N is given, display only the most recent N commands.\
+    if args:
+            print usage
+            return 0
+        elif not args[0].startswith("-"):
+            try:
+                limit = int(args[0])
+                start = end - limit
+            except ValueError:
+                sys.stderr.write("Invalid number '%s'\n" % args[0])
+                print usage
+                return 2
+        else:
+            print usage
+            return 2
+    for i in range(start, end):
+        print " %-6d %s" % (i + 1, cmd)
+def log_timing(cmd):
+    if False:
+        import time
+        print "%.03f %s" % (time.time(), cmd)
+def _run_command(args):
+    Fork and exec/import module
+    cmd = args[0]
+    args = args[1:]
+    is_module = False
+    if cmd.startswith("pykoa.tools"):
+        # Make sure interactive and noninteractive have the
+        # same code paths
+        preload_modules()
+        is_module = True
+    pid = os.fork()
+    if pid == 0:
+        restore_signals()
+        if not is_module:
+            # Exec
+            args = [os.path.basename(cmd)] + args
+            os.execv(cmd, args)
+        else:
+            short_name = cmd.split(".")[-1]
+            log_timing('setup-child')
+            setup_child(short_name, args)
+            log_timing('import')
+            #old_modules = sys.modules.keys()[:]
+            mod = __import__(cmd, globals(), locals(), ['main'])
+            #for m in sys.modules.keys():
+                #if m not in old_modules:
+                    #print "new: %s" % m
+            log_timing('run')
+            rc = mod.main(args)
+            log_timing('done')
+            sys.exit(rc)
+    else:
+        rc = os.waitpid(pid, 0)[1]
+        rc = os.WEXITSTATUS(rc)
+        return rc
+def run_command(args):
+    Run command and return rc code
+    # Disable sigint to ourself while cmd is running
+    # Readline puts in a signal handler.  Save it.
+    global g_sig_save
+    g_sig_save = signal.getsignal(signal.SIGINT)
+    signal.signal(signal.SIGINT, signal.SIG_IGN)
+    rc = _run_command(args)
+    return rc
+def handle_cmd(args):
+    Run command and return exit code
+    if not args:
+        return 1
+    if args and args[0].startswith("v="):
+        sys.stderr.write("Error: Version may only be set " + \
+                "when starting a shell\n")
+        return 1
+    # help cmd = alias for cmd -h
+    progname = args[0]
+    if progname == "help" and len(args) == 2:
+        progname = args[1]
+        args[1:] = ["-h"]
+    if progname == "help":
+        return do_help(args[1:])
+    elif progname == "versions":
+        return do_version(args[1:])
+    elif progname == "history":
+        return do_history(args[1:])
+    else:
+        prog = prog_map.get(progname)
+        if not prog:
+            msg = "Command '%s' not found.  Type 'help' for help.\n"
+            sys.stderr.write(msg % progname)
+            return 1
+        fire = [prog] + args[1:]
+        return run_command(fire)
+def main():
+    global g_user
+    # Down for maintenance?
+    FLAG_FILE = "/tmp/koa-down"
+    if os.path.exists(FLAG_FILE):
+        for l in open(FLAG_FILE):
+            sys.stderr.write(l)
+        return 1
+    # We are running as a user account via ssh/gsissh. Set our user name.
+    # We could do os.getuid() and pwd.getpwuid(), but ssh sets USER for us
+    # so that's more efficient.
+    g_user = os.environ['KOA_USER'] = os.environ['USER']
+    os.environ['KOA_HOME'] = g_base_dir
+    os.environ['PYTHONPATH'] = g_base_dir
+    sys.path.append(g_base_dir)
+    os.environ['PATH'] = '/usr/local/globus/bin:/usr/local/globus/sbin:' + \
+    os.environ['GLOBUS_LOCATION'] = '/usr/local/globus'
+    os.environ['LD_LIBRARY_PATH'] = '/usr/local/globus/lib'
+    cmd = os.environ.get('SSH_ORIGINAL_COMMAND', '')
+    cmd = cmd.strip()
+    # Attempt parse
+    args = do_split(cmd)
+    if args is None:
+        return 1
+    # Check variable setting
+    if args and "=" in args[0]:
+        if not do_variable_set(args[0]):
+            return 1
+        args = args[1:]
+    # Set default version level
+    if not g_version_set:
+    if not args:
+        setproctitle.setproctitle("[cli shell]")
+        preload_modules()
+        shell()
+        rc = 0
+    else:
+        setproctitle.setproctitle("[cli run]")
+        rc = handle_cmd(args)
+    return rc
+    rc = main()
+    sys.exit(rc)
Property changes on: SwiftApps/GOSwift/sbin/remote-cli.py
