[Swift-commit] r4696 - in trunk/src/org/griphyn/vdl: karajan/lib/swiftscript type
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Mon Jun 27 12:31:01 CDT 2011
Author: hategan
Date: 2011-06-27 12:31:01 -0500 (Mon, 27 Jun 2011)
New Revision: 4696
Modified:
   trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/WriteData.java
   trunk/src/org/griphyn/vdl/type/Type.java
Log:
fixed bug where writeData does not unwrap handles before printing to output stream
Modified: trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/WriteData.java
--- trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/WriteData.java	2011-06-27 15:33:59 UTC (rev 4695)
+++ trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/WriteData.java	2011-06-27 17:31:01 UTC (rev 4696)
@@ -4,15 +4,10 @@
 import java.io.File;
 import java.io.FileWriter;
 import java.io.IOException;
-import java.util.Arrays;
-import java.util.HashSet;
-import java.util.Set;
-import java.util.List;
-import java.util.Map;
-import java.util.TreeMap;
-import java.util.Collection;
 import java.util.Comparator;
 import java.util.Iterator;
+import java.util.Map;
+import java.util.TreeMap;
 import org.apache.log4j.Logger;
 import org.globus.cog.karajan.arguments.Arg;
@@ -118,12 +113,11 @@
 	private void writePrimitiveArray(BufferedWriter br, DSHandle src) throws IOException,
 			ExecutionException {
-		Map m = ((AbstractDataNode) src).getArrayValue();
-		Map c = new TreeMap(new ArrayIndexComparator());
+		Map<String, DSHandle> m = ((AbstractDataNode) src).getArrayValue();
+		Map<String, DSHandle> c = new TreeMap<String, DSHandle>(new ArrayIndexComparator());
 		c.putAll(m);
-		Iterator i = c.values().iterator();
-		while(i.hasNext()) {
-			br.write(((DSHandle)i.next()).toString());
+		for (DSHandle h : c.values()) {
+			br.write(h.getValue().toString());
 			br.newLine();
@@ -131,34 +125,29 @@
 	private void writeStructArray(BufferedWriter br, DSHandle src) throws IOException,
 		writeStructHeader(src.getType().itemType(), br);
 		c.putAll(m);
-			writeStruct(br, (DSHandle)i.next());
+			writeStruct(br, h);
 	private void writeStructHeader(Type type, BufferedWriter br) throws ExecutionException,
 			IOException {
-		List l = type.getFieldNames();
-		Iterator i = l.iterator();
-			br.write(i.next().toString());
+		for (String name : type.getFieldNames()) {
+			br.write(name);
 			br.write(" ");
 		br.newLine();
 	private void writeStruct(BufferedWriter br, DSHandle struct) throws IOException, ExecutionException {
-		List l = struct.getType().getFieldNames();
 		try {
-				DSHandle child = struct.getField(Path.EMPTY_PATH.addLast((String)i.next()));
-				br.write(child.toString());
+		    for (String name : struct.getType().getFieldNames()) {
+				DSHandle child = struct.getField(Path.EMPTY_PATH.addLast(name));
+				br.write(child.getValue().toString());
 				br.write(" ");
 			br.newLine();
@@ -167,10 +156,10 @@
-	class ArrayIndexComparator implements Comparator {
-		public int compare(Object o1, Object o2) {
-			int i1 = Integer.parseInt((String)o1);
-			int i2 = Integer.parseInt((String)o2);
+	class ArrayIndexComparator implements Comparator<String> {
+		public int compare(String o1, String o2) {
+			int i1 = Integer.parseInt(o1);
+			int i2 = Integer.parseInt(o2);
 			if(i1 < i2) return -1;
 			if(i1 > i2) return 1;
 			return 0;
Modified: trunk/src/org/griphyn/vdl/type/Type.java
--- trunk/src/org/griphyn/vdl/type/Type.java	2011-06-27 15:33:59 UTC (rev 4695)
+++ trunk/src/org/griphyn/vdl/type/Type.java	2011-06-27 17:31:01 UTC (rev 4696)
@@ -101,7 +101,7 @@
 	 * @return a list of strings
-	public List getFieldNames();
+	public List<String> getFieldNames();
 	 * get all the fields in this type
