[Swift-commit] r4630 - trunk/tests/documentation
    achavez at ci.uchicago.edu
    Fri Jun 17 15:23:23 CDT 2011
Author: achavez
Date: 2011-06-17 15:23:23 -0500 (Fri, 17 Jun 2011)
New Revision: 4630
Added:
   trunk/tests/documentation/4-6-2_fixed_array_mapper.setup.sh
   trunk/tests/documentation/one.txt
   trunk/tests/documentation/sites.template.xml
   trunk/tests/documentation/swift.properties
   trunk/tests/documentation/three.txt
   trunk/tests/documentation/two.txt
Log:
Added Missing Files.
Added: trunk/tests/documentation/4-6-2_fixed_array_mapper.setup.sh
--- trunk/tests/documentation/4-6-2_fixed_array_mapper.setup.sh	                        (rev 0)
+++ trunk/tests/documentation/4-6-2_fixed_array_mapper.setup.sh	2011-06-17 20:23:23 UTC (rev 4630)
@@ -0,0 +1,4 @@
+#!/bin/bash
+set -x
+cp -v $GROUP/one.txt $GROUP/two.txt $GROUP/three.txt .|| exit 1
+exit 0
Property changes on: trunk/tests/documentation/4-6-2_fixed_array_mapper.setup.sh
___________________________________________________________________
Added: svn:executable
Added: trunk/tests/documentation/one.txt
--- trunk/tests/documentation/one.txt	                        (rev 0)
+++ trunk/tests/documentation/one.txt	2011-06-17 20:23:23 UTC (rev 4630)
@@ -0,0 +1 @@
+this is one.txt
Added: trunk/tests/documentation/sites.template.xml
--- trunk/tests/documentation/sites.template.xml	                        (rev 0)
+++ trunk/tests/documentation/sites.template.xml	2011-06-17 20:23:23 UTC (rev 4630)
@@ -0,0 +1,15 @@
+<config>
+  <pool handle="localhost">
+    <filesystem provider="local" />
+    <execution provider="coaster" jobmanager="local:local"/>
+    <profile namespace="globus"   key="internalHostname">127.0.0.1</profile>
+    <profile namespace="karajan"  key="jobthrottle">1000</profile>
+    <profile namespace="karajan"  key="initialScore">10000</profile>
+    <profile namespace="globus"   key="jobsPerNode">4</profile>
+    <profile namespace="globus"   key="slots">8</profile>
+    <profile namespace="globus"   key="maxTime">1000</profile>
+    <profile namespace="globus"   key="nodeGranularity">1</profile>
+    <profile namespace="globus"   key="maxNodes">4</profile>
+    <workdirectory>/tmp</workdirectory>
+  </pool>
+</config>
Added: trunk/tests/documentation/swift.properties
--- trunk/tests/documentation/swift.properties	                        (rev 0)
+++ trunk/tests/documentation/swift.properties	2011-06-17 20:23:23 UTC (rev 4630)
@@ -0,0 +1,7 @@
+wrapperlog.always.transfer=true
+sitedir.keep=true
+execution.retries=0
+lazy.errors=false
+status.mode=provider
+use.provider.staging=false
+provider.staging.pin.swiftfiles=false
Added: trunk/tests/documentation/three.txt
--- trunk/tests/documentation/three.txt	                        (rev 0)
+++ trunk/tests/documentation/three.txt	2011-06-17 20:23:23 UTC (rev 4630)
@@ -0,0 +1 @@
+three
Added: trunk/tests/documentation/two.txt
--- trunk/tests/documentation/two.txt	                        (rev 0)
+++ trunk/tests/documentation/two.txt	2011-06-17 20:23:23 UTC (rev 4630)
@@ -0,0 +1 @@
+a second file
More information about the Swift-commit
