[Swift-commit] r4622 - trunk/tests
    achavez at ci.uchicago.edu
    Thu Jun 16 11:52:07 CDT 2011
Author: achavez
Date: 2011-06-16 11:52:07 -0500 (Thu, 16 Jun 2011)
New Revision: 4622
Added:
   trunk/tests/README.txt
Log:
Fixed a typo
Added: trunk/tests/README.txt
--- trunk/tests/README.txt	                        (rev 0)
+++ trunk/tests/README.txt	2011-06-16 16:52:07 UTC (rev 4622)
@@ -0,0 +1,7 @@
+USAGENOTES contains instructions on how to operate the test suite.
+It is an asciidoc document, in order to properly build it run the following command:
+asciidoc -a toc USAGENOTES.txt
+It will generate an HTML file called USAGENOTES.
+Warning:
+asciidoc must be installed.
More information about the Swift-commit
