[Swift-commit] r4682 - in trunk: docs docs/userguide etc tests/documentation
davidk at ci.uchicago.edu davidk at ci.uchicago.edu
Thu Jun 23 18:14:22 CDT 2011
Author: davidk
Date: 2011-06-23 18:14:21 -0500 (Thu, 23 Jun 2011)
New Revision: 4682
Added:
   trunk/docs/userguide/cdm
Removed:
   trunk/tests/documentation/swift.log
Modified:
   trunk/docs/build_docs.sh
   trunk/docs/userguide/language
   trunk/docs/userguide/mappers
   trunk/docs/userguide/userguide.txt
   trunk/etc/coaster-service.conf
Log:
Fixed a few issues with the documentation build script with file permissions and better handling of symlinks
Fixed an error in the userguide with the rotate example
Added CDM documentation to the userguide
Removed an unneeded option in coaster-service.conf
Modified: trunk/docs/build_docs.sh
--- trunk/docs/build_docs.sh	2011-06-23 23:03:18 UTC (rev 4681)
+++ trunk/docs/build_docs.sh	2011-06-23 23:14:21 UTC (rev 4682)
@@ -9,7 +9,9 @@
 # Change file permissions to values set below
-CHMOD_VALUE="664"
+CHMOD_DIRECTORY_MODE="775"
+CHMOD_FILE_MODE="664"
+GROUP="vdl2-svn"
 # Verify correct arguments
 if [ -n "$1" ]; then
@@ -21,6 +23,8 @@
 # Create installation directory if needed
 if [ ! -d "$INSTALLATION_DIRECTORY" ]; then
    mkdir $INSTALLATION_DIRECTORY || crash "Unable to create directory $INSTALLATION_DIRECTORY"
+   chgrp $GROUP $INSTALLATION_DIRECTORY > /dev/null 2>&1
+   chmod $CHMOD_DIRECTORY_MODE $INSTALLATION_DIRECTORY > /dev/null 2>&1
 fi
 # Gather version information
@@ -53,12 +57,16 @@
    fi
    # Copy all files to destination (may include graphics, etc)
-   for copyfile in `ls * 2>/dev/null`
+   for copyfile in `find -L . -type f 2>/dev/null |grep -v .svn`
    do
-      cp $copyfile $INSTALLATION_DIRECTORY/$VERSION/$directory || crash "Unable to copy $copyfile to $INSTALLATION_DIRECTORY/$VERSION/$directory"
-      chmod $CHMOD_VALUE $INSTALLATION_DIRECTORY/$VERSION/$directory/$copyfile > /dev/null 2>&1
+      DN=`dirname $copyfile`
+      mkdir -p $INSTALLATION_DIRECTORY/$VERSION/$directory/$DN > /dev/null 2>&1
+      cp $copyfile $INSTALLATION_DIRECTORY/$VERSION/$directory/$DN || crash "Unable to copy $copyfile to $INSTALLATION_DIRECTORY/$VERSION/$directory"
    done
    popd > /dev/null 2>&1
 done
+find $INSTALLATION_DIRECTORY/$VERSION -type f -exec chgrp $GROUP {} \; -exec chmod $CHMOD_FILE_MODE {} \; > /dev/null 2>&1
+find $INSTALLATION_DIRECTORY/$VERSION -type d -exec chgrp $GROUP {} \; -exec chmod $CHMOD_DIRECTORY_MODE {} \; > /dev/null 2>&1
Added: trunk/docs/userguide/cdm
--- trunk/docs/userguide/cdm	                        (rev 0)
+++ trunk/docs/userguide/cdm	2011-06-23 23:14:21 UTC (rev 4682)
@@ -0,0 +1,203 @@
+Collective Data Management
+Overview
+. The user specifies a CDM policy in a file, customarily fs.data.
+. fs.data is given to Swift on the command line.
+. The Swift data module (org.globus.swift.data) is informed of the CDM policy.
+. At job launch time, the VDL Karajan code queries the CDM policy,
+   .. altering the file staging phase, and
+   .. sending fs.data to the compute site.
+. At job run time, the Swift wrapper script
+   .. consults a Perl script to obtain policy, and
+   .. uses wrapper extensions to modify data movement.
+. Similarly, stage out can be changed.
+.Command line
+$ swift -sites.file sites.xml -tc.file tc.data -cdm.file fs.data stream.swift
+CDM policy file format
+.Example
+# Describe CDM for my job
+property GATHER_LIMIT 1
+rule .*input.txt DIRECT /gpfs/homes/wozniak/data
+rule .*xfile*.data BROADCAST /dev/shm
+rule .* DEFAULT
+The lines contain:
+. A directive, either rule or property
+. A rule has:
+   .. A regular expression
+   .. A policy token
+   .. Additional policy-specific arguments
+. A property has
+   .. A policy property token
+   .. The token value
+. Comments with # .
+. Blank lines are ignored.
+.Notes
+. The policy file is used as a lookup database by Swift and Perl methods.
+. For example, a lookup with the database above given the argument input.txt would result in the Direct policy.
+. If the lookup does not succeed, the result is DEFAULT.
+ . Policies are listed as subclasses of org.globus.swift.data.policy.Policy .
+Policy Descriptions
+.Default
+* Just use file staging as provided by Swift/CoG.  Identical to behavior if no CDM file is given.
+.Broadcast
+* The input files matching the pattern will be stored in the given directory, an LFS location, with links in the job directory.
+* On the BG/P, this will make use of the f2cn tool.
+* On machines not implementing an efficient broadcast, we will just ensure correctness.  For example, on a workstation, the location could be in a /tmp RAM FS.
+.Direct
+rule .*input.txt DIRECT /gpfs/scratch/wozniak/
+* Allows for direct I/O to the parallel FS without staging.
+* The input files matching the pattern must already exist in the given directory, a GFS location.  Links will be placed in the job directory.
+* The output files matching the pattern will be stored in the given directory, with links in the job directory.
+* Example: In the rule above, the Swift-generated file name ./data/input.txt would be accessed by the user job in /gpfs/homes/wozniak/data/input.txt .
+.Local
+rule .*input.txt LOCAL dd /gpfs/homes/wozniak/data obs=64K
+* Allows for client-directed input copy to the compute node.
+* The user may specify cp or dd as the input transfer program.
+* The input files matching the pattern must already exist in the given directory, a GFS location.  Copies will be placed in the job directory.
+* Argument list: [tool] [GFS directory] [tool arguments]*
+.Gather
+property GATHER_LIMIT 500000000 # 500 MB
+property GATHER_DIR /dev/shm/gather
+property GATHER_TARGET /gpfs/wozniak/data/gather_target
+rule .*.output.txt GATHER
+* The output files matching the pattern will be present to tasks in the job directory as usual but noted in a _swiftwrap shell array GATHER_OUTPUT.
+* The GATHER_OUTPUT files will be cached in the GATHER_DIR, an LFS location.
+* The cache will be flushed when a job ends if a du on GATHER_DIR exceeds GATHER_LIMIT.
+* As the cache fills or on stage out, the files will be bundled into randomly named tarballs in GATHER_TARGET, a GFS location.
+* If the compute node is an SMP, GATHER_DIR is a shared resource.  It is protected by the link file GATHER_DIR/.cdm.lock .
+* Unpacking the tarballs in GATHER_TARGET will produce the user-specified filenames.
+.Summary
+. Files created by application
+. Acquire lock
+. Move files to cache
+. Check cache size
+. If limit exceeded, move all cache files to outbox
+. Release lock
+. If limit was exceeded, stream outbox as tarball to target
+.Notes
+* Gather required quite a bit of shell functionality to manage the lock, etc. This is placed in cdm_lib.sh .
+* vdl_int.k needed an additional task submission (cdm_cleanup.sh) to perform the final flush at workflow completion time .  This task also uses cdm_lib.sh .
+VDL/Karajan processing
+. CDM functions are available in Karajan via the cdm namespace.
+. These functions are defined in org.globus.swift.data.Query .
+. If CDM is enabled, VDL skips file staging for files unless the policy is DEFAULT.
+Swift wrapper CDM routines
+. The cdm.pl script is shipped to the compute node if CDM is enabled.
+. When linking in inputs, CDM is consulted by _swiftwrap:cdm_lookup().
+. The cdm_action() shell function handles CDM methods, typically just producing a link.
+Test cases
+. Simple test cases are in:
+      https://svn.mcs.anl.gov/repos/wozniak/collab/cdm/scripts/cdm-direct and
+      https://svn.mcs.anl.gov/repos/wozniak/collab/cdm/scripts/all-pairs
+. Do a:
+      mkdir cdm
+      cd cdm
+      svn co https://svn.mcs.anl.gov/repos/wozniak/collab/cdm/scripts
+. In cdm-direct, run:
+      source ./setup.sh local local local
+. Run workflow:
+      swift -sites.file sites.xml -tc.file tc.data -cdm.file fs.data stream.swift
+. Note that staging is skipped for input.txt
+      policy: file://localhost/input.txt : DIRECT
+      FILE_STAGE_IN_START file=input.txt ...
+      FILE_STAGE_IN_SKIP file=input.txt policy=DIRECT
+      FILE_STAGE_IN_END file=input.txt ...
+. In the wrapper output, the input file is handled by CDM functionality:
+      Progress  2010-01-21 13:50:32.466572727-0600  LINK_INPUTS
+      CDM_POLICY: DIRECT /homes/wozniak/cdm/scripts/cdm-direct
+      CDM: jobs/t/cp_sh-tkul4nmj input.txt DIRECT /homes/wozniak/cdm/scripts/cdm-direct
+      CDM[DIRECT]: Linking jobs/t/cp_sh-tkul4nmj/input.txt to /homes/wozniak/cdm/scripts/cdm-direct/input.txt
+      Progress  2010-01-21 13:50:32.486016708-0600  EXECUTE
+. all-pairs is quite similar but uses more policies.
+PTMap case
+. Start with vanilla PTMap:
+   .. cd cdm
+   .. mkdir apps
+   .. cd apps
+   .. https://svn.mcs.anl.gov/repos/wozniak/collab/cdm/apps/ptmap
+. Source setup.sh
+. Use start.sh, which
+   .. applies CDM policy from fs.local.data
+CDM site-aware policy file format
+Example
+#Describe CDM for my job
+#Use DIRECT and BROADCAST if on cluster1, else use DEFAULT behavior
+rule cluster1 .*input.txt DIRECT /gpfs/homes/wozniak/data
+rule cluster1 .*xfile*.data BROADCAST /dev/shm
+rule ANYWHERE .* DEFAULT
+The lines contain:
+. A rule has:
+   .. A regular expression for site matchin
+   .. A regular expression for filename matching
+   .. A policy token
+. A property has
Modified: trunk/docs/userguide/language
--- trunk/docs/userguide/language	2011-06-23 23:03:18 UTC (rev 4681)
+++ trunk/docs/userguide/language	2011-06-23 23:14:21 UTC (rev 4682)
@@ -128,7 +128,7 @@
 foreach f,ix in frames {
-  output[ix] = rotate(frames, 180);
+  output[ix] = rotate(f, 180);
 Sequential iteration can be expressed using the iterate construct:
Modified: trunk/docs/userguide/mappers
--- trunk/docs/userguide/mappers	2011-06-23 23:03:18 UTC (rev 4681)
+++ trunk/docs/userguide/mappers	2011-06-23 23:14:21 UTC (rev 4682)
@@ -392,7 +392,7 @@
 |location|A directory that the files are located.
 |prefix|The prefix of the files
 |suffix|The suffix of the files, for instance: ".txt"
-|pattern|A UNIX glob style pattern, for instance: "*foo*" would match
+|pattern|A UNIX glob style pattern, for instance: "\*foo*" would match
 all file names that contain foo. When this mapper is used to specify
 output filenames, pattern is ignored.
@@ -500,7 +500,7 @@
-pattern	A UNIX glob style pattern, for instance: "*foo*" would match
+pattern	A UNIX glob style pattern, for instance: "\*foo*" would match
@@ -531,7 +531,7 @@
 |location|The directory where the files are located.
Modified: trunk/docs/userguide/userguide.txt
--- trunk/docs/userguide/userguide.txt	2011-06-23 23:03:18 UTC (rev 4681)
+++ trunk/docs/userguide/userguide.txt	2011-06-23 23:14:21 UTC (rev 4682)
@@ -35,3 +35,5 @@
 include::coasters[]
 include::howto_tips[]
+include::cdm[]
Modified: trunk/etc/coaster-service.conf
--- trunk/etc/coaster-service.conf	2011-06-23 23:03:18 UTC (rev 4681)
+++ trunk/etc/coaster-service.conf	2011-06-23 23:14:21 UTC (rev 4682)
@@ -10,9 +10,6 @@
 # How to launch workers: local, ssh, cobalt, or futuregrid
 export WORKER_MODE=ssh
-# Worker logging setting passed to worker.pl for sites.xml
-export WORKER_LOGGING=INFO
 # SSH hosts to start workers on (ssh mode only)
 export WORKER_HOSTS="host1 host2 host3"
Deleted: trunk/tests/documentation/swift.log
--- trunk/tests/documentation/swift.log	2011-06-23 23:03:18 UTC (rev 4681)
+++ trunk/tests/documentation/swift.log	2011-06-23 23:14:21 UTC (rev 4682)
@@ -1,6 +0,0 @@
-2011-06-17 10:34:26,338-0500 DEBUG Loader Loader started
-2011-06-17 10:35:47,746-0500 DEBUG Loader Loader started
-2011-06-17 10:47:09,057-0500 DEBUG Loader Loader started
-2011-06-17 10:47:30,938-0500 DEBUG Loader Loader started
-2011-06-17 10:48:45,486-0500 DEBUG Loader Loader started
-2011-06-17 11:12:05,375-0500 DEBUG Loader Loader started
