[Swift-commit] r4666 - trunk/src/org/griphyn/vdl/karajan
hategan at ci.uchicago.edu
Thu Jun 23 13:27:59 CDT 2011
Author: hategan
Date: 2011-06-23 13:27:59 -0500 (Thu, 23 Jun 2011)
New Revision: 4666
Modified:
trunk/src/org/griphyn/vdl/karajan/WrapperMap.java
Log:
only lock objects when necessary
Modified: trunk/src/org/griphyn/vdl/karajan/WrapperMap.java
--- trunk/src/org/griphyn/vdl/karajan/WrapperMap.java 2011-06-23 18:14:30 UTC (rev 4665)
+++ trunk/src/org/griphyn/vdl/karajan/WrapperMap.java 2011-06-23 18:27:59 UTC (rev 4666)
@@ -10,10 +10,10 @@
import org.griphyn.vdl.mapping.DSHandle;
public class WrapperMap {
- private Map map;
+ private Map<DSHandle, FutureWrappers> map;
public WrapperMap() {
- this.map = new HashMap();
+ this.map = new HashMap<DSHandle, FutureWrappers>();
public static class FutureWrappers {
@@ -21,38 +21,49 @@
public ArrayIndexFutureList arrayWrapper;
- public synchronized void close(DSHandle handle) {
- FutureWrappers fw = (FutureWrappers) map.get(handle);
- if (fw != null) {
- if (fw.nodeWrapper != null) {
- fw.nodeWrapper.close();
- if (fw.arrayWrapper != null) {
- fw.arrayWrapper.close();
+ public void close(DSHandle handle) {
+ DSHandleFutureWrapper nodeWrapper;
+ ArrayIndexFutureList arrayWrapper;
+ synchronized(this) {
+ FutureWrappers fw = map.get(handle);
+ if (fw == null) {
+ return;
+ nodeWrapper = fw.nodeWrapper;
+ arrayWrapper = fw.arrayWrapper;
+ if (nodeWrapper != null) {
+ nodeWrapper.close();
+ if (arrayWrapper != null) {
+ arrayWrapper.close();
- public synchronized boolean isClosed(DSHandle handle) {
- if (fw != null) {
- return fw.nodeWrapper.isClosed();
- else if (fw.arrayWrapper != null) {
- return fw.arrayWrapper.isClosed();
- else {
- return false;
+ public boolean isClosed(DSHandle handle) {
+ if (fw == null) {
+ return false;
+ return nodeWrapper.isClosed();
+ else if (arrayWrapper != null) {
+ return arrayWrapper.isClosed();
else {
return false;
public synchronized DSHandleFutureWrapper addNodeListener(DSHandle handle) {
if (fw == null) {
map.put(handle, fw = new FutureWrappers());
@@ -63,8 +74,8 @@
return fw.nodeWrapper;
- public synchronized ArrayIndexFutureList addFutureListListener(DSHandle handle, Map value) {
+ public synchronized ArrayIndexFutureList addFutureListListener(DSHandle handle, Map<?, ?> value) {
if (fw == null) {
@@ -81,13 +92,13 @@
public synchronized void markAsAvailable(DSHandle handle, Object key) {
if (fw != null && fw.arrayWrapper != null) {
fw.arrayWrapper.addKey(key);
- public Set entrySet() {
+ public Set<Map.Entry<DSHandle, FutureWrappers>> entrySet() {
return map.entrySet();
More information about the Swift-commit
