[Swift-commit] r4644 - usertools/plotter/src/plotter
jonmon at ci.uchicago.edu jonmon at ci.uchicago.edu
Mon Jun 20 15:41:18 CDT 2011
Author: jonmon
Date: 2011-06-20 15:41:18 -0500 (Mon, 20 Jun 2011)
New Revision: 4644
Modified:
   usertools/plotter/src/plotter/Plots.java
   usertools/plotter/src/plotter/Util.java
Log:
moved static collection method from Util to Plots
Modified: usertools/plotter/src/plotter/Plots.java
--- usertools/plotter/src/plotter/Plots.java	2011-06-20 20:21:03 UTC (rev 4643)
+++ usertools/plotter/src/plotter/Plots.java	2011-06-20 20:41:18 UTC (rev 4644)
@@ -1,11 +1,16 @@
 package plotter;
+import plotter.Util.*;
 import java.awt.Font;
 import java.util.Properties;
+import java.util.List;
 import org.jfree.chart.JFreeChart;
 import org.jfree.chart.title.LegendTitle;
+import org.jfree.data.xy.XYSeries;
+import org.jfree.data.xy.XYSeriesCollection;
  * Reusable JFreeChart-specific functions
  * @author wozniak
@@ -13,6 +18,42 @@
 public class Plots
+       Stores the label as the Series key.
+       Stores the filename as the Series description.
+    static XYSeriesCollection collection(List<double[][]> data,
+                                         List<String> labels,
+                                         List<String> names)
+        final XYSeriesCollection collection = new XYSeriesCollection();
+        int count = 0;
+        for (double[][] d : data)
+            String label = "data: " + count;
+            try
+                String s = labels.get(count);
+                if( !(s.equals("")) )
+                    label = s;
+            catch (IndexOutOfBoundsException e)
+            Util.verbose( "label: "+label );
+            XYSeries series = new XYSeries(label);
+            for (int i = 0; i < d.length; i++)
+                series.add(d[i][0], d[i][1]);
+            series.setDescription(names.get(count));
+            collection.addSeries(series);
+            count++;
+        return collection;
     static void setupLegend(JFreeChart chart,
                             Properties properties)
Modified: usertools/plotter/src/plotter/Util.java
--- usertools/plotter/src/plotter/Util.java	2011-06-20 20:21:03 UTC (rev 4643)
+++ usertools/plotter/src/plotter/Util.java	2011-06-20 20:41:18 UTC (rev 4644)
@@ -3,54 +3,10 @@
  * Plot data helpers.
-import java.util.List;
-import org.jfree.data.xy.XYSeries;
-import org.jfree.data.xy.XYSeriesCollection;
 public class Util
     static boolean v = false;
-       Stores the label as the Series key.
-       Stores the filename as the Series description.
-    static XYSeriesCollection collection(List<double[][]> data,
-                                         List<String> labels,
-                                         List<String> names)
-        final XYSeriesCollection collection = new XYSeriesCollection();
-        int count = 0;
-        for (double[][] d : data)
-            /* What does this do? */
-            /* label is set to something but then immediately overwritten */
-            /* That catch should not happen */
-            String label = "data: " + count;
-            try
-                String s = labels.get(count);
-                if( !(s.equals("")) )
-                    label = s;
-            catch (IndexOutOfBoundsException e)
-            Util.verbose( "label: "+label );
-            XYSeries series = new XYSeries(label);
-            for (int i = 0; i < d.length; i++)
-                series.add(d[i][0], d[i][1]);
-            series.setDescription(names.get(count));
-            collection.addSeries(series);
-            count++;
-        return collection;
     public static void fatal(String s)
         System.err.println(s);
