[Swift-commit] r4628 - in usertools/plotter: . old_scripts samples/dual samples/lines src/plotter
jonmon at ci.uchicago.edu jonmon at ci.uchicago.edu
Fri Jun 17 14:28:46 CDT 2011
Author: jonmon
Date: 2011-06-17 14:28:46 -0500 (Fri, 17 Jun 2011)
New Revision: 4628
Added:
   usertools/plotter/old_scripts/
   usertools/plotter/old_scripts/dual.zsh
   usertools/plotter/old_scripts/lines.zsh
   usertools/plotter/src/plotter/Plotter.java
   usertools/plotter/swift_plotter.zsh
Removed:
   usertools/plotter/dual.zsh
   usertools/plotter/lines.zsh
Modified:
   usertools/plotter/README.txt
   usertools/plotter/build.xml
   usertools/plotter/samples/dual/About.txt
   usertools/plotter/samples/lines/About.txt
   usertools/plotter/src/plotter/Bits.java
   usertools/plotter/src/plotter/Dual.java
   usertools/plotter/src/plotter/LineReader.java
   usertools/plotter/src/plotter/Lines.java
   usertools/plotter/src/plotter/Plots.java
   usertools/plotter/src/plotter/Util.java
Log:
o moved the old lines.zsh and dual.zsh into the old_scripts directory.
o Changes to the java source files, prints to stderr where appropriate.
o Added Plotter class.  Depending on what option you give at the command line will generate a single y-axis labeled(-s) or double y-axis labeled(-d) plot.
o Added swift_plotter.zsh script that will call the Plotter class.
o Added clean target to the build.xml script.
Modified: usertools/plotter/README.txt
--- usertools/plotter/README.txt	2011-06-17 02:19:13 UTC (rev 4627)
+++ usertools/plotter/README.txt	2011-06-17 19:28:46 UTC (rev 4628)
@@ -3,4 +3,4 @@
 Produces EPS output from two-column data sets using JFreeChart.
-User interface is lines.zsh
+User interface is swift_plotter.zsh
Modified: usertools/plotter/build.xml
--- usertools/plotter/build.xml	2011-06-17 02:19:13 UTC (rev 4627)
+++ usertools/plotter/build.xml	2011-06-17 19:28:46 UTC (rev 4628)
@@ -1,5 +1,3 @@
 <project name="plots"
          default="all">
@@ -13,13 +11,20 @@
           depends="compile" />
   <target name="compile">
-   <javac srcdir="src"
-          classpath="${classpath}"
-          listfiles="${lf}"
-          debug="true"
-          debuglevel="source,lines,vars">
-     <compilerarg value="-Xlint"/>
-   </javac>
+    <javac includeAntRuntime="false"
+           srcdir="src"
+           classpath="${classpath}"
+           listfiles="${lf}"
+           debug="true"
+           debuglevel="source,lines,vars">
+      <compilerarg value="-Xlint"/>
+    </javac>
   </target>
+  <target name="clean">
+    <delete>
+      <fileset dir="src/plotter" includes="**/*.class"/>
+    </delete>
+  </target>
 </project>
Deleted: usertools/plotter/dual.zsh
--- usertools/plotter/dual.zsh	2011-06-17 02:19:13 UTC (rev 4627)
+++ usertools/plotter/dual.zsh	2011-06-17 19:28:46 UTC (rev 4628)
@@ -1,16 +0,0 @@
-#!/bin/zsh
-# DUAL.ZSH
-# Create plot with two data sets, two Y axes
-# Arguments passed directly to Dual.java - see there for details
-# usage: dual.zsh <properties> <output file> <data file>*
-PLOTTERS=$( cd $( dirname $0 ) ; /bin/pwd )
-# declare -p PLOTTERS
-source ${PLOTTERS}/classpath.zsh
-[[ $? != 0 ]] && print "Could not build CLASSPATH!" && return 1
-java -ea -cp ${CP} plotter.Dual ${*}
Deleted: usertools/plotter/lines.zsh
--- usertools/plotter/lines.zsh	2011-06-17 02:19:13 UTC (rev 4627)
+++ usertools/plotter/lines.zsh	2011-06-17 19:28:46 UTC (rev 4628)
@@ -1,14 +0,0 @@
-#!/bin/zsh
-# LINES.ZSH
-# Arguments passed directly to Lines.java - see there for details
-# usage: lines.zsh <properties> <output file> <data file>*
-java -ea -cp ${CP} plotter.Lines ${*}
Added: usertools/plotter/old_scripts/dual.zsh
--- usertools/plotter/old_scripts/dual.zsh	                        (rev 0)
+++ usertools/plotter/old_scripts/dual.zsh	2011-06-17 19:28:46 UTC (rev 4628)
@@ -0,0 +1,16 @@
+#!/bin/zsh
+# DUAL.ZSH
+# Create plot with two data sets, two Y axes
+# Arguments passed directly to Dual.java - see there for details
+# usage: dual.zsh <properties> <output file> <data file>*
+PLOTTERS=$( cd $( dirname $0 ) ; /bin/pwd )
+# declare -p PLOTTERS
+source ${PLOTTERS}/classpath.zsh
+[[ $? != 0 ]] && print "Could not build CLASSPATH!" && return 1
+java -ea -cp ${CP} plotter.Dual ${*}
Property changes on: usertools/plotter/old_scripts/dual.zsh
___________________________________________________________________
Added: svn:executable
Added: usertools/plotter/old_scripts/lines.zsh
--- usertools/plotter/old_scripts/lines.zsh	                        (rev 0)
+++ usertools/plotter/old_scripts/lines.zsh	2011-06-17 19:28:46 UTC (rev 4628)
@@ -0,0 +1,14 @@
+#!/bin/zsh
+# LINES.ZSH
+# Arguments passed directly to Lines.java - see there for details
+# usage: lines.zsh <properties> <output file> <data file>*
+java -ea -cp ${CP} plotter.Lines ${*}
Property changes on: usertools/plotter/old_scripts/lines.zsh
Modified: usertools/plotter/samples/dual/About.txt
--- usertools/plotter/samples/dual/About.txt	2011-06-17 02:19:13 UTC (rev 4627)
+++ usertools/plotter/samples/dual/About.txt	2011-06-17 19:28:46 UTC (rev 4628)
@@ -1,5 +1,5 @@
 To run:
-../../dual.zsh plot.cfg tmp.eps set*.data
+../../swift_plotter.zsh -d plot.cfg tmp.eps set*.data
Modified: usertools/plotter/samples/lines/About.txt
--- usertools/plotter/samples/lines/About.txt	2011-06-17 02:19:13 UTC (rev 4627)
+++ usertools/plotter/samples/lines/About.txt	2011-06-17 19:28:46 UTC (rev 4628)
@@ -1,5 +1,5 @@
 To run:
-../../lines.zsh plot.cfg tmp.eps set*.data
+../../swift_plotter.zsh -s plot.cfg tmp.eps set*.data
Modified: usertools/plotter/src/plotter/Bits.java
--- usertools/plotter/src/plotter/Bits.java	2011-06-17 02:19:13 UTC (rev 4627)
+++ usertools/plotter/src/plotter/Bits.java	2011-06-17 19:28:46 UTC (rev 4628)
@@ -10,141 +10,141 @@
 public class Bits
-  public static Random rng = null;
-  static boolean locked = false;
-  static boolean ready  = false;
+    public static Random rng = null;
+    static boolean locked = false;
+    static boolean ready  = false;
-     If not locked, seed the generator with the clock.
-  public static void init()
-    init(System.currentTimeMillis());
+       If not locked, seed the generator with the clock.
+    public static void init()
+        init(System.currentTimeMillis());
-     If not locked, seed the generator with the clock mod 1000.
-     Useful for debugging.
-     @param print If true, print the seed.
-  public static long init(boolean print)
-    long seed = System.currentTimeMillis() % 1000;
-    init(seed);
+       If not locked, seed the generator with the clock mod 1000.
+       Useful for debugging.
+       @param print If true, print the seed.
+    public static long init(boolean print)
+        long seed = System.currentTimeMillis() % 1000;
+        init(seed);
-    if (print)
-      System.out.println("Bits.seed: " + seed);
+        if (print)
+            System.out.println("Bits.seed: " + seed);
-    return seed;
+        return seed;
-     @param seed The seed.
-  public static void init(long seed)
-    assert (!locked) : "Bits locked!";
-    // System.out.println("Seeding RNG...");
-    rng = new Random(seed);
-    ready = true;
+       @param seed The seed.
+    public static void init(long seed)
+        assert (!locked) : "Bits locked!";
+        // System.out.println("Seeding RNG...");
+        rng = new Random(seed);
+        ready = true;
-     Lock the generator to prevent seeding
-  public static void lock()
-    locked = true;
+       Lock the generator to prevent seeding
+    public static void lock()
+        locked = true;
-     Unlock the generator
-  public static void unlock()
-    locked = false;
+       Unlock the generator
+    public static void unlock()
+        locked = false;
-  public static double nextDouble()
-    if (! ready)
+    public static double nextDouble()
-      System.err.println("Bits not ready!");
-      System.exit(2);
+        if (! ready)
+            System.err.println("Bits not ready!");
+            System.exit(2);
+        return rng.nextDouble();
-    return rng.nextDouble();
-  public static double nextDouble(double d)
-    return rng.nextDouble() * d;
+    public static double nextDouble(double d)
+        return rng.nextDouble() * d;
-  public static int nextInt()
-    if (! ready)
+    public static int nextInt()
-      System.exit(2);
+        if (! ready)
+            System.exit(2);
+        return rng.nextInt();
-    return rng.nextInt();
-     Return a integer in [0..t).
-  public static int nextInt(int t)
-    double d = nextDouble();
-    int i = (new Double(d * t)).intValue();
-    return i;
+       Return a integer in [0..t).
+    public static int nextInt(int t)
+        double d = nextDouble();
+        int i = (new Double(d * t)).intValue();
+        return i;
-  public static boolean nextBoolean()
-    if (! ready)
+    public static boolean nextBoolean()
-      System.exit(2);
+        if (! ready)
+            System.exit(2);
+        return rng.nextBoolean();
-    return rng.nextBoolean();
-  public static long nextLong()
-    if (! ready)
+    public static long nextLong()
-      System.exit(2);
+        if (! ready)
+            System.exit(2);
+        return rng.nextLong();
-    return rng.nextLong();
-  public static long nextLong(long t)
-    long i = (new Double(d * t)).longValue();
-    return i;
+    public static long nextLong(long t)
+        long i = (new Double(d * t)).longValue();
+        return i;
-  public static BigInteger nextBigInteger(BigInteger i)
-    if (i.equals(BigInteger.ZERO))
-      return BigInteger.ZERO;
-    int b = i.bitLength()+1;
-    BigInteger result;
-    do
+    public static BigInteger nextBigInteger(BigInteger i)
-      result = BigInteger.valueOf(b);
-    } while (result.compareTo(i) >= 0);
+        if (i.equals(BigInteger.ZERO))
+            return BigInteger.ZERO;
-    return result;
+        int b = i.bitLength()+1;
+        BigInteger result;
+        do
+            result = BigInteger.valueOf(b);
+        } while (result.compareTo(i) >= 0);
-  public static void nextBytes(byte[] bytes)
-    rng.nextBytes(bytes);
+        return result;
+    public static void nextBytes(byte[] bytes)
+        rng.nextBytes(bytes);
Modified: usertools/plotter/src/plotter/Dual.java
--- usertools/plotter/src/plotter/Dual.java	2011-06-17 02:19:13 UTC (rev 4627)
+++ usertools/plotter/src/plotter/Dual.java	2011-06-17 19:28:46 UTC (rev 4628)
@@ -27,405 +27,409 @@
 public class Dual
-  static Properties properties;
+    static Properties properties;
-  public static boolean bw = false;
+    public static boolean bw = false;
-  static int width = 400;
-  static int height = 400;
+    static int width = 400;
+    static int height = 400;
-  // null indicates the value was not set by the user
-  static Double xmin = null;
-  static Double xmax = null;
-  static Double ymin1 = null;
-  static Double ymax1 = null;
-  static Double ymin2 = null;
-  static Double ymax2 = null;
+    // null indicates the value was not set by the user
+    static Double xmin = null;
+    static Double xmax = null;
+    static Double ymin1 = null;
+    static Double ymax1 = null;
+    static Double ymin2 = null;
+    static Double ymax2 = null;
-     Generate simple plot
-     @param collection The x,y data
-     @param title Plot title
-     @param xlabel X label text
-     @param ylabel1 Y label text
-     @param ylabel2 Y label text
-     @param output EPS filename
-  public static boolean plot(XYSeriesCollection[] collections,
-                             String title, String xlabel,
-                             String ylabel1, String ylabel2,
-                             String output)
-    EPSDocumentGraphics2D g2d = null;
-    Rectangle2D.Double rectangle = null;
-    OutputStream out = null;
-    try
+       Generate simple plot
+       @param collection The x,y data
+       @param title Plot title
+       @param xlabel X label text
+       @param ylabel1 Y label text
+       @param ylabel2 Y label text
+       @param output EPS filename
+       @return true/false depending if the method completed without error or not
+    public static boolean plot(XYSeriesCollection[] collections,
+                               String title, String xlabel,
+                               String ylabel1, String ylabel2,
+                               String output)
-      out = new FileOutputStream(output);
-      out = new BufferedOutputStream(out);
+        EPSDocumentGraphics2D g2d = null;
+        Rectangle2D.Double rectangle = null;
+        OutputStream out = null;
-      g2d = new EPSDocumentGraphics2D(false);
-      g2d.setGraphicContext
-        (new org.apache.xmlgraphics.java2d.GraphicContext());
+        try
+            out = new FileOutputStream(output);
+            out = new BufferedOutputStream(out);
-      rectangle = new Rectangle2D.Double(0, 0, width, height);
+            g2d = new EPSDocumentGraphics2D(false);
+            g2d.setGraphicContext
+                (new org.apache.xmlgraphics.java2d.GraphicContext());
-      g2d.setupDocument(out, width, height);
-    catch (IOException e)
-      System.out.println("Problem with file: " + output);
-      return false;
+            rectangle = new Rectangle2D.Double(0, 0, width, height);
-    final boolean withLegend = true;
+            g2d.setupDocument(out, width, height);
+        catch (IOException e)
+            System.err.println("Problem with file: " + output);
+            return false;
-    JFreeChart chart =
-      ChartFactory.createXYLineChart
-      (title, xlabel, ylabel1, collections[0],
-       PlotOrientation.VERTICAL, withLegend, false, false);
+        final boolean withLegend = true;
-    setupPlot(chart, collections, ylabel1, ylabel2);
-    chart.draw(g2d, rectangle);
+        JFreeChart chart =
+            ChartFactory.createXYLineChart
+            (title, xlabel, ylabel1, collections[0],
+             PlotOrientation.VERTICAL, withLegend, false, false);
-    try
-      g2d.finish();
-    catch (Exception e)
-      System.out.println("Err!");
+        setupPlot(chart, collections, ylabel1, ylabel2);
+        chart.draw(g2d, rectangle);
-    IOUtils.closeQuietly(out);
-    System.out.println("PLOTTED: " + output);
+        try
+            g2d.finish();
+        catch (Exception e)
+            System.err.println("Err!" + e);
-    return true;
+        IOUtils.closeQuietly(out);
+        System.out.println("PLOTTED: " + output);
-  private static void setupPlot(JFreeChart chart,
-                                XYSeriesCollection[] collections,
-                                String ylabel1, String ylabel2)
-    XYPlot plot = chart.getXYPlot();
-    XYLineAndShapeRenderer renderer1 = new XYLineAndShapeRenderer();
-    XYLineAndShapeRenderer renderer2 = new XYLineAndShapeRenderer();
+        return true;
-    int count = plot.getSeriesCount();
-    if (bw)
-      for (int i = 0; i < count; i++)
-        renderer1.setSeriesPaint(i, Color.BLACK);
-        renderer2.setSeriesPaint(i, Color.BLACK);
-    Series series1 = collections[0].getSeries(0);
-    if (! showShape(series1.getDescription()))
-      renderer1.setSeriesShapesVisible(0, false);
-    Series series2 = collections[1].getSeries(0);
-    if (! showShape(series2.getDescription()))
-      renderer2.setSeriesShapesVisible(1, false);
+    private static void setupPlot(JFreeChart chart,
+                                  XYSeriesCollection[] collections,
+                                  String ylabel1, String ylabel2)
+        XYPlot plot = chart.getXYPlot();
+        XYLineAndShapeRenderer renderer1 = new XYLineAndShapeRenderer();
+        XYLineAndShapeRenderer renderer2 = new XYLineAndShapeRenderer();
-    Plots.setupLegend(chart, properties);
-    setAxes(plot, ylabel1, ylabel2, collections[1]);
-    plot.setRenderer(0, renderer1);
-    plot.setRenderer(1, renderer2);
-    plot.setBackgroundPaint(Color.WHITE);
+        int count = plot.getSeriesCount();
+        if (bw)
+            for (int i = 0; i < count; i++)
+                renderer1.setSeriesPaint(i, Color.BLACK);
+                renderer2.setSeriesPaint(i, Color.BLACK);
-  static void setAxes(XYPlot plot, String ylabel1, String ylabel2,
-                      XYSeriesCollection collection)
-    plot.setDataset(1, collection);
+        Series series1 = collections[0].getSeries(0);
+        if (! showShape(series1.getDescription()))
+            renderer1.setSeriesShapesVisible(0, false);
+        Series series2 = collections[1].getSeries(0);
+        if (! showShape(series2.getDescription()))
+            renderer2.setSeriesShapesVisible(1, false);
-    // Actual values: modify if necessary
-    double axmin, axmax, aymin1, aymax1, aymin2, aymax2;
-    if (xmin != null || xmax != null)
-      NumberAxis axis = new NumberAxis();
-      plot.setDomainAxis(axis);
-      Range range = axis.getRange();
-      axmin = range.getLowerBound();
-      axmax = range.getUpperBound();
-      if (xmin != null) axmin = xmin;
-      if (xmax != null) axmax = xmax;
-      axis.setRange(axmin, axmax);
+        Plots.setupLegend(chart, properties);
+        setAxes(plot, ylabel1, ylabel2, collections[1]);
+        plot.setRenderer(0, renderer1);
+        plot.setRenderer(1, renderer2);
+        plot.setBackgroundPaint(Color.WHITE);
-    // Left Y axis
-    if (ymin1 != null || ymax1 != null)
+    static void setAxes(XYPlot plot, String ylabel1, String ylabel2,
+                        XYSeriesCollection collection)
-      NumberAxis axis = new NumberAxis(ylabel1);
-      plot.setRangeAxis(0, axis);
-      aymin1 = range.getLowerBound();
-      aymax1 = range.getUpperBound();
-      if (ymin1 != null) aymin1 = ymin1;
-      if (ymax1 != null) aymax1 = ymax1;
-      axis.setRange(aymin1, aymax1);
+        plot.setDataset(1, collection);
-    // Right Y axis setup
-    Font font = plot.getRangeAxis().getLabelFont();
-    final NumberAxis rightAxis = new NumberAxis(ylabel2);
-    rightAxis.setLabelFont(font);
-    plot.setRangeAxis(1, rightAxis);
+        // Actual values: modify if necessary
+        double axmin, axmax, aymin1, aymax1, aymin2, aymax2;
-    // Right Y axis
-    if (ymin2 != null || ymax2 != null)
-      Range range = rightAxis.getRange();
-      aymin2 = range.getLowerBound();
-      aymax2 = range.getUpperBound();
-      if (ymin2 != null) aymin2 = ymin2;
-      if (ymax2 != null) aymax2 = ymax2;
-      rightAxis.setRange(aymin2, aymax2);
+        if (xmin != null || xmax != null)
+            NumberAxis axis = new NumberAxis();
+            plot.setDomainAxis(axis);
+            Range range = axis.getRange();
+            axmin = range.getLowerBound();
+            axmax = range.getUpperBound();
+            if (xmin != null) axmin = xmin;
+            if (xmax != null) axmax = xmax;
+            axis.setRange(axmin, axmax);
-    plot.mapDatasetToRangeAxis(0, 0);
-    plot.mapDatasetToRangeAxis(1, 1);
-    plot.configureRangeAxes();
+        // Left Y axis
+        if (ymin1 != null || ymax1 != null)
+            NumberAxis axis = new NumberAxis(ylabel1);
+            plot.setRangeAxis(0, axis);
+            aymin1 = range.getLowerBound();
+            aymax1 = range.getUpperBound();
+            if (ymin1 != null) aymin1 = ymin1;
+            if (ymax1 != null) aymax1 = ymax1;
+            axis.setRange(aymin1, aymax1);
-     Args: Lines <properties> <output file> <data file>*
-     Reads settings from properties: see scanProperties()
-     Produces EPS output file
-     Data files are two-columns of numbers each -
-        see LineReader.read() and LineReader.array()
-  public static void main(String[] args)
-    // Settings:
-    boolean verbose = false;
+        // Right Y axis setup
+        Font font = plot.getRangeAxis().getLabelFont();
+        final NumberAxis rightAxis = new NumberAxis(ylabel2);
+        rightAxis.setLabelFont(font);
+        plot.setRangeAxis(1, rightAxis);
-    Getopt g = new Getopt("testprog", args, "v");
-    int c = -1;
-    while ((c = g.getopt()) != -1)
-      switch (c)
-        case 'v':
-          verbose = true;
+        // Right Y axis
+        if (ymin2 != null || ymax2 != null)
+            Range range = rightAxis.getRange();
+            aymin2 = range.getLowerBound();
+            aymax2 = range.getUpperBound();
+            if (ymin2 != null) aymin2 = ymin2;
+            if (ymax2 != null) aymax2 = ymax2;
+            rightAxis.setRange(aymin2, aymax2);
+        plot.mapDatasetToRangeAxis(0, 0);
+        plot.mapDatasetToRangeAxis(1, 1);
+        plot.configureRangeAxes();
-    if (args.length < 3)
+       Args: Lines <properties> <output file> <data file>*
+       Reads settings from properties: see scanProperties()
+       Produces EPS output file
+       Data files are two-columns of numbers each -
+       see LineReader.read() and LineReader.array()
+    public void plotter(String[] args)
-      ("usage: [<options>] <properties> <output> <data>*");
-      System.exit(2);
+        // Settings:
+        boolean verbose = false;
-    Bits.init();
-    Util.verbose(verbose);
+        Getopt g = new Getopt("testprog", args, "v");
+        int c = -1;
+        while ((c = g.getopt()) != -1)
+            switch (c)
+                case 'v':
+                    verbose = true;
-    String propFile = args[0];
-    String output = args[1];
-    List<String> names = new ArrayList<String>();
-    for (int i = 2; i < args.length; i++)
-      names.add(args[i]);
+        if (args.length < 3)
+                ("usage: [<options>] <properties> <output> <data>*");
+            System.exit(2);
-    String title = null;
-    String xlabel = null;
-    String ylabel1 = null;
-    String ylabel2 = null;
-    List<double[][]> data = new ArrayList<double[][]>();
-    List<String> labels = new ArrayList<String>();
+        Bits.init();
+        Util.verbose(verbose);
-    properties = new Properties();
-    load(propFile);
-    title = properties.getProperty("title");
-    xlabel = properties.getProperty("xlabel");
-    ylabel1 = properties.getProperty("ylabel1");
-    ylabel2 = properties.getProperty("ylabel2");
+        String propFile = args[0];
+        String output = args[1];
+        List<String> names = new ArrayList<String>();
+        for (int i = 2; i < args.length; i++)
+            names.add(args[i]);
-    scanProperties();
+        String title = null;
+        String xlabel = null;
+        String ylabel1 = null;
+        String ylabel2 = null;
+        List<double[][]> data = new ArrayList<double[][]>();
+        List<String> labels = new ArrayList<String>();
-    for (String name : names)
-      File file = new File(name);
-      Util.verbose("open: " + file);
-      List<String> lines = null;
-      try
-        lines = LineReader.read(file);
-      catch (FileNotFoundException e)
-        System.out.println("not found: " + file);
-        System.exit(1);
-      double[][] array = LineReader.array(lines);
-      data.add(array);
-      addLabel(name, labels);
-      Util.verbose("array:\n" + toString(array));
+        properties = new Properties();
+        load(propFile);
+        title = properties.getProperty("title");
+        xlabel = properties.getProperty("xlabel");
+        ylabel1 = properties.getProperty("ylabel1");
+        ylabel2 = properties.getProperty("ylabel2");
-    XYSeriesCollection[] collections =
-      collections(data, labels, names);
+        scanProperties();
-    plot(collections, title, xlabel, ylabel1, ylabel2, output);
+        for (String name : names)
+            File file = new File(name);
+            Util.verbose("open: " + file);
+            List<String> lines = null;
+            try
+                lines = LineReader.read(file);
+            catch (FileNotFoundException e)
+                System.err.println("not found: " + file);
+                System.exit(1);
+            double[][] array = LineReader.array(lines);
+            data.add(array);
+            addLabel(name, labels);
+            Util.verbose("array:\n" + toString(array));
-  static XYSeriesCollection[] collections(List<double[][]> data,
-                                          List<String> labels,
-                                          List<String> names)
-    final XYSeriesCollection[] result = new XYSeriesCollection[2];
-    result[0] = new XYSeriesCollection();
-    result[1] = new XYSeriesCollection();
+        XYSeriesCollection[] collections =
+            collections(data, labels, names);
-    int count = 0;
-    for (int i = 0; i < 2; i++)
+        plot(collections, title, xlabel, ylabel1, ylabel2, output);
+    static XYSeriesCollection[] collections(List<double[][]> data,
+                                            List<String> labels,
+                                            List<String> names)
-      double[][] d = data.get(i);
-      String label = "data: " + count;
-      try
-        label = labels.get(count);
-      catch (IndexOutOfBoundsException e)
+        final XYSeriesCollection[] result = new XYSeriesCollection[2];
+        result[0] = new XYSeriesCollection();
+        result[1] = new XYSeriesCollection();
-      XYSeries series = new XYSeries(label);
-      for (int j = 0; j < d.length; j++)
-        series.add(d[j][0], d[j][1]);
+        int count = 0;
+        for (int i = 0; i < 2; i++)
+            double[][] d = data.get(i);
+            String label = "data: " + count;
+            try
+                label = labels.get(count);
+            catch (IndexOutOfBoundsException e)
-      series.setDescription(names.get(count));
-      result[i].addSeries(series);
-      count++;
+            XYSeries series = new XYSeries(label);
+            for (int j = 0; j < d.length; j++)
+                series.add(d[j][0], d[j][1]);
+            series.setDescription(names.get(count));
+            result[i].addSeries(series);
+            count++;
+        return result;
-    return result;
-  static void load(String propFile)
-    try
+    static void load(String propFile)
-      if (propFile.equals("-"))
-        properties.load(System.in);
-      else
-        properties.load(new FileInputStream(propFile));
+        try
+            if (propFile.equals("-"))
+                properties.load(System.in);
+            else
+                properties.load(new FileInputStream(propFile));
+            System.err.println(e);
+            System.exit(1);
+            e.printStackTrace();
+            System.exit(1);
-      System.out.println(e);
-      System.exit(1);
-      e.printStackTrace();
-      System.exit(1);
-     Various plot properties.  All are currently optional
+       Various plot properties.  All are currently optional
-     Example.
-     Assume you want to plot a two-column table in file.data.
-     The first column is the x values and the second column
-     is the y values.  See LineReader for details.
+       Example.
+       Assume you want to plot a two-column table in file.data.
+       The first column is the x values and the second column
+       is the y values.  See LineReader for details.
-     Your properties may include:
-     title = Plot
-     xlabel = size
-     ylabel = speed
-     label.file.data = legend text
-     width (output image width)
-     height (output image height)
-     xmin, xmax, ymin1, ymax1, ymin2, ymax2
-         (auto-selected if not given)
-     bw (Black and white, true/false, default false)
-  static void scanProperties()
-    String tmp;
-    tmp = properties.getProperty("width");
-    if (tmp != null)
-      width = Integer.parseInt(tmp.trim());
-    tmp = properties.getProperty("height");
-    if (tmp != null)
-      height = Integer.parseInt(tmp.trim());
-    tmp = properties.getProperty("xmin");
-    if (tmp != null)
-      xmin = Double.parseDouble(tmp);
-    tmp = properties.getProperty("xmax");
-    if (tmp != null)
-      xmax = Double.parseDouble(tmp);
-    tmp = properties.getProperty("ymin1");
-    if (tmp != null)
-      ymin1 = Double.parseDouble(tmp);
-    tmp = properties.getProperty("ymax1");
-    if (tmp != null)
-      ymax1 = Double.parseDouble(tmp);
-    tmp = properties.getProperty("ymin2");
-    if (tmp != null)
-      ymin2 = Double.parseDouble(tmp);
-    tmp = properties.getProperty("ymax2");
-    if (tmp != null)
-      ymax2 = Double.parseDouble(tmp);
+       Your properties may include:
+       title = Plot
+       xlabel = size
+       ylabel = speed
+       label.file.data = legend text
+       width (output image width)
+       height (output image height)
+       xmin, xmax, ymin1, ymax1, ymin2, ymax2
+       (auto-selected if not given)
+       bw (Black and white, true/false, default false)
+    static void scanProperties()
+        String tmp;
+        tmp = properties.getProperty("width");
+        if (tmp != null)
+            width = Integer.parseInt(tmp.trim());
+        tmp = properties.getProperty("height");
+        if (tmp != null)
+            height = Integer.parseInt(tmp.trim());
+        tmp = properties.getProperty("xmin");
+        if (tmp != null)
+            xmin = Double.parseDouble(tmp);
+        tmp = properties.getProperty("xmax");
+        if (tmp != null)
+            xmax = Double.parseDouble(tmp);
+        tmp = properties.getProperty("ymin1");
+        if (tmp != null)
+            ymin1 = Double.parseDouble(tmp);
+        tmp = properties.getProperty("ymax1");
+        if (tmp != null)
+            ymax1 = Double.parseDouble(tmp);
+        tmp = properties.getProperty("ymin2");
+        if (tmp != null)
+            ymin2 = Double.parseDouble(tmp);
+        tmp = properties.getProperty("ymax2");
+        if (tmp != null)
+            ymax2 = Double.parseDouble(tmp);
-    tmp = properties.getProperty("bw");
-    if (tmp != null)
-      bw = Boolean.parseBoolean(tmp);
+        tmp = properties.getProperty("bw");
+        if (tmp != null)
+            bw = Boolean.parseBoolean(tmp);
-     Arrays.copyOfRange is a Java 1.6 feature.
-     This has the same signature.
-  static String[] select(String[] s, int p, int q)
-    String[] result = new String[q-p];
-    int j = 0;
-    for (int i = p; i < q; i++)
+       Arrays.copyOfRange is a Java 1.6 feature.
+       This has the same signature.
+      static String[] select(String[] s, int p, int q)
+      String[] result = new String[q-p];
+      int j = 0;
+      for (int i = p; i < q; i++)
       result[j++] = s[i];
-    return result;
+      return result;
-  static void addLabel(String name,
-                       List<String> labels)
-    String label = properties.getProperty("label."+name);
-    if (label == null)
-      label = "";
-    labels.add(label);
+    static void addLabel(String name,
+                         List<String> labels)
+        String label = properties.getProperty("label."+name);
+        if (label == null)
+            label = "";
+        labels.add(label);
-  static boolean showShape(String name)
-    // System.out.println(name);
-    String mode = properties.getProperty("shape."+name);
-    // System.out.println(mode);
-    if ("none".equals(mode))
-      return false;
-    return true;
+    static boolean showShape(String name)
+        // System.out.println(name);
+        String mode = properties.getProperty("shape."+name);
+        // System.out.println(mode);
+        if ("none".equals(mode))
+            return false;
+        return true;
-  static String toString(double[][] array)
-    StringBuilder sb = new StringBuilder();
-    for (int i = 0; i < array.length; i++)
+    static String toString(double[][] array)
-      double[] row = array[i];
-      for (int j = 0; j < row.length; j++)
-        sb.append(array[i][j]);
-        if (j < row.length-1)
-          sb.append(" ");
-      sb.append("\n");
+        StringBuilder sb = new StringBuilder();
+        for (int i = 0; i < array.length; i++)
+            double[] row = array[i];
+            for (int j = 0; j < row.length; j++)
+                sb.append(array[i][j]);
+                if (j < row.length-1)
+                    sb.append(" ");
+            sb.append("\n");
+        return sb.toString();
-    return sb.toString();
Modified: usertools/plotter/src/plotter/LineReader.java
--- usertools/plotter/src/plotter/LineReader.java	2011-06-17 02:19:13 UTC (rev 4627)
+++ usertools/plotter/src/plotter/LineReader.java	2011-06-17 19:28:46 UTC (rev 4628)
@@ -1,6 +1,7 @@
 package plotter;
 import java.util.*;
+import java.io.*;
  * Utility to read a file into a List of String lines.
@@ -11,148 +12,148 @@
 public class LineReader
-  LineReader()
+    LineReader()
-  public static List<String> read(java.io.File file)
-    throws java.io.FileNotFoundException
-    java.io.BufferedReader reader =
-      new java.io.BufferedReader(new java.io.FileReader(file));
-    return read(reader);
+    public static List<String> read(File file)
+        throws FileNotFoundException
+        BufferedReader reader =
+            new BufferedReader(new FileReader(file));
+        return read(reader);
-  public static List<String> read(String s)
-      new java.io.BufferedReader(new java.io.StringReader(s));
+    public static List<String> read(String s)
+            new BufferedReader(new StringReader(s));
-  public static List<String> read(java.io.BufferedReader reader)
-    List<String> result = new ArrayList<String>();
-    try
+    public static List<String> read(BufferedReader reader)
-      String prevline = "";
-      String line = "";
-      while ((line = reader.readLine()) != null)
-        int hash = line.indexOf("#");
-        if (hash >= 0)
-          line = line.substring(0,hash);
-        line = spaces(line);
-        line = (prevline + " " + line).trim();
-        if (line.endsWith("\\"))
+        List<String> result = new ArrayList<String>();
+        try
-          line = line.substring(0, line.length()-2);
-          prevline = line;
-          continue;
+            String prevline = "";
+            String line = "";
+            while ((line = reader.readLine()) != null)
+                int hash = line.indexOf("#");
+                if (hash >= 0)
+                    line = line.substring(0,hash);
+                line = spaces(line);
+                line = (prevline + " " + line).trim();
+                if (line.endsWith("\\"))
+                    line = line.substring(0, line.length()-2);
+                    prevline = line;
+                    continue;
+                else
+                    prevline = "";
+                    line = line.trim();
+                    if (line.length() > 0)
+                        result.add(line);
+            reader.close();
-        else
-          prevline = "";
-          line = line.trim();
-          if (line.length() > 0)
-            result.add(line);
+            System.err.println("LineReader: I/O problem.");
+            return null;
-      reader.close();
+        return result;
-    catch (java.io.IOException e)
+    public static List<String[]> tokens(List<String> lines)
-      System.out.println("LineReader: I/O problem.");
-      return null;
+        List<String[]> result = new ArrayList<String[]>(lines.size());
+        for (String line : lines)
+            String[] tokens = tokenize(line);
+            result.add(tokens);
+        return result;
-    return result;
-  public static List<String[]> tokens(List<String> lines)
-    List<String[]> result = new ArrayList<String[]>(lines.size());
-    for (String line : lines)
+    public static int maxTokens(List<String[]> tokens)
-      String[] tokens = tokenize(line);
-      result.add(tokens);
+        int result = 0;
+        for (String[] t : tokens)
+            if (t.length > result)
+                result = t.length;
+        return result;
-    return result;
-  public static int maxTokens(List<String[]> tokens)
-    int result = 0;
-    for (String[] t : tokens)
-      if (t.length > result)
-        result = t.length;
-    return result;
+       Take line-oriented data and produce an array of doubles.
+    public static double[][] array(List<String> lines)
+        List<String[]> tokens = tokens(lines);
+        int columns = maxTokens(tokens);
+        int rows = lines.size();
+        double[][] result = new double[rows][columns];
+        for (int i = 0; i < rows; i++)
+            for (int j = 0; j < columns; j++)
+                try
+                    String v = tokens.get(i)[j];
+                    double d = Double.parseDouble(v);
+                    result[i][j] = d;
+                catch (NumberFormatException e)
+                    throw new RuntimeException("Problem in row: " + i);
+        return result;
-     Take line-oriented data and produce an array of doubles.
-  public static double[][] array(List<String> lines)
-    List<String[]> tokens = tokens(lines);
-    int columns = maxTokens(tokens);
-    int rows = lines.size();
-    double[][] result = new double[rows][columns];
-    for (int i = 0; i < rows; i++)
-      for (int j = 0; j < columns; j++)
-        try
+    public static String spaces(String line)
+        String result = "";
+        for (int i = 0; i < line.length(); i++)
-          String v = tokens.get(i)[j];
-          double d = Double.parseDouble(v);
-          result[i][j] = d;
+            if (line.charAt(i)   == '=' &&
+                line.charAt(i+1) != '=' &&
+                line.charAt(i-1) != '=')
+                result += " = ";
+            else
+                result += line.substring(i,i+1);
-        catch (NumberFormatException e)
-          throw new RuntimeException("Problem in row: " + i);
-    return result;
+        return result;
-  public static String spaces(String line)
-    String result = "";
-    for (int i = 0; i < line.length(); i++)
+    public static String[] tokenize(String line)
-      if (line.charAt(i)   == '=' &&
-          line.charAt(i+1) != '=' &&
-          line.charAt(i-1) != '=')
-        result += " = ";
-      else
-        result += line.substring(i,i+1);
+        if (line == null)
+            return null;
+        List<String> words = new ArrayList<String>();
+        String[] ws = line.split("\\s");
+        for (int i = 0; i < ws.length; i++)
+            if (ws[i].length() > 0)
+                words.add(ws[i]);
+        String[] result = new String[words.size()];
+        for (int i = 0; i < words.size(); i++)
+            result[i] = words.get(i);
+        return result;
-    return result;
-  public static String[] tokenize(String line)
-    if (line == null)
-      return null;
-    List<String> words = new ArrayList<String>();
-    String[] ws = line.split("\\s");
-    for (int i = 0; i < ws.length; i++)
-      if (ws[i].length() > 0)
-        words.add(ws[i]);
-    String[] result = new String[words.size()];
-    for (int i = 0; i < words.size(); i++)
-      result[i] = words.get(i);
-    return result;
-  public static List<String> list(String line)
-    for (int i = 0; i < tokens.length; i++)
+      public static List<String> list(String line)
+      for (int i = 0; i < tokens.length; i++)
       result.add(tokens[i]);
-    return result;
+      return result;
Modified: usertools/plotter/src/plotter/Lines.java
--- usertools/plotter/src/plotter/Lines.java	2011-06-17 02:19:13 UTC (rev 4627)
+++ usertools/plotter/src/plotter/Lines.java	2011-06-17 19:28:46 UTC (rev 4628)
@@ -24,326 +24,327 @@
 public class Lines
-  static Double ymin = null;
-  static Double ymax = null;
+    static Double ymin = null;
+    static Double ymax = null;
-  static boolean withLegend = true;
+    static boolean withLegend = true;
-     Generate simple plot.
-     @param collection The x,y data.
-     @param title Plot title.
-     @param xlabel X label text.
-     @param ylabel Y label text.
-     @param output EPS filename.
-  public static boolean plot(XYSeriesCollection collection,
-                             String ylabel, String output)
-    try
+       Generate simple plot.
+       @param collection The x,y data.
+       @param title Plot title.
+       @param xlabel X label text.
+       @param ylabel Y label text.
+       @param output EPS filename.
+    public static boolean plot(XYSeriesCollection collection,
+                               String ylabel, String output)
+        try
-      return false;
-      (title, xlabel, ylabel, collection,
+            return false;
-    setupPlot(chart, collection);
+            (title, xlabel, ylabel, collection,
-    try
-      g2d.finish();
+        setupPlot(chart, collection);
+        try
+            g2d.finish();
-    return true;
-    XYLineAndShapeRenderer renderer = new XYLineAndShapeRenderer();
-    if (bw)
-      for (int i = 0; i < plot.getSeriesCount(); i++)
-        renderer.setSeriesPaint(i, Color.BLACK);
-      Series series = collection.getSeries(i);
-      if (! showShape(series.getDescription()))
-        renderer.setSeriesShapesVisible(i, false);
+        return true;
-    setAxes(plot);
-    plot.setRenderer(renderer);
+        XYLineAndShapeRenderer renderer = new XYLineAndShapeRenderer();
+        if (bw)
+            for (int i = 0; i < plot.getSeriesCount(); i++)
+                renderer.setSeriesPaint(i, Color.BLACK);
+            Series series = collection.getSeries(i);
+            if (! showShape(series.getDescription()))
+                renderer.setSeriesShapesVisible(i, false);
-  static void setAxes(XYPlot plot)
-    double axmin, axmax, aymin, aymax;
-      NumberAxis axis = (NumberAxis) plot.getDomainAxis();
+        setAxes(plot);
+        plot.setRenderer(renderer);
-    if (ymin != null || ymax != null)
+    static void setAxes(XYPlot plot)
-      NumberAxis axis = (NumberAxis) plot.getRangeAxis();
-      aymin = range.getLowerBound();
-      aymax = range.getUpperBound();
-      if (ymin != null) aymin = ymin;
-      if (ymax != null) aymax = ymax;
-      axis.setRange(aymin, aymax);
+        double axmin, axmax, aymin, aymax;
-    // Settings:
+            NumberAxis axis = (NumberAxis) plot.getDomainAxis();
-    int c = -1;
-      switch (c)
-        case 'v':
-          verbose = true;
+        if (ymin != null || ymax != null)
+            NumberAxis axis = (NumberAxis) plot.getRangeAxis();
+            aymin = range.getLowerBound();
+            aymax = range.getUpperBound();
+            if (ymin != null) aymin = ymin;
+            if (ymax != null) aymax = ymax;
+            axis.setRange(aymin, aymax);
-      System.exit(2);
+        // Settings:
-    Bits.init();
+        int c = -1;
+            switch (c)
+                case 'v':
+                    verbose = true;
+            System.exit(2);
-    String ylabel = null;
+        Bits.init();
-    load(propFile);
-    ylabel = properties.getProperty("ylabel");
-    scanProperties();
+        String ylabel = null;
-      try
-        System.exit(1);
-      data.add(array);
+        load(propFile);
+        ylabel = properties.getProperty("ylabel");
-    XYSeriesCollection collection = Util.collection(data, labels,
-                                                    names);
+        scanProperties();
-    plot(collection, title, xlabel, ylabel, output);
+            try
+                System.exit(1);
+            data.add(array);
-    try
-      else
+        XYSeriesCollection collection = Util.collection(data, labels,
+                                                        names);
+        plot(collection, title, xlabel, ylabel, output);
-      System.exit(1);
+        try
+            else
+            System.exit(1);
+            System.exit(1);
-      System.exit(1);
-     Example.
+       Example.
-     title = Plot
-     xlabel = size
-     ylabel = speed
-     xmin, xmax, ymin, ymax (auto-selected if not given)
-     legend.enabled (true/false, default true)
-    String tmp;
-    if (tmp != null)
-    if (tmp != null)
-    if (tmp != null)
-    if (tmp != null)
-    tmp = properties.getProperty("ymin");
-    if (tmp != null)
-      ymin = Double.parseDouble(tmp);
-    tmp = properties.getProperty("ymax");
-    if (tmp != null)
-      ymax = Double.parseDouble(tmp);
-    if (tmp != null)
-    tmp = properties.getProperty("legend.enabled");
-    if (tmp != null)
-      withLegend = Boolean.parseBoolean(tmp);
+       title = Plot
+       xlabel = size
+       ylabel = speed
+       xmin, xmax, ymin, ymax (auto-selected if not given)
+       legend.enabled (true/false, default true)
+        String tmp;
+        if (tmp != null)
+        if (tmp != null)
+        if (tmp != null)
+        if (tmp != null)
+        tmp = properties.getProperty("ymin");
+        if (tmp != null)
+            ymin = Double.parseDouble(tmp);
+        tmp = properties.getProperty("ymax");
+        if (tmp != null)
+            ymax = Double.parseDouble(tmp);
+        if (tmp != null)
+        tmp = properties.getProperty("legend.enabled");
+        if (tmp != null)
+            withLegend = Boolean.parseBoolean(tmp);
-    int j = 0;
+      int j = 0;
       result[j++] = s[i];
-    return result;
+      return result;
-      label = "";
+            label = "";
-      return false;
-    return true;
+            return false;
+        return true;
-          sb.append(" ");
-      sb.append("\n");
+                    sb.append(" ");
+            sb.append("\n");
Modified: usertools/plotter/src/plotter/Plots.java
--- usertools/plotter/src/plotter/Plots.java	2011-06-17 02:19:13 UTC (rev 4627)
+++ usertools/plotter/src/plotter/Plots.java	2011-06-17 19:28:46 UTC (rev 4628)
@@ -13,22 +13,22 @@
 public class Plots
-  static void setupLegend(JFreeChart chart,
-                          Properties properties)
-    LegendTitle legend = chart.getLegend();
-    Font font = getLegendFont(properties);
-    if (font != null)
-      legend.setItemFont(font);
+    static void setupLegend(JFreeChart chart,
+                            Properties properties)
+        LegendTitle legend = chart.getLegend();
+        Font font = getLegendFont(properties);
+        if (font != null)
+            legend.setItemFont(font);
-  static Font getLegendFont(Properties properties)
-    Font result = null;
-    String name = properties.getProperty("legend.font");
-    if (name == null)
-      return null;
-    result = new Font(name, Font.PLAIN, 12);
-    return result;
+    static Font getLegendFont(Properties properties)
+        Font result = null;
+        String name = properties.getProperty("legend.font");
+        if (name == null)
+            return null;
+        result = new Font(name, Font.PLAIN, 12);
+        return result;
Added: usertools/plotter/src/plotter/Plotter.java
--- usertools/plotter/src/plotter/Plotter.java	                        (rev 0)
+++ usertools/plotter/src/plotter/Plotter.java	2011-06-17 19:28:46 UTC (rev 4628)
@@ -0,0 +1,46 @@
+package plotter;
+import plotter.Lines;
+import plotter.Dual;
+public class Plotter
+    public static void main(String[] args)
+        if (args.length < 4 )
+            usage();
+        /* Gather the arguments except the first one */
+        String[] tmp = new String[args.length - 1];
+        for( int i = 0; i < tmp.length; ++i )
+            tmp[i] = args[i+1];
+        /* If asking for a single labeled Y-axis */
+        if (args[0].equalsIgnoreCase( "-s" ))
+            Lines l = new Lines();
+            l.plotter(tmp);
+        /* If asking for a dual labeled Y-axis */
+        else if (args[0].equalsIgnoreCase( "-d" ))
+            Dual d = new Dual();
+            d.plotter(tmp);
+        /* Do not understand option for what graph */
+        else
+            usage();
+    public static void usage()
+        System.err.println( "usage: [-s,-d] [<options>] <properties> <output> <data>*" );
+        System.exit(2);
Modified: usertools/plotter/src/plotter/Util.java
--- usertools/plotter/src/plotter/Util.java	2011-06-17 02:19:13 UTC (rev 4627)
+++ usertools/plotter/src/plotter/Util.java	2011-06-17 19:28:46 UTC (rev 4628)
@@ -11,54 +11,54 @@
 public class Util
-  static boolean v = false;
+    static boolean v = false;
-     Stores the label as the Series key.
-     Stores the filename as the Series description.
-  static XYSeriesCollection collection(List<double[][]> data,
-    final XYSeriesCollection collection = new XYSeriesCollection();
-    int count = 0;
-    for (double[][] d : data)
+       Stores the label as the Series key.
+       Stores the filename as the Series description.
+    static XYSeriesCollection collection(List<double[][]> data,
-      try
+        final XYSeriesCollection collection = new XYSeriesCollection();
-      for (int i = 0; i < d.length; i++)
-        series.add(d[i][0], d[i][1]);
+        int count = 0;
+        for (double[][] d : data)
+            try
-      collection.addSeries(series);
-      count++;
+            for (int i = 0; i < d.length; i++)
+                series.add(d[i][0], d[i][1]);
+            collection.addSeries(series);
+            count++;
+        return collection;
-    return collection;
-  public static void fatal(String s)
-    System.out.println(s);
-    System.exit(2);
+    public static void fatal(String s)
+        System.err.println(s);
+        System.exit(2);
-  public static void verbose(String s)
-    if (v)
+    public static void verbose(String s)
+        if (v)
+            System.out.println(s);
-  public static void verbose(boolean status)
-    v = status;
+    public static void verbose(boolean status)
+        v = status;
Added: usertools/plotter/swift_plotter.zsh
--- usertools/plotter/swift_plotter.zsh	                        (rev 0)
+++ usertools/plotter/swift_plotter.zsh	2011-06-17 19:28:46 UTC (rev 4628)
@@ -0,0 +1,10 @@
+#!/bin/zsh
+java -ea -cp ${CP} plotter.Plotter ${*}
Property changes on: usertools/plotter/swift_plotter.zsh
