[Swift-commit] r4601 - trunk/docs/userguide
jonmon at ci.uchicago.edu
Sat Jun 11 22:12:34 CDT 2011
Author: jonmon
Date: 2011-06-11 22:12:31 -0500 (Sat, 11 Jun 2011)
New Revision: 4601
Modified:
trunk/docs/userguide/app_procedures
trunk/docs/userguide/mappers
Log:
Update the import section inf the mappers file for the userguide. Also fixed a type for the readData fuction.
Modified: trunk/docs/userguide/app_procedures
--- trunk/docs/userguide/app_procedures 2011-06-11 01:57:49 UTC (rev 4600)
+++ trunk/docs/userguide/app_procedures 2011-06-12 03:12:31 UTC (rev 4601)
@@ -403,9 +403,9 @@
the same order as the header row and separated by whitespace. (since
Swift 0.4)
-readdata2
+readData2
-readdata2 will read data from a specified file, like readdata, but
+readData2 will read data from a specified file, like readdata, but
using a different file format more closely related to that used by the
ext mapper.
Modified: trunk/docs/userguide/mappers
--- trunk/docs/userguide/mappers 2011-06-11 01:57:49 UTC (rev 4600)
+++ trunk/docs/userguide/mappers 2011-06-12 03:12:31 UTC (rev 4601)
@@ -18,7 +18,7 @@
"/home/yongzh/data/", then the dataset might be declared as follows:
-imagefile f1<single_file_mapper;file="/home/yongzh/data/file1.bin">
+imagefile f1<single_file_mapper;file="/home/yongzh/data/file1.bin">
The above example declares a dataset called f1, which uses a single file
@@ -28,7 +28,7 @@
single_file_mapper is frequently used:
-binaryfile f1<"/home/yongzh/data/file1.bin">
+binaryfile f1<"/home/yongzh/data/file1.bin">
Swift comes with a number of mappers that handle common mapping
@@ -66,7 +66,7 @@
Declaration statements have the general form:
-typename variablename (<mapping> | = initialValue ) ;
+typename variablename (<mapping> | = initialValue ) ;
The format of the mapping expression is defined in the Mappers section.
@@ -84,7 +84,7 @@
assigned. Assignment statements have the general form:
-variable = value;
+variable = value;
where value can be either an expression or a procedure call that returns
@@ -106,7 +106,7 @@
function name, and outputs are specified to the left. For example:
-(type3 out1, type4 out2) myproc (type1 in1, type2 in2)
+(type3 out1, type4 out2) myproc (type1 in1, type2 in2)
The above example declares a procedure called myproc, which has two
@@ -121,18 +121,18 @@
passing. For example, if myproc1 is defined as:
-(binaryfile bf) myproc1 (int i, string s="foo")
+(binaryfile bf) myproc1 (int i, string s="foo")
Then that procedure can be called like this, omitting the optional
parameter s:
-binaryfile mybf = myproc1(1);
+binaryfile mybf = myproc1(1);
or like this supplying a value for the optional parameter s:
-binaryfile mybf = myproc1 (1, s="bar");
+binaryfile mybf = myproc1 (1, s="bar");
Atomic procedures
@@ -143,9 +143,9 @@
Atomic procedures are defined with the app keyword:
-app (binaryfile bf) myproc (int i, string s="foo") {
- myapp i s @filename(bf);
+app (binaryfile bf) myproc (int i, string s="foo") {
+ myapp i s @filename(bf);
which specifies that myproc invokes an executable called myapp,
@@ -158,11 +158,11 @@
A compound procedure contains a set of SwiftScript statements:
-(type2 b) foo_bar (type1 a) {
- type3 c;
- c = foo(a); // c holds the result of foo
- b = bar(c); // c is an input to bar
+(type2 b) foo_bar (type1 a) {
+ type3 c;
+ c = foo(a); // c holds the result of foo
+ b = bar(c); // c is an input to bar
Control Constructs
@@ -178,19 +178,19 @@
element in an array. For example:
-check_order (file a[]) {
- foreach f in a {
- compute(f);
+check_order (file a[]) {
+ foreach f in a {
+ compute(f);
foreach statements have the general form:
-foreach controlvariable (,index) in expression {
- statements
+foreach controlvariable (,index) in expression {
+ statements
The block of statements is evaluated once for each element in
@@ -206,11 +206,11 @@
the form:
-if(predicate) {
- statements
-} else {
- statements
+if(predicate) {
+ statements
+} else {
+ statements
where predicate is a boolean expression.
@@ -224,15 +224,15 @@
statements take the general form:
-switch(controlExpression) {
- case n1:
- statements2
- case n2:
- statements2
- default:
- statements
+switch(controlExpression) {
+ case n1:
+ statements2
+ case n2:
+ statements2
+ default:
+ statements
The control expression is evaluated, the resulting numerical value used
@@ -254,9 +254,9 @@
The general form is:
-iterate var {
- statements;
-} until (terminationExpression);
+iterate var {
+ statements;
+} until (terminationExpression);
with the variable var starting at 0 and increasing by one in each
@@ -300,18 +300,39 @@
For example, a SwiftScript program might contain this:
-import defs;
-file f;
+import "defs";
+file f;
-which would import the content of defs.swift in the current directory:
+which would import the content of defs.swift:
-type file;
+type file;
-Imported files are read from the current working directory.
+Imported files are read from two places. They are either read from
+the path that is specified from the import command, such as:
+import "definitions/file/defs";
+or they are read from the environment variable SWIFT_LIB. This
+environment variable is used just like the PATH environment
+variable. For example, if the command below was issued to the bash
+shell:
+export SWIFT_LIB=${HOME}/Swift/defs:${HOME}/Swift/functions
+then the import command will check for the file defs.swift in both
+"$\{HOME}/Swift/defs" and "$\{HOME}/Swift/functions" first before trying
+the path that was specified in the import command.
+Other valid imports:
+import "../functions/func"
+import "/home/user/Swift/definitions/defs"
There is no requirement that a module is imported only once. If a module
is imported multiple times, for example in different files, then Swift
will only process the imports once.
@@ -342,7 +363,7 @@
|f[0]|INVALID
|f.bar|INVALID
[options="header, autowidth"]
|parameter|meaning
@@ -351,12 +372,12 @@
Example:
-file f <single_file_mapper;file="plot_outfile_param">;
+file f <single_file_mapper;file="plot_outfile_param">;
There is a simplified syntax for this mapper:
-file f <"plot_outfile_param">;
+file f <"plot_outfile_param">;
The simple mapper
@@ -377,8 +398,8 @@
-type file;
-file f <simple_mapper;prefix="foo", suffix=".txt">;
+type file;
+file f <simple_mapper;prefix="foo", suffix=".txt">;
The above maps all filenames that start with foo and have an extension
@@ -390,17 +411,17 @@
|f|foo.txt
-type messagefile;
-(messagefile t) greeting(string m) {.
- app {
- echo m stdout=@filename(t);
-messagefile outfile <simple_mapper;prefix="foo",suffix=".txt">;
-outfile = greeting("hi");
+type messagefile;
+(messagefile t) greeting(string m) {.
+ app {
+ echo m stdout=@filename(t);
+messagefile outfile <simple_mapper;prefix="foo",suffix=".txt">;
+outfile = greeting("hi");
This will output the string 'hi' to the file foo.txt.
@@ -409,19 +430,19 @@
index into the filename between the prefix and suffix.
-type messagefile;
- app {
+type messagefile;
-messagefile outfile[] <simple_mapper;prefix="baz",suffix=".txt">;
-outfile[0] = greeting("hello");
-outfile[1] = greeting("middle");
-outfile[2] = greeting("goodbye");
+ app {
+messagefile outfile[] <simple_mapper;prefix="baz",suffix=".txt">;
+outfile[0] = greeting("hello");
+outfile[1] = greeting("middle");
+outfile[2] = greeting("goodbye");
@@ -431,28 +452,28 @@
|outfile[1]|baz0001.txt
|outfile[2]|baz0002.txt
simple_mapper can be used to map structures. It will map the name of
the structure member into the filename, between the prefix and the suffix.
-type messagefile;
-type mystruct {
- messagefile left;
- messagefile right;
- app {
-mystruct out <simple_mapper;prefix="qux",suffix=".txt">;
-out.left = greeting("hello");
-out.right = greeting("goodbye");
+type messagefile;
+type mystruct {
+ messagefile left;
+ messagefile right;
+ app {
+mystruct out <simple_mapper;prefix="qux",suffix=".txt">;
+out.left = greeting("hello");
+out.right = greeting("goodbye");
This will output the string "hello" into the file qux.left.txt and the
@@ -464,7 +485,7 @@
|out.left|quxleft.txt
|out.right|quxright.txt
concurrent mapper
concurrent_mapper is almost the same as the simple mapper, except that
@@ -486,8 +507,8 @@
Example:
-file f1;
-file f2 <concurrent_mapper;prefix="foo", suffix=".txt">;
+file f1;
+file f2 <concurrent_mapper;prefix="foo", suffix=".txt">;
The above example would use concurrent mapper for f1 and f2, and
generate f2 filename with prefix "foo" and extension ".txt"
@@ -516,7 +537,7 @@
Example:
-file texts[] <filesys_mapper;prefix="foo", suffix=".txt">;
+file texts[] <filesys_mapper;prefix="foo", suffix=".txt">;
The above example would map all filenames that start with "foo" and
@@ -531,9 +552,9 @@
|texts[1]|foo1.txt
|texts[2]|foo__1.txt
fixed array mapper
The fixed_array_mapper maps from a string that contains a list of
@@ -549,8 +570,8 @@
Example:
-file texts[] <fixed_array_mapper;files="file1.txt, fileB.txt, file3.txt">;
+file texts[] <fixed_array_mapper;files="file1.txt, fileB.txt, file3.txt">;
would cause a mapping like this:
@@ -574,9 +595,9 @@
Example:
-string s[] = [ "a.txt", "b.txt", "c.txt" ];
-file f[] <array_mapper;files=s>;
+string s[] = [ "a.txt", "b.txt", "c.txt" ];
+file f[] <array_mapper;files=s>;
This will establish the mapping:
@@ -609,11 +630,11 @@
Example:
-string s = "picture.gif";
-file f <regexp_mapper;
- source=s,
- match="(.*)gif",
- transform="\\1jpg">;
+string s = "picture.gif";
+file f <regexp_mapper;
+ source=s,
+ match="(.*)gif",
+ transform="\\1jpg">;
This example transforms a string ending gif into one ending jpg and
@@ -623,7 +644,7 @@
|Swift variable|Filename
csv mapper
@@ -635,11 +656,11 @@
elements like this:
-type student {
- file name;
- file age;
- file GPA;
+type student {
+ file name;
+ file age;
+ file GPA;
If the file does not contain a header with column info, then the column
@@ -658,7 +679,7 @@
Example:
-student stus[] <csv_mapper;file="stu_list.txt">;
+student stus[] <csv_mapper;file="stu_list.txt">;
The above example would read a list of student info from file
@@ -686,7 +707,7 @@
|stus[2].name|q
|stus[2].age|r
|stus[2].gpa|s
external mapper
@@ -715,11 +736,11 @@
echo "[0] foo"
echo "[1] bar"
then a mapping statement:
-student stus[] <ext;exec="mapper.sh">;
+student stus[] <ext;exec="mapper.sh">;
would map
More information about the Swift-commit
