[Swift-commit] r4591 - trunk/docs/userguide
    jonmon at ci.uchicago.edu
    Wed Jun  8 21:16:47 CDT 2011
Author: jonmon
Date: 2011-06-08 21:16:47 -0500 (Wed, 08 Jun 2011)
New Revision: 4591
Modified:
   trunk/docs/userguide/profiles
Log:
added globus namespace profile internalhostname entry. Also added env namespace SWIFT_GEN_SCRIPTS entry
Modified: trunk/docs/userguide/profiles
--- trunk/docs/userguide/profiles	2011-06-09 02:16:22 UTC (rev 4590)
+++ trunk/docs/userguide/profiles	2011-06-09 02:16:47 UTC (rev 4591)
@@ -178,6 +178,13 @@
 Swing window showing, graphically, the state of the coaster scheduler
 (blocks, jobs, etc.). Default: false
+internalhostname - If the head node has multiple network interfaces,
+only one of which is visible from the worker nodes. The choice of
+which interface is the one that worker nodes can connect to is a
+matter of the particular cluster. This must be set in the your
+sites file to clarify to the workers which exact interface on the
+head node they are to try to connect to.
 env namespace
 Profile keys set in the env namespace will be set in the unix
@@ -204,3 +211,8 @@
 about the remote site to be gathered and returned to the submit side.
 (since Swift 0.9)
+SWIFT_GEN_SCRIPTS - set in the env namespace profiles. This variable
+just needs to be set, it doesn't matter what it is set to. If set, then Swift
+will keep the script that was used to execute the job in the job directory.
+The script will be called run.sh and will have the command line that Swift
+tried to execute with.
More information about the Swift-commit
