[Swift-commit] r4587 - trunk/src/org/griphyn/vdl/karajan/lib
hategan at ci.uchicago.edu
Wed Jun 8 21:13:07 CDT 2011
Author: hategan
Date: 2011-06-08 21:13:07 -0500 (Wed, 08 Jun 2011)
New Revision: 4587
Modified:
trunk/src/org/griphyn/vdl/karajan/lib/Stageout.java
Log:
1. wait for static return arrays to be initialized before starting the app (i.e. make sure the size is known); 2. the list of stageouts for complex types (and arrays) was broken (e.g. it returned the leaf var instead of the root var; fixed both issues
Modified: trunk/src/org/griphyn/vdl/karajan/lib/Stageout.java
--- trunk/src/org/griphyn/vdl/karajan/lib/Stageout.java 2011-06-08 21:56:42 UTC (rev 4586)
+++ trunk/src/org/griphyn/vdl/karajan/lib/Stageout.java 2011-06-09 02:13:07 UTC (rev 4587)
@@ -9,17 +9,15 @@
import org.apache.log4j.Logger;
import org.globus.cog.karajan.arguments.Arg;
+import org.globus.cog.karajan.arguments.Arg.Channel;
import org.globus.cog.karajan.arguments.ArgUtil;
import org.globus.cog.karajan.arguments.NamedArguments;
-import org.globus.cog.karajan.arguments.Arg.Channel;
-import org.globus.cog.karajan.stack.VariableNotFoundException;
import org.globus.cog.karajan.stack.VariableStack;
import org.globus.cog.karajan.workflow.ExecutionException;
import org.globus.cog.karajan.workflow.futures.FutureNotYetAvailable;
import org.griphyn.vdl.mapping.AbstractDataNode;
import org.griphyn.vdl.mapping.DSHandle;
import org.griphyn.vdl.mapping.HandleOpenException;
-import org.griphyn.vdl.mapping.InvalidPathException;
import org.griphyn.vdl.mapping.MappingDependentException;
import org.griphyn.vdl.mapping.Path;
@@ -40,8 +38,8 @@
.isPrimitive());
- private List list(Path p, DSHandle var) {
- ArrayList l = new ArrayList(2);
+ private List<?> list(Path p, DSHandle var) {
+ ArrayList<Object> l = new ArrayList<Object>(2);
l.add(p);
l.add(var);
return l;
@@ -51,6 +49,19 @@
DSHandle var = (DSHandle) VAR.getValue(stack);
boolean deperr = false;
boolean mdeperr = false;
+ // currently only static arrays are supported as app returns
+ // however, previous to this, there was no code to check
+ // if these arrays had their sizes closed, which could lead to
+ // race conditions (e.g. if this array's mapper had some parameter
+ // dependencies that weren't closed at the time the app was started).
+ if (var.getType().isArray()) {
+ if (!var.isClosed()) {
+ if (logger.isDebugEnabled()) {
+ logger.debug("Waiting for array size from " + var);
+ throw new FutureNotYetAvailable(addFutureListener(stack, var));
try {
if (!isPrimitive(var)) {
retPaths(STAGEOUT, stack, var);
@@ -76,15 +87,12 @@
try {
Collection<Path> fp = var.getFringePaths();
for (Path p : fp) {
- channel.ret(stack, list(p, var.getField(p)));
+ channel.ret(stack, list(p, var));
catch (HandleOpenException e) {
throw new FutureNotYetAvailable(addFutureListener(stack, e
.getSource()));
- catch (InvalidPathException e) {
- throw new ExecutionException(e);
More information about the Swift-commit
