[Swift-commit] r4578 - in SwiftApps/Montage: . scripts
jonmon at ci.uchicago.edu
Tue Jun 7 14:50:56 CDT 2011
Author: jonmon
Date: 2011-06-07 14:50:56 -0500 (Tue, 07 Jun 2011)
New Revision: 4578
Modified:
SwiftApps/Montage/TODO
SwiftApps/Montage/scripts/Swift_Montage_Apps.swift
Log:
removed commented out lines during the testing of mapping the area files out. Updated TODO file
Modified: SwiftApps/Montage/TODO
--- SwiftApps/Montage/TODO 2011-06-07 19:47:37 UTC (rev 4577)
+++ SwiftApps/Montage/TODO 2011-06-07 19:50:56 UTC (rev 4578)
@@ -1,5 +1,4 @@
o scripts/Swift_Montage_Batch.swift
- -- Must map out the area files as well. Then change all the app procedures accordingly to remove the -n option.(-n stands for ignore the area files)
-- Need to fix mProjectBatch. Currently calls mProject blindly. Need to figure out how to choose between mProject and mProjectPP
o exec/montage.sh
Modified: SwiftApps/Montage/scripts/Swift_Montage_Apps.swift
--- SwiftApps/Montage/scripts/Swift_Montage_Apps.swift 2011-06-07 19:47:37 UTC (rev 4577)
+++ SwiftApps/Montage/scripts/Swift_Montage_Apps.swift 2011-06-07 19:50:56 UTC (rev 4578)
@@ -6,7 +6,6 @@
app ( Image bg_img ) mBackground( Image img, Image area_img, float a, float b, float c )
-// mBackground "-n" @img @bg_img a b c;
mBackground @img @bg_img a b c;
@@ -25,22 +24,18 @@
app ( Image diff_img ) mDiff( Image proj_img_1, Image area_img_1, Image proj_img_2, Image area_img_2, MosaicData hdr )
-// mDiff "-n" @proj_img_1 @proj_img_2 @diff_img @hdr;
-// mDiff_wrap "-n" @proj_img_1 @proj_img_2 @diff_img @hdr;
mDiff_wrap @proj_img_1 @proj_img_2 @diff_img @hdr;
app ( Image diff_img, Status stat ) mDiffFit( Image img_1, Image area_img_1, Image img_2, Image area_img_2, MosaicData hdr )
-// mDiffFit "-n" "-s" @stat @img_1 @img_2 @diff_img @hdr;
mDiffFit "-s" @stat @img_1 @img_2 @diff_img @hdr;
app ( Status stat ) mFitplane( Image diff_img )
-// mFitplane "-s" @stat @diff_img;
mFitplane_wrap "-s" @stat @diff_img;
@@ -75,7 +70,6 @@
-//app ( Image proj_img ) mProject( Image raw_img, MosaicData hdr )
app ( Image proj_img, Image area_img ) mProject( Image raw_img, MosaicData hdr )
mProject "-X" @raw_img @proj_img @hdr;
More information about the Swift-commit
