[Swift-commit] r4568 - SwiftApps/Montage
    jonmon at ci.uchicago.edu
    Mon Jun  6 10:57:09 CDT 2011
Author: jonmon
Date: 2011-06-06 10:57:09 -0500 (Mon, 06 Jun 2011)
New Revision: 4568
Modified:
   SwiftApps/Montage/TODO
Log:
Deleted some items from the Montage TODO list
Modified: SwiftApps/Montage/TODO
--- SwiftApps/Montage/TODO	2011-06-06 15:54:26 UTC (rev 4567)
+++ SwiftApps/Montage/TODO	2011-06-06 15:57:09 UTC (rev 4568)
@@ -3,12 +3,10 @@
   -- Need to fix mProjectBatch.  Currently calls mProject blindly.  Need to figure out how to choose between mProject and mProjectPP
 o exec/montage.sh
-  -- Fix how to calculate the run directory
   -- Figure out how to specify what site location that are going to be run on and do gensites on the templates
-  -- Make sure all environment variables are set that are needed to run the execution script
 o optimizations
-  -- Create different pool entries. One for projectiog, calculating difference images, and background rectification. Each one will require different number of workers to execute with so different pool entries will be required.  This will also change the tc.data files.
+  -- Try different sites.xml settings. Try different throttleing parameters as well as different queue sizes.
 o templates
-  -- Add more templates for other machines.  For sure needs localhost
+  -- Add more templates for other machines. Add one for Beagle
More information about the Swift-commit
